problem!! help!
Hello, I'm having a lot of problems with my computer. I ran the adaware scan and the spybot but i couldnt do the kaspersky scan or the panda scan. The problem I'm having is that I can't get into my email. Also, I can't search anything on google or any other search engines. There's also a pop up problem. Here is my HijackThis log.. any help would be gladly appreciated.
Logfile of Trend Micro HijackThis v2.0.2
Scan saved at 8:39:28 PM, on 9/18/2008
MSIE: Internet Explorer v7.00 (7.00.6000.16705)
Boot mode: Normal
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\lsass.exe
C:\Program Files\Common Files\Microsoft Shared\VS7DEBUG\MDM.EXE
C:\Program Files\Common Files\Protexis\License Service\PsiService_2.exe
C:\WINDOWS\Explorer.EXE
C:\Program Files\HHVcdV7Sys\VC7SecS.exe
C:\WINDOWS\system32\wscntfy.exe
C:\Program Files\Spybot - Search & Destroy\TeaTimer.exe
C:\WINDOWS\system32\ctfmon.exe
C:\Program Files\Internet Explorer\IEXPLORE.EXE
C:\WINDOWS\System32\spool\DRIVERS\W32X86\3\E_FATICAA.EXE
C:\PROGRA~1\Yahoo!\browser\ycommon.exe
C:\Program Files\Mozilla Firefox\firefox.exe
C:\WINDOWS\System32\Rundll32.exe
C:\Program Files\Trend Micro\HijackThis\HijackThis.exe
O4 - HKLM\..\Run: [{5edbf857-26da-2a2d-4ca3-519e74cf546d}] C:\WINDOWS\System32\Rundll32.exe "C:\WINDOWS\system32\offeojxjdbht.dll" DllStub
O4 - HKLM\..\Run: [BM1790d87a] Rundll32.exe "C:\WINDOWS\system32\fpgmvagx.dll",s
O4 - HKLM\..\RunOnce: [Spybot - Search & Destroy] "C:\Program Files\Spybot - Search & Destroy\SpybotSD.exe" /autocheck
O4 - HKLM\..\RunOnce: [SpybotDeletingA3308] command /c del "C:\Program Files\Outerinfo\FF\install.rdf"
O4 - HKLM\..\RunOnce: [SpybotDeletingC5275] cmd /c del "C:\Program Files\Outerinfo\FF\install.rdf"
O4 - HKLM\..\RunOnce: [SpybotDeletingA5719] command /c del "C:\Program Files\Outerinfo\FF\components\OuterinfoAds.xpt"
O4 - HKLM\..\RunOnce: [SpybotDeletingC7974] cmd /c del "C:\Program Files\Outerinfo\FF\components\OuterinfoAds.xpt"
O4 - HKLM\..\RunOnce: [SpybotDeletingA6393] command /c del "C:\WINDOWS\system32\drivers\core.cache.dsk"
O4 - HKLM\..\RunOnce: [SpybotDeletingC8275] cmd /c del "C:\WINDOWS\system32\drivers\core.cache.dsk"
O4 - HKLM\..\RunOnce: [SpybotDeletingA1655] command /c del "C:\WINDOWS\system32\fpgmvagx.dll_old"
O4 - HKLM\..\RunOnce: [SpybotDeletingC9256] cmd /c del "C:\WINDOWS\system32\fpgmvagx.dll_old"
O4 - HKCU\..\Run: [SpybotSD TeaTimer] C:\Program Files\Spybot - Search & Destroy\TeaTimer.exe
O4 - HKCU\..\Run: [ctfmon.exe] C:\WINDOWS\system32\ctfmon.exe
O4 - HKCU\..\Run: [EPSON Stylus CX4400 Series] C:\WINDOWS\System32\spool\DRIVERS\W32X86\3\E_FATICAA.EXE /FU "C:\DOCUME~1\COMPAQ~1\LOCALS~1\Temp\E_S72.tmp" /EF "HKCU"
O4 - HKCU\..\RunOnce: [SpybotDeletingB6767] command /c del "C:\Program Files\Outerinfo\FF\install.rdf"
O4 - HKCU\..\RunOnce: [SpybotDeletingD9034] cmd /c del "C:\Program Files\Outerinfo\FF\install.rdf"
O4 - HKCU\..\RunOnce: [SpybotDeletingB9783] command /c del "C:\Program Files\Outerinfo\FF\components\OuterinfoAds.xpt"
O4 - HKCU\..\RunOnce: [SpybotDeletingD2128] cmd /c del "C:\Program Files\Outerinfo\FF\components\OuterinfoAds.xpt"
O4 - HKCU\..\RunOnce: [SpybotDeletingB5941] command /c del "C:\WINDOWS\system32\drivers\core.cache.dsk"
O4 - HKCU\..\RunOnce: [SpybotDeletingD6654] cmd /c del "C:\WINDOWS\system32\drivers\core.cache.dsk"
O4 - HKCU\..\RunOnce: [SpybotDeletingB2572] command /c del "C:\WINDOWS\system32\fpgmvagx.dll_old"
O4 - HKCU\..\RunOnce: [SpybotDeletingD6767] cmd /c del "C:\WINDOWS\system32\fpgmvagx.dll_old"
O9 - Extra button: (no name) - {DFB852A3-47F8-48C4-A200-58CAB36FD2A2} - C:\PROGRA~1\SPYBOT~1\SDHelper.dll
O9 - Extra 'Tools' menuitem: Spybot - Search & Destroy Configuration - {DFB852A3-47F8-48C4-A200-58CAB36FD2A2} - C:\PROGRA~1\SPYBOT~1\SDHelper.dll
O23 - Service: InstallDriver Table Manager (IDriverT) - Macrovision Corporation - C:\Program Files\Common Files\InstallShield\Driver\11\Intel 32\IDriverT.exe
O23 - Service: iPod Service - Apple Inc. - C:\Program Files\iPod\bin\iPodService.exe
O23 - Service: Protexis Licensing V2 (PSI_SVC_2) - Protexis Inc. - C:\Program Files\Common Files\Protexis\License Service\PsiService_2.exe
O23 - Service: Virtual CD v7 Management Service (VC7SecS) - H+H Software GmbH - C:\Program Files\HHVcdV7Sys\VC7SecS.exe
End of file - 4292 bytes
Boot mode: Normal
Running processes:
My name is Carolyn and I'll be glad to help you with your computer problems. HijackThis logs can take some time to research, so please be patient with me. I know that you need your computer working as quickly as possible, and I will work hard to help see that it happens.
Please do not run any other tool untill instructed to do so!
Please reply to this thread, do not start another!
Please tell me about any problems that have occurred during the fix.
Please tell me of any other symptoms you may be having as these can help also.
Please try as much as possible not to run anything while executing a fix.
If you follow these instructions, everything should go smoothly.
Your log indicates that Spybot Search & Destroy will delete some files when you reboot your computer. If you have not done so already, please reboot now.
Download and Run ComboFix (by sUBs)
A word of warning: Neither I nor sUBs are responsible for any damage you may have caused your machine by running ComboFix on your own. This tool is not a toy and not for everyday use.
ComboFix SHOULD NOT be used unless requested by a forum helper.
We will begin with ComboFix.exe. Please visit this webpage for download links, and instructions for running the tool:
http://www.bleepingcomputer.com/combofix/how-to-use-combofix
Please ensure you read this guide carefully and install the Recovery Console first.
The Windows Recovery Console will allow you to boot up into a special recovery (repair) mode. This allows us to more easily help you should your computer have a problem after an attempted removal of malware. It is a simple procedure that will only take a few moments of your time.
Once installed, you should see a blue screen prompt that says:
The Recovery Console was successfully installed.
Please continue as follows:
When the tool is finished, it will produce a report for you.
Please include the following reports for further review, and so we may continue cleansing the system:
C:\ComboFix.txt
New HijackThis log.
HJT:
Scan saved at 8:27:38 PM, on 10/1/2008
Boot mode: Normal
Running processes:
C:\Documents and Settings\All Users\Application Data\EPSON\EPW!3 SSRP\E_S40RP7.EXE
C:\WINDOWS\explorer.exe
C:\Program Files\Safari\Safari.exe
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://go.microsoft.com/fwlink/?LinkId=69157
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = http://go.microsoft.com/fwlink/?LinkId=54896
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/fwlink/?LinkId=54896
O2 - BHO: Yahoo! Toolbar Helper - {02478D38-C3F9-4EFB-9B51-7695ECA05670} - C:\Program Files\Yahoo!\Companion\Installs\cpn\yt.dll
O2 - BHO: Spybot-S&D IE Protection - {53707962-6F74-2D53-2644-206D7942484F} - C:\PROGRA~1\SPYBOT~1\SDHelper.dll
O2 - BHO: Yahoo! IE Services Button - {5BAB4B5B-68BC-4B02-94D6-2FC0DE4A7897} - C:\PROGRA~1\Yahoo!\Common\yiesrvc.dll
O2 - BHO: SSVHelper Class - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files\Java\jre1.6.0_07\bin\ssv.dll
O2 - BHO: bambanner browser enhancer - {a209a7c6-3e7c-8276-94d1-13daf7e173bd} - C:\WINDOWS\system32\offeojxjdbht.dll
O2 - BHO: SidebarAutoLaunch Class - {F2AA9440-6328-4933-B7C9-A6CCDF9CBF6D} - C:\Program Files\Yahoo!\browser\YSidebarIEBHO.dll
O4 - HKCU\..\Run: [Yaboik] "C:\Documents and Settings\Compaq_Owner\My Documents\A?pPatch\?xplorer.exe"
O4 - HKCU\..\Run: [Mpnv] C:\WINDOWS\system32\?dobe\?hkdsk.exe
O20 - AppInit_DLLs: waxkfq.dll
O23 - Service: EPSON V3 Service4(01) (EPSON_PM_RPCV4_01) - SEIKO EPSON CORPORATION - C:\Documents and Settings\All Users\Application Data\EPSON\EPW!3 SSRP\E_S40RP7.EXE
End of file - 3986 bytes
The best way to deal with really long logs is to copy and post it in sections using more than one reply. Please let me know if you need additional instruction on how to do so.
ComboFix 08-10-01.02 - Compaq_Owner 2008-10-01 17:11:25.3 - NTFSx86
Running from: C:\Documents and Settings\Compaq_Owner\Desktop\ComboFix.exe
((((((((((((((((((((((((((((((((((((((( Other Deletions )))))))))))))))))))))))))))))))))))))))))))))))))
C:\Documents and Settings\Compaq_Owner\My Documents\APPATC~1
C:\Documents and Settings\Compaq_Owner\Start Menu\Programs\Outerinfo
C:\Program Files\Common Files\fnts~1
C:\Program Files\Common Files\fnts~1\F?nts\
C:\Program Files\Common Files\stem32~1
C:\Program Files\GetPack
C:\Program Files\iCheck
C:\Program Files\outerinfo
C:\Program Files\VirusHeat 4.3
C:\Temp\1cb
C:\Temp\1cb\syscheck.log
C:\temp\tn3
C:\WINDOWS\b116.exe
C:\WINDOWS\BM1790d87a.txt
C:\WINDOWS\BM1790d87a.xml
C:\WINDOWS\faceback.exe
C:\WINDOWS\fnts~1
C:\WINDOWS\pskt.ini
C:\WINDOWS\smante~1
C:\WINDOWS\system32\375013
C:\WINDOWS\system32\arniwfys.dll
C:\WINDOWS\system32\aximqj.dll
C:\WINDOWS\system32\baqfyt.dll
C:\WINDOWS\system32\bdfonlhj.dll
C:\WINDOWS\system32\binxpe.dll
C:\WINDOWS\system32\bmjbjpur.dll
C:\WINDOWS\system32\bnfrgd.dll
C:\WINDOWS\system32\bvsvmhpc.dll
C:\WINDOWS\system32\cbXOGXRk.dll
C:\WINDOWS\system32\cgulvqte.dll
C:\WINDOWS\system32\cgveoj.dll
C:\WINDOWS\system32\cqnjgifa.dll
C:\WINDOWS\system32\dobe~1
C:\WINDOWS\system32\dobe~1\?hkdsk.exe
C:\WINDOWS\system32\drivers\rasptii.sys
C:\WINDOWS\system32\eabktwps.dll
C:\WINDOWS\system32\eccydbrm.dll
C:\WINDOWS\system32\efhtqfwm.ini
C:\WINDOWS\system32\eqcxywpv.dll
C:\WINDOWS\system32\eyymhodc.dll
C:\WINDOWS\system32\FfhkQqss.ini
C:\WINDOWS\system32\FfhkQqss.ini2
C:\WINDOWS\system32\fhgftgjc.dll
C:\WINDOWS\system32\fifpeuis.dll
C:\WINDOWS\system32\foxlagsr.dll
C:\WINDOWS\system32\gnpqrtbi.ini
C:\WINDOWS\system32\grhiiflh.dll
C:\WINDOWS\system32\hhbrlrbn.dll
C:\WINDOWS\system32\hiyuxggi.dll
C:\WINDOWS\system32\hlfiihrg.ini
C:\WINDOWS\system32\hmotvnsj.dll
C:\WINDOWS\system32\hravbfcr.dll
C:\WINDOWS\system32\hxnhawln.dll
C:\WINDOWS\system32\iggxuyih.ini
C:\WINDOWS\system32\ihscynvh.dll
C:\WINDOWS\system32\iifggdDV.dll
C:\WINDOWS\system32\ijmwfgfy.dll
C:\WINDOWS\system32\impybmwj.ini
C:\WINDOWS\system32\iqmjhmmn.ini
C:\WINDOWS\system32\iqntiscb.dll
C:\WINDOWS\system32\ixpospuj.dll
C:\WINDOWS\system32\iyvtor.dll
C:\WINDOWS\system32\jbbgjv.dll
C:\WINDOWS\system32\jbjffbun.ini
C:\WINDOWS\system32\jikbnlln.dll
C:\WINDOWS\system32\jtjticgl.dll
C:\WINDOWS\system32\kjznep.dll
C:\WINDOWS\system32\mcrh.tmp
C:\WINDOWS\system32\mlJBRHYS.dll
C:\WINDOWS\system32\mpdvghjv.dll
C:\WINDOWS\system32\MSINET.oca
C:\WINDOWS\system32\nirwaaey.ini
C:\WINDOWS\system32\nllnbkij.ini
C:\WINDOWS\system32\nubffjbj.dll
C:\WINDOWS\system32\nzhanz.dll
C:\WINDOWS\system32\ogkfwtnq.dll
C:\WINDOWS\system32\opnmLCvt.dll
C:\WINDOWS\system32\oucqmg.dll
C:\WINDOWS\system32\oWyayJjl.ini
C:\WINDOWS\system32\pac.txt
C:\WINDOWS\system32\qoMgHARH.dll
C:\WINDOWS\system32\qskiqfgr.dll
C:\WINDOWS\system32\rAJkSvut.ini
C:\WINDOWS\system32\rgkyfa.dll
C:\WINDOWS\system32\rqRKCuUM.dll
C:\WINDOWS\system32\smbols~1
C:\WINDOWS\system32\ssqQkhfF.dll
C:\WINDOWS\system32\ufikdryp.ini
C:\WINDOWS\system32\umxxthbk.dll
C:\WINDOWS\system32\urqNeDvV.dll
C:\WINDOWS\system32\vssjdutq.dll
C:\WINDOWS\system32\vtUmLbyA.dll
C:\WINDOWS\system32\VuDcdccf.ini
C:\WINDOWS\system32\VvDeNqru.ini
C:\WINDOWS\system32\waburq.dll
C:\WINDOWS\system32\waxkfq.dll
C:\WINDOWS\system32\wqphjbon.dll
C:\WINDOWS\system32\wvUnNedC.dll
C:\WINDOWS\system32\wxtsjnwa.dll
C:\WINDOWS\system32\xemhbsrt.dll
C:\WINDOWS\system32\xemwxymi.dll
C:\WINDOWS\system32\xerhhijt.ini
C:\WINDOWS\system32\xjeknqka.dll
C:\WINDOWS\system32\xmlleh.dll
C:\WINDOWS\system32\yfgfwmji.ini
C:\WINDOWS\system32\yhhnac.dll
C:\WINDOWS\system32\ylqmxcjh.dll
C:\WINDOWS\system32\zlsmp.dll
C:\Program Files\Common Files\fnts~1\nopdb.exe . . . . failed to delete
((((((((((((((((((((((((((((((((((((((( Drivers/Services )))))))))))))))))))))))))))))))))))))))))))))))))
\Legacy_CMDSERVICE
\Legacy_MCHINJDRV
\Legacy_NETWORK_MONITOR
\Legacy_RASPTII
\Legacy_SVCPROC
\Legacy_TNIDRIVER
\Legacy_VIEWPOINT_MANAGER_SERVICE
\Service_cmdService
\Service_rasptii
\Service_TnIDriver
\Service_Viewpoint Manager Service
((((((((((((((((((((((((( Files Created from 2008-09-02 to 2008-10-02 )))))))))))))))))))))))))))))))
2008-10-01 17:47 . 2008-10-01 17:47 <DIR> d
C:\WINDOWS\LastGood
2008-09-27 12:23 . 2008-09-27 12:24 <DIR> d
C:\Documents and Settings\All Users\Application Data\WinZip
2008-09-23 22:36 . 2008-09-23 22:36 <DIR> d
C:\Program Files\Panda Security
2008-09-18 01:22 . 2008-09-18 01:22 <DIR> d
C:\Program Files\TeaTimer (Spybot - Search & Destroy)
2008-09-18 00:16 . 2008-09-18 00:16 <DIR> d
C:\Program Files\OINAnalytics
2008-09-17 00:22 . 2008-09-17 00:22 <DIR> d
C:\Documents and Settings\LocalService\Application Data\Apple Computer
2008-09-17 00:11 . 2008-09-17 00:11 <DIR> d
C:\Program Files\Mjcore
2008-09-17 00:08 . 2008-09-18 18:05 <DIR> d--hs---- C:\WINDOWS\TWFyaWEgUml2ZXJh
2008-09-17 00:08 . 2008-09-17 00:08 71,711 --a
C:\WINDOWS\system32\zpdilktkhogz.exe
2008-09-17 00:07 . 2008-09-17 00:07 <DIR> d
C:\WINDOWS\system32\wp
C:\WINDOWS\system32\RES
C:\WINDOWS\system32\pin
2008-09-17 00:07 . 2008-09-18 18:03 <DIR> d
C:\WINDOWS\system32\np5
C:\WINDOWS\system32\mC02
2008-09-17 00:07 . 2008-09-17 00:08 <DIR> d
C:\temp\mtc2
2008-09-11 00:36 . 2008-09-11 00:37 <DIR> d
C:\Program Files\iTunes
C:\Documents and Settings\All Users\Application Data\{3276BE95_AF08_429F_A64F_CA64CB79BCF6}
2008-09-11 00:35 . 2008-09-11 00:35 <DIR> d
C:\Program Files\Bonjour
2008-09-11 00:34 . 2008-09-11 00:34 <DIR> d
2008-09-11 00:32 . 2008-09-05 22:16 1,900,544 --a
C:\WINDOWS\system32\usbaaplrc.dll
2008-09-11 00:32 . 2008-09-05 22:16 36,864 --a
C:\WINDOWS\system32\drivers\usbaapl.sys
2008-09-06 15:09 . 2008-09-06 15:09 90,112 --a
C:\WINDOWS\system32\QuickTimeVR.qtx
2008-09-06 15:09 . 2008-09-06 15:09 57,344 --a
C:\WINDOWS\system32\QuickTime.qts
2008-09-04 22:51 . 2008-09-04 22:53 <DIR> d
C:\Program Files\V CAST Music with Rhapsody
2008-09-03 23:20 . 2008-09-03 23:40 <DIR> d
C:\WINDOWS\system32\CatRoot_bak
2008-09-02 21:22 . 2004-07-15 10:00 16,896 --a
C:\WINDOWS\system32\apintfnt.dll
(((((((((((((((((((((((((((((((((((((((( Find3M Report ))))))))))))))))))))))))))))))))))))))))))))))))))))
2008-09-28 19:49
d
w C:\Program Files\Safari
2008-09-26 20:48
d
w C:\Documents and Settings\Compaq_Owner\Application Data\LimeWire
2008-09-23 04:38
d
w C:\Program Files\LimeWire
2008-09-21 00:16
d
w C:\Program Files\Spybot - Search & Destroy
2008-09-19 03:32
d
w C:\Documents and Settings\All Users\Application Data\Spybot - Search & Destroy
2008-09-18 15:51 28,106 ----a-w C:\Documents and Settings\Compaq_Owner\Application Data\wklnhst.dat
2008-09-18 06:41
d
w C:\Program Files\Java
2008-09-11 07:37
d
w C:\Program Files\iPod
2008-09-11 07:34
d
w C:\Program Files\Common Files\Apple
2008-09-05 05:52
d
w C:\Program Files\Real
2008-09-03 04:22
d
w C:\Program Files\Verizon Wireless
2008-08-23 07:15
d
w C:\Program Files\Microsoft Silverlight
2008-08-22 03:15
d---a-w C:\Documents and Settings\All Users\Application Data\TEMP
2008-08-06 16:35
d
w C:\Program Files\Apple Software Update
2008-07-14 19:29 88 --sha-r C:\Documents and Settings\All Users\Application Data\53D7D18ABC.sys
2008-07-14 19:29 2,516 --sha-w C:\Documents and Settings\All Users\Application Data\KGyGaAvL.sys
2008-07-11 02:44 606,848 ----a-w C:\WINDOWS\flashax.exe
2008-07-11 02:44 12,288 ----a-w C:\WINDOWS\impborl.dll
2008-04-29 05:05 69,832 ----a-w C:\Documents and Settings\Compaq_Owner\Application Data\GDIPFONTCACHEV1.DAT
2006-08-17 03:20 184,808 -c--a-w C:\Documents and Settings\Guest\Application Data\shb.dat
2006-06-23 17:39 1,820 -c--a-w C:\Documents and Settings\Guest\Application Data\wklnhst.dat
2005-07-29 23:24 472 --sha-r C:\WINDOWS\TWFyaWEgUml2ZXJh\nqIVuqH0oA5ZtrL1.vbs
((((((((((((((((((((((((((((( snapshot@2007-12-17_22.48.08.40 )))))))))))))))))))))))))))))))))))))))))
+ 2008-02-26 11:48:44 297,984 ----a-w C:\WINDOWS\$hf_mig$\KB932823-v3\SP2QFE\msctf.dll
+ 2007-03-06 01:22:36 14,048 ----a-w C:\WINDOWS\$hf_mig$\KB932823-v3\spmsg.dll
+ 2007-03-06 01:22:41 213,216 ----a-w C:\WINDOWS\$hf_mig$\KB932823-v3\spuninst.exe
+ 2007-03-06 01:22:34 22,752 ----a-w C:\WINDOWS\$hf_mig$\KB932823-v3\update\spcustom.dll
+ 2007-03-06 01:22:59 716,000 ----a-w C:\WINDOWS\$hf_mig$\KB932823-v3\update\update.exe
+ 2007-03-06 01:23:51 371,424 ----a-w C:\WINDOWS\$hf_mig$\KB932823-v3\update\updspapi.dll
+ 2007-10-30 16:53:32 360,832 ----a-w C:\WINDOWS\$hf_mig$\KB941644\SP2QFE\tcpip.sys
+ 2007-03-06 01:22:36 14,048 ----a-w C:\WINDOWS\$hf_mig$\KB941644\spmsg.dll
+ 2007-03-06 01:22:41 213,216 ----a-w C:\WINDOWS\$hf_mig$\KB941644\spuninst.exe
+ 2007-03-06 01:22:34 22,752 ----a-w C:\WINDOWS\$hf_mig$\KB941644\update\spcustom.dll
+ 2007-03-06 01:22:59 716,000 ----a-w C:\WINDOWS\$hf_mig$\KB941644\update\update.exe
+ 2007-03-06 01:23:51 371,424 ----a-w C:\WINDOWS\$hf_mig$\KB941644\update\updspapi.dll
+ 2008-03-19 09:40:27 1,845,888 ----a-w C:\WINDOWS\$hf_mig$\KB941693\SP2QFE\win32k.sys
+ 2007-03-06 01:22:36 14,048 ----a-w C:\WINDOWS\$hf_mig$\KB941693\spmsg.dll
+ 2007-03-06 01:22:41 213,216 ----a-w C:\WINDOWS\$hf_mig$\KB941693\spuninst.exe
+ 2007-03-06 01:22:34 22,752 ----a-w C:\WINDOWS\$hf_mig$\KB941693\update\spcustom.dll
+ 2007-03-06 01:22:59 716,000 ----a-w C:\WINDOWS\$hf_mig$\KB941693\update\update.exe
+ 2007-03-06 01:23:51 371,424 ----a-w C:\WINDOWS\$hf_mig$\KB941693\update\updspapi.dll
+ 2007-12-04 18:29:10 551,936 ----a-w C:\WINDOWS\$hf_mig$\KB943055\SP2QFE\oleaut32.dll
+ 2007-03-06 01:22:36 14,048 ----a-w C:\WINDOWS\$hf_mig$\KB943055\spmsg.dll
+ 2007-03-06 01:22:41 213,216 ----a-w C:\WINDOWS\$hf_mig$\KB943055\spuninst.exe
+ 2007-03-06 01:22:34 22,752 ----a-w C:\WINDOWS\$hf_mig$\KB943055\update\spcustom.dll
+ 2007-03-06 01:22:59 716,000 ----a-w C:\WINDOWS\$hf_mig$\KB943055\update\update.exe
+ 2007-03-06 01:23:51 371,424 ----a-w C:\WINDOWS\$hf_mig$\KB943055\update\updspapi.dll
+ 2007-11-07 09:50:47 727,040 ----a-w C:\WINDOWS\$hf_mig$\KB943485\SP2QFE\lsasrv.dll
+ 2007-03-06 01:22:36 14,048 ----a-w C:\WINDOWS\$hf_mig$\KB943485\spmsg.dll
+ 2007-03-06 01:22:41 213,216 ----a-w C:\WINDOWS\$hf_mig$\KB943485\spuninst.exe
+ 2007-03-06 01:22:34 22,752 ----a-w C:\WINDOWS\$hf_mig$\KB943485\update\spcustom.dll
+ 2007-03-06 01:22:59 716,000 ----a-w C:\WINDOWS\$hf_mig$\KB943485\update\update.exe
+ 2007-03-06 01:23:51 371,424 ----a-w C:\WINDOWS\$hf_mig$\KB943485\update\updspapi.dll
+ 2007-12-07 02:01:07 124,928 ----a-w C:\WINDOWS\$hf_mig$\KB944533-IE7\SP2QFE\advpack.dll
+ 2007-12-19 22:57:52 347,136 ----a-w C:\WINDOWS\$hf_mig$\KB944533-IE7\SP2QFE\dxtmsft.dll
+ 2007-12-07 02:01:07 214,528 ----a-w C:\WINDOWS\$hf_mig$\KB944533-IE7\SP2QFE\dxtrans.dll
+ 2007-12-07 02:01:07 133,120 ----a-w C:\WINDOWS\$hf_mig$\KB944533-IE7\SP2QFE\extmgr.dll
+ 2007-12-07 02:01:07 63,488 ----a-w C:\WINDOWS\$hf_mig$\KB944533-IE7\SP2QFE\icardie.dll
+ 2007-12-06 08:34:28 70,656 ----a-w C:\WINDOWS\$hf_mig$\KB944533-IE7\SP2QFE\ie4uinit.exe
+ 2007-12-07 02:01:08 153,088 ----a-w C:\WINDOWS\$hf_mig$\KB944533-IE7\SP2QFE\ieakeng.dll
+ 2007-12-07 02:01:08 230,400 ----a-w C:\WINDOWS\$hf_mig$\KB944533-IE7\SP2QFE\ieaksie.dll
+ 2007-12-06 05:00:02 161,792 ----a-w C:\WINDOWS\$hf_mig$\KB944533-IE7\SP2QFE\ieakui.dll
+ 2007-04-17 09:32:38 2,455,488 ----a-w C:\WINDOWS\$hf_mig$\KB944533-IE7\SP2QFE\ieapfltr.dat
+ 2007-12-07 02:01:08 383,488 ----a-w C:\WINDOWS\$hf_mig$\KB944533-IE7\SP2QFE\ieapfltr.dll
+ 2007-12-07 02:01:08 388,096 ----a-w C:\WINDOWS\$hf_mig$\KB944533-IE7\SP2QFE\iedkcs32.dll
+ 2007-12-07 02:01:10 6,067,200 ----a-w C:\WINDOWS\$hf_mig$\KB944533-IE7\SP2QFE\ieframe.dll
+ 2007-12-07 02:01:10 44,544 ----a-w C:\WINDOWS\$hf_mig$\KB944533-IE7\SP2QFE\iernonce.dll
+ 2007-12-07 02:01:11 267,776 ----a-w C:\WINDOWS\$hf_mig$\KB944533-IE7\SP2QFE\iertutil.dll
+ 2007-12-06 08:34:29 13,824 ----a-w C:\WINDOWS\$hf_mig$\KB944533-IE7\SP2QFE\ieudinit.exe
+ 2007-12-06 08:34:45 625,664 ----a-w C:\WINDOWS\$hf_mig$\KB944533-IE7\SP2QFE\iexplore.exe
+ 2007-12-07 02:01:11 27,648 ----a-w C:\WINDOWS\$hf_mig$\KB944533-IE7\SP2QFE\jsproxy.dll
+ 2007-12-07 02:01:11 459,264 ----a-w C:\WINDOWS\$hf_mig$\KB944533-IE7\SP2QFE\msfeeds.dll
+ 2007-12-07 02:01:11 52,224 ----a-w C:\WINDOWS\$hf_mig$\KB944533-IE7\SP2QFE\msfeedsbs.dll
+ 2007-12-07 02:01:12 3,593,216 ----a-w C:\WINDOWS\$hf_mig$\KB944533-IE7\SP2QFE\mshtml.dll
+ 2007-12-07 02:01:12 478,208 ----a-w C:\WINDOWS\$hf_mig$\KB944533-IE7\SP2QFE\mshtmled.dll
+ 2007-12-07 02:01:13 193,024 ----a-w C:\WINDOWS\$hf_mig$\KB944533-IE7\SP2QFE\msrating.dll
+ 2007-12-07 02:01:13 671,232 ----a-w C:\WINDOWS\$hf_mig$\KB944533-IE7\SP2QFE\mstime.dll
+ 2007-12-07 02:01:13 102,912 ----a-w C:\WINDOWS\$hf_mig$\KB944533-IE7\SP2QFE\occache.dll
+ 2008-01-11 05:57:26 44,544 ----a-w C:\WINDOWS\$hf_mig$\KB944533-IE7\SP2QFE\pngfilt.dll
+ 2007-12-07 02:01:13 105,984 ----a-w C:\WINDOWS\$hf_mig$\KB944533-IE7\SP2QFE\url.dll
+ 2007-12-07 02:01:13 1,162,752 ----a-w C:\WINDOWS\$hf_mig$\KB944533-IE7\SP2QFE\urlmon.dll
+ 2007-12-07 02:01:13 233,472 ----a-w C:\WINDOWS\$hf_mig$\KB944533-IE7\SP2QFE\webcheck.dll
+ 2007-12-07 02:01:13 825,344 ----a-w C:\WINDOWS\$hf_mig$\KB944533-IE7\SP2QFE\wininet.dll
+ 2007-03-06 01:22:36 14,048 ----a-w C:\WINDOWS\$hf_mig$\KB944533-IE7\spmsg.dll
+ 2007-03-06 01:22:41 213,216 ----a-w C:\WINDOWS\$hf_mig$\KB944533-IE7\spuninst.exe
+ 2007-03-06 01:22:34 22,752 ----a-w C:\WINDOWS\$hf_mig$\KB944533-IE7\update\spcustom.dll
+ 2007-03-06 01:22:59 716,000 ----a-w C:\WINDOWS\$hf_mig$\KB944533-IE7\update\update.exe
+ 2007-03-06 01:23:51 371,424 ----a-w C:\WINDOWS\$hf_mig$\KB944533-IE7\update\updspapi.dll
+ 2008-02-20 05:19:35 147,968 ----a-w C:\WINDOWS\$hf_mig$\KB945553\SP2QFE\dnsapi.dll
+ 2008-02-20 18:49:36 45,568 ----a-w C:\WINDOWS\$hf_mig$\KB945553\SP2QFE\dnsrslvr.dll
+ 2007-03-06 01:22:36 14,048 ----a-w C:\WINDOWS\$hf_mig$\KB945553\spmsg.dll
+ 2007-03-06 01:22:41 213,216 ----a-w C:\WINDOWS\$hf_mig$\KB945553\spuninst.exe
+ 2007-03-06 01:22:34 22,752 ----a-w C:\WINDOWS\$hf_mig$\KB945553\update\spcustom.dll
+ 2007-03-06 01:22:59 716,000 ----a-w C:\WINDOWS\$hf_mig$\KB945553\update\update.exe
+ 2007-03-06 01:23:51 371,424 ----a-w C:\WINDOWS\$hf_mig$\KB945553\update\updspapi.dll
+ 2007-12-18 09:38:59 179,712 ----a-w C:\WINDOWS\$hf_mig$\KB946026\SP2QFE\mrxdav.sys
+ 2007-03-06 01:22:36 14,048 ----a-w C:\WINDOWS\$hf_mig$\KB946026\spmsg.dll
+ 2007-03-06 01:22:41 213,216 ----a-w C:\WINDOWS\$hf_mig$\KB946026\spuninst.exe
+ 2007-03-06 01:22:34 22,752 ----a-w C:\WINDOWS\$hf_mig$\KB946026\update\spcustom.dll
+ 2007-03-06 01:22:59 716,000 ----a-w C:\WINDOWS\$hf_mig$\KB946026\update\update.exe
+ 2007-03-06 01:23:51 371,424 ----a-w C:\WINDOWS\$hf_mig$\KB946026\update\updspapi.dll
+ 2008-05-02 13:30:08 83,968 ----a-w C:\WINDOWS\$hf_mig$\KB946648\SP2QFE\msgsc.dll
+ 2008-05-02 14:01:49 83,968 ----a-w C:\WINDOWS\$hf_mig$\KB946648\SP3GDR\msgsc.dll
+ 2008-05-02 13:42:10 83,968 ----a-w C:\WINDOWS\$hf_mig$\KB946648\SP3QFE\msgsc.dll
+ 2007-11-30 12:39:22 17,272 ----a-w C:\WINDOWS\$hf_mig$\KB946648\spmsg.dll
+ 2007-11-30 12:39:22 231,288 ----a-w C:\WINDOWS\$hf_mig$\KB946648\spuninst.exe
+ 2007-11-30 12:39:22 26,488 ----a-w C:\WINDOWS\$hf_mig$\KB946648\update\spcustom.dll
+ 2007-11-30 11:20:44 755,576 ----a-w C:\WINDOWS\$hf_mig$\KB946648\update\update.exe
+ 2007-11-30 12:39:22 382,840 ----a-w C:\WINDOWS\$hf_mig$\KB946648\update\updspapi.dll
+ 2008-03-01 13:03:00 124,928 ----a-w C:\WINDOWS\$hf_mig$\KB947864-IE7\SP2QFE\advpack.dll
+ 2008-03-01 13:03:00 347,136 ----a-w C:\WINDOWS\$hf_mig$\KB947864-IE7\SP2QFE\dxtmsft.dll
+ 2008-03-01 13:03:00 214,528 ----a-w C:\WINDOWS\$hf_mig$\KB947864-IE7\SP2QFE\dxtrans.dll
+ 2008-03-01 13:03:00 132,608 ----a-w C:\WINDOWS\$hf_mig$\KB947864-IE7\SP2QFE\extmgr.dll
+ 2008-03-01 13:03:00 63,488 ----a-w C:\WINDOWS\$hf_mig$\KB947864-IE7\SP2QFE\icardie.dll
+ 2008-02-22 09:39:56 70,656 ----a-w C:\WINDOWS\$hf_mig$\KB947864-IE7\SP2QFE\ie4uinit.exe
+ 2008-03-01 13:03:00 153,088 ----a-w C:\WINDOWS\$hf_mig$\KB947864-IE7\SP2QFE\ieakeng.dll
+ 2008-03-01 13:03:00 230,400 ----a-w C:\WINDOWS\$hf_mig$\KB947864-IE7\SP2QFE\ieaksie.dll
