!!!!netgear ma111 invalid ip problems!!!! help badly needed
gtkgtk
edited December 2004 in Science & Tech
ive got a wireless network setup with a netgear wrg614 router and 2 computers, a centrino laptop and a destop with a netgear ma111 wireless usb adaptor.
the centrino works fine with the internet, i am using it now
but the destop is having major problems. i recenltly installed a new hard drive, and in doing so i had to take all the usbs out. from doing this the ma111 stoped working, and when i pluged it in and tried to install it i got a "bad pool header". bosd. i followed instructinos of another forums, and got it working by disabling all instances of it in the device manager, then installing v2. But then it woiuld connect but the computer thingy in the taskbar still said disabled and i couldntsee other computers, they cannot see it, i cannot access internet, and cannot see the router page on 192.168.0.1.
i ran WINSOCKFIX, and this got the computer in the taskbar picking up signal, but i ztill cannot see other computers, they cannot see it, i cannot access internet, and cannot see the router page on 192.168.0.1. all computers have sp2 on xp,
i have tried reinstalling the ma111, changing settings, but cannot get it to work
should i just buy a belkin one or something, but i dont want to, cause that would be a was of au$120 dollars. it was working fine before i installed the new hard drive
  • AranyicAranyic Casstown, OH Icrontian
    Have you tried instead of disabling it in task manager actually right clicking on it and uninstalling the wireless adapater then reboot & plug it back in once the computer is completely up and running.
  • gtkgtk
    yes, you cant uninstall it
