Need Help Fixing my 9800Pro
So, I have a Radeon 9800Pro. To begin with, the power connector was fairly flimsy, but I accidently broke it
There are 4 metal prongs going into the board of the card, and at the right angle to the power connector, one of them snapped.
It looks somewhat like this:
_____ <to power plug in>
<board>
Everything on the card is fine, its just the piece of metal sticking out snapped, and I just need to reconnect it, but I have no idea how to go about this.. Can anyone help?
There are 4 metal prongs going into the board of the card, and at the right angle to the power connector, one of them snapped.It looks somewhat like this:
<board>
Please don't take offence to the next two comments, but shut the power off to your PC and take the card out before you solder it.:nervous:
If you have never soldered before then practice on any old card, or find someone you trust to do it for you.:D