+ 2008-02-15 05:44:25 161,792 ----a-w C:\WINDOWS\$hf_mig$\KB947864-IE7\SP2QFE\ieakui.dll
+ 2007-04-17 09:32:38 2,455,488 ----a-w C:\WINDOWS\$hf_mig$\KB947864-IE7\SP2QFE\ieapfltr.dat
+ 2008-03-01 13:03:00 383,488 ----a-w C:\WINDOWS\$hf_mig$\KB947864-IE7\SP2QFE\ieapfltr.dll
+ 2008-03-01 13:03:00 388,608 ----a-w C:\WINDOWS\$hf_mig$\KB947864-IE7\SP2QFE\iedkcs32.dll
+ 2008-03-01 13:03:01 6,067,712 ----a-w C:\WINDOWS\$hf_mig$\KB947864-IE7\SP2QFE\ieframe.dll
+ 2008-03-01 13:03:01 44,544 ----a-w C:\WINDOWS\$hf_mig$\KB947864-IE7\SP2QFE\iernonce.dll
+ 2008-03-01 13:03:01 267,776 ----a-w C:\WINDOWS\$hf_mig$\KB947864-IE7\SP2QFE\iertutil.dll
+ 2008-02-22 09:39:56 13,824 ----a-w C:\WINDOWS\$hf_mig$\KB947864-IE7\SP2QFE\ieudinit.exe
+ 2008-02-22 09:40:22 625,664 ----a-w C:\WINDOWS\$hf_mig$\KB947864-IE7\SP2QFE\iexplore.exe
+ 2008-03-01 13:03:01 27,648 ----a-w C:\WINDOWS\$hf_mig$\KB947864-IE7\SP2QFE\jsproxy.dll
+ 2008-03-01 13:03:01 459,264 ----a-w C:\WINDOWS\$hf_mig$\KB947864-IE7\SP2QFE\msfeeds.dll
+ 2008-03-01 13:03:01 52,224 ----a-w C:\WINDOWS\$hf_mig$\KB947864-IE7\SP2QFE\msfeedsbs.dll
+ 2008-03-01 13:03:01 3,593,216 ----a-w C:\WINDOWS\$hf_mig$\KB947864-IE7\SP2QFE\mshtml.dll
+ 2008-03-01 13:03:01 478,208 ----a-w C:\WINDOWS\$hf_mig$\KB947864-IE7\SP2QFE\mshtmled.dll
+ 2008-03-01 13:03:01 193,024 ----a-w C:\WINDOWS\$hf_mig$\KB947864-IE7\SP2QFE\msrating.dll
+ 2008-03-01 13:03:01 671,232 ----a-w C:\WINDOWS\$hf_mig$\KB947864-IE7\SP2QFE\mstime.dll
+ 2008-03-01 13:03:01 102,912 ----a-w C:\WINDOWS\$hf_mig$\KB947864-IE7\SP2QFE\occache.dll
+ 2008-03-01 13:03:01 44,544 ----a-w C:\WINDOWS\$hf_mig$\KB947864-IE7\SP2QFE\pngfilt.dll
+ 2008-03-01 13:03:02 105,984 ----a-w C:\WINDOWS\$hf_mig$\KB947864-IE7\SP2QFE\url.dll
+ 2008-03-01 13:03:02 1,162,752 ----a-w C:\WINDOWS\$hf_mig$\KB947864-IE7\SP2QFE\urlmon.dll
+ 2008-03-01 13:03:02 233,472 ----a-w C:\WINDOWS\$hf_mig$\KB947864-IE7\SP2QFE\webcheck.dll
+ 2008-03-01 13:03:02 827,392 ----a-w C:\WINDOWS\$hf_mig$\KB947864-IE7\SP2QFE\wininet.dll
+ 2007-03-06 01:22:33 14,048 ----a-w C:\WINDOWS\$hf_mig$\KB947864-IE7\spmsg.dll
+ 2007-03-06 01:22:39 213,216 ----a-w C:\WINDOWS\$hf_mig$\KB947864-IE7\spuninst.exe
+ 2007-03-06 01:22:31 22,752 ----a-w C:\WINDOWS\$hf_mig$\KB947864-IE7\update\spcustom.dll
+ 2007-03-06 01:22:56 716,000 ----a-w C:\WINDOWS\$hf_mig$\KB947864-IE7\update\update.exe
+ 2007-03-06 01:23:51 371,424 ----a-w C:\WINDOWS\$hf_mig$\KB947864-IE7\update\updspapi.dll
+ 2008-02-20 06:52:43 282,624 ----a-w C:\WINDOWS\$hf_mig$\KB948590\SP2QFE\gdi32.dll
+ 2007-03-06 01:22:36 14,048 ----a-w C:\WINDOWS\$hf_mig$\KB948590\spmsg.dll
+ 2007-03-06 01:22:41 213,216 ----a-w C:\WINDOWS\$hf_mig$\KB948590\spuninst.exe
+ 2007-03-06 01:22:34 22,752 ----a-w C:\WINDOWS\$hf_mig$\KB948590\update\spcustom.dll
+ 2007-03-06 01:22:59 716,000 ----a-w C:\WINDOWS\$hf_mig$\KB948590\update\update.exe
+ 2007-03-06 01:23:51 371,424 ----a-w C:\WINDOWS\$hf_mig$\KB948590\update\updspapi.dll
+ 2007-03-06 01:22:33 14,048 ----a-w C:\WINDOWS\$hf_mig$\KB948881\spmsg.dll
+ 2007-03-06 01:22:39 213,216 ----a-w C:\WINDOWS\$hf_mig$\KB948881\spuninst.exe
+ 2007-03-06 01:22:31 22,752 ----a-w C:\WINDOWS\$hf_mig$\KB948881\update\spcustom.dll
+ 2007-03-06 01:22:56 716,000 ----a-w C:\WINDOWS\$hf_mig$\KB948881\update\update.exe
+ 2007-03-06 01:23:47 371,424 ----a-w C:\WINDOWS\$hf_mig$\KB948881\update\updspapi.dll
+ 2008-01-23 04:56:21 554,008 ----a-w C:\WINDOWS\$hf_mig$\KB950749\SP2QFE\dao360.dll
+ 2007-12-10 12:41:11 518,944 ----a-w C:\WINDOWS\$hf_mig$\KB950749\SP2QFE\msexch40.dll
+ 2007-12-10 12:41:11 326,432 ----a-w C:\WINDOWS\$hf_mig$\KB950749\SP2QFE\msexcl40.dll
+ 2007-12-10 12:41:11 1,516,568 ----a-w C:\WINDOWS\$hf_mig$\KB950749\SP2QFE\msjet40.dll
+ 2007-12-10 12:41:11 355,112 ----a-w C:\WINDOWS\$hf_mig$\KB950749\SP2QFE\msjetol1.dll
+ 2008-03-27 07:39:13 151,583 ----a-w C:\WINDOWS\$hf_mig$\KB950749\SP2QFE\msjint40.dll
+ 2007-12-10 12:41:12 60,192 ----a-w C:\WINDOWS\$hf_mig$\KB950749\SP2QFE\msjter40.dll
+ 2007-12-10 12:41:12 248,608 ----a-w C:\WINDOWS\$hf_mig$\KB950749\SP2QFE\msjtes40.dll
+ 2007-12-10 12:41:12 219,936 ----a-w C:\WINDOWS\$hf_mig$\KB950749\SP2QFE\msltus40.dll
+ 2007-12-10 12:41:12 355,104 ----a-w C:\WINDOWS\$hf_mig$\KB950749\SP2QFE\mspbde40.dll
+ 2007-12-10 12:41:13 432,928 ----a-w C:\WINDOWS\$hf_mig$\KB950749\SP2QFE\msrd2x40.dll
+ 2007-12-10 12:41:13 322,336 ----a-w C:\WINDOWS\$hf_mig$\KB950749\SP2QFE\msrd3x40.dll
+ 2007-12-10 12:41:13 559,904 ----a-w C:\WINDOWS\$hf_mig$\KB950749\SP2QFE\msrepl40.dll
+ 2007-12-10 12:41:13 264,992 ----a-w C:\WINDOWS\$hf_mig$\KB950749\SP2QFE\mstext40.dll
+ 2007-12-10 12:41:13 838,432 ----a-w C:\WINDOWS\$hf_mig$\KB950749\SP2QFE\mswdat10.dll
+ 2007-12-10 12:41:14 621,344 ----a-w C:\WINDOWS\$hf_mig$\KB950749\SP2QFE\mswstr10.dll
+ 2007-12-10 12:41:14 355,104 ----a-w C:\WINDOWS\$hf_mig$\KB950749\SP2QFE\msxbde40.dll
+ 2007-03-06 01:22:36 14,048 ----a-w C:\WINDOWS\$hf_mig$\KB950749\spmsg.dll
+ 2007-03-06 01:22:41 213,216 ----a-w C:\WINDOWS\$hf_mig$\KB950749\spuninst.exe
+ 2007-03-06 01:22:34 22,752 ----a-w C:\WINDOWS\$hf_mig$\KB950749\update\spcustom.dll
+ 2007-03-06 01:22:59 716,000 ----a-w C:\WINDOWS\$hf_mig$\KB950749\update\update.exe
+ 2007-03-06 01:23:51 371,424 ----a-w C:\WINDOWS\$hf_mig$\KB950749\update\updspapi.dll
+ 2008-04-23 03:35:35 124,928 ----a-w C:\WINDOWS\$hf_mig$\KB950759-IE7\SP2QFE\advpack.dll
+ 2008-04-23 03:35:35 347,136 ----a-w C:\WINDOWS\$hf_mig$\KB950759-IE7\SP2QFE\dxtmsft.dll
+ 2008-04-23 03:35:35 214,528 ----a-w C:\WINDOWS\$hf_mig$\KB950759-IE7\SP2QFE\dxtrans.dll
+ 2008-04-23 03:35:35 132,608 ----a-w C:\WINDOWS\$hf_mig$\KB950759-IE7\SP2QFE\extmgr.dll
+ 2008-04-23 03:35:35 63,488 ----a-w C:\WINDOWS\$hf_mig$\KB950759-IE7\SP2QFE\icardie.dll
+ 2008-04-22 08:02:19 70,656 ----a-w C:\WINDOWS\$hf_mig$\KB950759-IE7\SP2QFE\ie4uinit.exe
+ 2008-04-23 03:35:35 153,088 ----a-w C:\WINDOWS\$hf_mig$\KB950759-IE7\SP2QFE\ieakeng.dll
+ 2008-04-23 03:35:35 230,400 ----a-w C:\WINDOWS\$hf_mig$\KB950759-IE7\SP2QFE\ieaksie.dll
+ 2008-04-20 05:07:38 161,792 ----a-w C:\WINDOWS\$hf_mig$\KB950759-IE7\SP2QFE\ieakui.dll
+ 2007-04-17 09:32:38 2,455,488 ----a-w C:\WINDOWS\$hf_mig$\KB950759-IE7\SP2QFE\ieapfltr.dat
+ 2008-04-23 03:35:35 383,488 ----a-w C:\WINDOWS\$hf_mig$\KB950759-IE7\SP2QFE\ieapfltr.dll
+ 2008-04-23 03:35:35 388,608 ----a-w C:\WINDOWS\$hf_mig$\KB950759-IE7\SP2QFE\iedkcs32.dll
+ 2008-04-23 03:35:36 6,068,224 ----a-w C:\WINDOWS\$hf_mig$\KB950759-IE7\SP2QFE\ieframe.dll
+ 2008-04-23 03:35:36 44,544 ----a-w C:\WINDOWS\$hf_mig$\KB950759-IE7\SP2QFE\iernonce.dll
+ 2008-04-23 03:35:36 267,776 ----a-w C:\WINDOWS\$hf_mig$\KB950759-IE7\SP2QFE\iertutil.dll
+ 2008-04-22 08:02:19 13,824 ----a-w C:\WINDOWS\$hf_mig$\KB950759-IE7\SP2QFE\ieudinit.exe
+ 2008-04-22 08:02:46 625,664 ----a-w C:\WINDOWS\$hf_mig$\KB950759-IE7\SP2QFE\iexplore.exe
+ 2008-04-23 03:35:36 27,648 ----a-w C:\WINDOWS\$hf_mig$\KB950759-IE7\SP2QFE\jsproxy.dll
+ 2008-04-23 03:35:36 459,264 ----a-w C:\WINDOWS\$hf_mig$\KB950759-IE7\SP2QFE\msfeeds.dll
+ 2008-04-23 03:35:36 52,224 ----a-w C:\WINDOWS\$hf_mig$\KB950759-IE7\SP2QFE\msfeedsbs.dll
+ 2008-04-23 03:35:36 3,593,728 ----a-w C:\WINDOWS\$hf_mig$\KB950759-IE7\SP2QFE\mshtml.dll
+ 2008-04-23 03:35:36 478,208 ----a-w C:\WINDOWS\$hf_mig$\KB950759-IE7\SP2QFE\mshtmled.dll
+ 2008-04-23 03:35:36 193,024 ----a-w C:\WINDOWS\$hf_mig$\KB950759-IE7\SP2QFE\msrating.dll
+ 2008-04-23 03:35:36 671,232 ----a-w C:\WINDOWS\$hf_mig$\KB950759-IE7\SP2QFE\mstime.dll
+ 2008-04-23 03:35:36 102,912 ----a-w C:\WINDOWS\$hf_mig$\KB950759-IE7\SP2QFE\occache.dll
+ 2008-04-23 03:35:36 44,544 ----a-w C:\WINDOWS\$hf_mig$\KB950759-IE7\SP2QFE\pngfilt.dll
+ 2008-04-23 03:35:36 105,984 ----a-w C:\WINDOWS\$hf_mig$\KB950759-IE7\SP2QFE\url.dll
+ 2008-04-23 03:35:36 1,162,752 ----a-w C:\WINDOWS\$hf_mig$\KB950759-IE7\SP2QFE\urlmon.dll
+ 2008-04-23 03:35:36 233,472 ----a-w C:\WINDOWS\$hf_mig$\KB950759-IE7\SP2QFE\webcheck.dll
+ 2008-04-23 03:35:36 827,392 ----a-w C:\WINDOWS\$hf_mig$\KB950759-IE7\SP2QFE\wininet.dll
+ 2007-03-06 01:22:33 14,048 ----a-w C:\WINDOWS\$hf_mig$\KB950759-IE7\spmsg.dll
+ 2007-03-06 01:22:39 213,216 ----a-w C:\WINDOWS\$hf_mig$\KB950759-IE7\spuninst.exe
+ 2007-03-06 01:22:31 22,752 ----a-w C:\WINDOWS\$hf_mig$\KB950759-IE7\update\spcustom.dll
+ 2007-03-06 01:22:56 716,000 ----a-w C:\WINDOWS\$hf_mig$\KB950759-IE7\update\update.exe
+ 2007-03-06 01:23:51 371,424 ----a-w C:\WINDOWS\$hf_mig$\KB950759-IE7\update\updspapi.dll
+ 2007-11-30 12:39:22 17,272 ----a-w C:\WINDOWS\$hf_mig$\KB950760\spmsg.dll
+ 2007-11-30 12:39:22 231,288 ----a-w C:\WINDOWS\$hf_mig$\KB950760\spuninst.exe
+ 2007-11-30 12:39:22 26,488 ----a-w C:\WINDOWS\$hf_mig$\KB950760\update\spcustom.dll
+ 2007-11-30 12:39:22 755,576 ----a-w C:\WINDOWS\$hf_mig$\KB950760\update\update.exe
+ 2007-11-30 12:39:22 382,840 ----a-w C:\WINDOWS\$hf_mig$\KB950760\update\updspapi.dll
+ 2008-05-08 12:14:51 203,008 ----a-w C:\WINDOWS\$hf_mig$\KB950762\SP2QFE\rmcast.sys
+ 2008-05-08 14:02:52 203,136 ----a-w C:\WINDOWS\$hf_mig$\KB950762\SP3GDR\rmcast.sys
+ 2008-05-08 13:58:17 203,136 ----a-w C:\WINDOWS\$hf_mig$\KB950762\SP3QFE\rmcast.sys
+ 2007-11-30 12:39:22 17,272 ----a-w C:\WINDOWS\$hf_mig$\KB950762\spmsg.dll
+ 2007-11-30 12:39:22 231,288 ----a-w C:\WINDOWS\$hf_mig$\KB950762\spuninst.exe
+ 2007-11-30 12:39:22 26,488 ----a-w C:\WINDOWS\$hf_mig$\KB950762\update\spcustom.dll
+ 2007-11-30 12:39:22 755,576 ----a-w C:\WINDOWS\$hf_mig$\KB950762\update\update.exe
+ 2007-11-30 12:39:22 382,840 ----a-w C:\WINDOWS\$hf_mig$\KB950762\update\updspapi.dll
+ 2008-07-07 20:06:43 253,952 ----a-w C:\WINDOWS\$hf_mig$\KB950974\SP2QFE\es.dll
+ 2008-07-07 20:26:58 253,952 ----a-w C:\WINDOWS\$hf_mig$\KB950974\SP3GDR\es.dll
+ 2008-07-07 20:23:18 253,952 ----a-w C:\WINDOWS\$hf_mig$\KB950974\SP3QFE\es.dll
+ 2007-11-30 12:39:22 17,272 ----a-w C:\WINDOWS\$hf_mig$\KB950974\spmsg.dll
+ 2007-11-30 12:39:22 231,288 ----a-w C:\WINDOWS\$hf_mig$\KB950974\spuninst.exe
+ 2007-11-30 12:39:22 26,488 ----a-w C:\WINDOWS\$hf_mig$\KB950974\update\spcustom.dll
+ 2007-11-30 12:39:18 755,576 ----a-w C:\WINDOWS\$hf_mig$\KB950974\update\update.exe
+ 2007-11-30 12:39:19 382,840 ----a-w C:\WINDOWS\$hf_mig$\KB950974\update\updspapi.dll
+ 2008-04-11 18:39:39 683,520 ----a-w C:\WINDOWS\$hf_mig$\KB951066\SP2QFE\inetcomm.dll
+ 2008-04-11 19:04:26 691,712 ----a-w C:\WINDOWS\$hf_mig$\KB951066\SP3GDR\inetcomm.dll
+ 2008-04-12 07:22:26 691,712 ----a-w C:\WINDOWS\$hf_mig$\KB951066\SP3QFE\inetcomm.dll
+ 2007-11-30 12:39:22 17,272 ----a-w C:\WINDOWS\$hf_mig$\KB951066\spmsg.dll
+ 2007-11-30 12:39:22 231,288 ----a-w C:\WINDOWS\$hf_mig$\KB951066\spuninst.exe
+ 2007-11-30 12:39:22 26,488 ----a-w C:\WINDOWS\$hf_mig$\KB951066\update\spcustom.dll
+ 2007-12-03 15:25:31 755,576 ----a-w C:\WINDOWS\$hf_mig$\KB951066\update\update.exe
+ 2007-11-30 12:39:22 382,840 ----a-w C:\WINDOWS\$hf_mig$\KB951066\update\updspapi.dll
+ 2008-07-14 11:03:00 62,976 ----a-w C:\WINDOWS\$hf_mig$\KB951072-v2\SP2QFE\tzchange.exe
+ 2008-07-11 12:42:28 62,976 ----a-w C:\WINDOWS\$hf_mig$\KB951072-v2\SP3GDR\tzchange.exe
+ 2008-07-11 12:51:51 62,976 ----a-w C:\WINDOWS\$hf_mig$\KB951072-v2\SP3QFE\tzchange.exe
+ 2007-11-30 11:18:51 17,272 ----a-w C:\WINDOWS\$hf_mig$\KB951072-v2\spmsg.dll
+ 2007-11-30 11:18:51 231,288 ----a-w C:\WINDOWS\$hf_mig$\KB951072-v2\spuninst.exe
+ 2007-11-30 11:18:51 26,488 ----a-w C:\WINDOWS\$hf_mig$\KB951072-v2\update\spcustom.dll
+ 2007-11-30 12:39:22 755,576 ----a-w C:\WINDOWS\$hf_mig$\KB951072-v2\update\update.exe
+ 2007-11-30 12:39:22 382,840 ----a-w C:\WINDOWS\$hf_mig$\KB951072-v2\update\updspapi.dll
+ 2008-06-13 09:52:16 272,128 ----a-w C:\WINDOWS\$hf_mig$\KB951376-v2\SP2QFE\bthport.sys
+ 2008-06-13 11:05:51 272,128 ----a-w C:\WINDOWS\$hf_mig$\KB951376-v2\SP3GDR\bthport.sys
+ 2008-06-13 11:27:43 272,128 ----a-w C:\WINDOWS\$hf_mig$\KB951376-v2\SP3QFE\bthport.sys
+ 2007-11-30 11:18:51 17,272 ----a-w C:\WINDOWS\$hf_mig$\KB951376-v2\spmsg.dll
+ 2007-11-30 11:18:51 231,288 ----a-w C:\WINDOWS\$hf_mig$\KB951376-v2\spuninst.exe
+ 2007-11-30 11:18:51 26,488 ----a-w C:\WINDOWS\$hf_mig$\KB951376-v2\update\spcustom.dll
+ 2007-11-30 11:18:51 755,576 ----a-w C:\WINDOWS\$hf_mig$\KB951376-v2\update\update.exe
+ 2007-11-30 11:18:51 382,840 ----a-w C:\WINDOWS\$hf_mig$\KB951376-v2\update\updspapi.dll
+ 2008-04-14 11:00:16 272,128 ----a-w C:\WINDOWS\$hf_mig$\KB951376\SP2QFE\bthport.sys
+ 2008-04-14 12:30:49 272,128 ----a-w C:\WINDOWS\$hf_mig$\KB951376\SP3GDR\bthport.sys
+ 2008-04-14 12:36:35 272,128 ----a-w C:\WINDOWS\$hf_mig$\KB951376\SP3QFE\bthport.sys
+ 2007-11-30 11:18:51 17,272 ----a-w C:\WINDOWS\$hf_mig$\KB951376\spmsg.dll
+ 2007-11-30 11:18:51 231,288 ----a-w C:\WINDOWS\$hf_mig$\KB951376\spuninst.exe
+ 2007-11-30 11:18:51 26,488 ----a-w C:\WINDOWS\$hf_mig$\KB951376\update\spcustom.dll
+ 2007-11-30 11:18:51 755,576 ----a-w C:\WINDOWS\$hf_mig$\KB951376\update\update.exe
+ 2007-11-30 11:18:51 382,840 ----a-w C:\WINDOWS\$hf_mig$\KB951376\update\updspapi.dll
+ 2008-05-07 04:55:40 1,288,192 ----a-w C:\WINDOWS\$hf_mig$\KB951698\SP2QFE\quartz.dll
+ 2008-05-07 05:12:40 1,288,192 ----a-w C:\WINDOWS\$hf_mig$\KB951698\SP3GDR\quartz.dll
+ 2008-05-07 05:04:15 1,288,192 ----a-w C:\WINDOWS\$hf_mig$\KB951698\SP3QFE\quartz.dll
+ 2007-11-30 11:18:51 17,272 ----a-w C:\WINDOWS\$hf_mig$\KB951698\spmsg.dll
+ 2007-11-30 11:18:51 231,288 ----a-w C:\WINDOWS\$hf_mig$\KB951698\spuninst.exe
+ 2007-11-30 11:18:51 26,488 ----a-w C:\WINDOWS\$hf_mig$\KB951698\update\spcustom.dll
+ 2007-11-30 12:39:22 755,576 ----a-w C:\WINDOWS\$hf_mig$\KB951698\update\update.exe
+ 2007-11-30 12:39:22 382,840 ----a-w C:\WINDOWS\$hf_mig$\KB951698\update\updspapi.dll
+ 2006-08-16 12:08:32 100,352 ----a-w C:\WINDOWS\$hf_mig$\KB951748\SP2QFE\6to4svc.dll
+ 2008-06-20 10:44:08 138,368 ----a-w C:\WINDOWS\$hf_mig$\KB951748\SP2QFE\afd.sys
+ 2008-06-20 17:36:11 147,968 ----a-w C:\WINDOWS\$hf_mig$\KB951748\SP2QFE\dnsapi.dll
+ 2008-06-20 17:36:11 245,248 ----a-w C:\WINDOWS\$hf_mig$\KB951748\SP2QFE\mswsock.dll
+ 2008-06-20 10:44:42 360,960 ----a-w C:\WINDOWS\$hf_mig$\KB951748\SP2QFE\tcpip.sys
+ 2008-06-20 09:32:39 225,920 ----a-w C:\WINDOWS\$hf_mig$\KB951748\SP2QFE\tcpip6.sys
+ 2008-06-20 11:40:08 138,496 ----a-w C:\WINDOWS\$hf_mig$\KB951748\SP3GDR\afd.sys
+ 2008-06-20 17:46:57 147,968 ----a-w C:\WINDOWS\$hf_mig$\KB951748\SP3GDR\dnsapi.dll
+ 2008-06-20 17:46:57 245,248 ----a-w C:\WINDOWS\$hf_mig$\KB951748\SP3GDR\mswsock.dll
+ 2008-06-20 11:51:12 361,600 ----a-w C:\WINDOWS\$hf_mig$\KB951748\SP3GDR\tcpip.sys
+ 2008-06-20 11:08:27 225,856 ----a-w C:\WINDOWS\$hf_mig$\KB951748\SP3GDR\tcpip6.sys
+ 2008-06-20 11:48:03 138,496 ----a-w C:\WINDOWS\$hf_mig$\KB951748\SP3QFE\afd.sys
+ 2008-06-20 17:43:05 147,968 ----a-w C:\WINDOWS\$hf_mig$\KB951748\SP3QFE\dnsapi.dll
+ 2008-06-20 17:43:05 245,248 ----a-w C:\WINDOWS\$hf_mig$\KB951748\SP3QFE\mswsock.dll
+ 2008-06-20 11:59:02 361,600 ----a-w C:\WINDOWS\$hf_mig$\KB951748\SP3QFE\tcpip.sys
+ 2008-06-20 11:16:44 225,856 ----a-w C:\WINDOWS\$hf_mig$\KB951748\SP3QFE\tcpip6.sys
+ 2007-11-30 12:39:22 17,272 ----a-w C:\WINDOWS\$hf_mig$\KB951748\spmsg.dll
+ 2007-11-30 12:39:22 231,288 ----a-w C:\WINDOWS\$hf_mig$\KB951748\spuninst.exe
+ 2007-11-30 12:39:22 26,488 ----a-w C:\WINDOWS\$hf_mig$\KB951748\update\spcustom.dll
+ 2007-11-30 12:39:18 755,576 ----a-w C:\WINDOWS\$hf_mig$\KB951748\update\update.exe
+ 2007-11-30 12:39:19 382,840 ----a-w C:\WINDOWS\$hf_mig$\KB951748\update\updspapi.dll
+ 2008-05-01 15:04:00 331,776 ----a-w C:\WINDOWS\$hf_mig$\KB952287\SP2QFE\msadce.dll
+ 2008-05-01 14:33:02 331,776 ----a-w C:\WINDOWS\$hf_mig$\KB952287\SP3GDR\msadce.dll
+ 2008-05-01 14:38:05 331,776 ----a-w C:\WINDOWS\$hf_mig$\KB952287\SP3QFE\msadce.dll
+ 2007-11-30 11:18:51 17,272 ----a-w C:\WINDOWS\$hf_mig$\KB952287\spmsg.dll
+ 2007-11-30 11:18:51 231,288 ----a-w C:\WINDOWS\$hf_mig$\KB952287\spuninst.exe
+ 2007-11-30 11:18:51 26,488 ----a-w C:\WINDOWS\$hf_mig$\KB952287\update\spcustom.dll
+ 2007-11-30 11:18:51 755,576 ----a-w C:\WINDOWS\$hf_mig$\KB952287\update\update.exe
+ 2007-11-30 11:18:51 382,840 ----a-w C:\WINDOWS\$hf_mig$\KB952287\update\updspapi.dll
+ 2008-06-24 16:28:00 74,240 ----a-w C:\WINDOWS\$hf_mig$\KB952954\SP2QFE\mscms.dll
+ 2008-06-24 16:43:16 74,240 ----a-w C:\WINDOWS\$hf_mig$\KB952954\SP3GDR\mscms.dll
+ 2008-06-24 16:53:10 74,240 ----a-w C:\WINDOWS\$hf_mig$\KB952954\SP3QFE\mscms.dll
+ 2007-11-30 12:39:22 17,272 ----a-w C:\WINDOWS\$hf_mig$\KB952954\spmsg.dll
+ 2007-11-30 12:39:22 231,288 ----a-w C:\WINDOWS\$hf_mig$\KB952954\spuninst.exe
+ 2007-11-30 12:39:22 26,488 ----a-w C:\WINDOWS\$hf_mig$\KB952954\update\spcustom.dll
+ 2007-11-30 12:39:22 755,576 ----a-w C:\WINDOWS\$hf_mig$\KB952954\update\update.exe
+ 2007-11-30 12:39:22 382,840 ----a-w C:\WINDOWS\$hf_mig$\KB952954\update\updspapi.dll
+ 2008-06-23 16:01:38 124,928 ----a-w C:\WINDOWS\$hf_mig$\KB953838-IE7\SP2QFE\advpack.dll
+ 2008-06-23 16:01:38 347,136 ----a-w C:\WINDOWS\$hf_mig$\KB953838-IE7\SP2QFE\dxtmsft.dll
+ 2008-06-23 16:01:39 214,528 ----a-w C:\WINDOWS\$hf_mig$\KB953838-IE7\SP2QFE\dxtrans.dll
+ 2008-06-23 16:01:39 132,608 ----a-w C:\WINDOWS\$hf_mig$\KB953838-IE7\SP2QFE\extmgr.dll
+ 2008-06-23 16:01:39 63,488 ----a-w C:\WINDOWS\$hf_mig$\KB953838-IE7\SP2QFE\icardie.dll
+ 2008-06-23 08:23:18 70,656 ----a-w C:\WINDOWS\$hf_mig$\KB953838-IE7\SP2QFE\ie4uinit.exe
+ 2008-06-23 16:01:39 153,088 ----a-w C:\WINDOWS\$hf_mig$\KB953838-IE7\SP2QFE\ieakeng.dll
+ 2008-06-23 16:01:39 230,400 ----a-w C:\WINDOWS\$hf_mig$\KB953838-IE7\SP2QFE\ieaksie.dll
+ 2008-06-21 05:23:53 161,792 ----a-w C:\WINDOWS\$hf_mig$\KB953838-IE7\SP2QFE\ieakui.dll
+ 2007-04-17 09:32:38 2,455,488 ----a-w C:\WINDOWS\$hf_mig$\KB953838-IE7\SP2QFE\ieapfltr.dat
+ 2008-06-23 16:01:40 383,488 ----a-w C:\WINDOWS\$hf_mig$\KB953838-IE7\SP2QFE\ieapfltr.dll
+ 2008-06-23 16:01:40 388,608 ----a-w C:\WINDOWS\$hf_mig$\KB953838-IE7\SP2QFE\iedkcs32.dll
+ 2008-06-23 16:01:43 6,068,736 ----a-w C:\WINDOWS\$hf_mig$\KB953838-IE7\SP2QFE\ieframe.dll
+ 2008-06-23 16:01:43 44,544 ----a-w C:\WINDOWS\$hf_mig$\KB953838-IE7\SP2QFE\iernonce.dll
+ 2008-06-23 16:01:44 267,776 ----a-w C:\WINDOWS\$hf_mig$\KB953838-IE7\SP2QFE\iertutil.dll
+ 2008-06-23 08:23:18 13,824 ----a-w C:\WINDOWS\$hf_mig$\KB953838-IE7\SP2QFE\ieudinit.exe
+ 2008-06-23 08:23:52 625,664 ----a-w C:\WINDOWS\$hf_mig$\KB953838-IE7\SP2QFE\iexplore.exe
+ 2008-06-23 16:01:46 27,648 ----a-w C:\WINDOWS\$hf_mig$\KB953838-IE7\SP2QFE\jsproxy.dll
+ 2008-06-23 16:01:46 459,264 ----a-w C:\WINDOWS\$hf_mig$\KB953838-IE7\SP2QFE\msfeeds.dll
+ 2008-06-23 16:01:46 52,224 ----a-w C:\WINDOWS\$hf_mig$\KB953838-IE7\SP2QFE\msfeedsbs.dll
+ 2008-06-23 16:01:49 3,594,240 ----a-w C:\WINDOWS\$hf_mig$\KB953838-IE7\SP2QFE\mshtml.dll
+ 2008-06-23 16:01:49 477,696 ----a-w C:\WINDOWS\$hf_mig$\KB953838-IE7\SP2QFE\mshtmled.dll
+ 2008-06-23 16:01:49 193,024 ----a-w C:\WINDOWS\$hf_mig$\KB953838-IE7\SP2QFE\msrating.dll
+ 2008-06-23 16:01:50 671,232 ----a-w C:\WINDOWS\$hf_mig$\KB953838-IE7\SP2QFE\mstime.dll
+ 2008-06-23 16:01:50 102,912 ----a-w C:\WINDOWS\$hf_mig$\KB953838-IE7\SP2QFE\occache.dll
+ 2008-06-23 16:01:50 44,544 ----a-w C:\WINDOWS\$hf_mig$\KB953838-IE7\SP2QFE\pngfilt.dll
+ 2008-06-23 16:01:50 105,984 ----a-w C:\WINDOWS\$hf_mig$\KB953838-IE7\SP2QFE\url.dll
+ 2008-06-23 16:01:51 1,162,752 ----a-w C:\WINDOWS\$hf_mig$\KB953838-IE7\SP2QFE\urlmon.dll
+ 2008-06-23 16:01:51 233,472 ----a-w C:\WINDOWS\$hf_mig$\KB953838-IE7\SP2QFE\webcheck.dll
+ 2008-06-23 16:01:51 827,904 ----a-w C:\WINDOWS\$hf_mig$\KB953838-IE7\SP2QFE\wininet.dll
+ 2007-03-06 01:22:33 14,048 ----a-w C:\WINDOWS\$hf_mig$\KB953838-IE7\spmsg.dll
+ 2007-03-06 01:22:39 213,216 ----a-w C:\WINDOWS\$hf_mig$\KB953838-IE7\spuninst.exe
+ 2007-03-06 01:22:31 22,752 ----a-w C:\WINDOWS\$hf_mig$\KB953838-IE7\update\spcustom.dll
+ 2007-03-06 01:22:56 716,000 ----a-w C:\WINDOWS\$hf_mig$\KB953838-IE7\update\update.exe
+ 2007-03-06 01:23:51 371,424 ----a-w C:\WINDOWS\$hf_mig$\KB953838-IE7\update\updspapi.dll
+ 2007-11-30 12:39:22 17,272 ----a-w C:\WINDOWS\$hf_mig$\KB953839\spmsg.dll
+ 2007-11-30 12:39:22 231,288 ----a-w C:\WINDOWS\$hf_mig$\KB953839\spuninst.exe
+ 2007-11-30 12:39:22 26,488 ----a-w C:\WINDOWS\$hf_mig$\KB953839\update\spcustom.dll
+ 2007-11-30 11:18:51 755,576 ----a-w C:\WINDOWS\$hf_mig$\KB953839\update\update.exe
+ 2007-11-30 11:18:51 382,840 ----a-w C:\WINDOWS\$hf_mig$\KB953839\update\updspapi.dll
+ 2007-03-06 01:22:41 213,216 -c----w C:\WINDOWS\$NtUninstallKB932823-v3$\spuninst\spuninst.exe
+ 2007-03-06 01:23:51 371,424 -c----w C:\WINDOWS\$NtUninstallKB932823-v3$\spuninst\updspapi.dll
+ 2007-03-06 01:22:41 213,216 -c----w C:\WINDOWS\$NtUninstallKB941644$\spuninst\spuninst.exe
+ 2007-03-06 01:23:51 371,424 -c----w C:\WINDOWS\$NtUninstallKB941644$\spuninst\updspapi.dll
+ 2006-04-20 11:51:50 359,808 -c----w C:\WINDOWS\$NtUninstallKB941644$\tcpip.sys
+ 2007-03-06 01:22:41 213,216 -c----w C:\WINDOWS\$NtUninstallKB941693$\spuninst\spuninst.exe
+ 2007-03-06 01:23:51 371,424 -c----w C:\WINDOWS\$NtUninstallKB941693$\spuninst\updspapi.dll
+ 2007-03-08 13:47:48 1,843,584 -c----w C:\WINDOWS\$NtUninstallKB941693$\win32k.sys
+ 2007-05-17 11:28:05 549,376 -c----w C:\WINDOWS\$NtUninstallKB943055$\oleaut32.dll
+ 2007-03-06 01:22:41 213,216 -c----w C:\WINDOWS\$NtUninstallKB943055$\spuninst\spuninst.exe
+ 2007-03-06 01:23:51 371,424 -c----w C:\WINDOWS\$NtUninstallKB943055$\spuninst\updspapi.dll
+ 2006-08-17 12:28:27 721,920 -c----w C:\WINDOWS\$NtUninstallKB943485$\lsasrv.dll
+ 2007-03-06 01:22:41 213,216 -c----w C:\WINDOWS\$NtUninstallKB943485$\spuninst\spuninst.exe
+ 2007-03-06 01:23:51 371,424 -c----w C:\WINDOWS\$NtUninstallKB943485$\spuninst\updspapi.dll
+ 2006-06-26 17:37:10 148,480 -c----w C:\WINDOWS\$NtUninstallKB945553$\dnsapi.dll
+ 2004-08-04 12:00:00 45,568 -c----w C:\WINDOWS\$NtUninstallKB945553$\dnsrslvr.dll
+ 2007-03-06 01:22:41 213,216 -c----w C:\WINDOWS\$NtUninstallKB945553$\spuninst\spuninst.exe
+ 2007-03-06 01:23:51 371,424 -c----w C:\WINDOWS\$NtUninstallKB945553$\spuninst\updspapi.dll
+ 2004-08-04 12:00:00 181,248 -c----w C:\WINDOWS\$NtUninstallKB946026$\mrxdav.sys
+ 2007-03-06 01:22:41 213,216 -c----w C:\WINDOWS\$NtUninstallKB946026$\spuninst\spuninst.exe
+ 2007-03-06 01:23:51 371,424 -c----w C:\WINDOWS\$NtUninstallKB946026$\spuninst\updspapi.dll
+ 2004-08-04 15:06:34 82,944 -c----w C:\WINDOWS\$NtUninstallKB946648$\msgsc.dll
+ 2007-11-30 12:39:22 231,288 -c----w C:\WINDOWS\$NtUninstallKB946648$\spuninst\spuninst.exe
+ 2007-11-30 12:39:22 382,840 -c----w C:\WINDOWS\$NtUninstallKB946648$\spuninst\updspapi.dll
+ 2007-06-19 13:31:19 282,112 -c----w C:\WINDOWS\$NtUninstallKB948590$\gdi32.dll
+ 2007-03-06 01:22:41 213,216 -c----w C:\WINDOWS\$NtUninstallKB948590$\spuninst\spuninst.exe
+ 2007-03-06 01:23:51 371,424 -c----w C:\WINDOWS\$NtUninstallKB948590$\spuninst\updspapi.dll
+ 2007-03-06 01:22:39 213,216 -c----w C:\WINDOWS\$NtUninstallKB948881$\spuninst\spuninst.exe
+ 2007-03-06 01:23:47 371,424 -c----w C:\WINDOWS\$NtUninstallKB948881$\spuninst\updspapi.dll
+ 2004-08-04 12:00:00 561,179 -c----w C:\WINDOWS\$NtUninstallKB950749$\dao360.dll
+ 2004-08-04 12:00:00 512,029 -c----w C:\WINDOWS\$NtUninstallKB950749$\msexch40.dll
+ 2004-08-04 12:00:00 319,517 -c----w C:\WINDOWS\$NtUninstallKB950749$\msexcl40.dll
+ 2004-08-04 12:00:00 1,507,356 -c----w C:\WINDOWS\$NtUninstallKB950749$\msjet40.dll
+ 2004-08-04 12:00:00 358,976 -c----w C:\WINDOWS\$NtUninstallKB950749$\msjetol1.dll
+ 2004-08-04 19:00:00 358,976 -c----w C:\WINDOWS\$NtUninstallKB950749$\msjetoledb40.dll
+ 2004-08-04 12:00:00 151,583 -c----w C:\WINDOWS\$NtUninstallKB950749$\msjint40.dll
+ 2004-08-04 12:00:00 53,279 -c----w C:\WINDOWS\$NtUninstallKB950749$\msjter40.dll
+ 2004-08-04 12:00:00 241,693 -c----w C:\WINDOWS\$NtUninstallKB950749$\msjtes40.dll
+ 2004-08-04 12:00:00 213,023 -c----w C:\WINDOWS\$NtUninstallKB950749$\msltus40.dll
+ 2004-08-04 12:00:00 348,189 -c----w C:\WINDOWS\$NtUninstallKB950749$\mspbde40.dll
+ 2004-08-04 12:00:00 421,919 -c----w C:\WINDOWS\$NtUninstallKB950749$\msrd2x40.dll
+ 2004-08-04 12:00:00 315,423 -c----w C:\WINDOWS\$NtUninstallKB950749$\msrd3x40.dll
+ 2004-08-04 12:00:00 552,989 -c----w C:\WINDOWS\$NtUninstallKB950749$\msrepl40.dll
+ 2004-08-04 12:00:00 258,077 -c----w C:\WINDOWS\$NtUninstallKB950749$\mstext40.dll
+ 2004-08-04 12:00:00 831,519 -c----w C:\WINDOWS\$NtUninstallKB950749$\mswdat10.dll
