problem with unix systems. please advise
edited May 2008 in Nerdery
dear Unix expertised people
my unix server is always giving problems, I analysis the server and found as
1. the Unix system could not detect the NIC or network interface card sometime, it acquired to be completely shutdown and chill-down for few seconds, once it is turn on, everything comes back to normal ==> what wrong with it?
2. I found this piece of information from the server: there are 217967 blocks and 24218 blocks free, I have awareness that it means I still have 11.11% vacancy space, ==>
a. what is actual size for a block
b. does unix systems server using hard disk space as virtual memory as Windows usually does? or is that the root cause problems
c. root systems need to be mounted sometime, ==> how to avoid it?
thank you for your time reading those above question,
Khanh
    edited April 2008
    What operating system are you using, specifically? Unix isn't specific enough and each variety has its own way of doing things. Also, post a copy of your system log as an attachment. If you don't know how to read it or where it is, then I will definitely need to know what kind of Unix you're using so I can tell you where to look.
    Block size varies depending on how you formatted your hard drive. You could divide your hard drive's formatted capacity by the number of blocks to find the block size, or just read it out of your system logs.
    I assume you're referring to the Windows pagefile when you say virtual memory and the answer is no. Though Unix can use a file on the filesystem as a pagefile like Windows does, most implementations use a separate, unformatted partition. This has performance advantages because the penalties associated with writing a file in a formatted filesystem aren't incurred.
    I don't understand question 2.c. Are you asking about needing to have root user privileges to accomplish some task?
    -drasnor :fold:
  • edited April 2008
    yes please
    -drasnor :fold:
    that right, I have the root privilledge, I got to fsck and mount some system directory before I can login normally
    thank yuo for your time
    <!-- / message --><!-- sig -->
    edited April 2008
    You get that error when you shut down the machine by pushing the power button or disconnecting power. Try shutting down the system by selecting "Shut Down" in the graphical interface or entering "shutdown -h now" as root in a terminal when you want to turn it off.
    I still need your system log to troubleshoot your NIC problem.
    -drasnor :fold:
  • edited May 2008
    drasnor wrote: »
    -drasnor :fold:
    very nice to have your attention, could you please tell me how to get that log files please, I have no ideas where it come from
    thank you for your time in reading this message, I really appreciate you help
    BD
    ps: on the windows, we have winver or ver to get operating system version, how about unix ? how can I get the unix version please tell, thank you
    edited May 2008
    Normally it will say which kind and what version it is as it boots up. Let's try something else: did Unix come on this computer? If so, who made the computer and what model is it?
    On my machine (Gentoo Linux), the system logs are contained in /var/log/messages and /var/log/dmesg. A copy of both of those is what I'm looking for.
    -drasnor :fold:
  • edited May 2008
    i think, it is sco openserver 5, I have download version 6.0 and try to learn how to make it work, I have no ideas where to get the systems logfiles, can you please show me ?
    thank you
    edited May 2008
    SCO OpenServer's logs can be found in /usr/adm/messages and /usr/adm/syslog.
    -drasnor :fold:
  • edited May 2008
    -drasnor :fold:
    I found those, but they are link only :o
    edited May 2008
    Where do they link to?
    -drasnor :fold:
  • edited May 2008
    http://www.megaupload.com/?d=EBM098XK ==> system logfiles
    thank you for your waiting yes, I follow the link and found the logfile, please have a look and advise me what to do
    thank you so much for your time
  • edited May 2008
    can you download my system logfiles ?
    edited May 2008
    No, the site won't let me download. Can you attach them here?
    -drasnor :fold:
  • edited May 2008
    messages log file
    Wed May 7 09:30:40 2008
    nb: shutting down NetBIOS...
    Wed May 7 09:33:17 2008
    SCO OpenServer(TM) Release 5
    (C) 1983-1995 The Santa Cruz Operation, Inc.
    (C) 1980-1994 Microsoft Corporation
    (C) 1976-1994 UNIX System Laboratories, Inc.
    All rights reserved.
    For complete copyright credits,
    enter "copyrights" at the command prompt.
    Kernel ID 96/01/23 on a Pentium CPU
    device address vector dma comment
    %fpu - 13 - type=80387
    %serial 0x03F8-0x03FF 4 - unit=0 type=Standard nports=1
    %serial 0x02F8-0x02FF 3 - unit=1 type=Standard nports=1
    %floppy 0x03F2-0x03F7 6 2 unit=0 type=135ds18
    %console - - - unit=vga type=0 12 screens=68k
    %parallel 0x0378-0x037A 7 - unit=0
    %pci 0x0CF8-0x0D00 - - am=1 sc=1 buses=2
    %apm - - - PM v1.2
    %adapter 0xE000-0xE0FF 11 - type=alad ha=0 bus=0 id=7 fts=sto
    %adapter 0x0170-0x0177 15 - type=wd ha=1 id=7 bus=0 fts=db
    %pnt 0xE400-0xE412 5 - pnt0 v2.2 addr=00:40:f6:b8:40:06
    %tape - - - type=S ha=0 id=2 lun=0 bus=0 hWed May 7 09:33:23 2008
    t=alad
    %disk 0x01F0-0x01F7 14 - type=W0 unit=0 cyls=585 hds=64 secs=63
    mem: total = 245376k, kernel = 13672k, user = 231704k
    swapdev = 1/41, swplo = 0, nswap = 160000, swapmem = 80000k
    rootdev = 1/42, pipedev = 1/42, dumpdev = 1/41
    kernel: Hz = 100, i/o bufs = 6652k
    Thu May 8 08:35:23 2008
    Thu May 8 08:37:23 2008
    %apm - - - PM v1.2
    WARNING: pnt0 PCnet-PCI not found, please run netconfig
    WARNING: 11: device not found!
