Hard Drive problem?
Thanks for taking ur time to read this....my problem is that i recently wanted to change my hard drive at that time using win98 to a new hard drive blank but i couldn't get da winxp to work on the new hard drive so i wanted to juss put back da old hard drive in for da time being but wen i hooked it back up it goes and tells me my driver specs n stuff like dat and it says needs reboot disk?? Can anyone tell me the problem and hopefully the cure?
Thx in advance
Thx in advance
If that's the case I'll guess that you didn't copy the drive over propperly. What did you use to do the drive copy? If you just used windows copy command for example it won't work to many hidden/system files that won't copy over. You need to boot up with a ghost disk for example and do a low level copy. If everything is coppied and the new y drive is set to master your system shouldn't know the difference only that it now has a bigger drive.
On another note though, a better sollution (though a good cleaning is always a good thing to do from time to time) would be to have windows installed on the smaller drive and use your new one for storrage. I'm assuming of course that your small drive is physically not damaged.
