PC Problem Please Help
Well I'm trying to reassemble my old PC. There is something odd. I have my motherboard, my power supply and my memmory in. I turned the power on, and it goes through, the fans turn on and everything. Then I put in my GFX card and turn it on, it powers up for 1 second then turns off. Is my GFX the problem or Motherboard.
"run it on a piece of cardboard."
What do you mean by that can you specify?
Turning on doesn't mean it's working.