    %pnt 0xE400-0Thu May 8 08:37:26 2008
    xE412 0 - pnt0 v2.1 Adapter Not Found
    %tape - - - type=S ha=0 id=2 lun=0 bus=0 ht=alad
    mem: total = 245376k, kernel = 13540k, user = 231836k
    Thu May 8 08:39:50 2008
    WARNING: pormapper on server 10.19.0.2 is not responding
    Thu May 8 08:40:21 2008
    Thu May 8 08:40:25 2008
    Thu May 8 08:42:53 2008
    %apm - - - PM v1.2
    %tape - - - type=S ha=0 id=2 lun=0 bus=0 hThu May 8 08:42:59 2008
    t=alad
    Thu May 8 08:46:08 2008
    %Stp-0 - - - Vendor=Seagate Product=STT20000N
    Fri May 9 08:31:16 2008
    Fri May 9 08:32:44 2008
    %apm - - - PM v1.2
    %pnt 0xE400-0Fri May 9 08:32:50 2008
    Fri May 9 08:34:09 2008
    Fri May 9 08:34:40 2008
    Fri May 9 08:35:11 2008
    Fri May 9 08:44:00 2008
    %apm - - - PM v1.2
    %pnt 0xE400-0Fri May 9 08:45:20 2008
    %apm - - - PM v1.2
    %pnt 0xE400-0xE412 255 - pnt0 v2.2 addr=00:40:f6:b8:40:06
    %tape - - - type=S ha=0 id=2 lun=0 bus=0Fri May 9 08:45:24 2008
    ht=alad
    Fri May 9 08:48:03 2008
    Fri May 9 08:52:44 2008
    %apm - - - PM v1.2
    %tape - - - type=S ha=0 id=2 lun=0 bus=0 hFri May 9 08:52:48 2008
    t=alad
    Fri May 9 08:55:15 2008
    Fri May 9 08:57:16 2008
    Fri May 9 08:58:41 2008
    %apm - - - PM v1.2
    %tape - - - type=S ha=0 id=2 lun=0 bus=0 hFri May 9 08:58:46 2008
    t=alad
    Fri May 9 09:00:32 2008
    May 9 00:04:28 mmats bootpd[906]: IP address not found: 10.19.0.100
    May 9 00:04:31 mmats bootpd[906]: IP address not found: 10.19.0.100
    May 9 00:04:42 mmats bootpd[906]: IP address not found: 10.19.0.139
    May 9 00:04:46 mmats bootpd[906]: IP address not found: 10.19.0.139
    May 9 00:06:57 mmats bootpd[906]: IP address not found: 10.19.0.129
    May 9 00:07:00 mmats bootpd[906]: IP address not found: 10.19.0.129
    May 9 00:07:10 mmats bootpd[906]: IP address not found: 10.19.0.135
    May 9 00:07:14 mmats bootpd[906]: IP address not found: 10.19.0.135
    May 9 00:08:56 mmats bootpd[906]: IP address not found: 10.19.0.150
    May 9 00:09:01 mmats bootpd[906]: IP address not found: 10.19.0.150
    May 9 00:09:49 mmats bootpd[906]: IP address not found: 10.19.0.140
    May 9 00:09:54 mmats bootpd[906]: IP address not found: 10.19.0.140
    May 9 00:13:51 mmats bootpd[906]: IP address not found: 10.19.0.114
    May 9 00:13:55 mmats bootpd[906]: IP address not found: 10.19.0.114
    May 9 00:16:08 mmats bootpd[906]: IP address not found: 10.19.0.146
    May 9 00:16:11 mmats bootpd[906]: IP address not found: 10.19.0.146
    May 9 00:22:45 mmats bootpd[906]: IP address not found: 10.19.0.162
    May 9 00:22:48 mmats bootpd[906]: IP address not found: 10.19.0.162
    May 9 00:29:58 mmats bootpd[906]: IP address not found: 10.19.0.112
    May 9 00:31:06 mmats bootpd[906]: IP address not found: 10.19.0.115
    May 9 00:31:11 mmats bootpd[906]: IP address not found: 10.19.0.115
    May 9 00:31:24 mmats bootpd[906]: IP address not found: 10.19.0.126
    May 9 00:31:29 mmats bootpd[906]: IP address not found: 10.19.0.126
    May 9 00:35:14 mmats bootpd[906]: IP address not found: 10.19.0.124
    May 9 00:35:17 mmats bootpd[906]: IP address not found: 10.19.0.124
    May 9 00:39:08 mmats bootpd[906]: IP address not found: 10.19.0.141
    May 9 00:39:13 mmats bootpd[906]: IP address not found: 10.19.0.141
    May 9 00:41:33 mmats bootpd[906]: IP address not found: 10.19.0.142
    May 9 00:41:36 mmats bootpd[906]: IP address not found: 10.19.0.142
    May 9 00:43:00 mmats bootpd[906]: IP address not found: 10.19.0.148
    May 9 00:43:03 mmats bootpd[906]: IP address not found: 10.19.0.148
    May 9 00:46:14 mmats bootpd[906]: IP address not found: 10.19.0.165
    May 9 00:51:17 mmats bootpd[906]: IP address not found: 10.19.0.100