+ 2004-08-04 12:00:00 614,429 -c----w C:\WINDOWS\$NtUninstallKB950749$\mswstr10.dll
+ 2004-08-04 12:00:00 348,189 -c----w C:\WINDOWS\$NtUninstallKB950749$\msxbde40.dll
+ 2007-03-06 01:22:41 213,216 -c----w C:\WINDOWS\$NtUninstallKB950749$\spuninst\spuninst.exe
+ 2007-03-06 01:23:51 371,424 -c----w C:\WINDOWS\$NtUninstallKB950749$\spuninst\updspapi.dll
+ 2007-11-30 12:39:22 231,288 -c----w C:\WINDOWS\$NtUninstallKB950760$\spuninst\spuninst.exe
+ 2007-11-30 12:39:22 382,840 -c----w C:\WINDOWS\$NtUninstallKB950760$\spuninst\updspapi.dll
+ 2006-07-13 08:48:58 202,240 -c----w C:\WINDOWS\$NtUninstallKB950762$\rmcast.sys
+ 2007-11-30 12:39:22 231,288 -c----w C:\WINDOWS\$NtUninstallKB950762$\spuninst\spuninst.exe
+ 2007-11-30 12:39:22 382,840 -c----w C:\WINDOWS\$NtUninstallKB950762$\spuninst\updspapi.dll
+ 2005-07-26 04:39:45 243,200 -c----w C:\WINDOWS\$NtUninstallKB950974$\es.dll
+ 2007-11-30 12:39:22 231,288 -c----w C:\WINDOWS\$NtUninstallKB950974$\spuninst\spuninst.exe
+ 2007-11-30 12:39:19 382,840 -c----w C:\WINDOWS\$NtUninstallKB950974$\spuninst\updspapi.dll
+ 2007-08-21 06:15:44 683,520 -c----w C:\WINDOWS\$NtUninstallKB951066$\inetcomm.dll
+ 2007-11-30 12:39:22 231,288 -c----w C:\WINDOWS\$NtUninstallKB951066$\spuninst\spuninst.exe
+ 2007-11-30 12:39:22 382,840 -c----w C:\WINDOWS\$NtUninstallKB951066$\spuninst\updspapi.dll
+ 2007-11-30 11:18:51 231,288 -c----w C:\WINDOWS\$NtUninstallKB951072-v2$\spuninst\spuninst.exe
+ 2007-11-30 12:39:22 382,840 -c----w C:\WINDOWS\$NtUninstallKB951072-v2$\spuninst\updspapi.dll
+ 2007-11-13 11:31:11 60,416 -c----w C:\WINDOWS\$NtUninstallKB951072-v2$\tzchange.exe
+ 2008-04-14 11:01:02 272,128 -c----w C:\WINDOWS\$NtUninstallKB951376-v2$\bthport.sys
+ 2007-11-30 11:18:51 231,288 -c----w C:\WINDOWS\$NtUninstallKB951376-v2$\spuninst\spuninst.exe
+ 2007-11-30 11:18:51 382,840 -c----w C:\WINDOWS\$NtUninstallKB951376-v2$\spuninst\updspapi.dll
+ 2007-11-30 11:18:51 231,288 -c----w C:\WINDOWS\$NtUninstallKB951376$\spuninst\spuninst.exe
+ 2007-11-30 11:18:51 382,840 -c----w C:\WINDOWS\$NtUninstallKB951376$\spuninst\updspapi.dll
+ 2007-10-29 22:43:03 1,287,680 -c----w C:\WINDOWS\$NtUninstallKB951698$\quartz.dll
+ 2007-11-30 11:18:51 231,288 -c----w C:\WINDOWS\$NtUninstallKB951698$\spuninst\spuninst.exe
+ 2007-11-30 12:39:22 382,840 -c----w C:\WINDOWS\$NtUninstallKB951698$\spuninst\updspapi.dll
+ 2004-08-04 12:00:00 138,496 -c----w C:\WINDOWS\$NtUninstallKB951748$\afd.sys
+ 2008-02-20 05:32:43 148,992 -c----w C:\WINDOWS\$NtUninstallKB951748$\dnsapi.dll
+ 2004-08-04 12:00:00 245,248 -c----w C:\WINDOWS\$NtUninstallKB951748$\mswsock.dll
+ 2007-11-30 12:39:22 231,288 -c----w C:\WINDOWS\$NtUninstallKB951748$\spuninst\spuninst.exe
+ 2007-11-30 12:39:19 382,840 -c----w C:\WINDOWS\$NtUninstallKB951748$\spuninst\updspapi.dll
+ 2007-10-30 17:20:55 360,064 -c----w C:\WINDOWS\$NtUninstallKB951748$\tcpip.sys
+ 2006-08-16 09:37:30 225,664 -c----w C:\WINDOWS\$NtUninstallKB951748$\tcpip6.sys
+ 2004-08-04 12:00:00 331,776 -c----w C:\WINDOWS\$NtUninstallKB952287$\msadce.dll
+ 2007-11-30 11:18:51 231,288 -c----w C:\WINDOWS\$NtUninstallKB952287$\spuninst\spuninst.exe
+ 2007-11-30 11:18:51 382,840 -c----w C:\WINDOWS\$NtUninstallKB952287$\spuninst\updspapi.dll
+ 2005-06-29 01:46:00 74,240 -c----w C:\WINDOWS\$NtUninstallKB952954$\mscms.dll
+ 2007-11-30 12:39:22 231,288 -c----w C:\WINDOWS\$NtUninstallKB952954$\spuninst\spuninst.exe
+ 2007-11-30 12:39:22 382,840 -c----w C:\WINDOWS\$NtUninstallKB952954$\spuninst\updspapi.dll
+ 2007-11-30 12:39:22 231,288 -c----w C:\WINDOWS\$NtUninstallKB953839$\spuninst\spuninst.exe
+ 2007-11-30 11:18:51 382,840 -c----w C:\WINDOWS\$NtUninstallKB953839$\spuninst\updspapi.dll
+ 2008-03-19 02:38:12 53,248 ----a-w C:\WINDOWS\assembly\GAC\Microsoft.DirectX.AudioVideoPlayback\1.0.2902.0__31bf3856ad364e35\Microsoft.DirectX.AudioVideoPlayback.dll
+ 2008-03-19 02:38:12 12,800 ----a-w C:\WINDOWS\assembly\GAC\Microsoft.DirectX.Diagnostics\1.0.2902.0__31bf3856ad364e35\Microsoft.DirectX.Diagnostics.dll
+ 2008-03-19 02:38:12 473,600 ----a-w C:\WINDOWS\assembly\GAC\Microsoft.DirectX.Direct3D\1.0.2902.0__31bf3856ad364e35\Microsoft.DirectX.Direct3D.dll
+ 2008-03-19 02:38:05 2,676,224 ----a-w C:\WINDOWS\assembly\GAC\Microsoft.DirectX.Direct3DX\1.0.2902.0__31bf3856ad364e35\Microsoft.DirectX.Direct3DX.dll
+ 2008-03-19 02:38:06 2,846,720 ----a-w C:\WINDOWS\assembly\GAC\Microsoft.DirectX.Direct3DX\1.0.2903.0__31bf3856ad364e35\Microsoft.DirectX.Direct3DX.dll
+ 2008-03-19 02:38:07 563,712 ----a-w C:\WINDOWS\assembly\GAC\Microsoft.DirectX.Direct3DX\1.0.2904.0__31bf3856ad364e35\Microsoft.DirectX.Direct3DX.dll
+ 2008-03-19 02:38:07 567,296 ----a-w C:\WINDOWS\assembly\GAC\Microsoft.DirectX.Direct3DX\1.0.2905.0__31bf3856ad364e35\Microsoft.DirectX.Direct3DX.dll
+ 2008-03-19 02:38:08 576,000 ----a-w C:\WINDOWS\assembly\GAC\Microsoft.DirectX.Direct3DX\1.0.2906.0__31bf3856ad364e35\Microsoft.DirectX.Direct3DX.dll
+ 2008-03-19 02:38:09 577,024 ----a-w C:\WINDOWS\assembly\GAC\Microsoft.DirectX.Direct3DX\1.0.2907.0__31bf3856ad364e35\Microsoft.DirectX.Direct3DX.dll
+ 2008-03-19 02:38:09 577,536 ----a-w C:\WINDOWS\assembly\GAC\Microsoft.DirectX.Direct3DX\1.0.2908.0__31bf3856ad364e35\Microsoft.DirectX.Direct3DX.dll
+ 2008-03-19 02:38:10 577,536 ----a-w C:\WINDOWS\assembly\GAC\Microsoft.DirectX.Direct3DX\1.0.2909.0__31bf3856ad364e35\Microsoft.DirectX.Direct3DX.dll
+ 2008-03-19 02:38:11 578,560 ----a-w C:\WINDOWS\assembly\GAC\Microsoft.DirectX.Direct3DX\1.0.2910.0__31bf3856ad364e35\Microsoft.DirectX.Direct3DX.dll
+ 2008-03-19 02:38:13 578,560 ----a-w C:\WINDOWS\assembly\GAC\Microsoft.DirectX.Direct3DX\1.0.2911.0__31bf3856ad364e35\Microsoft.DirectX.Direct3DX.dll
+ 2008-03-19 02:38:13 145,920 ----a-w C:\WINDOWS\assembly\GAC\Microsoft.DirectX.DirectDraw\1.0.2902.0__31bf3856ad364e35\Microsoft.DirectX.DirectDraw.dll
+ 2008-03-19 02:38:13 159,232 ----a-w C:\WINDOWS\assembly\GAC\Microsoft.DirectX.DirectInput\1.0.2902.0__31bf3856ad364e35\Microsoft.DirectX.DirectInput.dll
+ 2008-03-19 02:38:13 364,544 ----a-w C:\WINDOWS\assembly\GAC\Microsoft.DirectX.DirectPlay\1.0.2902.0__31bf3856ad364e35\Microsoft.DirectX.DirectPlay.dll
+ 2008-03-19 02:38:14 178,176 ----a-w C:\WINDOWS\assembly\GAC\Microsoft.DirectX.DirectSound\1.0.2902.0__31bf3856ad364e35\Microsoft.DirectX.DirectSound.dll
+ 2008-03-19 02:38:11 223,232 ----a-w C:\WINDOWS\assembly\GAC\Microsoft.DirectX\1.0.2902.0__31bf3856ad364e35\Microsoft.DirectX.dll
- 2007-12-07 04:24:44 68,608 ----a-w C:\WINDOWS\assembly\GAC_32\CustomMarshalers\2.0.0.0__b03f5f7f11d50a3a\CustomMarshalers.dll
+ 2008-04-12 08:07:43 69,120 ----a-w C:\WINDOWS\assembly\GAC_32\CustomMarshalers\2.0.0.0__b03f5f7f11d50a3a\CustomMarshalers.dll
- 2007-12-07 04:25:05 72,192 ----a-w C:\WINDOWS\assembly\GAC_32\ISymWrapper\2.0.0.0__b03f5f7f11d50a3a\ISymWrapper.dll
+ 2008-04-12 08:07:50 72,192 ----a-w C:\WINDOWS\assembly\GAC_32\ISymWrapper\2.0.0.0__b03f5f7f11d50a3a\ISymWrapper.dll
- 2007-12-07 04:25:06 4,308,992 ----a-w C:\WINDOWS\assembly\GAC_32\mscorlib\2.0.0.0__b77a5c561934e089\mscorlib.dll
+ 2008-04-12 08:07:27 4,444,160 ----a-w C:\WINDOWS\assembly\GAC_32\mscorlib\2.0.0.0__b77a5c561934e089\mscorlib.dll
- 2007-12-07 04:25:08 482,304 ----a-w C:\WINDOWS\assembly\GAC_32\System.Data.OracleClient\2.0.0.0__b77a5c561934e089\System.Data.OracleClient.dll
+ 2008-04-12 08:07:53 483,840 ----a-w C:\WINDOWS\assembly\GAC_32\System.Data.OracleClient\2.0.0.0__b77a5c561934e089\System.Data.OracleClient.dll
- 2007-12-07 04:25:01 2,902,016 ----a-w C:\WINDOWS\assembly\GAC_32\System.Data\2.0.0.0__b77a5c561934e089\System.Data.dll
+ 2008-04-12 08:07:36 3,036,160 ----a-w C:\WINDOWS\assembly\GAC_32\System.Data\2.0.0.0__b77a5c561934e089\System.Data.dll
- 2007-12-07 04:24:24 258,048 ----a-w C:\WINDOWS\assembly\GAC_32\System.EnterpriseServices\2.0.0.0__b03f5f7f11d50a3a\System.EnterpriseServices.dll
+ 2008-04-12 08:07:57 258,048 ----a-w C:\WINDOWS\assembly\GAC_32\System.EnterpriseServices\2.0.0.0__b03f5f7f11d50a3a\System.EnterpriseServices.dll
- 2007-12-07 04:24:24 114,176 ----a-w C:\WINDOWS\assembly\GAC_32\System.EnterpriseServices\2.0.0.0__b03f5f7f11d50a3a\System.EnterpriseServices.Wrapper.dll
+ 2008-04-12 08:07:57 113,664 ----a-w C:\WINDOWS\assembly\GAC_32\System.EnterpriseServices\2.0.0.0__b03f5f7f11d50a3a\System.EnterpriseServices.Wrapper.dll
- 2007-12-07 04:25:20 260,096 ----a-w C:\WINDOWS\assembly\GAC_32\System.Transactions\2.0.0.0__b77a5c561934e089\System.Transactions.dll
+ 2008-04-12 08:07:51 261,120 ----a-w C:\WINDOWS\assembly\GAC_32\System.Transactions\2.0.0.0__b77a5c561934e089\System.Transactions.dll
- 2007-12-07 04:24:54 5,156,864 ----a-w C:\WINDOWS\assembly\GAC_32\System.Web\2.0.0.0__b03f5f7f11d50a3a\System.Web.dll
+ 2008-04-12 08:07:34 5,431,296 ----a-w C:\WINDOWS\assembly\GAC_32\System.Web\2.0.0.0__b03f5f7f11d50a3a\System.Web.dll
- 2007-12-07 04:24:40 10,752 ----a-w C:\WINDOWS\assembly\GAC_MSIL\Accessibility\2.0.0.0__b03f5f7f11d50a3a\Accessibility.dll
+ 2008-04-12 08:07:41 10,752 ----a-w C:\WINDOWS\assembly\GAC_MSIL\Accessibility\2.0.0.0__b03f5f7f11d50a3a\Accessibility.dll
- 2007-12-07 04:24:22 507,904 ----a-w C:\WINDOWS\assembly\GAC_MSIL\AspNetMMCExt\2.0.0.0__b03f5f7f11d50a3a\AspNetMMCExt.dll
+ 2008-04-12 08:07:35 507,904 ----a-w C:\WINDOWS\assembly\GAC_MSIL\AspNetMMCExt\2.0.0.0__b03f5f7f11d50a3a\AspNetMMCExt.dll
- 2007-12-07 04:24:34 13,312 ----a-w C:\WINDOWS\assembly\GAC_MSIL\cscompmgd\8.0.0.0__b03f5f7f11d50a3a\cscompmgd.dll
+ 2008-04-12 08:07:43 13,312 ----a-w C:\WINDOWS\assembly\GAC_MSIL\cscompmgd\8.0.0.0__b03f5f7f11d50a3a\cscompmgd.dll
- 2007-12-07 04:25:03 8,192 ----a-w C:\WINDOWS\assembly\GAC_MSIL\IEExecRemote\2.0.0.0__b03f5f7f11d50a3a\IEExecRemote.dll
+ 2008-04-12 08:07:47 8,192 ----a-w C:\WINDOWS\assembly\GAC_MSIL\IEExecRemote\2.0.0.0__b03f5f7f11d50a3a\IEExecRemote.dll
- 2007-12-07 04:25:04 36,864 ----a-w C:\WINDOWS\assembly\GAC_MSIL\IEHost\2.0.0.0__b03f5f7f11d50a3a\IEHost.dll
+ 2008-04-12 08:07:47 77,824 ----a-w C:\WINDOWS\assembly\GAC_MSIL\IEHost\2.0.0.0__b03f5f7f11d50a3a\IEHost.dll
- 2007-12-07 04:25:04 5,632 ----a-w C:\WINDOWS\assembly\GAC_MSIL\IIEHost\2.0.0.0__b03f5f7f11d50a3a\IIEHost.dll
+ 2008-04-12 08:07:48 6,656 ----a-w C:\WINDOWS\assembly\GAC_MSIL\IIEHost\2.0.0.0__b03f5f7f11d50a3a\IIEHost.dll
- 2007-12-07 04:24:38 413,696 ----a-w C:\WINDOWS\assembly\GAC_MSIL\Microsoft.Build.Engine\2.0.0.0__b03f5f7f11d50a3a\Microsoft.Build.Engine.dll
+ 2008-04-12 08:07:58 348,160 ----a-w C:\WINDOWS\assembly\GAC_MSIL\Microsoft.Build.Engine\2.0.0.0__b03f5f7f11d50a3a\Microsoft.Build.Engine.dll
- 2007-12-07 04:24:38 36,864 ----a-w C:\WINDOWS\assembly\GAC_MSIL\Microsoft.Build.Framework\2.0.0.0__b03f5f7f11d50a3a\Microsoft.Build.Framework.dll
+ 2008-04-12 08:07:59 36,864 ----a-w C:\WINDOWS\assembly\GAC_MSIL\Microsoft.Build.Framework\2.0.0.0__b03f5f7f11d50a3a\Microsoft.Build.Framework.dll
- 2007-12-07 04:24:39 647,168 ----a-w C:\WINDOWS\assembly\GAC_MSIL\Microsoft.Build.Tasks\2.0.0.0__b03f5f7f11d50a3a\Microsoft.Build.Tasks.dll
+ 2008-04-12 08:08:00 655,360 ----a-w C:\WINDOWS\assembly\GAC_MSIL\Microsoft.Build.Tasks\2.0.0.0__b03f5f7f11d50a3a\Microsoft.Build.Tasks.dll
- 2007-12-07 04:24:40 73,728 ----a-w C:\WINDOWS\assembly\GAC_MSIL\Microsoft.Build.Utilities\2.0.0.0__b03f5f7f11d50a3a\Microsoft.Build.Utilities.dll
+ 2008-04-12 08:08:01 77,824 ----a-w C:\WINDOWS\assembly\GAC_MSIL\Microsoft.Build.Utilities\2.0.0.0__b03f5f7f11d50a3a\Microsoft.Build.Utilities.dll
- 2007-12-07 04:24:37 749,568 ----a-w C:\WINDOWS\assembly\GAC_MSIL\Microsoft.JScript\8.0.0.0__b03f5f7f11d50a3a\Microsoft.JScript.dll
+ 2008-04-12 08:07:48 749,568 ----a-w C:\WINDOWS\assembly\GAC_MSIL\Microsoft.JScript\8.0.0.0__b03f5f7f11d50a3a\Microsoft.JScript.dll
- 2007-12-07 04:25:24 110,592 ----a-w C:\WINDOWS\assembly\GAC_MSIL\Microsoft.VisualBasic.Compatibility.Data\8.0.0.0__b03f5f7f11d50a3a\Microsoft.VisualBasic.Compatibility.Data.dll
+ 2008-04-12 08:07:47 110,592 ----a-w C:\WINDOWS\assembly\GAC_MSIL\Microsoft.VisualBasic.Compatibility.Data\8.0.0.0__b03f5f7f11d50a3a\Microsoft.VisualBasic.Compatibility.Data.dll
- 2007-12-07 04:25:24 372,736 ----a-w C:\WINDOWS\assembly\GAC_MSIL\Microsoft.VisualBasic.Compatibility\8.0.0.0__b03f5f7f11d50a3a\Microsoft.VisualBasic.Compatibility.dll
+ 2008-04-12 08:07:46 372,736 ----a-w C:\WINDOWS\assembly\GAC_MSIL\Microsoft.VisualBasic.Compatibility\8.0.0.0__b03f5f7f11d50a3a\Microsoft.VisualBasic.Compatibility.dll
- 2007-12-07 04:24:14 28,672 ----a-w C:\WINDOWS\assembly\GAC_MSIL\Microsoft.VisualBasic.Vsa\8.0.0.0__b03f5f7f11d50a3a\Microsoft.VisualBasic.Vsa.dll
+ 2008-04-12 08:07:53 28,672 ----a-w C:\WINDOWS\assembly\GAC_MSIL\Microsoft.VisualBasic.Vsa\8.0.0.0__b03f5f7f11d50a3a\Microsoft.VisualBasic.Vsa.dll
- 2007-12-07 04:25:21 667,648 ----a-w C:\WINDOWS\assembly\GAC_MSIL\Microsoft.VisualBasic\8.0.0.0__b03f5f7f11d50a3a\Microsoft.VisualBasic.dll
+ 2008-04-12 08:07:45 671,744 ----a-w C:\WINDOWS\assembly\GAC_MSIL\Microsoft.VisualBasic\8.0.0.0__b03f5f7f11d50a3a\Microsoft.VisualBasic.dll
- 2007-12-07 04:25:25 5,632 ----a-w C:\WINDOWS\assembly\GAC_MSIL\Microsoft.VisualC\8.0.0.0__b03f5f7f11d50a3a\Microsoft.VisualC.Dll
+ 2008-04-12 08:07:30 5,632 ----a-w C:\WINDOWS\assembly\GAC_MSIL\Microsoft.VisualC\8.0.0.0__b03f5f7f11d50a3a\Microsoft.VisualC.Dll
- 2007-12-07 04:24:19 12,800 ----a-w C:\WINDOWS\assembly\GAC_MSIL\Microsoft.Vsa.Vb.CodeDOMProcessor\8.0.0.0__b03f5f7f11d50a3a\Microsoft.Vsa.Vb.CodeDOMProcessor.dll
+ 2008-04-12 08:07:56 12,800 ----a-w C:\WINDOWS\assembly\GAC_MSIL\Microsoft.Vsa.Vb.CodeDOMProcessor\8.0.0.0__b03f5f7f11d50a3a\Microsoft.Vsa.Vb.CodeDOMProcessor.dll
- 2007-12-07 04:24:16 32,768 ----a-w C:\WINDOWS\assembly\GAC_MSIL\Microsoft.Vsa\8.0.0.0__b03f5f7f11d50a3a\Microsoft.Vsa.dll
+ 2008-04-12 08:07:45 32,768 ----a-w C:\WINDOWS\assembly\GAC_MSIL\Microsoft.Vsa\8.0.0.0__b03f5f7f11d50a3a\Microsoft.Vsa.dll
- 2007-12-07 04:24:17 7,168 ----a-w C:\WINDOWS\assembly\GAC_MSIL\Microsoft_VsaVb\8.0.0.0__b03f5f7f11d50a3a\Microsoft_VsaVb.dll
+ 2008-04-12 08:07:44 7,168 ----a-w C:\WINDOWS\assembly\GAC_MSIL\Microsoft_VsaVb\8.0.0.0__b03f5f7f11d50a3a\Microsoft_VsaVb.dll
- 2007-12-07 04:25:12 110,592 ----a-w C:\WINDOWS\assembly\GAC_MSIL\sysglobl\2.0.0.0__b03f5f7f11d50a3a\sysglobl.dll
+ 2008-04-12 08:07:49 110,592 ----a-w C:\WINDOWS\assembly\GAC_MSIL\sysglobl\2.0.0.0__b03f5f7f11d50a3a\sysglobl.dll
- 2007-12-07 04:24:45 81,920 ----a-w C:\WINDOWS\assembly\GAC_MSIL\System.Configuration.Install\2.0.0.0__b03f5f7f11d50a3a\System.Configuration.Install.dll
+ 2008-04-12 08:07:50 81,920 ----a-w C:\WINDOWS\assembly\GAC_MSIL\System.Configuration.Install\2.0.0.0__b03f5f7f11d50a3a\System.Configuration.Install.dll
- 2007-12-07 04:25:13 413,696 ----a-w C:\WINDOWS\assembly\GAC_MSIL\System.Configuration\2.0.0.0__b03f5f7f11d50a3a\System.configuration.dll
+ 2008-04-12 08:07:36 425,984 ----a-w C:\WINDOWS\assembly\GAC_MSIL\System.Configuration\2.0.0.0__b03f5f7f11d50a3a\System.configuration.dll
- 2007-12-07 04:25:09 716,800 ----a-w C:\WINDOWS\assembly\GAC_MSIL\System.Data.SqlXml\2.0.0.0__b77a5c561934e089\System.Data.SqlXml.dll
+ 2008-04-12 08:07:37 741,376 ----a-w C:\WINDOWS\assembly\GAC_MSIL\System.Data.SqlXml\2.0.0.0__b77a5c561934e089\System.Data.SqlXml.dll
- 2007-12-07 04:24:29 888,832 ----a-w C:\WINDOWS\assembly\GAC_MSIL\System.Deployment\2.0.0.0__b03f5f7f11d50a3a\System.Deployment.dll
+ 2008-04-12 08:07:37 933,888 ----a-w C:\WINDOWS\assembly\GAC_MSIL\System.Deployment\2.0.0.0__b03f5f7f11d50a3a\System.Deployment.dll
- 2007-12-07 04:25:02 5,001,216 ----a-w C:\WINDOWS\assembly\GAC_MSIL\System.Design\2.0.0.0__b03f5f7f11d50a3a\System.Design.dll
+ 2008-04-12 08:08:02 5,070,848 ----a-w C:\WINDOWS\assembly\GAC_MSIL\System.Design\2.0.0.0__b03f5f7f11d50a3a\System.Design.dll
- 2007-12-07 04:24:48 188,416 ----a-w C:\WINDOWS\assembly\GAC_MSIL\System.DirectoryServices.Protocols\2.0.0.0__b03f5f7f11d50a3a\System.DirectoryServices.Protocols.dll
+ 2008-04-12 08:08:00 188,416 ----a-w C:\WINDOWS\assembly\GAC_MSIL\System.DirectoryServices.Protocols\2.0.0.0__b03f5f7f11d50a3a\System.DirectoryServices.Protocols.dll
- 2007-12-07 04:24:46 397,312 ----a-w C:\WINDOWS\assembly\GAC_MSIL\System.DirectoryServices\2.0.0.0__b03f5f7f11d50a3a\System.DirectoryServices.dll
+ 2008-04-12 08:07:41 401,408 ----a-w C:\WINDOWS\assembly\GAC_MSIL\System.DirectoryServices\2.0.0.0__b03f5f7f11d50a3a\System.DirectoryServices.dll
- 2007-12-07 04:24:50 81,920 ----a-w C:\WINDOWS\assembly\GAC_MSIL\System.Drawing.Design\2.0.0.0__b03f5f7f11d50a3a\System.Drawing.Design.dll
+ 2008-04-12 08:07:55 81,920 ----a-w C:\WINDOWS\assembly\GAC_MSIL\System.Drawing.Design\2.0.0.0__b03f5f7f11d50a3a\System.Drawing.Design.dll
- 2007-12-07 04:25:18 577,536 ----a-w C:\WINDOWS\assembly\GAC_MSIL\System.Drawing\2.0.0.0__b03f5f7f11d50a3a\System.Drawing.dll
+ 2008-04-12 08:07:31 630,784 ----a-w C:\WINDOWS\assembly\GAC_MSIL\System.Drawing\2.0.0.0__b03f5f7f11d50a3a\System.Drawing.dll
- 2007-12-07 04:25:09 372,736 ----a-w C:\WINDOWS\assembly\GAC_MSIL\System.Management\2.0.0.0__b03f5f7f11d50a3a\System.Management.dll
+ 2008-04-12 08:07:57 372,736 ----a-w C:\WINDOWS\assembly\GAC_MSIL\System.Management\2.0.0.0__b03f5f7f11d50a3a\System.Management.dll
- 2007-12-07 04:25:18 258,048 ----a-w C:\WINDOWS\assembly\GAC_MSIL\System.Messaging\2.0.0.0__b03f5f7f11d50a3a\System.Messaging.dll
+ 2008-04-12 08:07:54 258,048 ----a-w C:\WINDOWS\assembly\GAC_MSIL\System.Messaging\2.0.0.0__b03f5f7f11d50a3a\System.Messaging.dll
- 2007-12-07 04:25:10 299,008 ----a-w C:\WINDOWS\assembly\GAC_MSIL\System.Runtime.Remoting\2.0.0.0__b77a5c561934e089\System.Runtime.Remoting.dll
+ 2008-04-12 08:07:52 299,008 ----a-w C:\WINDOWS\assembly\GAC_MSIL\System.Runtime.Remoting\2.0.0.0__b77a5c561934e089\System.Runtime.Remoting.dll
- 2007-12-07 04:25:11 131,072 ----a-w C:\WINDOWS\assembly\GAC_MSIL\System.Runtime.Serialization.Formatters.Soap\2.0.0.0__b03f5f7f11d50a3a\System.Runtime.Serialization.Formatters.Soap.dll
+ 2008-04-12 08:07:51 131,072 ----a-w C:\WINDOWS\assembly\GAC_MSIL\System.Runtime.Serialization.Formatters.Soap\2.0.0.0__b03f5f7f11d50a3a\System.Runtime.Serialization.Formatters.Soap.dll
- 2007-12-07 04:24:42 258,048 ----a-w C:\WINDOWS\assembly\GAC_MSIL\System.Security\2.0.0.0__b03f5f7f11d50a3a\System.Security.dll
+ 2008-04-12 08:07:32 258,048 ----a-w C:\WINDOWS\assembly\GAC_MSIL\System.Security\2.0.0.0__b03f5f7f11d50a3a\System.Security.dll
- 2007-12-07 04:24:52 114,688 ----a-w C:\WINDOWS\assembly\GAC_MSIL\System.ServiceProcess\2.0.0.0__b03f5f7f11d50a3a\System.ServiceProcess.dll
+ 2008-04-12 08:07:32 114,688 ----a-w C:\WINDOWS\assembly\GAC_MSIL\System.ServiceProcess\2.0.0.0__b03f5f7f11d50a3a\System.ServiceProcess.dll
- 2007-12-07 04:25:20 835,584 ----a-w C:\WINDOWS\assembly\GAC_MSIL\System.Web.Mobile\2.0.0.0__b03f5f7f11d50a3a\System.Web.Mobile.dll
+ 2008-04-12 08:07:39 884,736 ----a-w C:\WINDOWS\assembly\GAC_MSIL\System.Web.Mobile\2.0.0.0__b03f5f7f11d50a3a\System.Web.Mobile.dll
- 2007-12-07 04:24:55 86,016 ----a-w C:\WINDOWS\assembly\GAC_MSIL\System.Web.RegularExpressions\2.0.0.0__b03f5f7f11d50a3a\System.Web.RegularExpressions.dll
+ 2008-04-12 08:07:40 90,112 ----a-w C:\WINDOWS\assembly\GAC_MSIL\System.Web.RegularExpressions\2.0.0.0__b03f5f7f11d50a3a\System.Web.RegularExpressions.dll
- 2007-12-07 04:24:56 823,296 ----a-w C:\WINDOWS\assembly\GAC_MSIL\System.Web.Services\2.0.0.0__b03f5f7f11d50a3a\System.Web.Services.dll
+ 2008-04-12 08:07:39 839,680 ----a-w C:\WINDOWS\assembly\GAC_MSIL\System.Web.Services\2.0.0.0__b03f5f7f11d50a3a\System.Web.Services.dll
- 2007-12-07 04:24:57 5,152,768 ----a-w C:\WINDOWS\assembly\GAC_MSIL\System.Windows.Forms\2.0.0.0__b77a5c561934e089\System.Windows.Forms.dll
+ 2008-04-12 08:07:42 5,013,504 ----a-w C:\WINDOWS\assembly\GAC_MSIL\System.Windows.Forms\2.0.0.0__b77a5c561934e089\System.Windows.Forms.dll
- 2007-12-07 04:24:58 2,027,520 ----a-w C:\WINDOWS\assembly\GAC_MSIL\System.Xml\2.0.0.0__b77a5c561934e089\System.XML.dll
+ 2008-04-12 08:07:34 2,068,480 ----a-w C:\WINDOWS\assembly\GAC_MSIL\System.Xml\2.0.0.0__b77a5c561934e089\System.XML.dll
- 2007-12-07 04:25:16 2,940,928 ----a-w C:\WINDOWS\assembly\GAC_MSIL\System\2.0.0.0__b77a5c561934e089\System.dll
+ 2008-04-12 08:07:38 3,076,096 ----a-w C:\WINDOWS\assembly\GAC_MSIL\System\2.0.0.0__b77a5c561934e089\System.dll
+ 2008-04-13 01:18:32 27,136 ----a-w C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\Accessibility\c6772fd12a581ad3be49e3f2a80b5622\Accessibility.ni.dll
+ 2008-04-13 01:18:37 884,736 ----a-w C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\AspNetMMCExt\a1d353edc300e3aff0784202f68a657b\AspNetMMCExt.ni.dll
+ 2008-04-13 01:18:38 237,568 ----a-w C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\CustomMarshalers\c10ec9b4de2b366236ec83237dc31281\CustomMarshalers.ni.dll
+ 2008-04-13 01:18:38 15,360 ----a-w C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\dfsvc\837fe02bdcf637d5bf1e5ffb935ebb80\dfsvc.ni.exe
+ 2008-04-13 01:18:41 876,544 ----a-w C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\Microsoft.Build.Eng#\9710a3c0d11dd264c3a6b88977699e9b\Microsoft.Build.Engine.ni.dll
+ 2008-04-13 01:18:41 81,920 ----a-w C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\Microsoft.Build.Fra#\e2858a45971fb30b0c0523dbb52c1d4e\Microsoft.Build.Framework.ni.dll
+ 2008-04-13 01:18:45 1,695,744 ----a-w C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\Microsoft.Build.Tas#\63d69ffdf3c640d2d104a4b74e8115f8\Microsoft.Build.Tasks.ni.dll
+ 2008-04-13 01:18:46 167,936 ----a-w C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\Microsoft.Build.Uti#\11cb5418c06e30100616fbf205588489\Microsoft.Build.Utilities.ni.dll
+ 2008-04-13 01:18:49 1,740,800 ----a-w C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\Microsoft.VisualBas#\923bd55258380eae77353d36a5a1b08f\Microsoft.VisualBasic.ni.dll
+ 2008-04-12 13:34:05 11,722,752 ----a-w C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\mscorlib\32e6f703c114f3a971cbe706586e3655\mscorlib.ni.dll
+ 2008-04-13 01:18:50 1,011,712 ----a-w C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\System.Configuration\eee9b48577689e92db5a7b5c5de98d9b\System.Configuration.ni.dll
+ 2008-04-12 13:35:08 7,049,216 ----a-w C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\System.Data\5f669e819da7010c1dca347a25597c42\System.Data.ni.dll
+ 2008-04-13 01:18:52 1,798,144 ----a-w C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\System.Deployment\c7dea4895e1fa33d65e448c03de48d26\System.Deployment.ni.dll
+ 2008-04-12 13:35:30 10,969,088 ----a-w C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\System.Design\c1e16b40e30a05c39be8aee46311841c\System.Design.ni.dll
+ 2008-04-13 01:18:54 1,224,704 ----a-w C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\System.DirectorySer#\914668b240550f529e54bb772c6fc881\System.DirectoryServices.ni.dll
+ 2008-04-13 01:18:55 512,000 ----a-w C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\System.DirectorySer#\f11bc82c09955cb8438d3885a99c297d\System.DirectoryServices.Protocols.ni.dll
+ 2008-04-12 13:35:33 229,376 ----a-w C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\System.Drawing.Desi#\b974f6c17d17a533adf6e7710c5a62fa\System.Drawing.Design.ni.dll
+ 2008-04-12 13:35:33 1,667,072 ----a-w C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\System.Drawing\0e83aac37b2623f1a24c70979f31dd56\System.Drawing.ni.dll
+ 2008-04-13 01:18:56 659,456 ----a-w C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\System.EnterpriseSe#\646131eda5f21f4e6216733d49c22c56\System.EnterpriseServices.ni.dll
+ 2008-04-13 01:18:56 294,912 ----a-w C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\System.EnterpriseSe#\646131eda5f21f4e6216733d49c22c56\System.EnterpriseServices.Wrapper.dll
+ 2008-04-13 01:18:58 733,184 ----a-w C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\System.Security\2b5994269cc5b996231c9b21afea9a91\System.Security.ni.dll
+ 2008-04-13 01:18:58 233,472 ----a-w C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\System.ServiceProce#\193ac978af569ad9ee45110b359961b9\System.ServiceProcess.ni.dll
+ 2008-04-13 01:19:00 679,936 ----a-w C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\System.Transactions\12e0aa1030badf4524f897e3f57b037a\System.Transactions.ni.dll
+ 2008-04-13 01:19:19 2,342,912 ----a-w C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\System.Web.Mobile\37d87b3cab1c66ec4430ebb2abeaa570\System.Web.Mobile.ni.dll
