Video settings; tell it to run video through HDMI; it will ask you if you want to set up audio after that; say yes, tell it to run audio through HDMI, and tell it what formats your receiver can handle. The end.
I already told you. If you set the video options, it'll ask you if you want to set the audio options; if you just want to set the audio, go to set the audio options.
codecs? where do i do that..
what formats are there?
im sorry MJ..didnt mean upset u