    May 9 00:51:20 mmats bootpd[906]: IP address not found: 10.19.0.100
    May 9 00:58:25 mmats bootpd[906]: IP address not found: 10.19.0.133
    May 9 00:58:28 mmats bootpd[906]: IP address not found: 10.19.0.133
    May 9 00:59:32 mmats bootpd[906]: IP address not found: 10.19.0.154
    May 9 00:59:36 mmats bootpd[906]: IP address not found: 10.19.0.154
    May 9 01:06:09 mmats bootpd[906]: IP address not found: 10.19.0.126
    May 9 01:06:14 mmats bootpd[906]: IP address not found: 10.19.0.126
    May 9 01:06:17 mmats bootpd[906]: IP address not found: 10.19.0.151
    May 9 01:06:21 mmats bootpd[906]: IP address not found: 10.19.0.151
    May 9 01:07:07 mmats bootpd[906]: IP address not found: 10.19.0.122
    May 9 01:07:11 mmats bootpd[906]: IP address not found: 10.19.0.122
    May 9 01:07:33 mmats bootpd[906]: IP address not found: 10.19.0.100
    May 9 01:07:36 mmats bootpd[906]: IP address not found: 10.19.0.100
    May 9 01:14:18 mmats bootpd[906]: IP address not found: 10.19.0.128
    May 9 01:14:21 mmats bootpd[906]: IP address not found: 10.19.0.128
    May 9 01:14:37 mmats bootpd[906]: IP address not found: 10.19.0.136
    May 9 01:14:41 mmats bootpd[906]: IP address not found: 10.19.0.136
    May 9 01:15:07 mmats bootpd[906]: IP address not found: 10.19.0.153
    May 9 01:15:11 mmats bootpd[906]: IP address not found: 10.19.0.153
    May 9 01:25:03 mmats bootpd[906]: IP address not found: 10.19.0.114
    May 9 01:25:06 mmats bootpd[906]: IP address not found: 10.19.0.114
    May 9 01:34:32 mmats bootpd[906]: IP address not found: 10.19.0.160
    May 9 01:34:36 mmats bootpd[906]: IP address not found: 10.19.0.160
    May 9 01:35:57 mmats bootpd[906]: IP address not found: 10.19.0.162
    May 9 01:36:00 mmats bootpd[906]: IP address not found: 10.19.0.162
    May 9 01:40:12 mmats bootpd[906]: IP address not found: 10.19.0.157
    May 9 01:40:55 mmats bootpd[906]: IP address not found: 10.19.0.139
    May 9 01:40:59 mmats bootpd[906]: IP address not found: 10.19.0.139
    May 9 01:42:19 mmats bootpd[906]: IP address not found: 10.19.0.150
    May 9 01:42:23 mmats bootpd[906]: IP address not found: 10.19.0.150
    May 9 01:44:26 mmats bootpd[906]: IP address not found: 10.19.0.128
    May 9 01:44:30 mmats bootpd[906]: IP address not found: 10.19.0.128
    May 9 01:44:59 mmats bootpd[906]: IP address not found: 10.19.0.112
    May 9 01:49:13 mmats bootpd[906]: IP address not found: 10.19.0.161
    May 9 01:49:18 mmats bootpd[906]: IP address not found: 10.19.0.161
    May 9 01:52:39 mmats bootpd[906]: IP address not found: 10.19.0.126
    May 9 01:52:43 mmats bootpd[906]: IP address not found: 10.19.0.126
    May 9 01:53:11 mmats bootpd[906]: IP address not found: 10.19.0.129
    May 9 01:53:15 mmats bootpd[906]: IP address not found: 10.19.0.129
    May 9 01:54:07 mmats bootpd[906]: IP address not found: 10.19.0.140
    May 9 01:54:11 mmats bootpd[906]: IP address not found: 10.19.0.140
    May 9 01:54:50 mmats bootpd[906]: IP address not found: 10.19.0.136
    May 9 01:54:54 mmats bootpd[906]: IP address not found: 10.19.0.136
    May 9 01:58:31 mmats bootpd[906]: IP address not found: 10.19.0.115
    May 9 01:58:36 mmats bootpd[906]: IP address not found: 10.19.0.115
    May 9 01:59:55 mmats bootpd[906]: IP address not found: 10.19.0.141
    May 9 01:59:59 mmats bootpd[906]: IP address not found: 10.19.0.141
    May 9 02:01:22 mmats bootpd[906]: IP address not found: 10.19.0.135
    May 9 02:01:25 mmats bootpd[906]: IP address not found: 10.19.0.135
    May 9 02:02:28 mmats bootpd[906]: IP address not found: 10.19.0.124
    May 9 02:02:31 mmats bootpd[906]: IP address not found: 10.19.0.124
    May 9 02:10:46 mmats bootpd[906]: IP address not found: 10.19.0.142
