How to low the speed of 4 pin fans
Hey guys,
I was just wondering if anyone knows about a place where I could get mayself some sort of power retrictor for my case fans.
I have just got a new case which has 4 fans on it, but they are all powered by 4 pin connectors which can all be tandomed together. So currently running of 12 volts and sounding like the back end of a hugh airconditioning unit.
Does anyone know of such a wire? to lower the voltage?
Any help would be good.
Cheers
Chris
Cheers
Chris
There are fan controllers that fit 3.5 bays & 5.25 bays.
Some will monitor and control up to 3 independent fan sources, display temperature, hard drive activity, system power, time and date.
Some only monitor and control 3-4 fans. They have different connectors for the fans, so be sure you check that. Because you have all fans of 4 pin molex type, you'll need the changeover extensions.
pcToys 5.25in Fan Controller (silver) There are reviews under it to see more of the setup, connectors, etc.
It has connectors included, - two 3 pin fan extensions and two 4 pin to 3 pin extensions, so you'll have to buy two more 4 pin to 3 pin extensions in order to get all 4 fans with 4 pin molex connectors on there.
Coolerguys has other fan controllers too. It's a reputable site.
xoxide.com is also a good site, and they have controllers that fit both size bays. Look under Fan Accessories.
All that said, I would recommend having some heat monitoring/warning software setup or keep a very close eye on your temps. You sure don't want to burn anything up by trying to quiet your case. Hope this helps clear up a little bit on the subject for you.
Just realized your in United Kingdom, so you'll be checking them out over there. But these 2 sites have quite a few you can look at for reference.
