Can any body help please?!!!
edited January 2005 in Science & Tech
I have Windows XP
when i click on the right button of the mouse on any icon on the desktop or in the hard disks, it doesn't work and a msgbox comes. the msgbox says:
The instruction at "0x021d415b" referenced memory at "0x00000000". The memory could not be "written."
What should i do?
help me please!!
i can't copy or delete or rename any file in my computer.
Thank you
  • HawkHawk Fla Icrontian
    edited November 2004
    What type of mouse are you using? Microsoft, Logitech, etc? And did you install any kind of mouse software? Have you changed out the mouse lately? Have you had any other glitches show up on the pc?
  • CycloniteCyclonite Tampa, Florida Icrontian
    run memtest as well.
    www.memtest.org
  • edited November 2004
    If you dont have too much installed, or just dont mind, I would try a reformat. I havent really ever heard of this problem, but i'll see what I can dig up
  • edited January 2005
    John_mm wrote:
    I have Windows XP
    What should i do?
    help me please!!
    Thank you
    hello john_mm,
    i have the same problem after i install dr.divx.
    during the installation i become this message
    after the installation i have the problem.
    (see attachment)
    it´s something wrong with the "encodedivxext.dll"
    after i deleted the dll i had no problems anymore.
    i hope that will help you :thumbsup:
    bye
    maverick