    May 9 02:10:50 mmats bootpd[906]: IP address not found: 10.19.0.142
    May 9 02:11:20 mmats bootpd[906]: IP address not found: 10.19.0.146
    May 9 02:11:24 mmats bootpd[906]: IP address not found: 10.19.0.146
    May 9 02:18:34 mmats bootpd[906]: IP address not found: 10.19.0.153
    May 9 02:18:37 mmats bootpd[906]: IP address not found: 10.19.0.100
    May 9 02:18:38 mmats bootpd[906]: IP address not found: 10.19.0.153
    May 9 02:18:40 mmats bootpd[906]: IP address not found: 10.19.0.100
    May 9 02:23:12 mmats bootpd[906]: IP address not found: 10.19.0.148
    May 9 02:23:15 mmats bootpd[906]: IP address not found: 10.19.0.148
    May 9 02:25:18 mmats bootpd[906]: IP address not found: 10.19.0.157
    May 9 02:29:45 mmats bootpd[906]: IP address not found: 10.19.0.154
    May 9 02:29:48 mmats bootpd[906]: IP address not found: 10.19.0.154
    May 9 02:30:20 mmats bootpd[906]: IP address not found: 10.19.0.165
    May 9 02:34:54 mmats bootpd[906]: IP address not found: 10.19.0.148
    May 9 02:34:57 mmats bootpd[906]: IP address not found: 10.19.0.148
    May 9 02:35:51 mmats bootpd[906]: IP address not found: 10.19.0.136
    May 9 02:35:56 mmats bootpd[906]: IP address not found: 10.19.0.136
    May 9 02:38:20 mmats bootpd[906]: IP address not found: 10.19.0.122
    May 9 02:38:25 mmats bootpd[906]: IP address not found: 10.19.0.122
    May 9 02:40:53 mmats bootpd[906]: IP address not found: 10.19.0.133
    May 9 02:40:56 mmats bootpd[906]: IP address not found: 10.19.0.133
    May 9 02:42:56 mmats bootpd[906]: IP address not found: 10.19.0.165
    May 9 02:45:34 mmats bootpd[906]: IP address not found: 10.19.0.151
    May 9 02:45:38 mmats bootpd[906]: IP address not found: 10.19.0.151
    May 9 02:51:03 mmats bootpd[906]: IP address not found: 10.19.0.138
    May 9 02:51:07 mmats bootpd[906]: IP address not found: 10.19.0.138
    May 9 03:01:34 mmats bootpd[906]: IP address not found: 10.19.0.135
    May 9 03:01:37 mmats bootpd[906]: IP address not found: 10.19.0.135
    May 9 03:02:43 mmats bootpd[906]: IP address not found: 10.19.0.124
    May 9 03:02:48 mmats bootpd[906]: IP address not found: 10.19.0.124
    May 9 03:05:01 mmats bootpd[906]: IP address not found: 10.19.0.112
    May 9 03:09:54 mmats bootpd[906]: IP address not found: 10.19.0.160
    May 9 03:09:57 mmats bootpd[906]: IP address not found: 10.19.0.160
    May 9 03:10:30 mmats bootpd[906]: IP address not found: 10.19.0.128
    May 9 03:10:34 mmats bootpd[906]: IP address not found: 10.19.0.128
    May 9 03:11:38 mmats bootpd[906]: IP address not found: 10.19.0.150
    May 9 03:11:41 mmats bootpd[906]: IP address not found: 10.19.0.150
    May 9 03:11:52 mmats bootpd[906]: IP address not found: 10.19.0.126
    May 9 03:11:56 mmats bootpd[906]: IP address not found: 10.19.0.126
    May 9 03:12:01 mmats bootpd[906]: IP address not found: 10.19.0.142
    May 9 03:12:05 mmats bootpd[906]: IP address not found: 10.19.0.142
    May 9 03:12:39 mmats bootpd[906]: IP address not found: 10.19.0.141
    May 9 03:12:43 mmats bootpd[906]: IP address not found: 10.19.0.141
    May 9 03:15:54 mmats bootpd[906]: IP address not found: 10.19.0.112
    May 9 03:16:57 mmats bootpd[906]: IP address not found: 10.19.0.139
    May 9 03:17:01 mmats bootpd[906]: IP address not found: 10.19.0.139
    May 9 03:22:11 mmats bootpd[906]: IP address not found: 10.19.0.162
    May 9 03:22:14 mmats bootpd[906]: IP address not found: 10.19.0.162
    May 9 03:22:14 mmats bootpd[906]: IP address not found: 10.19.0.157
    May 9 03:24:21 mmats bootpd[906]: IP address not found: 10.19.0.140
    May 9 03:24:26 mmats bootpd[906]: IP address not found: 10.19.0.140
    May 9 03:26:26 mmats bootpd[906]: IP address not found: 10.19.0.129
    May 9 03:26:30 mmats bootpd[906]: IP address not found: 10.19.0.129