+ 2008-04-13 01:19:20 237,568 ----a-w C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\System.Web.RegularE#\b5b81faf46fc63c20d5339b36edd02fa\System.Web.RegularExpressions.ni.dll
+ 2008-04-13 01:19:23 1,986,560 ----a-w C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\System.Web.Services\38991368499e2109ea4099a0fe29c5a3\System.Web.Services.ni.dll
+ 2008-04-13 01:19:16 12,509,184 ----a-w C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\System.Web\67cfb70213562afe2ca9b9066764af3a\System.Web.ni.dll
+ 2008-04-12 13:35:57 13,193,216 ----a-w C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\System.Windows.Forms\3d8c79c45aa674e43f075e2e66b8caf5\System.Windows.Forms.ni.dll
+ 2008-04-12 13:36:10 5,771,264 ----a-w C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\System.Xml\c98cb65a79cfccb44ea727ebe4593ede\System.Xml.ni.dll
+ 2008-04-12 13:34:46 8,265,728 ----a-w C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\System\ba0e3a22211ba7343e0116b051f2965a\System.ni.dll
+ 2007-12-20 07:47:25 38,428 ----a-w C:\WINDOWS\Downloaded Program Files\unagiuninst.exe
+ 2008-06-13 13:10:50 272,128
w C:\WINDOWS\Driver Cache\i386\bthport.sys
+ 2005-10-21 03:02:28 163,328 ----a-w C:\WINDOWS\erdnt\Hiv-backup\ERDNT.EXE
- 2007-03-13 18:57:10 163,328 ----a-w C:\WINDOWS\erdnt\subs\ERDNT.EXE
+ 2005-10-21 03:02:28 163,328 ----a-w C:\WINDOWS\erdnt\subs\ERDNT.EXE
+ 2000-08-31 15:00:00 89,504 ----a-w C:\WINDOWS\fdsv.exe
+ 2000-08-31 15:00:00 80,412 ----a-w C:\WINDOWS\grep.exe
+ 2004-08-04 12:00:00 2,589
w C:\WINDOWS\I386\RUNW32.BAT
+ 2007-10-10 23:55:51 124,928 -c----w C:\WINDOWS\ie7updates\KB944533-IE7\advpack.dll
+ 2006-10-17 19:58:06 346,624 -c----w C:\WINDOWS\ie7updates\KB944533-IE7\dxtmsft.dll
+ 2007-10-10 23:55:51 214,528 -c----w C:\WINDOWS\ie7updates\KB944533-IE7\dxtrans.dll
+ 2007-10-10 23:55:51 132,608 -c----w C:\WINDOWS\ie7updates\KB944533-IE7\extmgr.dll
+ 2007-10-10 23:55:51 63,488 -c----w C:\WINDOWS\ie7updates\KB944533-IE7\icardie.dll
+ 2007-10-10 10:59:40 70,656 -c----w C:\WINDOWS\ie7updates\KB944533-IE7\ie4uinit.exe
+ 2007-10-10 23:55:51 153,088 -c----w C:\WINDOWS\ie7updates\KB944533-IE7\ieakeng.dll
+ 2007-10-10 23:55:51 230,400 -c----w C:\WINDOWS\ie7updates\KB944533-IE7\ieaksie.dll
+ 2007-10-10 05:46:55 161,792 -c----w C:\WINDOWS\ie7updates\KB944533-IE7\ieakui.dll
+ 2007-10-10 23:55:52 383,488 -c----w C:\WINDOWS\ie7updates\KB944533-IE7\ieapfltr.dll
+ 2007-10-10 23:55:52 384,512 -c----w C:\WINDOWS\ie7updates\KB944533-IE7\iedkcs32.dll
+ 2007-10-10 23:55:54 6,065,664 -c----w C:\WINDOWS\ie7updates\KB944533-IE7\ieframe.dll
+ 2007-10-10 23:55:55 44,544 -c----w C:\WINDOWS\ie7updates\KB944533-IE7\iernonce.dll
+ 2007-10-10 23:55:55 267,776 -c----w C:\WINDOWS\ie7updates\KB944533-IE7\iertutil.dll
+ 2007-10-10 10:59:40 13,824 -c----w C:\WINDOWS\ie7updates\KB944533-IE7\ieudinit.exe
+ 2007-10-10 10:59:52 625,152 -c----w C:\WINDOWS\ie7updates\KB944533-IE7\iexplore.exe
+ 2007-10-10 23:55:56 27,648 -c----w C:\WINDOWS\ie7updates\KB944533-IE7\jsproxy.dll
+ 2007-10-10 23:55:56 459,264 -c----w C:\WINDOWS\ie7updates\KB944533-IE7\msfeeds.dll
+ 2007-10-10 23:55:56 52,224 -c----w C:\WINDOWS\ie7updates\KB944533-IE7\msfeedsbs.dll
+ 2007-10-30 23:42:28 3,590,656 -c----w C:\WINDOWS\ie7updates\KB944533-IE7\mshtml.dll
+ 2007-10-10 23:55:58 478,208 -c----w C:\WINDOWS\ie7updates\KB944533-IE7\mshtmled.dll
+ 2007-10-10 23:55:58 193,024 -c----w C:\WINDOWS\ie7updates\KB944533-IE7\msrating.dll
+ 2007-10-10 23:55:59 671,232 -c----w C:\WINDOWS\ie7updates\KB944533-IE7\mstime.dll
+ 2007-10-10 23:55:59 102,400 -c----w C:\WINDOWS\ie7updates\KB944533-IE7\occache.dll
+ 2006-10-17 19:58:08 44,544 -c----w C:\WINDOWS\ie7updates\KB944533-IE7\pngfilt.dll
+ 2007-03-06 01:22:41 213,216 -c----w C:\WINDOWS\ie7updates\KB944533-IE7\spuninst\spuninst.exe
+ 2007-03-06 01:23:51 371,424 -c----w C:\WINDOWS\ie7updates\KB944533-IE7\spuninst\updspapi.dll
+ 2007-10-10 23:55:59 105,984 -c----w C:\WINDOWS\ie7updates\KB944533-IE7\url.dll
+ 2007-10-10 23:56:00 1,159,680 -c----w C:\WINDOWS\ie7updates\KB944533-IE7\urlmon.dll
+ 2007-10-10 23:56:00 232,960 -c----w C:\WINDOWS\ie7updates\KB944533-IE7\webcheck.dll
+ 2007-10-10 23:56:00 824,832 -c----w C:\WINDOWS\ie7updates\KB944533-IE7\wininet.dll
+ 2007-12-07 02:21:45 124,928 -c----w C:\WINDOWS\ie7updates\KB947864-IE7\advpack.dll
+ 2007-12-19 23:01:06 347,136 -c----w C:\WINDOWS\ie7updates\KB947864-IE7\dxtmsft.dll
+ 2007-12-07 02:21:45 214,528 -c----w C:\WINDOWS\ie7updates\KB947864-IE7\dxtrans.dll
+ 2007-12-07 02:21:45 133,120 -c----w C:\WINDOWS\ie7updates\KB947864-IE7\extmgr.dll
+ 2007-12-07 02:21:45 63,488 -c----w C:\WINDOWS\ie7updates\KB947864-IE7\icardie.dll
+ 2007-12-06 11:00:57 70,656 -c----w C:\WINDOWS\ie7updates\KB947864-IE7\ie4uinit.exe
+ 2007-12-07 02:21:45 153,088 -c----w C:\WINDOWS\ie7updates\KB947864-IE7\ieakeng.dll
+ 2007-12-07 02:21:45 230,400 -c----w C:\WINDOWS\ie7updates\KB947864-IE7\ieaksie.dll
+ 2007-12-06 04:59:51 161,792 -c----w C:\WINDOWS\ie7updates\KB947864-IE7\ieakui.dll
+ 2007-12-07 02:21:45 383,488 -c----w C:\WINDOWS\ie7updates\KB947864-IE7\ieapfltr.dll
+ 2007-12-07 02:21:45 384,512 -c----w C:\WINDOWS\ie7updates\KB947864-IE7\iedkcs32.dll
+ 2007-12-07 02:21:46 6,066,176 -c----w C:\WINDOWS\ie7updates\KB947864-IE7\ieframe.dll
+ 2007-12-07 02:21:46 44,544 -c----w C:\WINDOWS\ie7updates\KB947864-IE7\iernonce.dll
+ 2007-12-07 02:21:46 267,776 -c----w C:\WINDOWS\ie7updates\KB947864-IE7\iertutil.dll
+ 2007-12-06 11:00:58 13,824 -c----w C:\WINDOWS\ie7updates\KB947864-IE7\ieudinit.exe
+ 2007-12-06 11:01:25 625,664 -c----w C:\WINDOWS\ie7updates\KB947864-IE7\iexplore.exe
+ 2007-12-07 02:21:47 27,648 -c----w C:\WINDOWS\ie7updates\KB947864-IE7\jsproxy.dll
+ 2007-12-07 02:21:47 459,264 -c----w C:\WINDOWS\ie7updates\KB947864-IE7\msfeeds.dll
+ 2007-12-07 02:21:47 52,224 -c----w C:\WINDOWS\ie7updates\KB947864-IE7\msfeedsbs.dll
+ 2007-12-08 05:21:48 3,592,192 -c----w C:\WINDOWS\ie7updates\KB947864-IE7\mshtml.dll
+ 2007-12-07 02:21:47 478,208 -c----w C:\WINDOWS\ie7updates\KB947864-IE7\mshtmled.dll
+ 2007-12-07 02:21:48 193,024 -c----w C:\WINDOWS\ie7updates\KB947864-IE7\msrating.dll
+ 2007-12-07 02:21:48 671,232 -c----w C:\WINDOWS\ie7updates\KB947864-IE7\mstime.dll
+ 2007-12-07 02:21:48 102,912 -c----w C:\WINDOWS\ie7updates\KB947864-IE7\occache.dll
+ 2008-01-11 05:53:32 44,544 -c----w C:\WINDOWS\ie7updates\KB947864-IE7\pngfilt.dll
+ 2007-03-06 01:22:39 213,216 -c----w C:\WINDOWS\ie7updates\KB947864-IE7\spuninst\spuninst.exe
+ 2007-03-06 01:23:51 371,424 -c----w C:\WINDOWS\ie7updates\KB947864-IE7\spuninst\updspapi.dll
+ 2007-12-07 02:21:48 105,984 -c----w C:\WINDOWS\ie7updates\KB947864-IE7\url.dll
+ 2007-12-07 02:21:48 1,159,680 -c----w C:\WINDOWS\ie7updates\KB947864-IE7\urlmon.dll
+ 2007-12-07 02:21:48 233,472 -c----w C:\WINDOWS\ie7updates\KB947864-IE7\webcheck.dll
+ 2007-12-07 02:21:48 824,832 -c----w C:\WINDOWS\ie7updates\KB947864-IE7\wininet.dll
+ 2008-03-01 13:06:20 124,928 -c----w C:\WINDOWS\ie7updates\KB950759-IE7\advpack.dll
+ 2008-03-01 13:06:21 347,136 -c----w C:\WINDOWS\ie7updates\KB950759-IE7\dxtmsft.dll
+ 2008-03-01 13:06:21 214,528 -c----w C:\WINDOWS\ie7updates\KB950759-IE7\dxtrans.dll
+ 2008-03-01 13:06:21 133,120 -c----w C:\WINDOWS\ie7updates\KB950759-IE7\extmgr.dll
+ 2008-03-01 13:06:21 63,488 -c----w C:\WINDOWS\ie7updates\KB950759-IE7\icardie.dll
+ 2008-02-29 08:55:23 70,656 -c----w C:\WINDOWS\ie7updates\KB950759-IE7\ie4uinit.exe
+ 2008-03-01 13:06:21 153,088 -c----w C:\WINDOWS\ie7updates\KB950759-IE7\ieakeng.dll
+ 2008-03-01 13:06:21 230,400 -c----w C:\WINDOWS\ie7updates\KB950759-IE7\ieaksie.dll
+ 2008-02-15 05:44:25 161,792 -c----w C:\WINDOWS\ie7updates\KB950759-IE7\ieakui.dll
+ 2008-03-01 13:06:22 383,488 -c----w C:\WINDOWS\ie7updates\KB950759-IE7\ieapfltr.dll
+ 2008-03-01 13:06:22 384,512 -c----w C:\WINDOWS\ie7updates\KB950759-IE7\iedkcs32.dll
+ 2008-03-01 13:06:24 6,066,176 -c----w C:\WINDOWS\ie7updates\KB950759-IE7\ieframe.dll
+ 2008-03-01 13:06:24 44,544 -c----w C:\WINDOWS\ie7updates\KB950759-IE7\iernonce.dll
+ 2008-03-01 13:06:25 267,776 -c----w C:\WINDOWS\ie7updates\KB950759-IE7\iertutil.dll
+ 2008-02-22 10:00:51 13,824 -c----w C:\WINDOWS\ie7updates\KB950759-IE7\ieudinit.exe
+ 2008-02-29 08:55:46 625,664 -c----w C:\WINDOWS\ie7updates\KB950759-IE7\iexplore.exe
+ 2008-03-01 13:06:25 27,648 -c----w C:\WINDOWS\ie7updates\KB950759-IE7\jsproxy.dll
+ 2008-03-01 13:06:26 459,264 -c----w C:\WINDOWS\ie7updates\KB950759-IE7\msfeeds.dll
+ 2008-03-01 13:06:26 52,224 -c----w C:\WINDOWS\ie7updates\KB950759-IE7\msfeedsbs.dll
+ 2008-03-02 01:36:30 3,591,680 -c----w C:\WINDOWS\ie7updates\KB950759-IE7\mshtml.dll
+ 2008-03-01 13:06:28 478,208 -c----w C:\WINDOWS\ie7updates\KB950759-IE7\mshtmled.dll
+ 2008-03-01 13:06:28 193,024 -c----w C:\WINDOWS\ie7updates\KB950759-IE7\msrating.dll
+ 2008-03-01 13:06:29 671,232 -c----w C:\WINDOWS\ie7updates\KB950759-IE7\mstime.dll
+ 2008-03-01 13:06:29 102,912 -c----w C:\WINDOWS\ie7updates\KB950759-IE7\occache.dll
+ 2008-03-01 13:06:29 44,544 -c----w C:\WINDOWS\ie7updates\KB950759-IE7\pngfilt.dll
+ 2007-03-06 01:22:39 213,216 -c----w C:\WINDOWS\ie7updates\KB950759-IE7\spuninst\spuninst.exe
+ 2007-03-06 01:23:51 371,424 -c----w C:\WINDOWS\ie7updates\KB950759-IE7\spuninst\updspapi.dll
+ 2008-03-01 13:06:29 105,984 -c----w C:\WINDOWS\ie7updates\KB950759-IE7\url.dll
+ 2008-03-01 13:06:30 1,159,680 -c----w C:\WINDOWS\ie7updates\KB950759-IE7\urlmon.dll
+ 2008-03-01 13:06:30 233,472 -c----w C:\WINDOWS\ie7updates\KB950759-IE7\webcheck.dll
+ 2008-03-01 13:06:31 826,368 -c----w C:\WINDOWS\ie7updates\KB950759-IE7\wininet.dll
+ 2008-04-23 04:16:28 124,928 -c----w C:\WINDOWS\ie7updates\KB953838-IE7\advpack.dll
+ 2008-04-23 04:16:28 347,136 -c----w C:\WINDOWS\ie7updates\KB953838-IE7\dxtmsft.dll
+ 2008-04-23 04:16:28 214,528 -c----w C:\WINDOWS\ie7updates\KB953838-IE7\dxtrans.dll
+ 2008-04-23 04:16:28 133,120 -c----w C:\WINDOWS\ie7updates\KB953838-IE7\extmgr.dll
+ 2008-04-23 04:16:28 63,488 -c----w C:\WINDOWS\ie7updates\KB953838-IE7\icardie.dll
+ 2008-04-22 07:39:58 70,656 -c----w C:\WINDOWS\ie7updates\KB953838-IE7\ie4uinit.exe
+ 2008-04-23 04:16:28 153,088 -c----w C:\WINDOWS\ie7updates\KB953838-IE7\ieakeng.dll
+ 2008-04-23 04:16:28 230,400 -c----w C:\WINDOWS\ie7updates\KB953838-IE7\ieaksie.dll
+ 2008-04-20 05:07:51 161,792 -c----w C:\WINDOWS\ie7updates\KB953838-IE7\ieakui.dll
+ 2008-04-23 04:16:28 383,488 -c----w C:\WINDOWS\ie7updates\KB953838-IE7\ieapfltr.dll
+ 2008-04-23 04:16:28 384,512 -c----w C:\WINDOWS\ie7updates\KB953838-IE7\iedkcs32.dll
+ 2008-04-23 04:16:28 6,066,176 -c----w C:\WINDOWS\ie7updates\KB953838-IE7\ieframe.dll
+ 2008-04-23 04:16:28 44,544 -c----w C:\WINDOWS\ie7updates\KB953838-IE7\iernonce.dll
+ 2008-04-23 04:16:28 267,776 -c----w C:\WINDOWS\ie7updates\KB953838-IE7\iertutil.dll
+ 2008-04-22 07:39:58 13,824 -c----w C:\WINDOWS\ie7updates\KB953838-IE7\ieudinit.exe
+ 2008-04-22 07:40:18 625,664 -c----w C:\WINDOWS\ie7updates\KB953838-IE7\iexplore.exe
+ 2008-04-23 04:16:28 27,648 -c----w C:\WINDOWS\ie7updates\KB953838-IE7\jsproxy.dll
+ 2008-04-23 04:16:28 459,264 -c----w C:\WINDOWS\ie7updates\KB953838-IE7\msfeeds.dll
+ 2008-04-23 04:16:28 52,224 -c----w C:\WINDOWS\ie7updates\KB953838-IE7\msfeedsbs.dll
+ 2008-04-24 05:16:30 3,591,680 -c----w C:\WINDOWS\ie7updates\KB953838-IE7\mshtml.dll
+ 2008-04-23 04:16:28 478,208 -c----w C:\WINDOWS\ie7updates\KB953838-IE7\mshtmled.dll
+ 2008-04-23 04:16:28 193,024 -c----w C:\WINDOWS\ie7updates\KB953838-IE7\msrating.dll
+ 2008-04-23 04:16:28 671,232 -c----w C:\WINDOWS\ie7updates\KB953838-IE7\mstime.dll
+ 2008-04-23 04:16:28 102,912 -c----w C:\WINDOWS\ie7updates\KB953838-IE7\occache.dll
+ 2008-04-23 04:16:28 44,544 -c----w C:\WINDOWS\ie7updates\KB953838-IE7\pngfilt.dll
+ 2007-03-06 01:22:39 213,216 -c----w C:\WINDOWS\ie7updates\KB953838-IE7\spuninst\spuninst.exe
+ 2007-03-06 01:23:51 371,424 -c----w C:\WINDOWS\ie7updates\KB953838-IE7\spuninst\updspapi.dll
+ 2008-04-23 04:16:28 105,984 -c----w C:\WINDOWS\ie7updates\KB953838-IE7\url.dll
+ 2008-04-23 04:16:29 1,159,680 -c----w C:\WINDOWS\ie7updates\KB953838-IE7\urlmon.dll
+ 2008-04-23 04:16:29 233,472 -c----w C:\WINDOWS\ie7updates\KB953838-IE7\webcheck.dll
+ 2008-04-23 04:16:29 826,368 -c----w C:\WINDOWS\ie7updates\KB953838-IE7\wininet.dll
+ 2008-08-06 16:35:10 27,136 ----a-r C:\WINDOWS\Installer\{6956856F-B6B3-4BE0-BA0B-8F495BE32033}\AppleSoftwareUpdateIco.exe
+ 2008-09-11 07:35:35 86,016 ----a-r C:\WINDOWS\Installer\{8A25392D-C5D2-4E79-A2BD-C15DDC5B0959}\PrntWzrdIco.exe
- 2007-01-23 06:36:39 167,936 ----a-r C:\WINDOWS\Installer\{90110409-6000-11D3-8CFE-0050048383C9}\accicons.exe
+ 2008-09-18 08:40:28 167,936 ----a-r C:\WINDOWS\Installer\{90110409-6000-11D3-8CFE-0050048383C9}\accicons.exe
+ 2008-09-18 08:40:29 2,560 ----a-r C:\WINDOWS\Installer\{90110409-6000-11D3-8CFE-0050048383C9}\cagicon.exe
- 2007-01-23 06:36:39 34,304 ----a-r C:\WINDOWS\Installer\{90110409-6000-11D3-8CFE-0050048383C9}\misc.exe
+ 2008-09-18 08:40:27 34,304 ----a-r C:\WINDOWS\Installer\{90110409-6000-11D3-8CFE-0050048383C9}\misc.exe
- 2007-01-23 06:36:40 8,192 ----a-r C:\WINDOWS\Installer\{90110409-6000-11D3-8CFE-0050048383C9}\mspicons.exe
+ 2008-09-18 08:40:29 8,192 ----a-r C:\WINDOWS\Installer\{90110409-6000-11D3-8CFE-0050048383C9}\mspicons.exe
- 2007-01-23 06:36:40 3,584 ----a-r C:\WINDOWS\Installer\{90110409-6000-11D3-8CFE-0050048383C9}\opwicon.exe
+ 2008-09-18 08:40:29 3,584 ----a-r C:\WINDOWS\Installer\{90110409-6000-11D3-8CFE-0050048383C9}\opwicon.exe
- 2007-01-23 06:36:40 114,688 ----a-r C:\WINDOWS\Installer\{90110409-6000-11D3-8CFE-0050048383C9}\outicon.exe
+ 2008-09-18 08:40:29 114,688 ----a-r C:\WINDOWS\Installer\{90110409-6000-11D3-8CFE-0050048383C9}\outicon.exe
- 2007-01-23 06:36:39 16,384 ----a-r C:\WINDOWS\Installer\{90110409-6000-11D3-8CFE-0050048383C9}\PEicons.exe
+ 2008-09-18 08:40:28 16,384 ----a-r C:\WINDOWS\Installer\{90110409-6000-11D3-8CFE-0050048383C9}\PEicons.exe
- 2007-01-23 06:36:39 30,720 ----a-r C:\WINDOWS\Installer\{90110409-6000-11D3-8CFE-0050048383C9}\pptico.exe
+ 2008-09-18 08:40:28 30,720 ----a-r C:\WINDOWS\Installer\{90110409-6000-11D3-8CFE-0050048383C9}\pptico.exe
- 2007-01-23 06:36:40 22,528 ----a-r C:\WINDOWS\Installer\{90110409-6000-11D3-8CFE-0050048383C9}\unbndico.exe
+ 2008-09-18 08:40:30 22,528 ----a-r C:\WINDOWS\Installer\{90110409-6000-11D3-8CFE-0050048383C9}\unbndico.exe
- 2007-01-23 06:36:39 45,056 ----a-r C:\WINDOWS\Installer\{90110409-6000-11D3-8CFE-0050048383C9}\wordicon.exe
+ 2008-09-18 08:40:27 45,056 ----a-r C:\WINDOWS\Installer\{90110409-6000-11D3-8CFE-0050048383C9}\wordicon.exe
- 2007-01-23 06:36:39 90,112 ----a-r C:\WINDOWS\Installer\{90110409-6000-11D3-8CFE-0050048383C9}\xlicons.exe
+ 2008-09-18 08:40:27 90,112 ----a-r C:\WINDOWS\Installer\{90110409-6000-11D3-8CFE-0050048383C9}\xlicons.exe
- 2006-11-19 02:56:31 12,288 ----a-r C:\WINDOWS\Installer\{91120409-6000-11D3-8CFE-0150048383C9}\cagicon.exe
+ 2008-08-01 00:13:05 12,288 ----a-r C:\WINDOWS\Installer\{91120409-6000-11D3-8CFE-0150048383C9}\cagicon.exe
- 2006-11-19 02:56:31 135,168 ----a-r C:\WINDOWS\Installer\{91120409-6000-11D3-8CFE-0150048383C9}\misc.exe
+ 2008-08-01 00:13:05 135,168 ----a-r C:\WINDOWS\Installer\{91120409-6000-11D3-8CFE-0150048383C9}\misc.exe
- 2006-11-19 02:56:31 11,264 ----a-r C:\WINDOWS\Installer\{91120409-6000-11D3-8CFE-0150048383C9}\mspicons.exe
+ 2008-08-01 00:13:05 11,264 ----a-r C:\WINDOWS\Installer\{91120409-6000-11D3-8CFE-0150048383C9}\mspicons.exe
- 2006-11-19 02:56:31 27,136 ----a-r C:\WINDOWS\Installer\{91120409-6000-11D3-8CFE-0150048383C9}\oisicon.exe
+ 2008-08-01 00:13:05 27,136 ----a-r C:\WINDOWS\Installer\{91120409-6000-11D3-8CFE-0150048383C9}\oisicon.exe
- 2006-11-19 02:56:31 4,096 ----a-r C:\WINDOWS\Installer\{91120409-6000-11D3-8CFE-0150048383C9}\opwicon.exe
+ 2008-08-01 00:13:05 4,096 ----a-r C:\WINDOWS\Installer\{91120409-6000-11D3-8CFE-0150048383C9}\opwicon.exe
- 2006-11-19 02:56:31 794,624 ----a-r C:\WINDOWS\Installer\{91120409-6000-11D3-8CFE-0150048383C9}\outicon.exe
+ 2008-08-01 00:13:05 794,624 ----a-r C:\WINDOWS\Installer\{91120409-6000-11D3-8CFE-0150048383C9}\outicon.exe
- 2006-11-19 02:56:31 249,856 ----a-r C:\WINDOWS\Installer\{91120409-6000-11D3-8CFE-0150048383C9}\pptico.exe
+ 2008-08-01 00:13:05 249,856 ----a-r C:\WINDOWS\Installer\{91120409-6000-11D3-8CFE-0150048383C9}\pptico.exe
- 2006-11-19 02:56:32 23,040 ----a-r C:\WINDOWS\Installer\{91120409-6000-11D3-8CFE-0150048383C9}\unbndico.exe
+ 2008-08-01 00:13:05 23,040 ----a-r C:\WINDOWS\Installer\{91120409-6000-11D3-8CFE-0150048383C9}\unbndico.exe
- 2006-11-19 02:56:30 286,720 ----a-r C:\WINDOWS\Installer\{91120409-6000-11D3-8CFE-0150048383C9}\wordicon.exe
+ 2008-08-01 00:13:05 286,720 ----a-r C:\WINDOWS\Installer\{91120409-6000-11D3-8CFE-0150048383C9}\wordicon.exe
- 2006-11-19 02:56:30 409,600 ----a-r C:\WINDOWS\Installer\{91120409-6000-11D3-8CFE-0150048383C9}\xlicons.exe
+ 2008-08-01 00:13:05 409,600 ----a-r C:\WINDOWS\Installer\{91120409-6000-11D3-8CFE-0150048383C9}\xlicons.exe
+ 2008-02-11 18:38:07 295,606 ----a-r C:\WINDOWS\Installer\{AC76BA86-7AD7-1033-7B44-A81200000003}\SC_Reader.exe
+ 2008-07-31 07:20:26 307,200 ----a-r C:\WINDOWS\Installer\{C9D96682-5A4D-45FA-BA3E-DDCB2B0CB868}\SafariIco.exe
+ 2008-09-27 19:24:08 632,320 ----a-r C:\WINDOWS\Installer\{CD95F661-A5C4-44F5-A6AA-ECDD91C240B7}\IconCD95F66110.exe
+ 2008-09-27 19:24:08 29,184 ----a-r C:\WINDOWS\Installer\{CD95F661-A5C4-44F5-A6AA-ECDD91C240B7}\IconCD95F6617.exe
+ 2008-03-19 02:40:43 441,406 ----a-r C:\WINDOWS\Installer\{E3993D46-AE3F-402E-9F9D-EEBDFBEC3564}\ARPPRODUCTICON.exe
+ 2008-09-11 07:37:56 102,400 ----a-r C:\WINDOWS\Installer\{EA418519-2160-43A0-AABD-6608DDD8D87F}\iTunesIco.exe
+ 2006-12-14 03:01:56 2,678 ----a-w C:\WINDOWS\java\Packages\Data\5Z5RZVZR.DAT
+ 2006-12-14 03:01:55 2,678 ----a-w C:\WINDOWS\java\Packages\Data\BBZDJH37.DAT
+ 2006-12-14 03:01:54 2,678 ----a-w C:\WINDOWS\java\Packages\Data\KS9VLBXJ.DAT
+ 2006-12-14 03:02:03 2,678 ----a-w C:\WINDOWS\java\Packages\Data\N1RVJ575.DAT
+ 2006-12-07 04:47:46 2,232 ----a-w C:\WINDOWS\java\Packages\Data\TZL7HRXZ.DAT
+ 2007-07-31 03:19:20 92,504 ----a-w C:\WINDOWS\LastGood\system32\cdm.dll
+ 2007-07-31 03:19:36 549,720 ----a-w C:\WINDOWS\LastGood\system32\wuapi.dll
+ 2007-07-31 03:19:16 53,080 ----a-w C:\WINDOWS\LastGood\system32\wuauclt.exe
+ 2007-07-31 03:19:42 1,712,984 ----a-w C:\WINDOWS\LastGood\system32\wuaueng.dll
+ 2007-07-31 03:19:32 325,976 ----a-w C:\WINDOWS\LastGood\system32\wucltui.dll
+ 2007-07-31 03:18:40 33,624 ----a-w C:\WINDOWS\LastGood\system32\wups.dll
+ 2007-07-31 03:19:12 43,352 ----a-w C:\WINDOWS\LastGood\system32\wups2.dll
+ 2007-07-31 03:19:28 203,096 ----a-w C:\WINDOWS\LastGood\system32\wuweb.dll
+ 2005-03-18 23:23:10 53,248 ----a-w C:\WINDOWS\Microsoft.NET\DirectX for Managed Code\1.0.2902.0\Microsoft.DirectX.AudioVideoPlayback.dll
+ 2005-03-18 23:23:10 12,800 ----a-w C:\WINDOWS\Microsoft.NET\DirectX for Managed Code\1.0.2902.0\Microsoft.DirectX.Diagnostics.dll
+ 2005-03-18 23:23:14 473,600 ----a-w C:\WINDOWS\Microsoft.NET\DirectX for Managed Code\1.0.2902.0\Microsoft.DirectX.Direct3D.dll
+ 2004-09-29 19:38:58 2,676,224 ----a-w C:\WINDOWS\Microsoft.NET\DirectX for Managed Code\1.0.2902.0\Microsoft.DirectX.Direct3DX.dll
+ 2005-03-18 23:23:10 145,920 ----a-w C:\WINDOWS\Microsoft.NET\DirectX for Managed Code\1.0.2902.0\Microsoft.DirectX.DirectDraw.dll
+ 2005-03-18 23:23:10 159,232 ----a-w C:\WINDOWS\Microsoft.NET\DirectX for Managed Code\1.0.2902.0\Microsoft.DirectX.DirectInput.dll
+ 2005-03-18 23:23:14 364,544 ----a-w C:\WINDOWS\Microsoft.NET\DirectX for Managed Code\1.0.2902.0\Microsoft.DirectX.DirectPlay.dll
+ 2005-03-18 23:23:12 178,176 ----a-w C:\WINDOWS\Microsoft.NET\DirectX for Managed Code\1.0.2902.0\Microsoft.DirectX.DirectSound.dll
+ 2005-03-18 23:23:14 223,232 ----a-w C:\WINDOWS\Microsoft.NET\DirectX for Managed Code\1.0.2902.0\Microsoft.DirectX.dll
+ 2004-12-01 22:53:06 2,846,720 ----a-w C:\WINDOWS\Microsoft.NET\DirectX for Managed Code\1.0.2903.0\Microsoft.DirectX.Direct3DX.dll
+ 2005-02-06 02:32:54 563,712 ----a-w C:\WINDOWS\Microsoft.NET\DirectX for Managed Code\1.0.2904.0\Microsoft.DirectX.Direct3DX.dll
+ 2005-03-19 00:23:14 567,296 ----a-w C:\WINDOWS\Microsoft.NET\DirectX for Managed Code\1.0.2905.0\Microsoft.DirectX.Direct3DX.dll
+ 2005-05-26 22:15:56 576,000 ----a-w C:\WINDOWS\Microsoft.NET\DirectX for Managed Code\1.0.2906.0\Microsoft.DirectX.Direct3DX.dll
+ 2005-07-23 00:21:34 577,024 ----a-w C:\WINDOWS\Microsoft.NET\DirectX for Managed Code\1.0.2907.0\Microsoft.DirectX.Direct3DX.dll
+ 2005-09-28 21:11:52 577,536 ----a-w C:\WINDOWS\Microsoft.NET\DirectX for Managed Code\1.0.2908.0\Microsoft.DirectX.Direct3DX.dll
+ 2005-12-06 00:20:50 577,536 ----a-w C:\WINDOWS\Microsoft.NET\DirectX for Managed Code\1.0.2909.0\Microsoft.DirectX.Direct3DX.dll
+ 2006-02-03 14:40:48 578,560 ----a-w C:\WINDOWS\Microsoft.NET\DirectX for Managed Code\1.0.2910.0\Microsoft.DirectX.Direct3DX.dll
+ 2006-03-31 18:27:50 578,560 ----a-w C:\WINDOWS\Microsoft.NET\DirectX for Managed Code\1.0.2911.0\Microsoft.DirectX.Direct3DX.dll
- 2005-09-23 14:28:52 72,704 ----a-w C:\WINDOWS\Microsoft.NET\Framework\NETFXSBS10.exe
+ 2007-10-24 08:47:38 82,944 ----a-w C:\WINDOWS\Microsoft.NET\Framework\NETFXSBS10.exe
- 2005-09-23 14:28:52 7,680 ----a-w C:\WINDOWS\Microsoft.NET\Framework\sbscmp10.dll
+ 2007-10-24 08:47:38 16,896 ----a-w C:\WINDOWS\Microsoft.NET\Framework\sbscmp10.dll
- 2005-09-23 14:28:56 7,680 ----a-w C:\WINDOWS\Microsoft.NET\Framework\sbscmp20_mscorwks.dll
+ 2007-10-24 08:47:40 16,896 ----a-w C:\WINDOWS\Microsoft.NET\Framework\sbscmp20_mscorwks.dll
- 2005-09-23 14:28:58 7,680 ----a-w C:\WINDOWS\Microsoft.NET\Framework\sbscmp20_perfcounter.dll
+ 2007-10-24 08:47:42 16,896 ----a-w C:\WINDOWS\Microsoft.NET\Framework\sbscmp20_perfcounter.dll
- 2005-09-23 14:28:56 7,680 ----a-w C:\WINDOWS\Microsoft.NET\Framework\SharedReg12.dll
+ 2007-10-24 08:47:40 16,896 ----a-w C:\WINDOWS\Microsoft.NET\Framework\SharedReg12.dll
- 2005-09-23 14:28:52 86,528 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v1.0.3705\mscormmc.dll
+ 2007-10-24 08:47:38 97,280 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v1.0.3705\mscormmc.dll
- 2005-09-23 14:28:36 18,944 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\1033\alinkui.dll
+ 2007-10-24 08:47:26 28,672 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\1033\alinkui.dll
- 2005-09-23 14:28:42 136,192 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\1033\cscompui.dll
+ 2007-10-24 08:47:30 145,408 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\1033\cscompui.dll
- 2005-09-23 14:28:44 4,608 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\1033\CvtResUI.dll
+ 2007-10-24 08:47:32 13,824 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\1033\CvtResUI.dll
- 2005-09-23 14:29:04 183,808 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\1033\vbc7ui.dll
+ 2007-10-24 08:47:48 193,016 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\1033\vbc7ui.dll
- 2005-09-23 14:28:28 208,896 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\1033\Vsavb7rtUI.dll
+ 2007-10-24 08:47:20 218,112 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\1033\Vsavb7rtUI.dll
- 2005-09-23 14:28:56 10,752 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\Accessibility.dll
+ 2007-10-24 08:47:40 10,752 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\Accessibility.dll
- 2005-09-23 14:28:58 138,240 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\AdoNetDiag.dll
+ 2007-10-24 08:47:42 147,968 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\AdoNetDiag.dll
- 2005-09-23 14:28:36 87,552 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\alink.dll
+ 2007-10-24 08:47:26 99,320 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\alink.dll
- 2007-04-13 11:21:18 58,712 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\AppLaunch.exe
+ 2007-10-24 08:47:42 59,392 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\AppLaunch.exe
- 2005-09-23 14:28:32 36,864 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\aspnet_compiler.exe
+ 2007-10-24 08:47:22 36,864 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\aspnet_compiler.exe
