Graphics card not being recognized / Driver problem?
I truly wish I could just junk the whole machine at this point, but that's not in budget at the moment.
I got an emachine from a friend. I've added some ram and a pci video card Verto GeForce FX 5800 (no other option on my motherboard) and it runs games reasonably. Or at least it did. I moved, and in the process damaged the power switch. Before I figured that out I'd messed around with everything inside trying to isolate the problem. In order to get everything working again I ended up flashing the bios.
Right now it's booting & running fine - but only with onboard graphics. The driver disk got lost in the move, per the instructions I did check that it defaults to PCI for graphics. The nVidia drivers don't recognize the card and won't re-install. Any ideas? (other than chucking it through a window)
I downloaded the GeForce FX drivers from the nVidia website. It runs some program then tells me I don't have a relevant card installed, so I never get a driver installed from that.
Found the instructions for putting the card in but not the driver disk. Called the mfg and got an answering machine. Not holding my breath waiting on their reply....
Still gotta reboot it in a sec, but it looks like my issue was likely caused by not getting everything back in just right after taking it all out to look for wtf is wrong in here (and remove dust, dog hair and a couple dead bugs... amazing how much crud can build up inside the case).
Thanks so much for the help :-)
