Merging Hard Drives Help + Advice for backing up data
hi,
resently i tryied to create RAID 5 array for home use - it didnt work, and i understand now that its not a good idea for PC anyway...
now i have 4 WD 1000FYPS hard drives... what i'd like to know is:
1) can i make all 4 drives to appear as one drive (one big huge volume)?? (under Windows Vista)
2) if yes - then how
, and if its a good idea anyway...
3) I'd like to backup all the data to another hard drive, but i'd like the back up to be updatet automaticly (say...once a week). is there a software that can do that?
4) also i'd like to know how much storage i'll need to back up 4 TB (meant the data (mainly HD video and music - if it matters) whould be compressed)?
thanks!
, and if its a good idea anyway...3) I'd like to backup all the data to another hard drive, but i'd like the back up to be updatet automaticly (say...once a week). is there a software that can do that?
thanks!
Although 1 TB is Waaay plenty for OS/programs thats how I would have the HDDs setup.
i have a seperate drive for OS and programs
the 4 TB whould go for data only
Just have an E, F, G, H drives and label them Movies, Music, Downloads, Documents for example.
