problems with USB/Firewire Combo Card
I picked up a USB/Firewire Combo Card (PCMCIA) and am having a whale of a time to get it to work. Win XP Pro SP2 chimes when I insert it into my laptop, but that seems as far as it goes - since when I plug a firewire or USB device into the card (like an ipod or a USB flash drive) nothing is recognized. It came with a driver CD and I believe I loaded the drivers properly, but not 100% sure since the CD has about 20 different folders on it. This unit came from Taiwan - I know I know - that's probably not a good idea, but the unit is all over the web and being sold in hundreds of online shops so it may be a legit unit. I know my PCMCIA slot is fine since I can insert a single firewire port card into it and it works great. Any suggestions?
Do you have any make/model for the card that you can provide?
