Problems
shackwrrrshackwrrr Lima, oh
edited January 2008 in Software
I didnt know where to put this. but I cant download anything. When I try to download anything big like a service pack thats 200 mb I get problems. While downloading it just plain stops no counter movement no info chages. It does it with firefox, IE And down them all in firefox. Ive messed with the tcp settings with tcp optimiser but nothing chages. I restart the download and it will do the same thing too. Please help
    edited January 2008
    That will often happen if your internet connection is unstable, your connection drops, temporarily, your download lags out and you lose it.
    I'd suggest getting a resumable download manager something like flashgot for example. If your download hangs you can resume it.
  • shackwrrrshackwrrr Lima, oh
    edited January 2008
    thanks for the help All is fine now. It was the POS pre-N belkin router. We traded it for a linksys with speed booster and all is fine now. downloaded a 800 mb file perfect
    edited January 2008
    That was going to be the next suggestion.