    May 9 03:31:56 mmats bootpd[906]: IP address not found: 10.19.0.165
    May 9 03:32:29 mmats bootpd[906]: IP address not found: 10.19.0.161
    May 9 03:32:33 mmats bootpd[906]: IP address not found: 10.19.0.161
    May 9 03:34:25 mmats bootpd[906]: IP address not found: 10.19.0.148
    May 9 03:34:28 mmats bootpd[906]: IP address not found: 10.19.0.148
    May 9 03:38:06 mmats bootpd[906]: IP address not found: 10.19.0.136
    May 9 03:38:09 mmats bootpd[906]: IP address not found: 10.19.0.136
    May 9 03:40:34 mmats bootpd[906]: IP address not found: 10.19.0.146
    May 9 03:40:39 mmats bootpd[906]: IP address not found: 10.19.0.146
    May 9 03:42:57 mmats bootpd[906]: IP address not found: 10.19.0.115
    May 9 03:43:01 mmats bootpd[906]: IP address not found: 10.19.0.115
    May 9 03:45:58 mmats bootpd[906]: IP address not found: 10.19.0.154
    May 9 03:46:01 mmats bootpd[906]: IP address not found: 10.19.0.154
    May 9 03:48:24 mmats bootpd[906]: IP address not found: 10.19.0.165
    May 9 03:53:52 mmats bootpd[906]: IP address not found: 10.19.0.100
    May 9 03:53:55 mmats bootpd[906]: IP address not found: 10.19.0.100
    May 9 03:55:37 mmats bootpd[906]: IP address not found: 10.19.0.138
    May 9 03:55:39 mmats bootpd[906]: IP address not found: 10.19.0.142
    May 9 03:55:42 mmats bootpd[906]: IP address not found: 10.19.0.142
    May 9 03:55:42 mmats bootpd[906]: IP address not found: 10.19.0.138
    May 9 04:03:17 mmats bootpd[906]: IP address not found: 10.19.0.133
    May 9 04:03:20 mmats bootpd[906]: IP address not found: 10.19.0.133
    May 9 04:05:08 mmats bootpd[906]: IP address not found: 10.19.0.129
    May 9 04:05:12 mmats bootpd[906]: IP address not found: 10.19.0.129
    May 9 04:11:00 mmats bootpd[906]: IP address not found: 10.19.0.112
    May 9 04:16:21 mmats bootpd[906]: IP address not found: 10.19.0.142
    May 9 04:16:25 mmats bootpd[906]: IP address not found: 10.19.0.142
    May 9 04:24:09 mmats bootpd[906]: IP address not found: 10.19.0.139
    May 9 04:24:12 mmats bootpd[906]: IP address not found: 10.19.0.139
    May 9 04:39:12 mmats bootpd[906]: exiting after 15 minutes of inactivity
    May 9 08:31:16 mmats nb: shutting down NetBIOS...
    May 9 08:31:16 mmats lockd[397]: term_nlm():
    May 9 08:31:16 mmats lockd[397]: nlm lock server died! exiting.
    May 9 08:32:43 mmats syslogd: restart
    May 9 08:32:50 mmats SCO OpenServer(TM) Release 5
    May 9 08:32:50 mmats (C) 1983-1995 The Santa Cruz Operation, Inc.
    May 9 08:32:50 mmats (C) 1980-1994 Microsoft Corporation
    May 9 08:32:50 mmats (C) 1976-1994 UNIX System Laboratories, Inc.
    May 9 08:32:50 mmats All rights reserved.
    May 9 08:32:50 mmats For complete copyright credits,
    May 9 08:32:50 mmats enter "copyrights" at the command prompt.
    May 9 08:32:50 mmats Kernel ID 96/01/23 on a Pentium CPU
    May 9 08:32:50 mmats device address vector dma comment
    May 9 08:32:50 mmats %fpu - 13 - type=80387
    May 9 08:32:50 mmats %serial 0x03F8-0x03FF 4 - unit=0 type=Standard nports=1
    May 9 08:32:50 mmats %serial 0x02F8-0x02FF 3 - unit=1 type=Standard nports=1
    May 9 08:32:50 mmats %floppy 0x03F2-0x03F7 6 2 unit=0 type=135ds18
    May 9 08:32:50 mmats %console - - - unit=vga type=0 12 screens=68k
    May 9 08:32:50 mmats %parallel 0x0378-0x037A 7 - unit=0
    May 9 08:32:50 mmats %pci 0x0CF8-0x0D00 - - am=1 sc=1 buses=2
    May 9 08:32:50 mmats %apm - - - PM v1.2
    May 9 08:32:50 mmats %adapter 0xE000-0xE0FF 11 - type=alad ha=0 bus=0 id=7 fts=sto
    May 9 08:32:50 mmats %adapter 0x0170-0x0177 15 - type=wd ha=1 id=7 bus=0 fts=db
    May 9 08:32:50 mmats WARNING: pnt0 PCnet-PCI not found, please run netconfig
    May 9 08:32:50 mmats WARNING: 11: device not found!
