Sound problems
Hey, I just put in a Asus K8V SE mobo and everything was going great until, I realized I had no sound. I fiddled and finally gave up on onboard sound and stuck a Sound Blaster Live! 24-bit card in the comp. My sound still won't work, unless i turn the speakers up all the way, I can hear a really awful, distorted, scratchy rendition of what I should be hearing. I accidently installed Windows XP Professional twice after putting the motherboard in (is this normal? whenever I put a new mobo in I have to reinstall Windows), but I doubt that has anything to do with it. I have tried different speakers of course, as well as drivers for both the card and the onboard sound (Creative doesn't have drivers on the Net for the Sound Blaster Live! 24-bit card for some reason, so I just used the CD). Help! I never realized how important sound was to everything on a computer.
if you have, I would suggest seeing if there are any BIOSes available to update your board with. If none of this fixes your problem, it might be a faulty audio chip.
I opened the sound and audio properties and under Audio I had to manually choose my Soundblaster card. Then under Volume turn it back up. Working fine ever since, but now am thinking of just running the onboard sound and putting the SB card back in my old system.
Now it doesnt say 24 bit but it does state the requirement of win2000 or XP and >>>>"Creative SB Live! Series Audio card installed."<<<<
Give it a try : )
You found the correct setting, and yes, the F8 / delete at startup is indeed the BIOS. Since it doesn't work, I'd try looking for an internet driver for the card, as Khold suggests, and also trying a different PCI slot. (also try both at the same time.) If it STILL fails to work, odds are it's the SB card itself - although there is a chance the mobo doesn't like it, it's a low chance.
Did you switch pci slots and/or try the (LiveDrvUni-Pack(ENG).exe) from Soundblaster.com? SB Live cards then and now (24bit) arent that much different whether 24bit or the regular Live or Live Value cards so give that driver a shot if the digital audio fix dont take care of it.
Hope you get some kind of sound going, I know what it is like to have a problem going on and cant figure it out. Most cases it is something small and simple and easily overlooked
As for turning it on or off, double click the volume icon in your system tray (if it is not there, go to Control Panel, open Sounds and Audio Devices, then click Advanced on Device Volume), click the Options menu and make sure Advanced Controls is checked, then click the "Advanced" button under the master volume. There should be an option to force digital output only - change it to the opposite as you have it now, and try making noise again.
VIA Chipsets have been notorious for having these problems with Sound Blaster Audio products, although I have usually been able to get them to work by trying different PCI slots, and applying the George Breese patch.
You might want to look here for info on VIA chipsets and some solutions for your problems.
http://www.georgebreese.com/net/software/#CREATIVE
Hope this helps.
ben