- 2007-04-13 11:20:52 10,752 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\aspnet_filter.dll
+ 2007-10-24 08:47:22 22,024 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\aspnet_filter.dll
- 2007-04-13 11:20:52 8,192 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\aspnet_isapi.dll
+ 2007-10-24 08:47:22 17,928 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\aspnet_isapi.dll
- 2007-04-13 11:20:52 23,552 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\Aspnet_perf.dll
+ 2007-10-24 08:47:22 33,288 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\Aspnet_perf.dll
- 2007-04-13 11:20:50 75,264 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\aspnet_rc.dll
+ 2007-10-24 08:47:22 84,480 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\aspnet_rc.dll
- 2005-09-23 14:28:32 13,824 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\aspnet_regbrowsers.exe
+ 2007-10-24 08:47:22 24,576 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\aspnet_regbrowsers.exe
- 2007-04-13 11:20:52 32,608 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\aspnet_regiis.exe
+ 2007-10-24 08:47:22 32,776 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\aspnet_regiis.exe
- 2005-09-23 14:28:32 106,496 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\aspnet_regsql.exe
+ 2007-10-24 08:47:22 106,496 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\aspnet_regsql.exe
- 2007-04-13 11:20:52 33,632 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\aspnet_state.exe
+ 2007-10-24 08:47:22 33,800 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\aspnet_state.exe
- 2007-04-13 11:20:52 32,600 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\aspnet_wp.exe
+ 2007-10-24 08:47:22 33,280 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\aspnet_wp.exe
- 2007-04-13 11:20:52 507,904 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\AspNetMMCExt.dll
+ 2007-10-24 08:47:22 507,904 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\AspNetMMCExt.dll
- 2005-09-23 14:28:56 106,496 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\CasPol.exe
+ 2007-10-24 08:47:40 106,496 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\CasPol.exe
- 2007-04-13 11:21:16 88,576 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\CORPerfMonExt.dll
+ 2007-10-24 08:47:40 101,896 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\CORPerfMonExt.dll
- 2005-09-23 14:28:42 76,984 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\csc.exe
+ 2007-10-24 08:47:30 80,376 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\csc.exe
- 2005-09-23 14:28:42 1,144,832 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\cscomp.dll
+ 2007-10-24 08:47:30 1,162,744 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\cscomp.dll
- 2005-09-23 14:28:42 13,312 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\cscompmgd.dll
+ 2007-10-24 08:47:30 13,312 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\cscompmgd.dll
- 2005-09-23 14:28:58 17,920 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\Culture.dll
+ 2007-10-24 08:47:42 27,136 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\Culture.dll
- 2005-09-23 14:28:56 68,608 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\CustomMarshalers.dll
+ 2007-10-24 08:47:40 69,120 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\CustomMarshalers.dll
- 2005-09-23 14:28:44 31,936 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\cvtres.exe
+ 2007-10-24 08:47:30 35,320 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\cvtres.exe
- 2005-09-23 14:28:38 52,736 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\dfdll.dll
+ 2007-10-24 08:47:28 66,552 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\dfdll.dll
- 2007-04-13 11:20:58 5,120 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\dfsvc.exe
+ 2007-10-24 08:47:28 5,120 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\dfsvc.exe
- 2005-09-23 14:29:12 547,840 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\diasymreader.dll
+ 2007-10-24 08:47:54 572,936 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\diasymreader.dll
- 2005-09-23 14:28:56 788,992 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\EventLogMessages.dll
+ 2007-10-24 08:47:40 798,224 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\EventLogMessages.dll
- 2005-09-23 14:28:50 9,216 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\fusion.dll
+ 2007-10-24 08:47:36 18,936 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\fusion.dll
- 2007-04-13 11:21:16 9,728 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\IEExec.exe
+ 2007-10-24 08:47:40 9,728 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\IEExec.exe
- 2005-09-23 14:28:56 8,192 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\IEExecRemote.dll
+ 2007-10-24 08:47:40 8,192 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\IEExecRemote.dll
- 2005-09-23 14:28:56 36,864 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\IEHost.dll
+ 2007-10-24 08:47:40 77,824 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\IEHost.dll
- 2005-09-23 14:28:56 5,632 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\IIEHost.dll
+ 2007-10-24 08:47:40 6,656 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\IIEHost.dll
- 2007-04-13 11:21:16 228,688 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\ilasm.exe
+ 2007-10-24 08:47:40 230,904 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\ilasm.exe
- 2007-04-13 11:21:16 28,672 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\InstallUtil.exe
+ 2007-10-24 08:47:40 28,672 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\InstallUtil.exe
- 2005-09-23 14:28:56 55,296 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\InstallUtilLib.dll
+ 2007-10-24 08:47:40 65,032 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\InstallUtilLib.dll
- 2005-09-23 14:28:56 72,192 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\ISymWrapper.dll
+ 2007-10-24 08:47:40 72,192 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\ISymWrapper.dll
- 2005-09-23 14:28:48 40,960 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\jsc.exe
+ 2007-10-24 08:47:34 40,960 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\jsc.exe
- 2007-04-13 11:21:10 413,696 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\Microsoft.Build.Engine.dll
+ 2007-10-24 08:47:36 348,160 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\Microsoft.Build.Engine.dll
- 2005-09-23 14:28:48 36,864 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\Microsoft.Build.Framework.dll
+ 2007-10-24 08:47:36 36,864 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\Microsoft.Build.Framework.dll
- 2007-04-13 11:21:10 647,168 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\Microsoft.Build.Tasks.dll
+ 2007-10-24 08:47:36 655,360 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\Microsoft.Build.Tasks.dll
- 2005-09-23 14:28:48 73,728 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\Microsoft.Build.Utilities.dll
+ 2007-10-24 08:47:36 77,824 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\Microsoft.Build.Utilities.dll
- 2007-04-13 11:21:08 749,568 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\Microsoft.JScript.dll
+ 2007-10-24 08:47:34 749,568 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\Microsoft.JScript.dll
- 2005-09-23 14:29:10 110,592 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\Microsoft.VisualBasic.Compatibility.Data.dll
+ 2007-10-24 08:47:52 110,592 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\Microsoft.VisualBasic.Compatibility.Data.dll
- 2005-09-23 14:29:10 372,736 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\Microsoft.VisualBasic.Compatibility.dll
+ 2007-10-24 08:47:52 372,736 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\Microsoft.VisualBasic.Compatibility.dll
- 2005-09-23 14:29:08 667,648 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\Microsoft.VisualBasic.dll
+ 2007-10-24 08:47:50 671,744 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\Microsoft.VisualBasic.dll
- 2005-09-23 14:28:30 28,672 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\Microsoft.VisualBasic.Vsa.dll
+ 2007-10-24 08:47:20 28,672 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\Microsoft.VisualBasic.Vsa.dll
- 2005-09-23 14:29:10 5,632 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\Microsoft.VisualC.Dll
+ 2007-10-24 08:47:52 5,632 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\Microsoft.VisualC.Dll
- 2005-09-23 14:28:30 32,768 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\Microsoft.Vsa.dll
+ 2007-10-24 08:47:20 32,768 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\Microsoft.Vsa.dll
- 2005-09-23 14:28:30 12,800 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\Microsoft.Vsa.Vb.CodeDOMProcessor.dll
+ 2007-10-24 08:47:20 12,800 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\Microsoft.Vsa.Vb.CodeDOMProcessor.dll
- 2005-09-23 14:28:30 7,168 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\Microsoft_VsaVb.dll
+ 2007-10-24 08:47:20 7,168 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\Microsoft_VsaVb.dll
- 2007-04-13 11:20:52 87,040 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\MmcAspExt.dll
+ 2007-10-24 08:47:22 97,792 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\MmcAspExt.dll
- 2005-09-23 14:28:48 69,632 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\MSBuild.exe
+ 2007-10-24 08:47:36 69,632 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\MSBuild.exe
- 2007-04-13 11:21:18 802,304 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\mscordacwks.dll
+ 2007-10-24 08:47:40 822,280 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\mscordacwks.dll
- 2005-09-23 14:28:56 73,216 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\mscordbc.dll
+ 2007-10-24 08:47:40 83,456 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\mscordbc.dll
- 2005-09-23 14:28:56 288,768 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\mscordbi.dll
+ 2007-10-24 08:47:40 308,224 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\mscordbi.dll
- 2007-04-13 11:21:16 36,864 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\mscorie.dll
+ 2007-10-24 08:47:40 47,104 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\mscorie.dll
- 2007-04-13 11:21:16 326,656 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\mscorjit.dll
+ 2007-10-24 08:47:40 348,672 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\mscorjit.dll
- 2005-09-23 14:28:56 81,408 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\mscorld.dll
+ 2007-10-24 08:47:40 94,208 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\mscorld.dll
- 2007-04-13 11:21:16 4,308,992 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\mscorlib.dll
+ 2007-10-24 08:47:40 4,444,160 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\mscorlib.dll
- 2007-04-13 11:21:16 102,912 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\mscorpe.dll
+ 2007-10-24 08:47:40 114,688 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\mscorpe.dll
- 2005-09-23 14:29:00 330,752 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\mscorrc.dll
+ 2007-10-24 08:47:44 340,992 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\mscorrc.dll
- 2005-09-23 14:28:56 67,072 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\mscorsec.dll
+ 2007-10-24 08:47:40 77,312 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\mscorsec.dll
- 2005-09-23 14:28:50 9,216 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\mscorsn.dll
+ 2007-10-24 08:47:36 18,944 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\mscorsn.dll
- 2007-04-13 11:21:18 227,328 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\mscorsvc.dll
+ 2007-10-24 08:47:40 242,688 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\mscorsvc.dll
- 2007-04-13 11:21:18 68,952 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\mscorsvw.exe
+ 2007-10-24 08:47:40 70,144 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\mscorsvw.exe
- 2005-09-23 14:28:56 10,240 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\mscortim.dll
+ 2007-10-24 08:47:40 19,456 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\mscortim.dll
- 2007-04-13 11:21:12 5,634,048 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\mscorwks.dll
+ 2007-10-24 08:47:36 5,814,784 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\mscorwks.dll
- 2005-09-23 14:29:00 22,528 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\MUI\0409\mscorsecr.dll
+ 2007-10-24 08:47:44 31,744 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\MUI\0409\mscorsecr.dll
- 2007-04-13 11:21:16 99,152 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\ngen.exe
+ 2007-10-24 08:47:40 101,880 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\ngen.exe
- 2007-04-13 11:21:18 15,360 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\normalization.dll
+ 2007-10-24 08:47:40 24,584 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\normalization.dll
- 2005-09-23 14:28:56 78,336 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\PerfCounter.dll
+ 2007-10-24 08:47:40 89,096 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\PerfCounter.dll
- 2007-04-13 11:21:12 136,192 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\peverify.dll
+ 2007-10-24 08:47:36 144,896 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\peverify.dll
- 2005-09-23 14:28:56 53,248 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\RegAsm.exe
+ 2007-10-24 08:47:40 53,248 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\RegAsm.exe
- 2005-09-23 14:28:56 32,768 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\RegSvcs.exe
+ 2007-10-24 08:47:40 32,768 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\RegSvcs.exe
- 2005-09-23 14:29:02 59,072 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\regtlibv12.exe
+ 2007-10-24 08:47:46 61,952 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\regtlibv12.exe
- 2005-09-23 14:28:58 7,680 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\sbscmp20_mscorlib.dll
+ 2007-10-24 08:47:42 16,896 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\sbscmp20_mscorlib.dll
- 2005-09-23 14:28:56 107,520 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\shfusion.dll
+ 2007-10-24 08:47:40 119,296 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\shfusion.dll
- 2005-09-23 14:29:00 85,504 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\ShFusRes.dll
+ 2007-10-24 08:47:44 95,232 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\ShFusRes.dll
- 2007-04-13 11:21:18 382,464 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\SOS.dll
+ 2007-10-24 08:47:40 392,696 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\SOS.dll
- 2007-04-13 11:21:18 110,592 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\sysglobl.dll
+ 2007-10-24 08:47:40 110,592 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\sysglobl.dll
- 2007-04-13 11:21:18 413,696 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.configuration.dll
+ 2007-10-24 08:47:42 425,984 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.configuration.dll
- 2005-09-23 14:28:56 81,920 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.Configuration.Install.dll
+ 2007-10-24 08:47:40 81,920 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.Configuration.Install.dll
- 2007-04-13 11:21:16 2,902,016 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.Data.dll
+ 2007-10-24 08:47:40 3,036,160 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.Data.dll
- 2007-04-13 11:21:18 482,304 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.Data.OracleClient.dll
+ 2007-10-24 08:47:40 483,840 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.Data.OracleClient.dll
- 2007-04-13 11:21:18 716,800 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.Data.SqlXml.dll
+ 2007-10-24 08:47:40 741,376 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.Data.SqlXml.dll
- 2007-04-13 11:20:58 888,832 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.Deployment.dll
+ 2007-10-24 08:47:28 933,888 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.Deployment.dll
- 2007-04-13 11:21:16 5,001,216 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.Design.dll
+ 2007-10-24 08:47:40 5,070,848 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.Design.dll
- 2005-09-23 14:28:56 397,312 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.DirectoryServices.dll
+ 2007-10-24 08:47:40 401,408 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.DirectoryServices.dll
- 2007-04-13 11:21:18 188,416 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.DirectoryServices.Protocols.dll
+ 2007-10-24 08:47:40 188,416 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.DirectoryServices.Protocols.dll
- 2007-04-13 11:21:16 2,940,928 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.dll
+ 2007-10-24 08:47:40 3,076,096 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.dll
- 2005-09-23 14:28:56 81,920 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.Drawing.Design.dll
+ 2007-10-24 08:47:40 81,920 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.Drawing.Design.dll
- 2007-04-13 11:21:16 577,536 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.Drawing.dll
+ 2007-10-24 08:47:40 630,784 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.Drawing.dll
- 2007-04-13 11:21:16 258,048 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.EnterpriseServices.dll
+ 2007-10-24 08:47:40 258,048 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.EnterpriseServices.dll
- 2007-04-13 11:21:18 47,616 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.EnterpriseServices.Thunk.dll
+ 2007-10-24 08:47:40 57,392 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.EnterpriseServices.Thunk.dll
- 2007-04-13 11:21:18 114,176 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.EnterpriseServices.Wrapper.dll
+ 2007-10-24 08:47:40 113,664 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.EnterpriseServices.Wrapper.dll
- 2007-04-13 11:21:16 372,736 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.Management.dll
+ 2007-10-24 08:47:40 372,736 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.Management.dll
- 2005-09-23 14:28:56 258,048 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.Messaging.dll
+ 2007-10-24 08:47:40 258,048 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.Messaging.dll
- 2007-04-13 11:21:16 299,008 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.Runtime.Remoting.dll
+ 2007-10-24 08:47:40 299,008 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.Runtime.Remoting.dll
- 2005-09-23 14:28:56 131,072 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.Runtime.Serialization.Formatters.Soap.dll
+ 2007-10-24 08:47:40 131,072 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.Runtime.Serialization.Formatters.Soap.dll
- 2005-09-23 14:28:56 258,048 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.Security.dll
+ 2007-10-24 08:47:40 258,048 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.Security.dll
- 2005-09-23 14:28:56 114,688 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.ServiceProcess.dll
+ 2007-10-24 08:47:40 114,688 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.ServiceProcess.dll
- 2007-04-13 11:21:18 260,096 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.Transactions.dll
+ 2007-10-24 08:47:40 261,120 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.Transactions.dll
- 2007-04-13 11:21:16 5,156,864 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.Web.dll
+ 2007-10-24 08:47:40 5,431,296 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.Web.dll
- 2005-09-23 14:28:56 835,584 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.Web.Mobile.dll
+ 2007-10-24 08:47:40 884,736 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.Web.Mobile.dll
- 2005-09-23 14:28:56 86,016 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.Web.RegularExpressions.dll
+ 2007-10-24 08:47:40 90,112 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.Web.RegularExpressions.dll
- 2005-09-23 14:28:56 823,296 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.Web.Services.dll
+ 2007-10-24 08:47:40 839,680 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.Web.Services.dll
- 2007-04-13 11:21:16 5,152,768 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.Windows.Forms.dll
+ 2007-10-24 08:47:40 5,013,504 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.Windows.Forms.dll
- 2007-04-13 11:21:16 2,027,520 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.XML.dll
+ 2007-10-24 08:47:40 2,068,480 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.XML.dll
- 2005-09-23 14:28:56 71,680 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\TLBREF.DLL
+ 2007-10-24 08:47:40 81,400 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\TLBREF.DLL
- 2007-04-13 11:21:28 1,166,672 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\vbc.exe
+ 2007-10-24 08:47:48 1,172,472 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\vbc.exe
- 2007-04-13 11:20:50 1,330,688 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\VsaVb7rt.dll
+ 2007-10-24 08:47:20 1,344,000 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\VsaVb7rt.dll
- 2007-04-13 11:20:52 406,016 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\webengine.dll
+ 2007-10-24 08:47:22 434,688 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\webengine.dll
- 2005-09-23 14:28:56 28,160 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\WMINet_Utils.dll
+ 2007-10-24 08:47:40 37,896 ----a-w C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\WMINet_Utils.dll
+ 2000-08-31 15:00:00 28,672 ----a-w C:\WINDOWS\Nircmd.exe
+ 1995-08-01 12:44:46 212,480 ----a-w C:\WINDOWS\PCDLIB32.DLL
+ 2000-08-31 15:00:00 98,816 ----a-w C:\WINDOWS\sed.exe
+ 2000-08-31 15:00:00 161,792 ----a-w C:\WINDOWS\SWREG.exe
+ 2000-08-31 15:00:00 136,704 ----a-w C:\WINDOWS\SWSC.exe
+ 2000-08-31 15:00:00 212,480 ----a-w C:\WINDOWS\swxcacls.exe
+ 2004-08-04 12:00:00 2,000 ----a-w C:\WINDOWS\system\KEYBOARD.DRV
+ 2004-08-04 12:00:00 73,376 ----a-w C:\WINDOWS\system\MCIAVI.DRV
+ 2004-08-04 12:00:00 25,264 ----a-w C:\WINDOWS\system\MCISEQ.DRV
+ 2004-08-04 12:00:00 28,160 ----a-w C:\WINDOWS\system\MCIWAVE.DRV
+ 2004-08-04 12:00:00 2,032 ----a-w C:\WINDOWS\system\MOUSE.DRV
+ 2004-08-04 12:00:00 1,744 ----a-w C:\WINDOWS\system\SOUND.DRV
+ 2004-08-04 12:00:00 3,360 ----a-w C:\WINDOWS\system\SYSTEM.DRV
+ 2004-08-04 12:00:00 4,048 ----a-w C:\WINDOWS\system\TIMER.DRV
+ 2004-08-04 12:00:00 2,176 ----a-w C:\WINDOWS\system\VGA.DRV
+ 2004-08-04 12:00:00 13,600 ----a-w C:\WINDOWS\system\WFWNET.DRV
+ 2004-08-04 12:00:00 146,432 ----a-w C:\WINDOWS\system\WINSPOOL.DRV
- 2007-10-10 23:55:51 124,928 ----a-w C:\WINDOWS\system32\advpack.dll
+ 2008-06-23 16:57:27 124,928 ----a-w C:\WINDOWS\system32\advpack.dll
+ 1999-08-09 22:39:20 14,832 ----a-w C:\WINDOWS\system32\asfsipc.dll
- 2007-07-31 03:19:20 92,504 ----a-w C:\WINDOWS\system32\cdm.dll
+ 2008-07-19 05:10:48 94,920 ----a-w C:\WINDOWS\system32\cdm.dll
+ 2008-06-18 03:30:25 107,888 ----a-w C:\WINDOWS\system32\CmdLineExt.dll
+ 2004-08-04 12:00:00 10,544 ----a-w C:\WINDOWS\system32\comm.drv
+ 2004-11-15 19:40:37 1,731 -c--a-w C:\WINDOWS\system32\config\systemprofile\Application Data\Sonic\Update Manager\sumdb.dat
+ 2005-02-06 02:45:26 2,222,800 ----a-w C:\WINDOWS\system32\d3dx9_24.dll
+ 2005-03-19 00:19:58 2,337,488 ----a-w C:\WINDOWS\system32\d3dx9_25.dll
+ 2005-05-26 22:34:52 2,297,552 ----a-w C:\WINDOWS\system32\d3dx9_26.dll
+ 2005-07-23 02:59:04 2,319,568 ----a-w C:\WINDOWS\system32\d3dx9_27.dll
+ 2005-12-06 01:09:18 2,323,664 ----a-w C:\WINDOWS\system32\d3dx9_28.dll
+ 2006-02-03 15:43:16 2,332,368 ----a-w C:\WINDOWS\system32\d3dx9_29.dll
+ 2006-03-31 19:40:58 2,388,176 ----a-w C:\WINDOWS\system32\d3dx9_30.dll
+ 2006-09-28 23:05:20 2,414,360 ----a-w C:\WINDOWS\system32\d3dx9_31.dll
+ 2006-11-29 20:06:18 3,426,072 ----a-w C:\WINDOWS\system32\d3dx9_32.dll
+ 2004-05-19 19:18:46 221,184 ----a-w C:\WINDOWS\system32\DartSock.dll
