nVENTIV Mach II Power Problem
edited October 2004 in Hardware
Hello everyone!
I am not sure if this is the right forum but I have a problem with my Mach II, I think it is the ST not the GT. I set it up all correctly and booted it for the first time. I booted into windows and then I decided to shutdown. After I did this the unit went into the usual countdown sequence from 120 seconds. I then Unplugged the unit from the wall, and when I reinserted the power cable nothing came on. The LCD is blank and the LED's on the back do not light up. I read in the manual that it may be the circuit safety switch, but it said that only takes 15-20 minutes and it has been over an hour.
Has anyone had this problem? I don't know much about the Mach II except for what I read in the manual. Thanks in advance for any help!
DMcanally
    edited October 2004
    mackanz or Citrix would be the two people to talk too they both have them
