Case Window Problem
edited October 2004 in Hardware
So I have a Noblesse Case with a window on the left side, but this window has really started to piss me off. It is only held in by some crappy rubber lining stuff that really doesn't do the job. I knocked the window out the other day, and it took me an hour to get it back in only to be knocked out again 15 minutes later when transporting the case. Any ideas on how to keep this window in the case? Thanks.
  • ZuntarZuntar North Carolina Icrontian
    edited August 2004
    There isn't a pic of a windowed version of this case in the link that you gave, so its hard to see how it is put together; I looked a little but no luck. I'm gonna guess that you would need to use some form of adhessive in the groove/ slot where the window attatches, or where the moulding connects to the metal of the case, depending on where your problem resides. Maybe take a pic of the case window when is slightly pushed in so we can see?
  • edited September 2004
    well, if you can get them, get some polished half sphere headed bolts, and some square nuts, and drill holes through the side of the case. IF you do it correctly, it looks much nicer. a good example of the way this looks is
    http://www.directron.com/dreamerii.html
    (side view)
  • erichblas2005erichblas2005 Your Native Texan Houston,Texas Member
    edited October 2004
    man you are so lucky to get that case. I tried to get that case but no one heard of it.
