Right click problems
edited May 2007 in Nerdery
I am running windows XP and the right click is extremely slow to respond. I am really tired of it. Anyone have an idea where I might start to look for a solution??:confused:
  • ZuntarZuntar North Carolina Icrontian
    edited May 2007
    Hey bro! this may sound strange, but in reading about your problem it sounds like its network related. try unplugging the network cable and see if it stops. have you disconnected any network computers or any network drives?
    edited May 2007
    Also is this a new problem that came out of no where, one that's been steadily getting worse, or one that's been there since you've started using this machine.
    edited May 2007
    Do you by any chance have an integrated Intel graphics chip?
  • Your-Amish-DaddyYour-Amish-Daddy The heart of Texas
    edited May 2007
    I think he'd have is video drivers installed...He might be having a problem with a failing hard drive. I used to have that problem years ago in 2000, Turned out to be a bad drive.
  • edited May 2007
    Whatup Bro' I have not changed my network connections (this is on my wife's computer) The problem has been around a long time . She says it is getting worse. Don't know what started it last year. she does have an integrated video but it is disabled. we installed an NVIDIA GeForce 6200.
    edited May 2007
    Do a bad sector check on the hard drive and see if it gets worse when you're done.
    edited May 2007
    Also do the needed spy/anti-virus scans and a defrag. Plus look to see what options are in the option bar when you right click. Could be a case of just a lot of programs installed that aren't needed.
  • edited May 2007
    Thanks for the ideas guys. I checked the hard drive for errors, ran anti virus and defragged. all to no avail. I did discover that when I right click on folders, there is no problem. It only happens when I click on files. Doesn't seem to matter what type though.
    edited May 2007
    To hell with what I said, it might be drive indexing...
    edited May 2007
    sakdiesel wrote: »
    You have switched computers around and or changed out computers on your "network" within the last year! Try disabling the lan connection and see what happens. Basically I believe that when you right click it is searching for a shell extension of a program or link that is no longer available. Perhaps an old program that did not uninstall properly, or was moved or has become corrupt or it could be referring to an application placed in a network share.;)
    edited May 2007
    yeah turn off drive indexing it's the most useless function MS has ever implemented. Right click on a drive in explorer choose properties and right there you'll see a check box for drive indexing, just remove it on each of your drives.
