Ok, sorry to sound like a nub, but I got this infrared LED and i need for a little experiment with my Wii and I have no idea how to power it. Its got a blue glass ball on to of two long silver prongs, any help?
1.5v to 3v usually. Doesn't really matter which way the power goes in I think, but look at it and find the top of the diode in the ball, and follow that down out of the bulb to the stems and that SHOULD be positive.
the led should have a flattened edge somewhere on the "bulb" (it's not really a bulb). This is the negative side.
Hook it up backward and it will do nothing.
apply too much voltage and it will smoke. once.
what i mean is that a diode hooked up backwards will work properly. It will do nothing.
IR LEDs + Wiimote + reflective tape = OMGFINGERWIIMOTES