+ 2004-05-27 18:08:38 118,784 ----a-w C:\WINDOWS\system32\DartTelnet.dll
+ 2004-08-04 12:00:00 1,788 ----a-w C:\WINDOWS\system32\Dcache.bin
+ 2004-06-09 16:29:56 6,977 ----a-w C:\WINDOWS\system32\DDMI2.sys
- 2005-09-23 14:28:38 83,456 ----a-w C:\WINDOWS\system32\dfshim.dll
+ 2007-10-24 08:47:28 96,760 ----a-w C:\WINDOWS\system32\dfshim.dll
+ 2006-10-03 02:24:00 487,424 ----a-w C:\WINDOWS\system32\DLLAV32.dll
- 2007-10-10 23:55:51 124,928 -c--a-w C:\WINDOWS\system32\dllcache\advpack.dll
+ 2008-06-23 16:57:27 124,928 -c--a-w C:\WINDOWS\system32\dllcache\advpack.dll
- 2004-08-04 12:00:00 138,496 -c--a-w C:\WINDOWS\system32\dllcache\afd.sys
+ 2008-06-20 10:44:38 138,368 -c--a-w C:\WINDOWS\system32\dllcache\afd.sys
+ 2008-06-13 13:10:50 272,128 -c--a-w C:\WINDOWS\system32\dllcache\bthport.sys
- 2007-07-31 03:19:20 92,504 -c--a-w C:\WINDOWS\system32\dllcache\cdm.dll
+ 2008-07-19 05:10:48 94,920 -c--a-w C:\WINDOWS\system32\dllcache\cdm.dll
- 2004-08-04 12:00:00 561,179 -c--a-w C:\WINDOWS\system32\dllcache\dao360.dll
+ 2008-03-25 04:50:25 554,008 -c--a-w C:\WINDOWS\system32\dllcache\dao360.dll
- 2006-06-26 17:37:10 148,480 -c--a-w C:\WINDOWS\system32\dllcache\dnsapi.dll
+ 2008-06-20 17:41:10 148,992 -c--a-w C:\WINDOWS\system32\dllcache\dnsapi.dll
- 2004-08-04 12:00:00 45,568 -c--a-w C:\WINDOWS\system32\dllcache\dnsrslvr.dll
+ 2008-02-20 05:32:43 45,568 -c--a-w C:\WINDOWS\system32\dllcache\dnsrslvr.dll
+ 2004-08-04 13:07:58 2,944 -c--a-w C:\WINDOWS\system32\dllcache\drmkaud.sys
- 2006-10-17 19:58:06 346,624 -c--a-w C:\WINDOWS\system32\dllcache\dxtmsft.dll
+ 2008-06-23 16:57:27 347,136 -c--a-w C:\WINDOWS\system32\dllcache\dxtmsft.dll
- 2007-10-10 23:55:51 214,528 -c--a-w C:\WINDOWS\system32\dllcache\dxtrans.dll
+ 2008-06-23 16:57:27 214,528 -c--a-w C:\WINDOWS\system32\dllcache\dxtrans.dll
- 2005-07-26 04:39:45 243,200 -c--a-w C:\WINDOWS\system32\dllcache\es.dll
+ 2008-07-07 20:32:22 253,952 -c--a-w C:\WINDOWS\system32\dllcache\es.dll
- 2007-10-10 23:55:51 132,608 -c--a-w C:\WINDOWS\system32\dllcache\extmgr.dll
+ 2008-06-23 16:57:27 133,120 -c--a-w C:\WINDOWS\system32\dllcache\extmgr.dll
- 2007-06-19 13:31:19 282,112 -c--a-w C:\WINDOWS\system32\dllcache\gdi32.dll
+ 2008-02-20 06:51:05 282,624 -c--a-w C:\WINDOWS\system32\dllcache\gdi32.dll
- 2007-10-10 23:55:51 63,488 -c--a-w C:\WINDOWS\system32\dllcache\icardie.dll
+ 2008-06-23 16:57:28 63,488 -c--a-w C:\WINDOWS\system32\dllcache\icardie.dll
- 2007-10-10 10:59:40 70,656 -c--a-w C:\WINDOWS\system32\dllcache\ie4uinit.exe
+ 2008-06-23 09:20:25 70,656 -c--a-w C:\WINDOWS\system32\dllcache\ie4uinit.exe
- 2007-10-10 23:55:51 153,088 -c--a-w C:\WINDOWS\system32\dllcache\ieakeng.dll
+ 2008-06-23 16:57:29 153,088 -c--a-w C:\WINDOWS\system32\dllcache\ieakeng.dll
- 2007-10-10 23:55:51 230,400 -c--a-w C:\WINDOWS\system32\dllcache\ieaksie.dll
+ 2008-06-23 16:57:29 230,400 -c--a-w C:\WINDOWS\system32\dllcache\ieaksie.dll
- 2007-10-10 05:46:55 161,792 -c--a-w C:\WINDOWS\system32\dllcache\ieakui.dll
+ 2008-06-21 05:23:54 161,792 -c--a-w C:\WINDOWS\system32\dllcache\ieakui.dll
- 2007-10-10 23:55:52 383,488 -c--a-w C:\WINDOWS\system32\dllcache\ieapfltr.dll
+ 2008-06-23 16:57:29 383,488 -c--a-w C:\WINDOWS\system32\dllcache\ieapfltr.dll
- 2007-10-10 23:55:52 384,512 -c--a-w C:\WINDOWS\system32\dllcache\iedkcs32.dll
+ 2008-06-23 16:57:29 384,512 -c--a-w C:\WINDOWS\system32\dllcache\iedkcs32.dll
- 2007-10-10 23:55:54 6,065,664 -c--a-w C:\WINDOWS\system32\dllcache\ieframe.dll
+ 2008-06-23 16:57:33 6,066,176 -c--a-w C:\WINDOWS\system32\dllcache\ieframe.dll
- 2007-10-10 23:55:55 44,544 -c--a-w C:\WINDOWS\system32\dllcache\iernonce.dll
+ 2008-06-23 16:57:33 44,544 -c--a-w C:\WINDOWS\system32\dllcache\iernonce.dll
- 2007-10-10 23:55:55 267,776 -c--a-w C:\WINDOWS\system32\dllcache\iertutil.dll
+ 2008-06-23 16:57:34 267,776 -c--a-w C:\WINDOWS\system32\dllcache\iertutil.dll
- 2007-10-10 10:59:40 13,824 -c--a-w C:\WINDOWS\system32\dllcache\ieudinit.exe
+ 2008-06-23 09:20:26 13,824 -c--a-w C:\WINDOWS\system32\dllcache\ieudinit.exe
- 2007-10-10 10:59:52 625,152 -c--a-w C:\WINDOWS\system32\dllcache\iexplore.exe
+ 2008-06-23 09:20:52 625,664 -c--a-w C:\WINDOWS\system32\dllcache\iexplore.exe
- 2007-08-21 06:15:44 683,520 -c--a-w C:\WINDOWS\system32\dllcache\inetcomm.dll
+ 2008-04-11 18:50:43 683,520 -c--a-w C:\WINDOWS\system32\dllcache\inetcomm.dll
- 2007-10-10 23:55:56 27,648 -c--a-w C:\WINDOWS\system32\dllcache\jsproxy.dll
+ 2008-06-23 16:57:35 27,648 -c--a-w C:\WINDOWS\system32\dllcache\jsproxy.dll
+ 2004-08-04 12:00:00 2,000 -c--a-w C:\WINDOWS\system32\dllcache\keyboard.drv
- 2006-08-17 12:28:27 721,920 -c--a-w C:\WINDOWS\system32\dllcache\lsasrv.dll
+ 2007-11-07 09:26:56 721,920 -c--a-w C:\WINDOWS\system32\dllcache\lsasrv.dll
+ 2004-08-04 12:00:00 2,560 -c--a-w C:\WINDOWS\system32\dllcache\lz32.dll
+ 2004-08-04 12:00:00 73,376 -c--a-w C:\WINDOWS\system32\dllcache\mciavi.drv
+ 2004-08-04 12:00:00 25,264 -c--a-w C:\WINDOWS\system32\dllcache\mciseq.drv
+ 2004-08-04 12:00:00 28,160 -c--a-w C:\WINDOWS\system32\dllcache\mciwave.drv
+ 2004-08-04 12:00:00 2,032 -c--a-w C:\WINDOWS\system32\dllcache\mouse.drv
- 2004-08-04 12:00:00 181,248 -c--a-w C:\WINDOWS\system32\dllcache\mrxdav.sys
+ 2007-12-18 09:51:35 179,584 -c--a-w C:\WINDOWS\system32\dllcache\mrxdav.sys
- 2004-08-04 12:00:00 331,776 -c--a-w C:\WINDOWS\system32\dllcache\msadce.dll
+ 2008-05-01 14:30:33 331,776 -c--a-w C:\WINDOWS\system32\dllcache\msadce.dll
- 2005-06-29 01:46:00 74,240 -c--a-w C:\WINDOWS\system32\dllcache\mscms.dll
+ 2008-06-24 16:23:05 74,240 -c--a-w C:\WINDOWS\system32\dllcache\mscms.dll
- 2004-08-04 12:00:00 294,400 -c--a-w C:\WINDOWS\system32\dllcache\msctf.dll
+ 2008-02-26 11:59:50 294,912 -c--a-w C:\WINDOWS\system32\dllcache\msctf.dll
- 2004-08-04 12:00:00 512,029 -c--a-w C:\WINDOWS\system32\dllcache\msexch40.dll
+ 2008-03-25 04:50:28 518,944 -c--a-w C:\WINDOWS\system32\dllcache\msexch40.dll
- 2004-08-04 12:00:00 319,517 -c--a-w C:\WINDOWS\system32\dllcache\msexcl40.dll
+ 2008-03-25 04:50:30 326,432 -c--a-w C:\WINDOWS\system32\dllcache\msexcl40.dll
- 2007-10-10 23:55:56 459,264 -c--a-w C:\WINDOWS\system32\dllcache\msfeeds.dll
+ 2008-06-23 16:57:36 459,264 -c--a-w C:\WINDOWS\system32\dllcache\msfeeds.dll
- 2007-10-10 23:55:56 52,224 -c--a-w C:\WINDOWS\system32\dllcache\msfeedsbs.dll
+ 2008-06-23 16:57:36 52,224 -c--a-w C:\WINDOWS\system32\dllcache\msfeedsbs.dll
- 2007-10-30 23:42:28 3,590,656 -c--a-w C:\WINDOWS\system32\dllcache\mshtml.dll
+ 2008-06-24 17:57:40 3,592,192 -c--a-w C:\WINDOWS\system32\dllcache\mshtml.dll
- 2007-10-10 23:55:58 478,208 -c--a-w C:\WINDOWS\system32\dllcache\mshtmled.dll
+ 2008-06-23 16:57:39 477,696 -c--a-w C:\WINDOWS\system32\dllcache\mshtmled.dll
- 2004-08-04 12:00:00 1,507,356 -c--a-w C:\WINDOWS\system32\dllcache\msjet40.dll
+ 2008-03-25 04:50:34 1,516,568 -c--a-w C:\WINDOWS\system32\dllcache\msjet40.dll
- 2004-08-04 12:00:00 358,976 -c--a-w C:\WINDOWS\system32\dllcache\msjetol1.dll
+ 2008-03-25 04:50:40 355,112 -c--a-w C:\WINDOWS\system32\dllcache\msjetol1.dll
- 2004-08-04 12:00:00 151,583 -c--a-w C:\WINDOWS\system32\dllcache\msjint40.dll
+ 2008-03-27 08:12:54 151,583 -c--a-w C:\WINDOWS\system32\dllcache\msjint40.dll
- 2004-08-04 12:00:00 53,279 -c--a-w C:\WINDOWS\system32\dllcache\msjter40.dll
+ 2008-03-25 04:50:42 60,192 -c--a-w C:\WINDOWS\system32\dllcache\msjter40.dll
- 2004-08-04 12:00:00 241,693 -c--a-w C:\WINDOWS\system32\dllcache\msjtes40.dll
+ 2008-03-25 04:50:42 248,608 -c--a-w C:\WINDOWS\system32\dllcache\msjtes40.dll
- 2004-08-04 12:00:00 213,023 -c--a-w C:\WINDOWS\system32\dllcache\msltus40.dll
+ 2008-03-25 04:50:44 219,936 -c--a-w C:\WINDOWS\system32\dllcache\msltus40.dll
- 2004-08-04 12:00:00 348,189 -c--a-w C:\WINDOWS\system32\dllcache\mspbde40.dll
+ 2008-03-25 04:50:45 355,104 -c--a-w C:\WINDOWS\system32\dllcache\mspbde40.dll
- 2007-10-10 23:55:58 193,024 -c--a-w C:\WINDOWS\system32\dllcache\msrating.dll
+ 2008-06-23 16:57:39 193,024 -c--a-w C:\WINDOWS\system32\dllcache\msrating.dll
- 2004-08-04 12:00:00 421,919 -c--a-w C:\WINDOWS\system32\dllcache\msrd2x40.dll
+ 2008-03-25 04:50:47 432,928 -c--a-w C:\WINDOWS\system32\dllcache\msrd2x40.dll
- 2004-08-04 12:00:00 315,423 -c--a-w C:\WINDOWS\system32\dllcache\msrd3x40.dll
+ 2008-03-25 04:50:49 322,336 -c--a-w C:\WINDOWS\system32\dllcache\msrd3x40.dll
- 2004-08-04 12:00:00 552,989 -c--a-w C:\WINDOWS\system32\dllcache\msrepl40.dll
+ 2008-03-25 04:50:52 559,904 -c--a-w C:\WINDOWS\system32\dllcache\msrepl40.dll
- 2004-08-04 12:00:00 258,077 -c--a-w C:\WINDOWS\system32\dllcache\mstext40.dll
+ 2008-03-25 04:50:55 264,992 -c--a-w C:\WINDOWS\system32\dllcache\mstext40.dll
- 2007-10-10 23:55:59 671,232 -c--a-w C:\WINDOWS\system32\dllcache\mstime.dll
+ 2008-06-23 16:57:40 671,232 -c--a-w C:\WINDOWS\system32\dllcache\mstime.dll
- 2004-08-04 12:00:00 831,519 -c--a-w C:\WINDOWS\system32\dllcache\mswdat10.dll
+ 2008-03-25 04:50:57 838,432 -c--a-w C:\WINDOWS\system32\dllcache\mswdat10.dll
- 2004-08-04 12:00:00 245,248 -c--a-w C:\WINDOWS\system32\dllcache\mswsock.dll
+ 2008-06-20 17:41:10 245,248 -c--a-w C:\WINDOWS\system32\dllcache\mswsock.dll
- 2004-08-04 12:00:00 614,429 -c--a-w C:\WINDOWS\system32\dllcache\mswstr10.dll
+ 2008-03-25 04:50:58 621,344 -c--a-w C:\WINDOWS\system32\dllcache\mswstr10.dll
- 2004-08-04 12:00:00 348,189 -c--a-w C:\WINDOWS\system32\dllcache\msxbde40.dll
+ 2008-03-25 04:50:58 355,104 -c--a-w C:\WINDOWS\system32\dllcache\msxbde40.dll
+ 2004-08-04 12:00:00 2,944 -c--a-w C:\WINDOWS\system32\dllcache\null.sys
- 2007-10-10 23:55:59 102,400 -c--a-w C:\WINDOWS\system32\dllcache\occache.dll
+ 2008-06-23 16:57:40 102,912 -c--a-w C:\WINDOWS\system32\dllcache\occache.dll
- 2007-05-17 11:28:05 549,376 -c--a-w C:\WINDOWS\system32\dllcache\oleaut32.dll
+ 2007-12-04 18:38:13 550,912 -c--a-w C:\WINDOWS\system32\dllcache\oleaut32.dll
- 2006-10-17 19:58:08 44,544 -c--a-w C:\WINDOWS\system32\dllcache\pngfilt.dll
+ 2008-06-23 16:57:40 44,544 -c--a-w C:\WINDOWS\system32\dllcache\pngfilt.dll
- 2007-10-29 22:43:03 1,287,680 -c--a-w C:\WINDOWS\system32\dllcache\quartz.dll
+ 2008-05-07 05:18:48 1,287,680 -c--a-w C:\WINDOWS\system32\dllcache\quartz.dll
- 2006-07-13 08:48:58 202,240 -c--a-w C:\WINDOWS\system32\dllcache\rmcast.sys
+ 2008-05-08 12:28:49 202,752 -c--a-w C:\WINDOWS\system32\dllcache\rmcast.sys
+ 2004-08-04 12:00:00 1,744 -c--a-w C:\WINDOWS\system32\dllcache\sound.drv
+ 2004-08-04 12:00:00 3,360 -c--a-w C:\WINDOWS\system32\dllcache\system.drv
- 2006-04-20 11:51:50 359,808 -c--a-w C:\WINDOWS\system32\dllcache\tcpip.sys
+ 2008-06-20 10:45:13 360,320 -c--a-w C:\WINDOWS\system32\dllcache\tcpip.sys
- 2006-08-16 09:37:30 225,664 -c--a-w C:\WINDOWS\system32\dllcache\tcpip6.sys
+ 2008-06-20 09:52:06 225,920 -c--a-w C:\WINDOWS\system32\dllcache\tcpip6.sys
+ 2004-08-04 12:00:00 4,048 -c--a-w C:\WINDOWS\system32\dllcache\timer.drv
- 2007-10-10 23:55:59 105,984 -c--a-w C:\WINDOWS\system32\dllcache\url.dll
+ 2008-06-23 16:57:40 105,984 -c--a-w C:\WINDOWS\system32\dllcache\url.dll
- 2007-10-10 23:56:00 1,159,680 -c--a-w C:\WINDOWS\system32\dllcache\urlmon.dll
+ 2008-06-23 16:57:40 1,159,680 -c--a-w C:\WINDOWS\system32\dllcache\urlmon.dll
+ 2004-08-04 12:00:00 2,176 -c--a-w C:\WINDOWS\system32\dllcache\vga.drv
- 2007-10-10 23:56:00 232,960 -c--a-w C:\WINDOWS\system32\dllcache\webcheck.dll
+ 2008-06-23 16:57:41 233,472 -c--a-w C:\WINDOWS\system32\dllcache\webcheck.dll
+ 2004-08-04 12:00:00 13,600 -c--a-w C:\WINDOWS\system32\dllcache\wfwnet.drv
- 2007-03-08 13:47:48 1,843,584 -c--a-w C:\WINDOWS\system32\dllcache\win32k.sys
+ 2008-03-19 09:47:00 1,845,248 -c--a-w C:\WINDOWS\system32\dllcache\win32k.sys
- 2007-10-10 23:56:00 824,832 -c--a-w C:\WINDOWS\system32\dllcache\wininet.dll
+ 2008-06-23 16:57:41 826,368 -c--a-w C:\WINDOWS\system32\dllcache\wininet.dll
+ 2004-08-04 12:00:00 2,864 -c--a-w C:\WINDOWS\system32\dllcache\winsock.dll
+ 2004-08-04 12:00:00 146,432 -c--a-w C:\WINDOWS\system32\dllcache\winspool.drv
+ 2004-08-04 12:00:00 2,112 -c--a-w C:\WINDOWS\system32\dllcache\winspool.exe
+ 2004-08-04 12:00:00 2,736 -c--a-w C:\WINDOWS\system32\dllcache\wowdeb.exe
- 2007-07-31 03:19:36 549,720 -c--a-w C:\WINDOWS\system32\dllcache\wuapi.dll
+ 2008-07-19 05:09:44 563,912 -c--a-w C:\WINDOWS\system32\dllcache\wuapi.dll
- 2007-07-31 03:19:16 53,080 -c--a-w C:\WINDOWS\system32\dllcache\wuauclt.exe
+ 2008-07-19 05:10:42 53,448 -c--a-w C:\WINDOWS\system32\dllcache\wuauclt.exe
- 2007-07-31 03:19:42 1,712,984 -c--a-w C:\WINDOWS\system32\dllcache\wuaueng.dll
+ 2008-07-19 05:09:42 1,811,656 -c--a-w C:\WINDOWS\system32\dllcache\wuaueng.dll
- 2007-07-31 03:19:32 325,976 -c--a-w C:\WINDOWS\system32\dllcache\wucltui.dll
+ 2008-07-19 05:09:46 325,832 -c--a-w C:\WINDOWS\system32\dllcache\wucltui.dll
- 2007-07-31 03:19:28 203,096 -c--a-w C:\WINDOWS\system32\dllcache\wuweb.dll
+ 2008-07-19 05:09:44 205,000 -c--a-w C:\WINDOWS\system32\dllcache\wuweb.dll
+ 2003-03-14 19:33:00 61,440 ----a-w C:\WINDOWS\system32\DLLCDF32.dll
+ 2006-10-03 02:24:00 94,208 ----a-w C:\WINDOWS\system32\DLLCPY32.dll
+ 2006-10-03 02:24:00 163,840 ----a-w C:\WINDOWS\system32\DLLDEV32.dll
+ 2003-03-14 19:32:44 32,768 ----a-w C:\WINDOWS\system32\DLLDIR32.dll
+ 2006-10-03 02:24:00 151,552 ----a-w C:\WINDOWS\system32\DLLDRV32.dll
+ 2003-03-14 19:33:02 45,056 ----a-w C:\WINDOWS\system32\DLLIMG32.dll
+ 2006-10-03 02:24:00 53,248 ----a-w C:\WINDOWS\system32\DLLIO32.dll
+ 2003-03-14 19:32:46 32,768 ----a-w C:\WINDOWS\system32\DLLISO32.dll
+ 2003-03-14 19:32:40 24,576 ----a-w C:\WINDOWS\system32\DLLIX.dll
+ 2003-03-14 19:32:42 32,768 ----a-w C:\WINDOWS\system32\DLLMSC32.dll
+ 2006-10-03 02:24:00 36,864 ----a-w C:\WINDOWS\system32\DLLPNT32.dll
+ 2003-03-14 19:32:44 49,152 ----a-w C:\WINDOWS\system32\DLLPRF32.dll
+ 2003-03-14 19:33:04 53,248 ----a-w C:\WINDOWS\system32\DLLPRJ32.dll
+ 2003-03-14 19:32:50 65,536 ----a-w C:\WINDOWS\system32\DLLPTL32.dll
+ 2003-03-14 19:35:00 40,960 ----a-w C:\WINDOWS\system32\DLLRD32.dll
+ 2006-10-03 02:24:00 188,416 ----a-w C:\WINDOWS\system32\DLLRES32.dll
+ 2003-03-14 19:32:54 57,344 ----a-w C:\WINDOWS\system32\DLLTPO32.dll
+ 2005-03-13 23:54:00 6,656 ----a-w C:\WINDOWS\system32\DLPT2.sys
+ 2008-08-29 17:18:58 87,336 ----a-w C:\WINDOWS\system32\dns-sd.exe
- 2006-06-26 17:37:10 148,480 ----a-w C:\WINDOWS\system32\dnsapi.dll
+ 2008-06-20 17:41:10 148,992 ----a-w C:\WINDOWS\system32\dnsapi.dll
- 2004-08-04 12:00:00 45,568 ----a-w C:\WINDOWS\system32\dnsrslvr.dll
+ 2008-02-20 05:32:43 45,568 ----a-w C:\WINDOWS\system32\dnsrslvr.dll
+ 2008-08-29 16:53:50 61,440 ----a-w C:\WINDOWS\system32\dnssd.dll
+ 2005-02-23 22:58:56 11,776 ----a-w C:\WINDOWS\system32\drivers\afc.sys
- 2004-08-04 12:00:00 138,496 ----a-w C:\WINDOWS\system32\drivers\afd.sys
+ 2008-06-20 10:44:38 138,368 ----a-w C:\WINDOWS\system32\drivers\afd.sys
+ 2007-05-30 12:10:42 10,872 ----a-w C:\WINDOWS\system32\drivers\AvgAsCln.sys
+ 2008-06-13 13:10:50 272,128 ----a-w C:\WINDOWS\system32\drivers\bthport.sys
+ 2004-08-04 13:07:58 2,944 ----a-w C:\WINDOWS\system32\drivers\drmkaud.sys
- 2006-09-19 23:44:04 15,664 ----a-w C:\WINDOWS\system32\drivers\GEARAspiWDM.sys
+ 2008-04-17 20:12:54 15,464 ----a-w C:\WINDOWS\system32\drivers\GEARAspiWDM.sys
+ 2008-06-22 00:26:05 29,184 ----a-w C:\WINDOWS\system32\drivers\goprot51.sys
- 2003-09-11 07:36:54 21,060 ----a-w C:\WINDOWS\system32\drivers\iviaspi.sys
+ 2005-09-21 00:27:20 10,368 ----a-w C:\WINDOWS\system32\drivers\iviaspi.sys
- 2005-05-26 19:01:18 21,344 ----a-w C:\WINDOWS\system32\drivers\lgusbbus.sys
+ 2007-04-09 16:53:24 12,672 ----a-w C:\WINDOWS\system32\drivers\lgusbbus.sys
- 2005-05-26 19:01:36 38,144 ----a-w C:\WINDOWS\system32\drivers\lgusbdiag.sys
+ 2007-04-09 16:56:22 21,248 ----a-w C:\WINDOWS\system32\drivers\lgusbdiag.sys
- 2005-06-25 02:36:16 39,036 ----a-w C:\WINDOWS\system32\drivers\lgusbmodem.sys
+ 2007-04-09 16:55:08 22,912 ----a-w C:\WINDOWS\system32\drivers\lgusbmodem.sys
- 2004-08-04 12:00:00 181,248 ----a-w C:\WINDOWS\system32\drivers\mrxdav.sys
+ 2007-12-18 09:51:35 179,584 ----a-w C:\WINDOWS\system32\drivers\mrxdav.sys
+ 2004-08-04 12:00:00 2,944 ----a-w C:\WINDOWS\system32\drivers\null.sys
+ 2008-06-17 04:53:21 22,328 ----a-w C:\WINDOWS\system32\drivers\PnkBstrK.sys
+ 2007-04-18 03:09:28 11,032 ----a-w C:\WINDOWS\system32\drivers\regi.sys
- 2006-07-13 08:48:58 202,240 -c--a-w C:\WINDOWS\system32\drivers\rmcast.sys
+ 2008-05-08 12:28:49 202,752 ----a-w C:\WINDOWS\system32\drivers\rmcast.sys
- 2006-04-20 11:51:50 359,808 ----a-w C:\WINDOWS\system32\drivers\tcpip.sys
+ 2008-06-20 10:45:13 360,320 ----a-w C:\WINDOWS\system32\drivers\tcpip.sys
- 2006-08-16 09:37:30 225,664 -c--a-w C:\WINDOWS\system32\drivers\tcpip6.sys
+ 2008-06-20 09:52:06 225,920 ----a-w C:\WINDOWS\system32\drivers\tcpip6.sys
+ 2005-01-31 19:54:52 76,672 ----a-w C:\WINDOWS\system32\drivers\vdrv7000.sys
+ 2008-04-17 20:12:54 107,368 -c--a-w C:\WINDOWS\system32\DRVSTORE\GEARAspiWD_D213663B6381F01E45A131159A9DEFE018321CB3\x86\GEARAspi.dll
+ 2008-04-17 20:12:54 15,464 -c--a-w C:\WINDOWS\system32\DRVSTORE\GEARAspiWD_D213663B6381F01E45A131159A9DEFE018321CB3\x86\GEARAspiWDM.sys
+ 2007-04-05 22:04:16 17,920 -c--a-w C:\WINDOWS\system32\DRVSTORE\motccgp_AAA6EBF99A29B32284FBE77DCBA5A978B418DB78\motccgp.sys
+ 2007-01-24 02:03:44 7,680 -c--a-w C:\WINDOWS\system32\DRVSTORE\motccgp_AAA6EBF99A29B32284FBE77DCBA5A978B418DB78\motccgpfl.sys
+ 2006-12-07 00:33:54 6,400 -c--a-w C:\WINDOWS\system32\DRVSTORE\motccgp_AAA6EBF99A29B32284FBE77DCBA5A978B418DB78\motswch.sys
+ 2006-11-13 21:45:54 1,419,232 -c--a-w C:\WINDOWS\system32\DRVSTORE\motccgp_AAA6EBF99A29B32284FBE77DCBA5A978B418DB78\wdfcoinstaller01005.dll
+ 2007-05-04 23:54:08 22,528 -c--a-w C:\WINDOWS\system32\DRVSTORE\motmodem_73B0B439953C130D8EB59CD7FCAE8E6CAAE33C7B\motmodem.sys
+ 2006-11-13 21:45:54 1,419,232 -c--a-w C:\WINDOWS\system32\DRVSTORE\motmodem_73B0B439953C130D8EB59CD7FCAE8E6CAAE33C7B\wdfcoinstaller01005.dll
+ 2006-07-28 15:10:08 6,144 -c--a-w C:\WINDOWS\system32\DRVSTORE\motodrv_33FDC8751D718FF9BCD2F345588D4E10B502D569\mot_ci.dll
+ 2007-05-05 00:04:04 42,112 -c--a-w C:\WINDOWS\system32\DRVSTORE\motodrv_33FDC8751D718FF9BCD2F345588D4E10B502D569\motodrv.sys
+ 2007-01-24 04:36:20 6,016 -c--a-w C:\WINDOWS\system32\DRVSTORE\motousbnet_ABB6512ACA55A7A4E2FA3DE425ED10A6DA3518DB\motfilt.sys
+ 2007-01-24 04:36:28 22,016 -c--a-w C:\WINDOWS\system32\DRVSTORE\motousbnet_ABB6512ACA55A7A4E2FA3DE425ED10A6DA3518DB\Motousbnet.sys
+ 2006-12-07 00:33:54 6,400 -c--a-w C:\WINDOWS\system32\DRVSTORE\motousbnet_ABB6512ACA55A7A4E2FA3DE425ED10A6DA3518DB\motswch.sys
+ 2006-11-13 21:45:54 1,419,232 -c--a-w C:\WINDOWS\system32\DRVSTORE\motousbnet_ABB6512ACA55A7A4E2FA3DE425ED10A6DA3518DB\wdfcoinstaller01005.dll
+ 2007-05-04 23:54:08 22,528 -c--a-w C:\WINDOWS\system32\DRVSTORE\motport_6F4CC69E1DFD455E7B0E2326811BDD44A181D021\motport.sys
+ 2006-11-13 21:45:54 1,419,232 -c--a-w C:\WINDOWS\system32\DRVSTORE\motport_6F4CC69E1DFD455E7B0E2326811BDD44A181D021\wdfcoinstaller01005.dll
+ 2008-09-06 05:16:46 36,864 -c--a-w C:\WINDOWS\system32\DRVSTORE\usbaapl_4BA70430CFB145AED5FAD1594679A495A188AB90\usbaapl.sys
+ 2008-09-06 05:16:46 1,900,544 -c--a-w C:\WINDOWS\system32\DRVSTORE\usbaapl_4BA70430CFB145AED5FAD1594679A495A188AB90\usbaaplrc.dll
+ 2005-04-26 20:17:48 643,072 ----a-w C:\WINDOWS\system32\DVDProX2.dll
- 2006-10-17 19:58:06 346,624 ----a-w C:\WINDOWS\system32\dxtmsft.dll
+ 2008-06-23 16:57:27 347,136 ----a-w C:\WINDOWS\system32\dxtmsft.dll
- 2007-10-10 23:55:51 214,528 ----a-w C:\WINDOWS\system32\dxtrans.dll
+ 2008-06-23 16:57:27 214,528 ----a-w C:\WINDOWS\system32\dxtrans.dll
+ 2006-04-19 09:00:00 62,976 ----a-w C:\WINDOWS\system32\E_FD4BCAA.DLL
+ 2006-12-08 10:04:00 76,800 ----a-w C:\WINDOWS\system32\E_FLBCAA.DLL
+ 2006-10-31 08:10:00 51,360 ----a-w C:\WINDOWS\system32\EpPicMgr.dll
+ 2004-03-03 14:10:00 29,114 ----a-w C:\WINDOWS\system32\EPPICPattern1.dat
+ 2004-03-03 14:10:00 27,417 ----a-w C:\WINDOWS\system32\EPPICPattern121.dat
+ 2004-03-03 14:10:00 31,053 ----a-w C:\WINDOWS\system32\EPPICPattern131.dat
+ 2004-03-03 14:10:00 13,280 ----a-w C:\WINDOWS\system32\EPPICPattern2.dat
+ 2004-03-03 14:10:00 21,021 ----a-w C:\WINDOWS\system32\EPPICPattern3.dat
+ 2004-03-03 14:10:00 10,673 ----a-w C:\WINDOWS\system32\EPPICPattern4.dat
+ 2004-03-03 14:10:00 15,670 ----a-w C:\WINDOWS\system32\EPPICPattern5.dat
+ 2004-03-03 14:10:00 4,943 ----a-w C:\WINDOWS\system32\EPPICPattern6.dat
+ 2004-03-03 14:10:00 73,220 ----a-w C:\WINDOWS\system32\EPPICPrinterDB.dat
+ 2006-10-31 08:10:00 51,360 ----a-w C:\WINDOWS\system32\EpPicPrt.dll
- 2005-07-26 04:39:45 243,200 ----a-w C:\WINDOWS\system32\es.dll
+ 2008-07-07 20:32:22 253,952 ----a-w C:\WINDOWS\system32\es.dll
+ 2006-12-28 08:00:00 208,896 ----a-w C:\WINDOWS\system32\esint7e.dll
+ 2006-12-28 08:00:00 66,560 ----a-w C:\WINDOWS\system32\eswia7e.dll
+ 2006-03-10 08:00:00 3,584 ----a-w C:\WINDOWS\system32\eswiaml.dll
- 2007-10-10 23:55:51 132,608 ----a-w C:\WINDOWS\system32\extmgr.dll
+ 2008-06-23 16:57:27 133,120 ----a-w C:\WINDOWS\system32\extmgr.dll
- 2007-08-01 03:13:22 207,304 ----a-w C:\WINDOWS\system32\FNTCACHE.DAT
+ 2008-04-09 07:36:53 244,720 ----a-w C:\WINDOWS\system32\FNTCACHE.DAT
- 2007-06-19 13:31:19 282,112 ----a-w C:\WINDOWS\system32\gdi32.dll
+ 2008-02-20 06:51:05 282,624 ----a-w C:\WINDOWS\system32\gdi32.dll
+ 2006-04-02 23:52:08 1,851,546 ----a-w C:\WINDOWS\system32\gdql_lsa.dll
- 2006-10-04 02:47:52 109,360 ----a-w C:\WINDOWS\system32\GEARAspi.dll
+ 2008-04-17 20:12:54 107,368 ----a-w C:\WINDOWS\system32\GEARAspi.dll
+ 2005-11-21 20:17:38 135,168 ----a-w C:\WINDOWS\system32\GoProto.dll
+ 1998-10-16 01:28:16 85,504 ----a-w C:\WINDOWS\system32\HtmlWH.dll
- 2007-10-10 23:55:51 63,488 ----a-w C:\WINDOWS\system32\icardie.dll
+ 2008-06-23 16:57:28 63,488 ----a-w C:\WINDOWS\system32\icardie.dll
- 2007-10-10 10:59:40 70,656 ----a-w C:\WINDOWS\system32\ie4uinit.exe
+ 2008-06-23 09:20:25 70,656 ----a-w C:\WINDOWS\system32\ie4uinit.exe
- 2007-10-10 23:55:51 153,088 ----a-w C:\WINDOWS\system32\ieakeng.dll
+ 2008-06-23 16:57:29 153,088 ----a-w C:\WINDOWS\system32\ieakeng.dll
- 2007-10-10 23:55:51 230,400 ----a-w C:\WINDOWS\system32\ieaksie.dll
+ 2008-06-23 16:57:29 230,400 ----a-w C:\WINDOWS\system32\ieaksie.dll
- 2007-10-10 05:46:55 161,792 ----a-w C:\WINDOWS\system32\ieakui.dll
+ 2008-06-21 05:23:54 161,792 ----a-w C:\WINDOWS\system32\ieakui.dll
- 2007-10-10 23:55:52 383,488 ----a-w C:\WINDOWS\system32\ieapfltr.dll
+ 2008-06-23 16:57:29 383,488 ----a-w C:\WINDOWS\system32\ieapfltr.dll
- 2007-10-10 23:55:52 384,512 ----a-w C:\WINDOWS\system32\iedkcs32.dll
+ 2008-06-23 16:57:29 384,512 ----a-w C:\WINDOWS\system32\iedkcs32.dll
- 2007-10-10 23:55:54 6,065,664 ----a-w C:\WINDOWS\system32\ieframe.dll
+ 2008-06-23 16:57:33 6,066,176 ----a-w C:\WINDOWS\system32\ieframe.dll
- 2007-10-10 23:55:55 44,544 ----a-w C:\WINDOWS\system32\iernonce.dll
+ 2008-06-23 16:57:33 44,544 ----a-w C:\WINDOWS\system32\iernonce.dll
- 2007-10-10 23:55:55 267,776 ----a-w C:\WINDOWS\system32\iertutil.dll
+ 2008-06-23 16:57:34 267,776 ----a-w C:\WINDOWS\system32\iertutil.dll
- 2007-10-10 10:59:40 13,824 ----a-w C:\WINDOWS\system32\ieudinit.exe
+ 2008-06-23 09:20:26 13,824 ----a-w C:\WINDOWS\system32\ieudinit.exe
- 2007-08-21 06:15:44 683,520 ----a-w C:\WINDOWS\system32\inetcomm.dll
+ 2008-04-11 18:50:43 683,520 ----a-w C:\WINDOWS\system32\inetcomm.dll
- 2004-08-24 23:09:18 54,784 ----a-w C:\WINDOWS\system32\Inetwh32.dll
+ 1999-01-28 22:44:20 49,152 ----a-w C:\WINDOWS\system32\Inetwh32.dll
- 2007-07-12 09:22:00 135,168 ----a-w C:\WINDOWS\system32\java.exe
+ 2008-06-10 08:21:01 135,168 ----a-w C:\WINDOWS\system32\java.exe
- 2007-07-12 09:22:04 135,168 ----a-w C:\WINDOWS\system32\javaw.exe
+ 2008-06-10 08:21:04 135,168 ----a-w C:\WINDOWS\system32\javaw.exe
- 2007-07-12 10:22:38 139,264 ----a-w C:\WINDOWS\system32\javaws.exe
+ 2008-06-10 09:32:34 139,264 ----a-w C:\WINDOWS\system32\javaws.exe
- 2007-10-10 23:55:56 27,648 ----a-w C:\WINDOWS\system32\jsproxy.dll
+ 2008-06-23 16:57:35 27,648 ----a-w C:\WINDOWS\system32\jsproxy.dll
+ 2004-08-04 12:00:00 2,000 ----a-w C:\WINDOWS\system32\keyboard.drv
+ 2004-08-04 12:00:00 221,600 ----a-w C:\WINDOWS\system32\lanman.drv
- 2006-08-17 12:28:27 721,920 ----a-w C:\WINDOWS\system32\lsasrv.dll
