8I915P Duo Pro sata raid 0 transfer problem
I have 2 wd2000JD sata drives, configured raid 0 on ga-8I915P Duo Pro
My problem is that when I use raid drives and I make two transfers on 2 other Maxtor drives useing non raid Via controler each drive with it's own cable, master set transfer goes wild....2 M each transfer
If anyone knows to solve this problem I should be most greatfull
10x
10x
I think you are saying that when you are transfering a file from your raid drives to your non-raid the transfter takes 2 minutes each. How big are the files, and are you trying to do two transfers at the same or are you copying one, letting it finish them copying the other.
