My turn for problems?
Hi all, my folding seems to have gone haywire. It finished a WU then this. I have deleted everything in the work folder and restarted it several times, t just says there's a problem and turns off. Any suggestions please?
[12:52:03] Completed 247500 out of 250000 steps (99 percent)
[13:11:50] Writing local files
[13:11:50] Completed 250000 out of 250000 steps (100 percent)
[13:11:50] Writing final coordinates.
[13:11:51] Past main M.D. loop
[13:11:51] Will end MPI now
[13:12:51]
[13:12:51] Finished Work Unit:
[13:12:51] - Reading up to 21421872 from "work/wudata_04.arc": Read 21421872
[13:12:51] - Reading up to 593600 from "work/wudata_04.xtc": Read 593600
[13:12:51] goefile size: 0
[13:12:51] logfile size: 212525
[13:12:51] Leaving Run
[13:12:55] - Writing 22234369 bytes of core data to disk...
[13:12:55] ... Done.
[13:12:56] - Failed to delete work/wudata_04.sas
[13:12:56] - Failed to delete work/wudata_04.goe
[13:12:56] Warning: check for stray files
[13:12:56] - Shutting down core
[13:14:56]
[13:14:56] Folding@home Core Shutdown: FINISHED_UNIT
[13:14:56]
[13:14:58] CoreStatus = 64 (100)
[13:14:58] Sending work to server
[13:14:58] Project: 2665 (Run 2, Clone 32, Gen 42)
[13:14:58] + Attempting to send results [August 22 13:14:58 UTC]
[13:20:53] + Results successfully sent
[13:20:53] Thank you for your contribution to Folding@Home.
[13:20:53] + Number of Units Completed: 13
[13:20:54] Using generic mpiexec calls
[13:22:58] - Preparing to get new work unit...
[13:22:58] + Attempting to get work packet
[13:22:58] - Connecting to assignment server
[13:22:59] - Successful: assigned to (171.64.65.64).
[13:22:59] + News From Folding@Home: Welcome to Folding@Home
[13:22:59] Loaded queue successfully.
[13:24:51] + Closed connections
[13:24:51]
[13:24:51] + Processing work unit
[13:24:51] Work type a1 not eligible for variable processors
[13:24:51] Core required: FahCore_a1.exe
[13:24:51] Core found.
[13:24:51] Using generic mpiexec calls
[13:24:51] Working on queue slot 05 [August 22 13:24:51 UTC]
[13:24:51] + Working ...
[13:24:51]
[13:24:51] *
[13:24:51] Folding@Home Gromacs SMP Core
[13:24:51] Version 1.74 (March 10, 2007)
[13:24:51]
[13:24:51] Preparing to commence simulation
[13:24:51] - Looking at optimizations...
[13:24:51] - Created dyn
[13:24:51] - Files status OK
[13:24:56] - Expanded 4825542 -> 24426905 (decompressed 506.2 percent)
[13:24:56] - Starting from initial work packet
[13:24:56]
[13:24:56] Project: 2665 (Run 0, Clone 50, Gen 6)
[13:24:56]
[13:24:56] Assembly optimizations on if available.
[13:24:56] Entering M.D.
[13:25:16] .2 percent)
[13:25:16] - Starting from initial work packet
[13:25:16]
[13:25:16] Project: 2665 (Run 0, Clone 50, Gen 6)
[13:25:16]
[13:25:20] Entering M.D.
[13:25:26] Rejecting checkpoint
[13:25:28] ][0]=5.19565 v[11415][0]=NaN
[13:25:28]
[13:25:28] Folding@home Core Shutdown: BAD_CORE_FILES
[13:25:28] Finalizing output
[13:27:28] ES
[13:27:28]
[13:27:28] Folding@home Core Shutdown: BAD_CORE_FILES
[13:27:29] aN
[13:27:29]
[13:27:29] Folding@home Core Shutdown: BAD_CORE_FILES
[13:27:29] Finalizing output
[13:29:31] CoreStatus = 1 (1)
[13:29:31] Client-core communications error: ERROR 0x1
[13:29:31] This is a sign of more serious problems, shutting down.
[13:12:51]
[13:14:56]
[13:14:56]
[13:24:51]
[13:24:51]
[13:24:51] *
[13:24:51]
[13:24:56]
[13:24:56]
[13:25:16]
[13:25:16]
[13:25:28]
[13:27:28] ES
[13:27:28]
[13:27:29] aN
[13:27:29]
It was a pig to set up (but not a very big pig
http://icrontic.com/forum/showthread.php?t=73340
I ended up having to go into safe mode and deleting everything folding. Then I ran the new client, Beta 3, completed all the config info and it started. I looked at task manager and it was only using one core so I stopped it and restarted it. This is what I got.
I have deleted and reinstalled it several times, leaving config options at default (except user and team No.), changing advanced options, whatever. It runs with one core and/or refuses to run at all on restarting. I've no idea why.
Help a brother chums.
It looks like you have not set it to run -smp , If you have not given it the flag it will run in uniprocessor mode ( 1 Core )
You can set flags in advanced options of the setup or give the shortcut a flag.
Hope that helps
Scott
If you are running this on the rig in your sig you may be better off running the GPU client than the SMP CPU client. ( More PPD )
# Windows SMP Console Edition #################################################
Folding@Home Client Version 6.22 SMP Beta2r3
http://folding.stanford.edu
Launch directory: C:\Users\Public\Folding SMP
Executable: C:\Users\Public\Folding SMP\Folding@home-Win32-x86.exe
Arguments: -smp -deino -advmethods -verbosity 9
[02:33:17] - Ask before connecting: No
[02:33:17] - User name: Scott_M (Team 93)
[02:33:17] - User ID: 1778089E4D4C46CB
[02:33:17] - Machine ID: 1
[02:33:17]
Scott
I must admit I don't know anything about the GPU or deino clients. I am using the machine in my sig so which would you suggest using?
Many thanks all.
ps. Task manager shows it is still using just one CPU core, does that matter with GPU folding?
Nice.
Sorry for the late reply. Looks like _k_ got you going !!
You will probably see around 3500-4000 PPD on stock clocks. Depending on the project.
Glad you are up and running again. Fold on !
Scott
