power supply - mobo connection
Hi all,
Quick question - building a data server for the office using a Tyan Tomcat K8E which aparently takes a "newer EVS1 power supply" - not having toyed around with components for a couple years I missed that minor detail and bought the cheapest, largest case I could (also weighs like 100#). Regardless, the mobo takes a 24 pin and an 8 pin connector, the power supply comes with a 20+4 and a 4. Can I get a 20 to 24 adapter and plug the two 4s in together to the 8 or am I just going to have to bite the bullet and buy a new PS?
tia
tia
My gut tells me that if you are building a data server for the office, you are not going to want to play around with an adapted PSU though. I would recommend getting the correct PSU for your system and DON"T get the cheapest one there is! Bad or under powered PSU's are the no.1 cause for hardware issues.
thanks Zuntar & Kryyst
msquito
