Help Hard Drive Cleaning
Hi
I want to create more space on my main hard drive. I have already deleted the files that I don't need. I want to know which other files I can remove safely.
THANKS
THANKS
Let it delete all temp files, all internet files, any office setup files, webclient/publisher temp files.
You can let it compress old files, but that may take awhile and I never do, but that is just choice.
http://www.ccleaner.com/
I can vouch for that. On my very first run of cCleaner it opened up 3-4 GB. Definitely something to look into.
Probably you do routine cleaning manually?
Or you ar just the best YAD evar! :bigggrin::bigggrin::bigggrin:
Edit:/ I usually clean the crap off my machines regularly ... with several different programs etc..
Yeah, I do not use the Issues part of cCleaner much anymore; once it borked a perfectly fine cd-writer somehow, and it kept saying error please insert disc blah blah, until I re-installed the burning software. I usually use the registry cleaners in SystemMechanic and Tune Up Utilities; they seem to work very well. Though they are both pay for software. The only free one I have much experience with is Wise Registry Cleaner, that so far has not caused any damage.
1) Reduce the size of your Recycle bin to 1%
2) Go into your internet explorer settings and reduce the size of the cache to like 50mb
3) Go into your system settings and lower the size of the system restore cache. Though that will limit your amount of restore points if that's something you rely on.
4) Turn off drive indexing. This may or may not give back some space, but it'll help with speed.
