Vid Card Fan making wierd noise...
edited January 2005 in Hardware
its on a 9600pro, and the fan is making a wierd loud noise. At first the comp wouldn't turn on. Once the noise started it would shut down. I cleaned the fan out w. compressed air and that problem stopped, but I'm stlill afraid to run the comp with it making that noise. I really dont want to have to get a new fan for it, so please help!
  • edited January 2005
    You could try oiling it but you will need to buy another fan eventually. They dont last forever. They arnt expensive either and you could go for a silent cooler made by someone like Zalman if you dont like fan noise (and who does?)
    edited January 2005
    yea the zalman is good but man its a pain to put together! I just get alike a vantec cooler or something and problem solved for good
  • yaggayagga Havn't you heard? ... New
    edited January 2005
    wasn't so much a "pain" for me, but it was annoying when I put the thing together backwards, fixed it and then the other side is backwards, and then had to take it all apart again to finally get it right.