    May 9 08:32:51 mmats xE412 0 - pnt0 v2.1 Adapter Not Found
    May 9 08:32:51 mmats %tape - - - type=S ha=0 id=2 lun=0 bus=0 ht=alad
    May 9 08:32:51 mmats %disk 0x01F0-0x01F7 14 - type=W0 unit=0 cyls=585 hds=64 secs=63
    May 9 08:32:51 mmats mem: total = 245376k, kernel = 13540k, user = 231836k
    May 9 08:32:51 mmats swapdev = 1/41, swplo = 0, nswap = 160000, swapmem = 80000k
    May 9 08:32:51 mmats rootdev = 1/42, pipedev = 1/42, dumpdev = 1/41
    May 9 08:32:51 mmats kernel: Hz = 100, i/o bufs = 6652k
    May 9 08:32:56 mmats syslogd: re-initialise
    May 9 08:32:56 mmats syslogd: restart
    May 9 08:33:27 mmats snmpd[307]: send_trap: No more interfaces: No such file or directory
    May 9 08:33:27 mmats snmpd[307]: Agent started (pid 307)
    May 9 08:34:09 mmats
    May 9 08:34:09 mmats WARNING: pormapper on server 10.19.0.2 is not responding
    May 9 08:34:40 mmats
    May 9 08:34:40 mmats WARNING: pormapper on server 10.19.0.2 is not responding
    May 9 08:35:11 mmats
    May 9 08:35:11 mmats WARNING: pormapper on server 10.19.0.2 is not responding
    May 9 08:45:20 mmats syslogd: restart
    May 9 08:45:24 mmats SCO OpenServer(TM) Release 5
    May 9 08:45:24 mmats (C) 1983-1995 The Santa Cruz Operation, Inc.
    May 9 08:45:24 mmats (C) 1980-1994 Microsoft Corporation
    May 9 08:45:24 mmats (C) 1976-1994 UNIX System Laboratories, Inc.
    May 9 08:45:24 mmats All rights reserved.
    May 9 08:45:24 mmats For complete copyright credits,
    May 9 08:45:24 mmats enter "copyrights" at the command prompt.
    May 9 08:45:24 mmats Kernel ID 96/01/23 on a Pentium CPU
    May 9 08:45:24 mmats device address vector dma comment
    May 9 08:45:24 mmats %fpu - 13 - type=80387
    May 9 08:45:24 mmats %serial 0x03F8-0x03FF 4 - unit=0 type=Standard nports=1
    May 9 08:45:24 mmats %serial 0x02F8-0x02FF 3 - unit=1 type=Standard nports=1
    May 9 08:45:24 mmats %floppy 0x03F2-0x03F7 6 2 unit=0 type=135ds18
    May 9 08:45:24 mmats %console - - - unit=vga type=0 12 screens=68k
    May 9 08:45:24 mmats %parallel 0x0378-0x037A 7 - unit=0
    May 9 08:45:24 mmats %pci 0x0CF8-0x0D00 - - am=1 sc=1 buses=2
    May 9 08:45:24 mmats %apm - - - PM v1.2
    May 9 08:45:24 mmats %adapter 0xE000-0xE0FF 11 - type=alad ha=0 bus=0 id=7 fts=sto
    May 9 08:45:24 mmats %adapter 0x0170-0x0177 15 - type=wd ha=1 id=7 bus=0 fts=db
    May 9 08:45:24 mmats %pnt 0xE400-0xE412 255 - pnt0 v2.2 addr=00:40:f6:b8:40:06
    May 9 08:45:25 mmats ht=alad
    May 9 08:45:25 mmats %disk 0x01F0-0x01F7 14 - type=W0 unit=0 cyls=585 hds=64 secs=63
    May 9 08:45:25 mmats mem: total = 245376k, kernel = 13672k, user = 231704k
    May 9 08:45:25 mmats swapdev = 1/41, swplo = 0, nswap = 160000, swapmem = 80000k
    May 9 08:45:25 mmats rootdev = 1/42, pipedev = 1/42, dumpdev = 1/41
    May 9 08:45:25 mmats kernel: Hz = 100, i/o bufs = 6652k
    May 9 08:45:31 mmats syslogd: re-initialise
    May 9 08:45:31 mmats syslogd: restart
    May 9 08:45:55 mmats snmpd[315]: Agent started (pid 315)
    May 9 08:48:03 mmats nb: shutting down NetBIOS...
    May 9 08:48:03 mmats ]: Agent started (pid 315)
    May 9 08:48:03 mmats lockd[404]: term_nlm():
    May 9 08:48:03 mmats lockd[404]: nlm lock server died! exiting.
    May 9 08:52:44 mmats syslogd: restart
    May 9 08:52:48 mmats SCO OpenServer(TM) Release 5
    May 9 08:52:48 mmats (C) 1983-1995 The Santa Cruz Operation, Inc.
