Peltier cooling problem
I run a 226 watt potted pelt on an AMD X2 4800+ and just recently took the waterblock off to clean my system and put everything back together. It all went back the same way I originally had it, but now my cpu core temps are up around 50C, but the water temp is ony 45C. Sounds to me like the pelt stopped working, but if it did, wouldn't that insulate the cpu and cause it to overheat? Does anybody have any ideas? I'd appreciate any input.
Thanks.
Thanks.
Ceramique is what I'm using.
