Signal conversion help
I am trying to take an HDMI signal from a PC to an Intelix HDMI-F, which uses two STP cables (One carries voltage, the other carries A/V). I'm trying to take those cables into a PLN adapter, but I cannot for the life of me figure out how to convert these cables down into a single run for PLN so I can shoot out a single cable at the other end and convert that back to two cables for the receiving HDMI-F adapter at the other end.
Anyone have any thoughts?
//EDIT: Cancel this. Going to go with VGA and analog audio, which requires a single run. It's only a 480p signal anyhow.