    May 9 08:52:48 mmats (C) 1980-1994 Microsoft Corporation
    May 9 08:52:48 mmats (C) 1976-1994 UNIX System Laboratories, Inc.
    May 9 08:52:48 mmats All rights reserved.
    May 9 08:52:48 mmats For complete copyright credits,
    May 9 08:52:48 mmats enter "copyrights" at the command prompt.
    May 9 08:52:48 mmats Kernel ID 96/01/23 on a Pentium CPU
    May 9 08:52:48 mmats device address vector dma comment
    May 9 08:52:48 mmats %fpu - 13 - type=80387
    May 9 08:52:48 mmats %serial 0x03F8-0x03FF 4 - unit=0 type=Standard nports=1
    May 9 08:52:48 mmats %serial 0x02F8-0x02FF 3 - unit=1 type=Standard nports=1
    May 9 08:52:48 mmats %floppy 0x03F2-0x03F7 6 2 unit=0 type=135ds18
    May 9 08:52:48 mmats %console - - - unit=vga type=0 12 screens=68k
    May 9 08:52:48 mmats %parallel 0x0378-0x037A 7 - unit=0
    May 9 08:52:48 mmats %pci 0x0CF8-0x0D00 - - am=1 sc=1 buses=2
    May 9 08:52:48 mmats %apm - - - PM v1.2
    May 9 08:52:48 mmats %adapter 0xE000-0xE0FF 11 - type=alad ha=0 bus=0 id=7 fts=sto
    May 9 08:52:48 mmats %adapter 0x0170-0x0177 15 - type=wd ha=1 id=7 bus=0 fts=db
    May 9 08:52:48 mmats %pnt 0xE400-0xE412 5 - pnt0 v2.2 addr=00:40:f6:b8:40:06
    May 9 08:52:49 mmats t=alad
    May 9 08:52:49 mmats %disk 0x01F0-0x01F7 14 - type=W0 unit=0 cyls=585 hds=64 secs=63
    May 9 08:52:49 mmats mem: total = 245376k, kernel = 13672k, user = 231704k
    May 9 08:52:49 mmats swapdev = 1/41, swplo = 0, nswap = 160000, swapmem = 80000k
    May 9 08:52:49 mmats rootdev = 1/42, pipedev = 1/42, dumpdev = 1/41
    May 9 08:52:49 mmats kernel: Hz = 100, i/o bufs = 6652k
    May 9 08:52:56 mmats syslogd: re-initialise
    May 9 08:52:56 mmats syslogd: restart
    May 9 08:53:17 mmats snmpd[308]: Agent started (pid 308)
    May 9 08:54:06 mmats bootpd[497]: version 2.3.5
    May 9 08:54:06 mmats bootpd[497]: IP address not found: 10.19.0.112
    May 9 08:55:15 mmats %Stp-0 - - - Vendor=Seagate Product=STT20000N
    May 9 08:55:53 mmats bootpd[497]: IP address not found: 10.19.0.141
    May 9 08:55:56 mmats bootpd[497]: IP address not found: 10.19.0.141
    May 9 08:56:01 mmats bootpd[497]: IP address not found: 10.19.0.138
    May 9 08:56:06 mmats bootpd[497]: IP address not found: 10.19.0.138
    May 9 08:56:24 mmats bootpd[497]: IP address not found: 10.19.0.135
    May 9 08:56:27 mmats bootpd[497]: IP address not found: 10.19.0.135
    May 9 08:56:37 mmats bootpd[497]: IP address not found: 10.19.0.122
    May 9 08:56:40 mmats bootpd[497]: IP address not found: 10.19.0.122
    May 9 08:57:16 mmats nb: shutting down NetBIOS...
    May 9 08:57:16 mmats lockd[402]: term_nlm():
    May 9 08:57:16 mmats lockd[402]: nlm lock server died! exiting.
    May 9 08:58:40 mmats syslogd: restart
    May 9 08:58:46 mmats SCO OpenServer(TM) Release 5
    May 9 08:58:46 mmats (C) 1983-1995 The Santa Cruz Operation, Inc.
    May 9 08:58:46 mmats (C) 1980-1994 Microsoft Corporation
    May 9 08:58:46 mmats (C) 1976-1994 UNIX System Laboratories, Inc.
    May 9 08:58:46 mmats All rights reserved.
    May 9 08:58:46 mmats For complete copyright credits,
    May 9 08:58:46 mmats enter "copyrights" at the command prompt.
