Monitor clicks into standby mode when RS232 <> TTL cable connected
Anyone know why my dell p1110 monitor turns off when I connect a RS232 <> TTL cable to the four pin header... I'm trying to use windas to fix the oh-so common brightness issue these monitors have and can't get very far without being able to connect the cable and view the screen at the same time. It doesn't fully turn off, but goes blank and the green light turns amber. Any suggestions are greatly appriciated.
Nah, you don't understand. The brightness is at 0, and the contrast at 100. This kind of monitor has problems like this sometimes, and there is software to fix it.. Windas. But I can't make windas work without the rs232 <> TTL cable attached to the PC and the monitor. When I connect it to the monitor, it clicks into standby mode.
