Extreme motherboard temps (Striker Extreme)
Hi,
I just my new C2D system together yesterday:
Asus Striker Extreme
C2D E4300
2GB Crucial Ballistix
8800GTS 320MB
Used some old parts:
520W OCZ Powerstream PSU
1x 160GB 1x 250GB SATA Drives
Pioneer DVR-111L
The problem is when I start the pc, BIOS and Everest displays motherboard temp as -55 Degrees then Asus pc probe displays motherboard temp as 201 degrees
I just using the stock cooler on the CPU till I get my WC gear.
The sinks on the north and south bridge are cool to the touch during ORTHOS. And the motherboard temps never change whether idle or load. CPU temp seems accurate with Core Temp 0.95.
Someone tell me WTF is going here!!!
Thanks in advance
EDIT//
The pic is taken at 3GHz IDLE with all stock volts
C2D E4300
8800GTS 320MB
Pioneer DVR-111L
Thanks in advance
EDIT//
At one time I saw the BIOS and everest show 127 degrees, but probe always shows 201 degrees.
What i''m worried about though is that the heatpipes are cool to the touch even under load. Does this mean that there is a poor connection between the NB/SB and the heatpipes? Or don't they get that hot anyway?
Thanks.
This is no big deal, because these sensors are not tested before put to use.