    May 9 08:58:46 mmats Kernel ID 96/01/23 on a Pentium CPU
    May 9 08:58:46 mmats device address vector dma comment
    May 9 08:58:46 mmats %fpu - 13 - type=80387
    May 9 08:58:46 mmats %serial 0x03F8-0x03FF 4 - unit=0 type=Standard nports=1
    May 9 08:58:46 mmats %serial 0x02F8-0x02FF 3 - unit=1 type=Standard nports=1
    May 9 08:58:46 mmats %floppy 0x03F2-0x03F7 6 2 unit=0 type=135ds18
    May 9 08:58:46 mmats %console - - - unit=vga type=0 12 screens=68k
    May 9 08:58:46 mmats %parallel 0x0378-0x037A 7 - unit=0
    May 9 08:58:46 mmats %pci 0x0CF8-0x0D00 - - am=1 sc=1 buses=2
    May 9 08:58:46 mmats %apm - - - PM v1.2
    May 9 08:58:46 mmats %adapter 0xE000-0xE0FF 11 - type=alad ha=0 bus=0 id=7 fts=sto
    May 9 08:58:46 mmats %adapter 0x0170-0x0177 15 - type=wd ha=1 id=7 bus=0 fts=db
    May 9 08:58:46 mmats %pnt 0xE400-0xE412 5 - pnt0 v2.2 addr=00:40:f6:b8:40:06
    May 9 08:58:46 mmats t=alad
    May 9 08:58:46 mmats %disk 0x01F0-0x01F7 14 - type=W0 unit=0 cyls=585 hds=64 secs=63
    May 9 08:58:46 mmats mem: total = 245376k, kernel = 13672k, user = 231704k
    May 9 08:58:46 mmats swapdev = 1/41, swplo = 0, nswap = 160000, swapmem = 80000k
    May 9 08:58:46 mmats rootdev = 1/42, pipedev = 1/42, dumpdev = 1/41
    May 9 08:58:46 mmats kernel: Hz = 100, i/o bufs = 6652k
    May 9 08:58:52 mmats syslogd: re-initialise
    May 9 08:58:52 mmats syslogd: restart
    May 9 08:59:15 mmats snmpd[305]: Agent started (pid 305)
    May 9 09:00:33 mmats %Stp-0 - - - Vendor=Seagate Product=STT20000N
    May 9 09:00:33 mmats 305)
    May 9 09:03:12 mmats bootpd[507]: version 2.3.5
    May 9 09:03:12 mmats bootpd[507]: IP address not found: 10.19.0.139
    May 9 09:03:14 mmats bootpd[507]: IP address not found: 10.19.0.139
    May 9 09:04:56 mmats bootpd[507]: IP address not found: 10.19.0.100
    May 9 09:04:59 mmats bootpd[507]: IP address not found: 10.19.0.100
    May 9 09:10:06 mmats bootpd[507]: IP address not found: 10.19.0.114
    May 9 09:10:09 mmats bootpd[507]: IP address not found: 10.19.0.114
    May 9 09:13:48 mmats bootpd[507]: IP address not found: 10.19.0.150
    May 9 09:13:52 mmats bootpd[507]: IP address not found: 10.19.0.150
    May 9 09:14:51 mmats bootpd[507]: IP address not found: 10.19.0.154
    May 9 09:14:54 mmats bootpd[507]: IP address not found: 10.19.0.154
    May 9 09:17:20 mmats bootpd[507]: IP address not found: 10.19.0.131
    May 9 09:17:25 mmats bootpd[507]: IP address not found: 10.19.0.131
    May 9 09:17:29 mmats bootpd[507]: IP address not found: 10.19.0.133
    May 9 09:17:32 mmats bootpd[507]: IP address not found: 10.19.0.133
    May 9 09:18:10 mmats bootpd[507]: IP address not found: 10.19.0.156
    May 9 09:18:13 mmats bootpd[507]: IP address not found: 10.19.0.156
    May 9 09:18:25 mmats bootpd[507]: IP address not found: 10.19.0.146
    May 9 09:18:30 mmats bootpd[507]: IP address not found: 10.19.0.146
    May 9 09:21:04 mmats bootpd[507]: IP address not found: 10.19.0.136
    May 9 09:21:07 mmats bootpd[507]: IP address not found: 10.19.0.136
    May 9 09:22:33 mmats bootpd[507]: IP address not found: 10.19.0.134
    May 9 09:22:36 mmats bootpd[507]: IP address not found: 10.19.0.134
    May 9 09:23:16 mmats ftpd[536]: #2 open of pid file failed: No such file or directory
    May 9 09:24:12 mmats bootpd[507]: IP address not found: 10.19.0.137
    May 9 09:24:15 mmats bootpd[507]: IP address not found: 10.19.0.137
    May 9 09:25:22 mmats ftpd[559]: #2 open of pid file failed: No such file or directory
    May 9 09:29:40 mmats bootpd[507]: IP address not found: 10.19.0.155
    May 9 09:29:43 mmats bootpd[507]: IP address not found: 10.19.0.155
  • edited May 2008
    it sounds like the server getting worst everyday, I have to boot it every morning now, please help
    thankyou
    edited May 2008
    If you haven't replaced your NIC, you probably should. It looks like it's dying.
    -drasnor :fold:
  • Your-Amish-DaddyYour-Amish-Daddy The heart of Texas
    edited May 2008
    Yeah I was about to say the network card is not responding to calls, either the driver is gone or the card is bad.
  • edited May 2008
    thank you all for your kindly response, I have bought a new NIC, is it possible for you to show me how to replace NIC and IPconfig on SCO systems please
    BD
    edited May 2008
    I can't help you with that. I don't have SCO so I can't test it out on my hardware. You might want to look up the documentation that came with your server for the procedure.
    -drasnor :fold:
