Wireless problems...
edited October 2004 in Science & Tech
Okay so I am new here but definately not new to the IT field.
I have a problem. I have a linksys wireless router in the addition to my house. Upstairs in my room, I have a very poor connection to it, 1mbps. Is there a way I can use my 2nd router as something like a repeater to take the signal from the one downstairs, and make it alot stronger for my upstairs usage?
  • edited October 2004
    If you got the router not to long ago I noticed that linksys was making them with the signal booster built in. Now if you have an older model I think you can buy a signal booster and attach it to your router.Signal Booster
    edited October 2004
    Not that I know of unless you actually wire it in you can't hop the signal from one router to another accept by using a lan cable. But Overlord also speaks the truth you can get boosters and some of the newer linksys routers come boosted. But they are only on the linksys g's.
    With boosters whatch out for signal interference
  • SSR_06SSR_06 Iowa
    edited October 2004
    if you have a detachable antenna just get a stronger antenna.
    question-would'nt the signal be the problem not the antenna?
    edited October 2004
    better intena = more strength to pick up signal
