that is bizarre, i use remote desktop all the time and i havent seen anything like this before. maybe its something in the bios relating to num lock. i dunno, good luck though . . .
Since no one has said it yet and it really should be said. Don't use remote Desktop it sucks. Use UltraVNC instead you won't have any of these problems it's more secure and you can do a lot more with it.
