connection speed problems on new build
so to sum it up spent 500ish quid on a pc
spec: amd 6000+ x2
m2n32-sli deluxe wireless edition
2gb corsir 800mhz DDR II
200gb seagate 7.2k rpm HD
16x dvd-rw
8600gts albatron
thats EVERYTHING thats in my pc atm
ok now the fun part when i try 2 DL download something i get 30kb/s MAX, now i no what ur thinking hes got a **** connection, i got 2mb broadband and the last time i checked 2mb = 240kb/s ish.. now a few days have pasted so i desided to break out my old laptop (advent 7017) and did a speed test and DL a few files WOW i get 243kb/s on both them then i quickly hook my new custom build pc up and it goes bk 2 30kb....... same cable same router even the same OS i have run pout of options
any suggestions?
computers running FAST as lighting been able to crush BF 2142 on max seeting doom 3 hell even broke out a game of C&C3 TW no problems only the download speed crys as he watching the LONG buffing time on stage6
spec: amd 6000+ x2
16x dvd-rw
8600gts albatron
any suggestions?
tryed it didnt work
ran a speed test and got 42.3kb/s then uninstalled the network manager and got 52.3kb/s so where on the right track
Get some kind of registry cleaner (Reg Mechanic or Reg Supreme type thing) as well, there may be left over registry entries.
Did you reboot after uninstalling and then try the speedtest?
o and BTW i am using the usb plug to connect to the internet my ethernet is in my x360,
EDIT: i also tryed ethernet and it was SLOWER! 32kb/s
bt voyager 205 router if that help thx
Go into the device manager and look at the Advanced tab for the Nvidia network adapter. Is it set to Auto for the speed/duplex?
yeh its on auto is that good? snd usb is fine atm my m8s running 8mb BT broadband across town and hes on the same router as me using usb 2.0 cuz hes also got his 360 hooked up to the etherport in the router
quick question if ur running the m2n32-sli mobo what router u got, just woundering cuz my bt 12 month contract is almost up and u no what isp r like when there "may" loss a customer :P they get desprate and offer all kinda offers heheh
