Choosing LED lights
I fried all 4 led bulbs that where accidently connected negative to positive.
Are the harnesses that power cdroms, hdd 12v? what about the floppy?
I know that there are different intensity levels, but not sure what is best suited for this situation. On the radioshack website they show alot of different ones, would any work? http://www.radioshack.com/search/index.jsp?kwCatId=&kw=led&origkw=led&sr=1
Thanks
I had to rewrite the post because i found my problem :o
Thanks
What are you running these off of. It sounds like to me they got way too much power. Are you running these off of a 12 volt feed? If so do you have resistors to limit how much power can flow through? Without it the led will suck as much power as it can until it blows (usually very quickly)
Also depends on how you're doing the wiring. If you're doing a series circuit then you can only get 3 LED's to the 5V most likely. Also, if it is series then then the first + leg(longer one) touches the wire, and then the - leg of that LED has to touch the + leg of the next LED. So it is + touching - in series essentially.
Parallel is different as you probably know.