+ 2007-11-07 09:26:56 721,920 ----a-w C:\WINDOWS\system32\lsasrv.dll
+ 2004-08-04 12:00:00 2,560 ----a-w C:\WINDOWS\system32\lz32.dll
+ 2008-03-25 02:32:44 218,496 ----a-r C:\WINDOWS\system32\Macromed\Flash\FlashUtil9f.exe
+ 2008-03-25 03:21:18 2,889,088 ----a-w C:\WINDOWS\system32\Macromed\Flash\NPSWF32.dll
+ 2008-03-25 03:21:20 218,496 ----a-w C:\WINDOWS\system32\Macromed\Flash\NPSWF32_FlashUtil.exe
- 2007-12-06 02:45:10 74,649 ----a-w C:\WINDOWS\system32\Macromed\Flash\uninstall_activeX.exe
+ 2008-04-25 01:01:39 74,649 ----a-w C:\WINDOWS\system32\Macromed\Flash\uninstall_activeX.exe
+ 2008-06-04 03:41:54 70,264 ----a-w C:\WINDOWS\system32\Macromed\Flash\uninstall_plugin.exe
+ 2008-09-10 20:59:32 32,768 ----a-w C:\WINDOWS\system32\mC02\mC022328.exe
+ 2004-08-04 12:00:00 73,376 ----a-w C:\WINDOWS\system32\mciavi.drv
+ 2004-08-04 12:00:00 25,264 ----a-w C:\WINDOWS\system32\mciseq.drv
+ 2004-08-04 12:00:00 28,160 ----a-w C:\WINDOWS\system32\mciwave.drv
- 2002-01-05 18:48:16 974,848 ----a-w C:\WINDOWS\system32\mfc70.dll
+ 2002-01-05 21:48:16 974,848 ----a-w C:\WINDOWS\system32\mfc70.dll
+ 2007-04-17 18:56:40 663,552 ----a-w C:\WINDOWS\system32\mgxoschk.dll
+ 2008-07-31 17:24:05 49,244 ---ha-w C:\WINDOWS\system32\mlfcache.dat
+ 2006-07-28 15:10:08 6,144 ----a-w C:\WINDOWS\system32\mot_ci.dll
+ 2004-08-04 12:00:00 2,032 ----a-w C:\WINDOWS\system32\mouse.drv
+ 2001-05-11 21:18:14 420,240 ----a-w C:\WINDOWS\system32\mpg4c32.dll
- 2007-12-02 23:00:05 18,684,536 ----a-w C:\WINDOWS\system32\MRT.exe
+ 2008-08-26 20:28:12 16,208,504 ----a-w C:\WINDOWS\system32\MRT.exe
+ 2004-08-04 12:00:00 20,480 ----a-w C:\WINDOWS\system32\msacm32.drv
- 2005-06-29 01:46:00 74,240 ----a-w C:\WINDOWS\system32\mscms.dll
+ 2008-06-24 16:23:05 74,240 ----a-w C:\WINDOWS\system32\mscms.dll
- 2007-04-13 11:21:14 271,360 ----a-w C:\WINDOWS\system32\mscoree.dll
+ 2007-10-24 08:47:38 282,112 ----a-w C:\WINDOWS\system32\mscoree.dll
- 2005-09-23 14:28:52 150,016 ----a-w C:\WINDOWS\system32\mscorier.dll
+ 2007-10-24 08:47:38 158,720 ----a-w C:\WINDOWS\system32\mscorier.dll
- 2005-09-23 14:28:52 74,240 ----a-w C:\WINDOWS\system32\mscories.dll
+ 2007-10-24 08:47:38 84,480 ----a-w C:\WINDOWS\system32\mscories.dll
- 2004-08-04 12:00:00 294,400 ----a-w C:\WINDOWS\system32\MSCTF.dll
+ 2008-02-26 11:59:50 294,912 ----a-w C:\WINDOWS\system32\msctf.dll
- 2004-08-04 12:00:00 512,029 ----a-w C:\WINDOWS\system32\msexch40.dll
+ 2008-03-25 04:50:28 518,944 ----a-w C:\WINDOWS\system32\msexch40.dll
- 2004-08-04 12:00:00 319,517 ----a-w C:\WINDOWS\system32\msexcl40.dll
+ 2008-03-25 04:50:30 326,432 ----a-w C:\WINDOWS\system32\msexcl40.dll
- 2007-10-10 23:55:56 459,264 ----a-w C:\WINDOWS\system32\msfeeds.dll
+ 2008-06-23 16:57:36 459,264 ----a-w C:\WINDOWS\system32\msfeeds.dll
- 2007-10-10 23:55:56 52,224 ----a-w C:\WINDOWS\system32\msfeedsbs.dll
+ 2008-06-23 16:57:36 52,224 ----a-w C:\WINDOWS\system32\msfeedsbs.dll
+ 2004-08-04 12:00:00 188,416 ----a-w C:\WINDOWS\system32\msh261.drv
+ 2004-08-04 19:00:00 294,912 ----a-w C:\WINDOWS\system32\msh263.drv
- 2007-10-30 23:42:28 3,590,656 ----a-w C:\WINDOWS\system32\mshtml.dll
+ 2008-06-24 17:57:40 3,592,192 ----a-w C:\WINDOWS\system32\mshtml.dll
- 2007-10-10 23:55:58 478,208 ----a-w C:\WINDOWS\system32\mshtmled.dll
+ 2008-06-23 16:57:39 477,696 ----a-w C:\WINDOWS\system32\mshtmled.dll
- 2004-08-04 12:00:00 1,507,356 ----a-w C:\WINDOWS\system32\msjet40.dll
+ 2008-03-25 04:50:34 1,516,568 ----a-w C:\WINDOWS\system32\msjet40.dll
- 2004-08-04 19:00:00 358,976 ----a-w C:\WINDOWS\system32\msjetoledb40.dll
+ 2008-03-25 04:50:40 355,112 ----a-w C:\WINDOWS\system32\msjetoledb40.dll
- 2004-08-04 12:00:00 151,583 ----a-w C:\WINDOWS\system32\msjint40.dll
+ 2008-03-27 08:12:54 151,583 ----a-w C:\WINDOWS\system32\msjint40.dll
- 2004-08-04 12:00:00 53,279 ----a-w C:\WINDOWS\system32\msjter40.dll
+ 2008-03-25 04:50:42 60,192 ----a-w C:\WINDOWS\system32\msjter40.dll
- 2004-08-04 12:00:00 241,693 ----a-w C:\WINDOWS\system32\msjtes40.dll
+ 2008-03-25 04:50:42 248,608 ----a-w C:\WINDOWS\system32\msjtes40.dll
- 2004-08-04 12:00:00 213,023 ----a-w C:\WINDOWS\system32\msltus40.dll
+ 2008-03-25 04:50:44 219,936 ----a-w C:\WINDOWS\system32\msltus40.dll
- 2004-08-04 12:00:00 348,189 ----a-w C:\WINDOWS\system32\mspbde40.dll
+ 2008-03-25 04:50:45 355,104 ----a-w C:\WINDOWS\system32\mspbde40.dll
- 2007-10-10 23:55:58 193,024 ----a-w C:\WINDOWS\system32\msrating.dll
+ 2008-06-23 16:57:39 193,024 ----a-w C:\WINDOWS\system32\msrating.dll
- 2004-08-04 12:00:00 421,919 ----a-w C:\WINDOWS\system32\msrd2x40.dll
+ 2008-03-25 04:50:47 432,928 ----a-w C:\WINDOWS\system32\msrd2x40.dll
- 2004-08-04 12:00:00 315,423 ----a-w C:\WINDOWS\system32\msrd3x40.dll
+ 2008-03-25 04:50:49 322,336 ----a-w C:\WINDOWS\system32\msrd3x40.dll
- 2004-08-04 12:00:00 552,989 ----a-w C:\WINDOWS\system32\msrepl40.dll
+ 2008-03-25 04:50:52 559,904 ----a-w C:\WINDOWS\system32\msrepl40.dll
- 2004-08-04 12:00:00 258,077 ----a-w C:\WINDOWS\system32\mstext40.dll
+ 2008-03-25 04:50:55 264,992 ----a-w C:\WINDOWS\system32\mstext40.dll
- 2007-10-10 23:55:59 671,232 ----a-w C:\WINDOWS\system32\mstime.dll
+ 2008-06-23 16:57:40 671,232 ----a-w C:\WINDOWS\system32\mstime.dll
- 2002-01-05 17:40:20 487,424 ----a-w C:\WINDOWS\system32\msvcp70.dll
+ 2002-01-05 19:40:18 487,424 ----a-w C:\WINDOWS\system32\msvcp70.dll
- 2003-03-19 03:14:52 499,712 ----a-w C:\WINDOWS\system32\msvcp71.dll
+ 2003-03-19 06:14:52 499,712 ----a-r C:\WINDOWS\system32\msvcp71.dll
- 2002-01-05 15:37:00 344,064 ----a-w C:\WINDOWS\system32\msvcr70.dll
+ 2002-01-05 20:37:26 344,064 ----a-w C:\WINDOWS\system32\msvcr70.dll
- 2003-02-21 11:42:22 348,160 ----a-w C:\WINDOWS\system32\msvcr71.dll
+ 2003-02-21 12:42:22 348,160 ----a-w C:\WINDOWS\system32\msvcr71.dll
- 2004-08-04 12:00:00 831,519 ----a-w C:\WINDOWS\system32\mswdat10.dll
+ 2008-03-25 04:50:57 838,432 ----a-w C:\WINDOWS\system32\mswdat10.dll
- 2004-08-04 12:00:00 245,248 ----a-w C:\WINDOWS\system32\mswsock.dll
+ 2008-06-20 17:41:10 245,248 ----a-w C:\WINDOWS\system32\mswsock.dll
- 2004-08-04 12:00:00 614,429 ----a-w C:\WINDOWS\system32\mswstr10.dll
+ 2008-03-25 04:50:58 621,344 ----a-w C:\WINDOWS\system32\mswstr10.dll
- 2004-08-04 12:00:00 348,189 ----a-w C:\WINDOWS\system32\msxbde40.dll
+ 2008-03-25 04:50:58 355,104 ----a-w C:\WINDOWS\system32\msxbde40.dll
+ 2003-04-19 00:29:26 44,544 ----a-w C:\WINDOWS\system32\msxml4a.dll
- 2003-04-19 06:29:26 82,432 ----a-w C:\WINDOWS\system32\msxml4r.dll
+ 2003-04-19 00:29:26 82,432 ----a-w C:\WINDOWS\system32\msxml4r.dll
- 2006-12-22 21:02:36 6,144 ----a-w C:\WINDOWS\system32\mui\0409\mscorees.dll
+ 2007-10-24 08:47:44 15,360 ----a-w C:\WINDOWS\system32\mui\0409\mscorees.dll
+ 2006-03-31 23:57:40 430,080 ----a-w C:\WINDOWS\system32\MXRestore.exe
+ 2004-07-06 17:52:10 811,008 ----a-w C:\WINDOWS\system32\NCTAudioCDGrabber2.dll
+ 2004-07-13 17:57:26 1,843,200 ----a-w C:\WINDOWS\system32\NCTAudioFile2.dll
+ 2004-07-13 17:58:10 315,392 ----a-w C:\WINDOWS\system32\NCTAudioPlayer2.dll
- 2007-10-10 23:55:59 102,400 ----a-w C:\WINDOWS\system32\occache.dll
+ 2008-06-23 16:57:40 102,912 ----a-w C:\WINDOWS\system32\occache.dll
+ 2008-08-29 12:11:24 166,400 ----a-w C:\WINDOWS\system32\offeojxjdbht.dll
- 2007-05-17 11:28:05 549,376 ----a-w C:\WINDOWS\system32\oleaut32.dll
+ 2007-12-04 18:38:13 550,912 ----a-w C:\WINDOWS\system32\oleaut32.dll
- 2007-12-07 04:26:44 63,016 ----a-w C:\WINDOWS\system32\perfc009.dat
+ 2008-04-12 08:08:09 64,200 ----a-w C:\WINDOWS\system32\perfc009.dat
- 2007-12-07 04:26:44 402,406 ----a-w C:\WINDOWS\system32\perfh009.dat
+ 2008-04-12 08:08:09 407,670 ----a-w C:\WINDOWS\system32\perfh009.dat
+ 2006-10-21 00:11:04 126,976 ----a-w C:\WINDOWS\system32\PhotoImpression Slideshow.scr
+ 2004-04-10 01:19:18 294,912 ----a-w C:\WINDOWS\system32\PhotoImpression Slideshow\ArtistTitle.dll
+ 2003-06-26 21:54:10 24,576 ----a-w C:\WINDOWS\system32\PhotoImpression Slideshow\ArtistTitleRes.dll
+ 2006-02-10 19:27:10 167,936 ----a-w C:\WINDOWS\system32\PhotoImpression Slideshow\dtype32.dll
+ 2006-02-10 19:27:10 155,648 ----a-w C:\WINDOWS\system32\PhotoImpression Slideshow\dtype32x.dll
+ 2005-12-20 00:09:00 819,200 ----a-w C:\WINDOWS\system32\PhotoImpression Slideshow\EzDll.dll
+ 2004-12-14 20:00:00 430,080 ----a-w C:\WINDOWS\system32\PhotoImpression Slideshow\fpxlib.dll
+ 2006-01-24 18:20:00 1,645,320 ----a-w C:\WINDOWS\system32\PhotoImpression Slideshow\gdiplus.dll
+ 2006-09-18 18:51:00 73,835 ----a-w C:\WINDOWS\system32\PhotoImpression Slideshow\ImgCtrl.dll
+ 2006-05-30 18:46:44 245,760 ----a-w C:\WINDOWS\system32\PhotoImpression Slideshow\kgl.dll
+ 2006-11-02 22:35:30 35,584 ----a-w C:\WINDOWS\system32\PhotoImpression Slideshow\MagCore.dll
+ 2006-09-30 18:40:24 340,044 ----a-w C:\WINDOWS\system32\PhotoImpression Slideshow\magengin.dll
+ 2006-09-18 18:43:00 28,672 ----a-w C:\WINDOWS\system32\PhotoImpression Slideshow\magFileIO.dll
+ 2006-09-18 19:27:00 430,080 ----a-w C:\WINDOWS\system32\PhotoImpression Slideshow\magFpxio.dll
+ 2005-06-20 22:38:32 98,304 ----a-w C:\WINDOWS\system32\PhotoImpression Slideshow\maghelpr.dll
+ 2006-11-02 22:34:40 56,064 ----a-w C:\WINDOWS\system32\PhotoImpression Slideshow\MagicFrame.dll
+ 2006-11-02 22:28:42 60,160 ----a-w C:\WINDOWS\system32\PhotoImpression Slideshow\MagPCMac.dll
+ 2006-09-29 22:55:16 118,784 ----a-w C:\WINDOWS\system32\PhotoImpression Slideshow\magPltfm.dll
+ 2006-09-18 18:51:00 233,472 ----a-w C:\WINDOWS\system32\PhotoImpression Slideshow\magTools.dll
+ 2006-11-02 22:29:22 158,464 ----a-w C:\WINDOWS\system32\PhotoImpression Slideshow\MagUIEngine.dll
+ 2006-11-02 22:34:54 150,272 ----a-w C:\WINDOWS\system32\PhotoImpression Slideshow\MagUIImage.dll
+ 2006-11-02 22:30:26 88,832 ----a-w C:\WINDOWS\system32\PhotoImpression Slideshow\MagUIInter.dll
+ 2005-05-27 23:09:00 1,024,082 ----a-w C:\WINDOWS\system32\PhotoImpression Slideshow\MFC42LU.DLL
+ 2005-05-27 22:58:00 69,632 ----a-w C:\WINDOWS\system32\PhotoImpression Slideshow\MSLUIRT.dll
+ 2005-05-27 22:58:00 393,216 ----a-w C:\WINDOWS\system32\PhotoImpression Slideshow\MSLUP60.dll
+ 2005-05-27 22:58:00 249,856 ----a-w C:\WINDOWS\system32\PhotoImpression Slideshow\MSLURT.dll
+ 2003-11-12 21:52:10 499,712 ----a-r C:\WINDOWS\system32\PhotoImpression Slideshow\msvcp71.dll
+ 2003-02-21 13:42:22 348,160 ----a-r C:\WINDOWS\system32\PhotoImpression Slideshow\msvcr71.dll
+ 2002-08-30 03:41:08 323,072 ----a-w C:\WINDOWS\system32\PhotoImpression Slideshow\msvcrt.dll
+ 2006-07-12 17:49:16 614,481 ----a-w C:\WINDOWS\system32\PhotoImpression Slideshow\RawEngine.dll
+ 2006-09-30 18:34:40 622,592 ----a-w C:\WINDOWS\system32\PhotoImpression Slideshow\ToolsCtrl.dll
+ 2005-12-07 19:37:00 45,056 ----a-w C:\WINDOWS\system32\PhotoImpression Slideshow\uaswmf.dll
+ 2006-09-11 16:38:28 1,146,880 ----a-w C:\WINDOWS\system32\PhotoImpression Slideshow\uDXPubTool.dll
+ 2006-02-23 23:44:00 888,832 ----a-w C:\WINDOWS\system32\PhotoImpression Slideshow\uEzDll.dll
+ 2004-12-15 01:43:00 245,408 ----a-w C:\WINDOWS\system32\PhotoImpression Slideshow\unicows.dll
+ 2006-10-20 18:01:44 36,864 ----a-w C:\WINDOWS\system32\PhotoImpression Slideshow\uScreenPlayer.dll
+ 2006-04-21 00:42:08 622,592 ----a-w C:\WINDOWS\system32\PhotoImpression Slideshow\uSlideShow.dll
+ 2006-08-23 00:56:12 1,785,856 ----a-w C:\WINDOWS\system32\PhotoImpression Slideshow\uVDibTool.dll
+ 2006-01-24 21:55:38 372,736 ----a-w C:\WINDOWS\system32\PhotoImpression Slideshow\uVideoLib.dll
+ 2005-03-30 23:25:00 155,648 ----a-w C:\WINDOWS\system32\PhotoImpression Slideshow\uWMVDLL.dll
+ 2006-10-20 08:10:00 108,704 ----a-w C:\WINDOWS\system32\PICEntry.dll
+ 2006-10-20 08:10:00 80,024 ----a-w C:\WINDOWS\system32\PICSDK.dll
+ 2006-10-20 08:10:00 501,912 ----a-w C:\WINDOWS\system32\PICSDK2.dll
+ 2008-09-16 21:59:18 162,834 ----a-w C:\WINDOWS\system32\pin\CONFG32I9.exe
- 2006-10-17 19:58:08 44,544 ----a-w C:\WINDOWS\system32\pngfilt.dll
+ 2008-06-23 16:57:40 44,544 ----a-w C:\WINDOWS\system32\pngfilt.dll
+ 2008-06-17 04:44:58 66,872 ----a-w C:\WINDOWS\system32\PnkBstrA.exe
+ 2008-06-17 04:52:55 107,832 ----a-w C:\WINDOWS\system32\PnkBstrB.exe
- 2007-10-29 22:43:03 1,287,680 ----a-w C:\WINDOWS\system32\quartz.dll
+ 2008-05-07 05:18:48 1,287,680 ----a-w C:\WINDOWS\system32\quartz.dll
+ 2004-08-04 19:00:00 23,552 -c--a-w C:\WINDOWS\system32\ReinstallBackups\0006\DriverFiles\i386\wdmaud.drv
+ 2008-09-04 20:48:10 402,200 ----a-w C:\WINDOWS\system32\RES\comec130t.exe
- 2004-08-24 23:09:18 1,044,480 ----a-w C:\WINDOWS\system32\roboex32.dll
+ 2003-07-25 00:01:04 1,044,480 ----a-w C:\WINDOWS\system32\ROBOEX32.DLL
+ 2006-08-01 21:01:08 438,272 ----a-w C:\WINDOWS\system32\SkinCrafter.dll
+ 2008-07-19 05:10:20 36,552 ----a-w C:\WINDOWS\system32\SoftwareDistribution\Setup\ServiceStartup\wups.dll\7.2.6001.784\wups.dll
+ 2008-07-19 05:10:40 45,768 ----a-w C:\WINDOWS\system32\SoftwareDistribution\Setup\ServiceStartup\wups2.dll\7.2.6001.784\wups2.dll
+ 2004-08-04 12:00:00 1,744 ----a-w C:\WINDOWS\system32\sound.drv
- 2006-09-26 00:58:48 14,640 ----a-w C:\WINDOWS\system32\spmsg.dll
+ 2007-11-30 12:39:22 17,272 ----a-w C:\WINDOWS\system32\spmsg.dll
+ 2007-02-03 02:57:42 202,912 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\3\E_DUPA20.EXE
+ 2007-01-22 10:00:02 6,656 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\3\E_DUPA2E.DLL
+ 2007-03-01 13:01:00 397,824 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\3\E_FABRCAA.DLL
+ 2007-03-01 13:01:00 3,648 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\3\E_FAIFCAA.DAT
+ 2007-01-22 09:02:00 138,752 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\3\E_FAIRCAA.DLL
+ 2006-12-20 13:00:00 172,032 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\3\E_FAMTCAA.EXE
+ 2007-03-02 13:01:00 667,136 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\3\E_FAPRCAA.DLL
+ 2007-01-25 13:00:00 155,648 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\3\E_FARNCAA.EXE
+ 2006-11-13 13:00:00 129,536 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\3\E_FASKCAA.DLL
+ 2007-03-06 08:01:00 454,656 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\3\E_FASOCAA.DLL
+ 2007-03-01 13:01:00 64,512 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\3\E_FASRCAA.DLL
+ 2007-03-01 13:01:00 180,736 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\3\E_FATICAA.EXE
+ 2006-11-13 09:00:00 23,552 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\3\E_FAUDCAA.DLL
+ 2007-02-21 13:01:00 32,768 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\3\E_FBA6CAA.DLL
+ 2006-11-30 13:12:00 172,032 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\3\E_FBAPCAA.DLL
+ 2006-11-16 09:01:00 176,128 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\3\E_FBCSCAA.EXE
+ 2007-01-30 13:03:00 35,840 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\3\E_FBL6CAA.DLL
+ 2006-11-13 12:00:00 458,752 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\3\E_FCONCAA.DLL
+ 2007-04-10 12:00:00 71,680 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\3\E_FDSPCAA.DLL
+ 2007-02-26 08:01:00 9,728 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\3\E_FGEPCAA.DLL
+ 2006-09-21 11:04:00 18,432 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\3\E_FGRCCAA.DLL
+ 2007-01-24 09:00:00 529,920 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\3\E_FHBRCAA.DLL
+ 2006-01-23 12:20:00 325,632 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\3\E_FHM0CAA.DLL
+ 2007-01-24 09:00:00 33,792 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\3\E_FHSRCAA.DLL
+ 2005-11-30 12:20:00 212,992 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\3\E_FHT0CAA.DLL
+ 2007-01-22 18:03:00 218,112 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\3\E_FHUTCAA.DLL
+ 2007-01-22 18:03:00 105,984 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\3\E_FHUTCAA.EXE
+ 2007-01-10 12:00:00 403,456 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\3\E_FJBCCAA.DLL
+ 2007-01-10 13:00:00 119,296 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\3\E_FMAICAA.DLL
+ 2006-05-18 12:20:00 49,664 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\3\E_FMW0CAA.DLL
+ 2005-04-19 02:10:02 258,114 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\3\E_FOKACAA.DLL
+ 2006-10-31 12:00:00 196,608 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\3\E_FPRECAA.EXE
+ 2006-10-31 12:00:00 626,688 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\3\E_FPRUCAA.DLL
+ 2006-09-26 12:20:00 997,888 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\3\E_FSR0CAA.DLL
+ 2006-12-25 15:01:00 723,456 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\3\E_FUI1CAA.DLL
+ 2007-01-23 14:00:00 1,401,344 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\3\E_FUICCAA.DLL
+ 2006-10-30 14:01:00 4,608 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\3\E_FUIPCAA.DLL
+ 2007-01-22 15:01:00 187,392 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\3\E_FUIRCAA.DLL
+ 2007-01-11 12:02:00 113,664 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\3\E_S40RP7.EXE
+ 2006-11-30 13:12:00 172,032 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\3\EBAPI4.DLL
+ 2006-04-19 14:00:00 34,304 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\3\EBPBIDI.DLL
+ 2007-02-06 10:07:00 296,448 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\3\EPSET32.DLL
+ 2004-04-21 08:00:00 5,729 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\3\EPUPDATE.DAT
+ 2006-11-01 14:18:00 723,128 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\3\EPUPDATE.EXE
+ 2007-02-03 02:57:42 202,912 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\epsonstylus_cx4400f57e\E_DUPA20.EXE
+ 2007-01-22 10:00:02 6,656 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\epsonstylus_cx4400f57e\E_DUPA2E.DLL
+ 2007-03-01 13:01:00 397,824 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\epsonstylus_cx4400f57e\E_FABRCAA.DLL
+ 2007-03-01 13:01:00 3,648 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\epsonstylus_cx4400f57e\E_FAIFCAA.DAT
+ 2007-01-22 09:02:00 138,752 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\epsonstylus_cx4400f57e\E_FAIRCAA.DLL
+ 2006-12-20 13:00:00 172,032 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\epsonstylus_cx4400f57e\E_FAMTCAA.EXE
+ 2007-03-02 13:01:00 667,136 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\epsonstylus_cx4400f57e\E_FAPRCAA.DLL
+ 2007-01-25 13:00:00 155,648 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\epsonstylus_cx4400f57e\E_FARNCAA.EXE
+ 2006-11-13 13:00:00 129,536 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\epsonstylus_cx4400f57e\E_FASKCAA.DLL
+ 2007-03-06 08:01:00 454,656 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\epsonstylus_cx4400f57e\E_FASOCAA.DLL
+ 2007-03-01 13:01:00 64,512 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\epsonstylus_cx4400f57e\E_FASRCAA.DLL
+ 2007-03-01 13:01:00 180,736 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\epsonstylus_cx4400f57e\E_FATICAA.EXE
+ 2006-11-13 08:00:00 23,552 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\epsonstylus_cx4400f57e\E_FAUDCAA.DLL
+ 2007-02-21 13:01:00 32,768 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\epsonstylus_cx4400f57e\E_FBA6CAA.DLL
+ 2006-11-30 12:12:00 172,032 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\epsonstylus_cx4400f57e\E_FBAPCAA.DLL
+ 2006-11-16 09:01:00 176,128 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\epsonstylus_cx4400f57e\E_FBCSCAA.EXE
+ 2007-01-30 13:03:00 35,840 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\epsonstylus_cx4400f57e\E_FBL6CAA.DLL
+ 2006-11-13 11:00:00 458,752 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\epsonstylus_cx4400f57e\E_FCONCAA.DLL
+ 2007-01-10 12:00:00 71,680 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\epsonstylus_cx4400f57e\E_FDSPCAA.DLL
+ 2007-02-26 08:01:00 9,728 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\epsonstylus_cx4400f57e\E_FGEPCAA.DLL
+ 2006-09-21 10:04:00 18,432 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\epsonstylus_cx4400f57e\E_FGRCCAA.DLL
+ 2007-01-24 08:00:00 529,920 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\epsonstylus_cx4400f57e\E_FHBRCAA.DLL
+ 2006-01-23 11:20:00 325,632 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\epsonstylus_cx4400f57e\E_FHM0CAA.DLL
+ 2007-01-24 08:00:00 33,792 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\epsonstylus_cx4400f57e\E_FHSRCAA.DLL
+ 2005-11-30 11:20:00 212,992 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\epsonstylus_cx4400f57e\E_FHT0CAA.DLL
+ 2007-01-22 17:03:00 218,112 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\epsonstylus_cx4400f57e\E_FHUTCAA.DLL
+ 2007-01-22 17:03:00 105,984 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\epsonstylus_cx4400f57e\E_FHUTCAA.EXE
+ 2007-01-10 11:00:00 403,456 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\epsonstylus_cx4400f57e\E_FJBCCAA.DLL
+ 2007-01-10 12:00:00 119,296 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\epsonstylus_cx4400f57e\E_FMAICAA.DLL
+ 2006-05-18 11:20:00 49,664 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\epsonstylus_cx4400f57e\E_FMW0CAA.DLL
+ 2005-04-19 01:10:02 258,114 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\epsonstylus_cx4400f57e\E_FOKACAA.DLL
+ 2006-10-31 11:00:00 196,608 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\epsonstylus_cx4400f57e\E_FPRECAA.EXE
+ 2006-10-31 11:00:00 626,688 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\epsonstylus_cx4400f57e\E_FPRUCAA.DLL
+ 2006-09-26 11:20:00 997,888 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\epsonstylus_cx4400f57e\E_FSR0CAA.DLL
+ 2006-12-25 15:01:00 723,456 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\epsonstylus_cx4400f57e\E_FUI1CAA.DLL
+ 2007-01-23 13:00:00 1,401,344 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\epsonstylus_cx4400f57e\E_FUICCAA.DLL
+ 2006-10-30 13:01:00 4,608 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\epsonstylus_cx4400f57e\E_FUIPCAA.DLL
+ 2007-01-22 14:01:00 187,392 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\epsonstylus_cx4400f57e\E_FUIRCAA.DLL
+ 2007-01-11 12:02:00 113,664 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\epsonstylus_cx4400f57e\E_S40RP7.EXE
+ 2006-11-30 12:12:00 172,032 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\epsonstylus_cx4400f57e\EBAPI4.DLL
+ 2006-04-19 13:00:00 34,304 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\epsonstylus_cx4400f57e\EBPBIDI.DLL
+ 2007-02-06 10:07:00 296,448 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\epsonstylus_cx4400f57e\EPSET32.DLL
+ 2004-04-21 08:00:00 5,729 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\epsonstylus_cx4400f57e\EPUPDATE.DAT
+ 2006-11-01 13:18:00 723,128 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\epsonstylus_cx4400f57e\EPUPDATE.EXE
+ 2004-04-21 08:00:00 5,729 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\EPUPDATE.DAT
+ 2006-11-01 14:18:00 723,128 ----a-w C:\WINDOWS\system32\spool\drivers\w32x86\EPUPDATE.EXE
+ 2004-08-04 12:00:00 3,360 ----a-w C:\WINDOWS\system32\system.drv
+ 2004-08-04 12:00:00 4,048 ----a-w C:\WINDOWS\system32\timer.drv
+ 2003-03-14 19:32:54 24,576 ----a-w C:\WINDOWS\system32\TTI32.dll
+ 2003-03-14 19:32:54 24,576 ----a-w C:\WINDOWS\system32\TTIC32.dll
- 2007-11-13 11:31:11 60,416 ----a-w C:\WINDOWS\system32\tzchange.exe
+ 2008-07-14 11:09:18 62,976 ----a-w C:\WINDOWS\system32\tzchange.exe
- 2007-10-10 23:55:59 105,984 ----a-w C:\WINDOWS\system32\url.dll
+ 2008-06-23 16:57:40 105,984 ----a-w C:\WINDOWS\system32\url.dll
- 2007-10-10 23:56:00 1,159,680 ----a-w C:\WINDOWS\system32\urlmon.dll
+ 2008-06-23 16:57:40 1,159,680 ----a-w C:\WINDOWS\system32\urlmon.dll
+ 2004-12-09 18:21:20 73,728 ----a-w C:\WINDOWS\system32\vc7api.dll
+ 2005-11-23 23:17:36 253,952 ----a-w C:\WINDOWS\system32\vc7comm.dll
+ 2005-06-09 22:32:14 278,528 ----a-w C:\WINDOWS\system32\vc7dlg.dll
+ 2004-10-29 15:56:26 24,064 ----a-w C:\WINDOWS\system32\VC7Env.dll
+ 2005-04-19 16:47:48 163,840 ----a-w C:\WINDOWS\system32\vc7extse.dll
+ 2005-05-20 17:30:30 53,248 ----a-w C:\WINDOWS\system32\vc7op.dll
+ 2005-03-02 20:35:06 53,248 ----a-w C:\WINDOWS\system32\vc7perm.dll
+ 2005-06-15 21:03:08 81,920 ----a-w C:\WINDOWS\system32\vc7prop.dll
+ 2005-06-13 17:43:06 77,824 ----a-w C:\WINDOWS\system32\VC7Scsi.dll
+ 2005-02-28 20:01:12 172,032 ----a-w C:\WINDOWS\system32\vc7sec.dll
+ 2004-11-02 18:56:02 49,152 ----a-w C:\WINDOWS\system32\vc7upd.dll
+ 2004-08-04 12:00:00 2,176 ----a-w C:\WINDOWS\system32\vga.drv
+ 2007-03-09 16:37:54 139,264 ----a-w C:\WINDOWS\system32\viscomqtde.dll
+ 2007-03-09 16:36:48 81,920 ----a-w C:\WINDOWS\system32\viscomwave.dll
+ 2004-08-04 19:00:00 23,552 ----a-w C:\WINDOWS\system32\wdmaud.drv
- 2007-10-10 23:56:00 232,960 ----a-w C:\WINDOWS\system32\webcheck.dll
+ 2008-06-23 16:57:41 233,472 ----a-w C:\WINDOWS\system32\webcheck.dll
+ 2004-08-04 12:00:00 13,600 ----a-w C:\WINDOWS\system32\wfwnet.drv
- 2007-03-08 13:47:48 1,843,584 ----a-w C:\WINDOWS\system32\win32k.sys
+ 2008-03-19 09:47:00 1,845,248 ----a-w C:\WINDOWS\system32\win32k.sys
- 2007-10-10 23:56:00 824,832 ----a-w C:\WINDOWS\system32\wininet.dll
+ 2008-06-23 16:57:41 826,368 ----a-w C:\WINDOWS\system32\wininet.dll
+ 2004-08-04 12:00:00 2,864 ----a-w C:\WINDOWS\system32\winsock.dll
+ 2004-08-04 12:00:00 146,432 ----a-w C:\WINDOWS\system32\winspool.drv
+ 2004-08-04 12:00:00 2,112 ----a-w C:\WINDOWS\system32\winspool.exe
+ 1999-08-09 22:40:56 163,600 ----a-w C:\WINDOWS\system32\wmaudsdk.dll
- 2006-10-19 05:47:20 295,936 ----a-w C:\WINDOWS\system32\wmpeffects.dll
+ 2008-06-25 01:12:58 295,936 ----a-w C:\WINDOWS\system32\wmpeffects.dll
+ 2001-05-17 01:54:44 309,616 ----a-w C:\WINDOWS\system32\wmv8dmod.dll
+ 2007-08-07 19:32:16 57,344 ----a-w C:\WINDOWS\system32\Wnaspint.dll
+ 2004-08-04 12:00:00 2,736 ----a-w C:\WINDOWS\system32\wowdeb.exe
+ 2008-05-05 16:16:46 127,488 ----a-w C:\WINDOWS\system32\wp\xerd2140.exe
- 2007-07-31 03:19:36 549,720 ----a-w C:\WINDOWS\system32\wuapi.dll
+ 2008-07-19 05:09:44 563,912 ----a-w C:\WINDOWS\system32\wuapi.dll
- 2007-07-31 03:19:16 53,080 ----a-w C:\WINDOWS\system32\wuauclt.exe
+ 2008-07-19 05:10:42 53,448 ----a-w C:\WINDOWS\system32\wuauclt.exe
- 2007-07-31 03:19:42 1,712,984 ----a-w C:\WINDOWS\system32\wuaueng.dll
+ 2008-07-19 05:09:42 1,811,656 ----a-w C:\WINDOWS\system32\wuaueng.dll
- 2007-07-31 03:19:32 325,976 ----a-w C:\WINDOWS\system32\wucltui.dll
+ 2008-07-19 05:09:46 325,832 ----a-w C:\WINDOWS\system32\wucltui.dll
- 2007-07-31 03:19:28 203,096 ----a-w C:\WINDOWS\system32\wuweb.dll
+ 2008-07-19 05:09:44 205,000 ----a-w C:\WINDOWS\system32\wuweb.dll
+ 2006-02-03 15:41:26 14,032 ----a-w C:\WINDOWS\system32\x3daudio1_0.dll
+ 2007-01-08 22:30:42 15,128 ----a-w C:\WINDOWS\system32\x3daudio1_1.dll
+ 2006-02-03 15:42:06 230,096 ----a-w C:\WINDOWS\system32\xactengine2_0.dll
+ 2006-03-31 19:39:48 229,584 ----a-w C:\WINDOWS\system32\xactengine2_1.dll
+ 2006-05-31 14:24:16 230,168 ----a-w C:\WINDOWS\system32\xactengine2_2.dll
+ 2006-07-28 16:30:32 236,824 ----a-w C:\WINDOWS\system32\xactengine2_3.dll
+ 2006-09-28 23:05:56 237,848 ----a-w C:\WINDOWS\system32\xactengine2_4.dll
+ 2006-12-08 19:02:00 251,672 ----a-w C:\WINDOWS\system32\xactengine2_5.dll
+ 2007-01-24 22:27:30 255,848 ----a-w C:\WINDOWS\system32\xactengine2_6.dll
+ 2006-03-31 19:39:24 62,672 ----a-w C:\WINDOWS\system32\xinput1_1.dll
+ 2006-07-28 16:30:14 62,744 ----a-w C:\WINDOWS\system32\xinput1_2.dll
+ 2006-09-28 23:04:02 68,888 ----a-w C:\WINDOWS\system32\xinput1_3.dll
+ 2005-12-06 01:07:30 61,136 ----a-w C:\WINDOWS\system32\xinput9_1_0.dll
+ 1999-12-07 10:03:00 73,216 ----a-w C:\WINDOWS\twain_32\escndv\es007e\ade.dll
+ 1999-04-27 08:17:00 3,136 ----a-w C:\WINDOWS\twain_32\escndv\es007e\ade001.bin
+ 2006-03-10 08:00:00 77,824 ----a-w C:\WINDOWS\twain_32\escndv\es007e\esddc.dll
+ 2006-10-24 08:00:00 188,416 ----a-w C:\WINDOWS\twain_32\escndv\es007e\esdevcl.dll
+ 2006-10-24 08:00:00 131,072 ----a-w C:\WINDOWS\twain_32\escndv\es007e\esdevif.dll
+ 2006-03-08 08:00:00 49,152 ----a-w C:\WINDOWS\twain_32\escndv\es007e\esdscl.dll
+ 2006-12-12 08:00:00 425,984 ----a-w C:\WINDOWS\twain_32\escndv\es007e\esdtr.dll
+ 2006-08-30 08:00:00 94,208 ----a-w C:\WINDOWS\twain_32\escndv\es007e\esdtr2.dll
+ 2006-03-06 08:00:00 172,032 ----a-w C:\WINDOWS\twain_32\escndv\es007e\esfit.dll
+ 2005-09-27 08:00:00 53,248 ----a-w C:\WINDOWS\twain_32\escndv\es007e\esicm.dll
+ 2006-07-05 08:00:00 561,152 ----a-w C:\WINDOWS\twain_32\escndv\es007e\esimfl.dll
+ 2006-10-24 08:00:00 229,376 ----a-w C:\WINDOWS\twain_32\escndv\es007e\esimgctl.dll
+ 2006-08-01 08:00:00 1,658,880 ----a-w C:\WINDOWS\twain_32\escndv\es007e\esimgdet.dll
+ 2006-10-24 08:00:00 348,267 ----a-w C:\WINDOWS\twain_32\escndv\es007e\esmps.dll
+ 2006-03-08 08:00:00 561,272 ----a-w C:\WINDOWS\twain_32\escndv\es007e\esmpsres.dll
+ 2006-04-17 08:00:00 3,555,328 ----a-w C:\WINDOWS\twain_32\escndv\es007e\esres.dll
+ 2006-12-13 08:00:00 327,680 ----a-w C:\WINDOWS\twain_32\escndv\es007e\esscncl.dll
+ 2006-03-08 08:00:00 40,960 ----a-w C:\WINDOWS\twain_32\escndv\es007e\estwm.exe
+ 2006-10-24 08:00:00 249,856 ----a-w C:\WINDOWS\twain_32\escndv\es007e\estwpmg.dll
+ 2006-12-13 08:00:00 675,840 ----a-w C:\WINDOWS\twain_32\escndv\es007e\esui.dll
+ 2006-03-08 08:00:00 126,976 ----a-w C:\WINDOWS\twain_32\escndv\es007e\esutwb.dll
+ 2006-05-26 08:00:00 73,728 ----a-w C:\WINDOWS\twain_32\escndv\es007e\ffmt\epbmp.dll
+ 2006-03-08 08:00:00 45,056 ----a-w C:\WINDOWS\twain_32\escndv\es007e\ffmt\epbmpres.dll
+ 2006-02-15 08:00:00 98,304 ----a-w C:\WINDOWS\twain_32\escndv\es007e\ffmt\epipd.dll
+ 2006-06-23 08:00:00 151,552 ----a-w C:\WINDOWS\twain_32\escndv\es007e\ffmt\epjpg.dll
+ 2006-03-08 08:00:00 45,056 ----a-w C:\WINDOWS\twain_32\escndv\es007e\ffmt\epjpgres.dll
+ 2006-10-24 08:00:00 94,208 ----a-w C:\WINDOWS\twain_32\escndv\es007e\ffmt\epmtf.dll
+ 2006-03-08 08:00:00 45,056 ----a-w C:\WINDOWS\twain_32\escndv\es007e\ffmt\epmtfres.dll
+ 2006-10-24 08:00:00 102,400 ----a-w C:\WINDOWS\twain_32\escndv\es007e\ffmt\eppdf.dll
+ 2006-04-17 08:00:00 49,152 ----a-w C:\WINDOWS\twain_32\escndv\es007e\ffmt\eppdfres.dll
+ 2006-05-26 08:00:00 86,016 ----a-w C:\WINDOWS\twain_32\escndv\es007e\ffmt\eppij.dll
+ 2006-03-08 08:00:00 45,056 ----a-w C:\WINDOWS\twain_32\escndv\es007e\ffmt\eppijres.dll
+ 2006-05-26 08:00:00 86,016 ----a-w C:\WINDOWS\twain_32\escndv\es007e\ffmt\eppit.dll
+ 2006-03-08 08:00:00 45,056 ----a-w C:\WINDOWS\twain_32\escndv\es007e\ffmt\eppitres.dll
+ 2006-06-23 08:00:00 94,208 ----a-w C:\WINDOWS\twain_32\escndv\es007e\ffmt\eptif.dll
+ 2006-03-08 08:00:00 45,056 ----a-w C:\WINDOWS\twain_32\escndv\es007e\ffmt\eptifres.dll
+ 2005-08-29 08:00:00 143,360 ----a-w C:\WINDOWS\twain_32\escndv\es007e\ffmt\esexf.dll
+ 2005-08-29 08:00:00 98,304 ----a-w C:\WINDOWS\twain_32\escndv\es007e\ffmt\espimtif.dll
+ 2006-03-08 08:00:00 45,056 ----a-w C:\WINDOWS\twain_32\escndv\es007e\ffmt\local\epbmpres.dll
+ 2006-03-08 08:00:00 45,056 ----a-w C:\WINDOWS\twain_32\escndv\es007e\ffmt\local\epjpgres.dll
+ 2006-03-08 08:00:00 45,056 ----a-w C:\WINDOWS\twain_32\escndv\es007e\ffmt\local\epmtfres.dll
+ 2006-04-17 08:00:00 49,152 ----a-w C:\WINDOWS\twain_32\escndv\es007e\ffmt\local\eppdfres.dll
+ 2006-03-08 08:00:00 45,056 ----a-w C:\WINDOWS\twain_32\escndv\es007e\ffmt\local\eppijres.dll
+ 2006-03-08 08:00:00 45,056 ----a-w C:\WINDOWS\twain_32\escndv\es007e\ffmt\local\eppitres.dll
+ 2006-03-08 08:00:00 45,056 ----a-w C:\WINDOWS\twain_32\escndv\es007e\ffmt\local\eptifres.dll
+ 2006-03-08 08:00:00 561,272 ----a-w C:\WINDOWS\twain_32\escndv\es007e\local\esmpsres.dll
+ 2006-04-17 08:00:00 3,555,328 ----a-w C:\WINDOWS\twain_32\escndv\es007e\local\esres.dll
+ 2006-03-08 08:00:00 118,784 ----a-w C:\WINDOWS\twain_32\escndv\escndv.exe
+ 2006-03-08 08:00:00 45,056 ----a-w C:\WINDOWS\twain_32\escndv\escndvrs.dll
+ 2006-03-08 08:00:00 40,960 ----a-w C:\WINDOWS\twain_32\escndv\estwm.exe
+ 2006-03-08 08:00:00 45,056 ----a-w C:\WINDOWS\twain_32\escndv\local\escndvrs.dll
+ 2000-08-31 15:00:00 49,152 ----a-w C:\WINDOWS\VFind.exe
+ 2008-04-12 08:07:47 8,192 ----a-w C:\WINDOWS\WinSxS\MSIL_IEExecRemote_b03f5f7f11d50a3a_2.0.0.0_x-ww_6e57c34e\IEExecRemote.dll
+ 2005-09-23 06:49:12 95,744 ----a-w C:\WINDOWS\WinSxS\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww_6e805841\ATL80.dll
+ 2007-10-24 08:47:56 479,232 ----a-w C:\WINDOWS\WinSxS\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.1433_x-ww_5cf844d2\msvcm80.dll
+ 2007-10-24 08:47:56 558,080 ----a-w C:\WINDOWS\WinSxS\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.1433_x-ww_5cf844d2\msvcp80.dll
+ 2007-10-24 08:47:56 635,904 ----a-w C:\WINDOWS\WinSxS\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.1433_x-ww_5cf844d2\msvcr80.dll
+ 2006-06-05 22:14:28 479,232 ----a-w C:\WINDOWS\WinSxS\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.163_x-ww_681e29fb\msvcm80.dll
+ 2006-06-05 22:14:28 548,864 ----a-w C:\WINDOWS\WinSxS\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.163_x-ww_681e29fb\msvcp80.dll
+ 2006-06-05 22:14:28 626,688 ----a-w C:\WINDOWS\WinSxS\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.163_x-ww_681e29fb\msvcr80.dll
+ 2005-09-23 08:16:02 1,093,632 ----a-w C:\WINDOWS\WinSxS\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww_dec6ddd2\mfc80.dll
+ 2005-09-23 08:16:06 1,079,808 ----a-w C:\WINDOWS\WinSxS\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww_dec6ddd2\mfc80u.dll
+ 2005-09-23 08:16:08 69,632 ----a-w C:\WINDOWS\WinSxS\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww_dec6ddd2\mfcm80.dll
+ 2005-09-23 08:16:10 57,344 ----a-w C:\WINDOWS\WinSxS\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww_dec6ddd2\mfcm80u.dll
+ 2005-09-23 07:58:06 40,960 ----a-w C:\WINDOWS\WinSxS\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww_3415f6d0\mfc80CHS.dll
+ 2005-09-23 07:58:06 45,056 ----a-w C:\WINDOWS\WinSxS\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww_3415f6d0\mfc80CHT.dll
+ 2005-09-23 07:58:06 65,536 ----a-w C:\WINDOWS\WinSxS\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww_3415f6d0\mfc80DEU.dll
+ 2005-09-23 07:58:06 57,344 ----a-w C:\WINDOWS\WinSxS\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww_3415f6d0\mfc80ENU.dll
+ 2005-09-23 07:58:06 61,440 ----a-w C:\WINDOWS\WinSxS\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww_3415f6d0\mfc80ESP.dll
+ 2005-09-23 07:58:06 61,440 ----a-w C:\WINDOWS\WinSxS\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww_3415f6d0\mfc80FRA.dll
+ 2005-09-23 07:58:06 61,440 ----a-w C:\WINDOWS\WinSxS\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww_3415f6d0\mfc80ITA.dll
+ 2005-09-23 07:58:06 49,152 ----a-w C:\WINDOWS\WinSxS\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww_3415f6d0\mfc80JPN.dll
+ 2005-09-23 07:58:06 49,152 ----a-w C:\WINDOWS\WinSxS\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww_3415f6d0\mfc80KOR.dll
+ 2005-09-23 08:35:10 65,536 ----a-w C:\WINDOWS\WinSxS\x86_Microsoft.VC80.OpenMP_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww_0ee63867\vcomp.dll
+ 2008-04-15 17:54:19 1,724,416 ----a-w C:\WINDOWS\WinSxS\x86_Microsoft.Windows.GdiPlus_6595b64144ccf1df_1.0.2600.3352_x-ww_81af8e88\GdiPlus.dll
- 2007-12-07 04:24:24 258,048 ----a-w C:\WINDOWS\WinSxS\x86_System.EnterpriseServices_b03f5f7f11d50a3a_2.0.0.0_x-ww_7d5f3790\System.EnterpriseServices.dll
+ 2008-04-12 08:07:57 258,048 ----a-w C:\WINDOWS\WinSxS\x86_System.EnterpriseServices_b03f5f7f11d50a3a_2.0.0.0_x-ww_7d5f3790\System.EnterpriseServices.dll
- 2007-12-07 04:24:24 114,176 ----a-w C:\WINDOWS\WinSxS\x86_System.EnterpriseServices_b03f5f7f11d50a3a_2.0.0.0_x-ww_7d5f3790\System.EnterpriseServices.Wrapper.dll
+ 2008-04-12 08:07:57 113,664 ----a-w C:\WINDOWS\WinSxS\x86_System.EnterpriseServices_b03f5f7f11d50a3a_2.0.0.0_x-ww_7d5f3790\System.EnterpriseServices.Wrapper.dll
+ 2000-08-31 15:00:00 68,096 ----a-w C:\WINDOWS\zip.exe
-- Snapshot reset to current date --
((((((((((((((((((((((((((((((((((((( Reg Loading Points ))))))))))))))))))))))))))))))))))))))))))))))))))
*Note* empty entries & legit default entries are not shown
REGEDIT4
[HKEY_LOCAL_MACHINE\~\Browser Helper Objects\{a209a7c6-3e7c-8276-94d1-13daf7e173bd}]
2008-08-29 05:11 166400 --a
[HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Run]
"Yaboik"="C:\Documents and Settings\Compaq_Owner\My Documents\A?pPatch\?xplorer.exe" [?]
"Mpnv"="C:\WINDOWS\system32\?dobe\?hkdsk.exe" [?]
"SpybotSD TeaTimer"="C:\Program Files\Spybot - Search & Destroy\TeaTimer.exe" [2008-08-18 1832272]
"ctfmon.exe"="C:\WINDOWS\system32\ctfmon.exe" [2004-08-04 15360]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run]
"{5edbf857-26da-2a2d-4ca3-519e74cf546d}"="C:\WINDOWS\system32\offeojxjdbht.dll" [2008-08-29 166400]
"QuickTime Task"="C:\Program Files\QuickTime\qttask.exe" [2008-09-06 413696]
[HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\windows]
"AppInit_DLLs"=waxkfq.dll
[HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^America Online 9.0 Tray Icon.lnk]
path=C:\Documents and Settings\All Users\Start Menu\Programs\Startup\America Online 9.0 Tray Icon.lnk
backup=C:\WINDOWS\pss\America Online 9.0 Tray Icon.lnkCommon Startup
[HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^AOL Companion.lnk]
path=C:\Documents and Settings\All Users\Start Menu\Programs\Startup\AOL Companion.lnk
backup=C:\WINDOWS\pss\AOL Companion.lnkCommon Startup
[HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^HP Digital Imaging Monitor.lnk]
path=C:\Documents and Settings\All Users\Start Menu\Programs\Startup\HP Digital Imaging Monitor.lnk
backup=C:\WINDOWS\pss\HP Digital Imaging Monitor.lnkCommon Startup
[HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^HP Image Zone Fast Start.lnk]
path=C:\Documents and Settings\All Users\Start Menu\Programs\Startup\HP Image Zone Fast Start.lnk
backup=C:\WINDOWS\pss\HP Image Zone Fast Start.lnkCommon Startup
[HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^Image Transfer.lnk]
path=C:\Documents and Settings\All Users\Start Menu\Programs\Startup\Image Transfer.lnk
backup=C:\WINDOWS\pss\Image Transfer.lnkCommon Startup
[HKLM\~\startupfolder\C:^Documents and Settings^Compaq_Owner^Start Menu^Programs^Startup^Compaq Organize.lnk]
path=C:\Documents and Settings\Compaq_Owner\Start Menu\Programs\Startup\Compaq Organize.lnk
backup=C:\WINDOWS\pss\Compaq Organize.lnkStartup
[HKLM\~\startupfolder\C:^Documents and Settings^Compaq_Owner^Start Menu^Programs^Startup^LimeWire On Startup.lnk]
path=C:\Documents and Settings\Compaq_Owner\Start Menu\Programs\Startup\LimeWire On Startup.lnk
backup=C:\WINDOWS\pss\LimeWire On Startup.lnkStartup
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\iTunesHelper]
--a
2008-09-08 23:02 289576 C:\Program Files\iTunes\iTunesHelper.exe
[HKEY_LOCAL_MACHINE\software\microsoft\security center\Monitoring\SymantecFirewall]
"DisableMonitoring"=dword:00000001
[HKLM\~\services\sharedaccess\parameters\firewallpolicy\standardprofile\AuthorizedApplications\List]
"C:\\Program Files\\LimeWire\\LimeWire.exe"=
"C:\\Program Files\\Mozilla Firefox\\firefox.exe"=
"C:\\Program Files\\Corel\\DVD9\\WinDVD.exe"=
"C:\\WINDOWS\\system32\\spool\\drivers\\w32x86\\3\\E_DUPA20.EXE"=
"C:\\Program Files\\Firaxis Games\\Sid Meier's Civilization 4 Demo\\Civilization4.exe"=
"C:\\Program Files\\Windows Media Player\\wmplayer.exe"=
"C:\\Program Files\\Bonjour\\mDNSResponder.exe"=
"C:\\Program Files\\iTunes\\iTunes.exe"=
R1 vdrv7000;vdrv7000;C:\WINDOWS\system32\DRIVERS\vdrv7000.sys [2005-01-31 76672]
R2 PSI_SVC_2;Protexis Licensing V2;C:\Program Files\Common Files\Protexis\License Service\PsiService_2.exe [2007-07-24 185632]
R2 regi;regi;C:\WINDOWS\system32\drivers\regi.sys [2007-04-17 11032]
R2 VC7SecS;Virtual CD v7 Management Service;C:\Program Files\HHVcdV7Sys\VC7SecS.exe [2005-11-24 106496]
S4 UPnPService;UPnPService;C:\Program Files\Common Files\MAGIX Shared\UPnPService\UPnPService.exe [2006-12-14 544768]
[HKEY_CURRENT_USER\software\microsoft\windows\currentversion\explorer\mountpoints2\{3afa4cc1-3d8d-11dc-a85b-0011d805b895}]
\Shell\AutoRun\command - H:\system\viewer\Viewer.exe
\Shell\View your videos\command - H:\system\viewer\Viewer.exe
Contents of the 'Scheduled Tasks' folder
- - - - ORPHANS REMOVED - - - -
BHO-{0FB6138D-0CA5-4EA5-A46F-86DFE700A287} - C:\WINDOWS\system32\ssqQkhfF.dll
BHO-{1BC9B244-A35D-40D3-B181-EC778E349E0D} - (no file)
BHO-{30EC3838-C860-463B-9211-807D5195F06E} - (no file)
BHO-{4a96e9ff-a4cb-49c5-8975-20550fc47a6f} - C:\WINDOWS\system32\waxkfq.dll
BHO-{5F6E5BDB-1442-45B7-B0C9-E927035A7415} - (no file)
BHO-{68A59E49-20D8-0B5B-8C3B-5DC0705987C1} - C:\WINDOWS\system32\zlsmp.dll
BHO-{6B221E01-F517-4959-8C41-81948E7F2F17} - (no file)
BHO-{759B1EEC-8289-4D01-AFD5-B3ADF6728470} - (no file)
BHO-{7CD8A910-22B6-434B-AF8A-9837ADCA1B62} - (no file)
BHO-{8542ADAA-B3BF-454E-AAA3-CB20F764D664} - (no file)
BHO-{9A1DB4EE-2DB6-4F12-B5DA-5DF09154D30F} - (no file)
BHO-{AB16ED6F-5DAB-7676-AC3C-7DA296B649CA} - (no file)
BHO-{AD10BF3E-5DF0-7826-AC3C-7DA296B518CA} - (no file)
BHO-{AD40BB34-5CAF-7672-AC3C-7DA296B64BCB} - (no file)
BHO-{AF41E168-01AD-792B-FF3C-7DA296B542C8} - (no file)
BHO-{B61FC97E-8605-402C-997C-BEA9B3A6B094} - (no file)
BHO-{BD04EB49-E758-4C2D-A1A0-3961F29374BB} - (no file)
BHO-{c73b807f-a2cf-4156-91de-fcf58fa98b70} - (no file)
BHO-{EF18E2FB-C141-437D-A7C0-D38B7F5A9732} - (no file)
BHO-{FB44E06F-00AD-2D27-AA3C-7DA296B51FCE} - (no file)
HKCU-Run-Srro - C:\PROGRA~1\COMMON~1\FNTS~1\nopdb.exe
HKLM-Run-14a3ebe6 - C:\WINDOWS\system32\ijmwfgfy.dll
HKLM-Run-BM1790d87a - C:\WINDOWS\system32\umxxthbk.dll
MSConfigStartUp-AIM - C:\Program Files\AIM\aim.exe
MSConfigStartUp-AOL Spyware Protection - C:\PROGRA~1\COMMON~1\AOL\AOLSPY~1\AOLSP Scheduler.exe
MSConfigStartUp-AOLDialer - C:\Program Files\Common Files\AOL\ACS\AOLDial.exe
MSConfigStartUp-HostManager - C:\Program Files\Common Files\AOL\1132185535\ee\AOLHostManager.exe
MSConfigStartUp-WT GameChannel - C:\Program Files\WildTangent\Apps\GameChannel.exe
Supplementary Scan
FireFox -: Profile - C:\Documents and Settings\Compaq_Owner\Application Data\Mozilla\Firefox\Profiles\hkm924et.default\
FireFox -: prefs.js - SEARCH.DEFAULTURL - hxxp://www.google.com/search?lr=&ie=UTF-8&oe=UTF-8&q=
FF -: plugin - C:\Program Files\iTunes\Mozilla Plugins\npitunes.dll
FF -: plugin - C:\Program Files\Mozilla Firefox\plugins\npmusicn.dll
FF -: plugin - C:\Program Files\Real\RhapsodyPlayerEngine\nprhapengine.dll
FF -: plugin - C:\Program Files\Viewpoint\Viewpoint Experience Technology\npViewpoint.dll
FF -: plugin - C:\Program Files\Yahoo!\Shared\npYState.dll
catchme 0.3.1361 W2K/XP/Vista - rootkit/stealth malware detector by Gmer, http://www.gmer.net
Rootkit scan 2008-10-01 17:53:31
Windows 5.1.2600 Service Pack 2 NTFS
scanning hidden processes ...
scanning hidden autostart entries ...
scanning hidden files ...
scan completed successfully
hidden files: 0
[HKEY_LOCAL_MACHINE\System\ControlSet001\Services\vdrv7000]
"ImagePath"="system32\DRIVERS\vdrv7000.sys"
Other Running Processes
C:\Documents and Settings\All Users\Application Data\EPSON\EPW!3 SSRP\E_S40RP7.EXE
C:\Program Files\Common Files\Microsoft Shared\VS7DEBUG\MDM.EXE
C:\Program Files\Windows Media Player\wmpnetwk.exe
C:\WINDOWS\system32\wscntfy.exe
C:\WINDOWS\system32\rundll32.exe
C:\Program Files\Internet Explorer\iexplore.exe
C:\PROGRA~1\Yahoo!\browser\ycommon.exe
Completion time: 2008-10-01 17:59:46 - machine was rebooted [Compaq_Owner]
ComboFix-quarantined-files.txt 2008-10-02 00:59:42
ComboFix2.txt 2007-12-21 22:26:53
Pre-Run: 122,849,583,104 bytes free
Post-Run: 123,729,530,880 bytes free
2088 --- E O F --- 2008-09-11 06:54:12
P2P Warning!
IMPORTANT I notice there are signs of one or more P2P (Person to Person) File Sharing Programs on your computer.
LimeWire
P2P programs form a direct conduit onto your computer, their security measures are easily circumvented, and Malware writers are increasingly exploiting them to spread their wares onto your computer. Further to that, if your P2P programme is not configured correctly you may be sharing more files than you realise. There have been cases where people's Passwords, Address Books and other personal, private, and financial details have been exposed to the file sharing network by a badly configured programme.
This article from InfoWorld illustrates perfectly the dangers of a poorly configured P2P program.
http://www.infoworld.com/article/07/09/06/Seattle-man-arrested-for-p-to-p-ID-theft_1.html
Many of the programs come bundled with other unwanted programs, but even the ones free of any bundled software are not safe to use.
When you use them you are downloading software from an unknown source directly onto your computer, bypassing your Firewall and Anti-Virus software. Hardly surprising then that many of these Downloads are being targeted to carry infections.
Note: It is pretty much certain that if you continue to use P2P programs, then you will get infected again.
I would recommend that you uninstall LimeWire, however that choice is up to you. If you choose to remove these programs, you can do so via Control Panel >> Add or Remove Programs.
If you wish to keep it, please do not use it until your computer is cleaned.
Disable Spybot's TeaTimer. This is a two step process.
Spybot S&D's tea timer normally provides real-time protection from spyware, however it may interfere with what we need to do. We will disable it until the machine is clean when it can be re-enabled.
First step:
- Right-click the Spybot Icon in the System Tray (looks like a blue/white calendar with a padlock symbol)
- If you have the new version 1.5, Click once on Resident Protection, then Right click the Spybot icon again and make sure Resident Protection is now Unchecked. The Spybot icon in the System tray should now be now colorless.
- If you have Version 1.4, Click on Exit Spybot S&D Resident
Second step, For Either Version :- Open Spybot S&D
- Click Mode, choose Advanced Mode
- Go To the bottom of the Vertical Panel on the Left, Click Tools
- then, also in left panel, click Resident shows a red/white shield.
- If your firewall raises a question, say OK
- In the Resident protection status frame, Uncheck the box labeled Resident "Tea-Timer"(Protection of over-all system settings) active
- OK any prompts.
- Use File, Exit to terminate Spybot
- Reboot your machine for the changes to take effect.
Don't forget to re-enable it, when your computer is clean.Download and Run OTMoveIt3
Download OTMoveIt3 by Old Timer and save it to your Desktop.
Run a custom CFScript
1. Close any open browsers.
2. Open notepad and copy/paste the text in the quotebox below into it:
KILLALL:: File:: C:\WINDOWS\system32\zpdilktkhogz.exe C:\WINDOWS\TWFyaWEgUml2ZXJh\nqIVuqH0oA5ZtrL1.vbs C:\WINDOWS\system32\offeojxjdbht.dll C:\WINDOWS\system32\waxkfq.dll Folder:: C:\Program Files\OINAnalytics C:\WINDOWS\TWFyaWEgUml2ZXJh C:\Program Files\Mjcore Registry:: [-HKEY_LOCAL_MACHINE\~\Browser Helper Objects\{a209a7c6-3e7c-8276-94d1-13daf7e173bd}] [HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Run] "Yaboik"=- "Mpnv"=- [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run] "{5edbf857-26da-2a2d-4ca3-519e74cf546d}"=- [HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\windows] "AppInit_DLLs"=- DirLook:: C:\WINDOWS\system32\wp C:\WINDOWS\system32\RES C:\WINDOWS\system32\pin C:\WINDOWS\system32\np5 C:\WINDOWS\system32\mC02Save this as CFScript.txt, in the same location as ComboFix.exe
Refering to the picture above, drag CFScript into ComboFix.exe
When finished, it shall produce a log for you at "C:\ComboFix.txt"
Note:
Do not mouseclick combofix's window whilst it's running. That may cause it to stall
Please post the following:
moveit:
========== FILES ==========
File/Folder C:\Documents and Settings\Compaq_Owner\My Documents\A?pPatch not found.
File/Folder C:\WINDOWS\system32\?dobe not found.
========== COMMANDS ==========
User's Temp folder emptied.
User's Temporary Internet Files folder emptied.
User's Internet Explorer cache folder emptied.
Local Service Temp folder emptied.
Local Service Temporary Internet Files folder emptied.
Windows Temp folder emptied.
Java cache emptied.
FireFox cache emptied.
Temp folders emptied.
OTMoveIt3 by OldTimer - Version 1.0.3.1 log created on 10032008_173531
combofix:
ComboFix 08-10-01.02 - Compaq_Owner 2008-10-03 17:38:39.4 - NTFSx86
Microsoft Windows XP Home Edition 5.1.2600.2.1252.1.1033.18.186 [GMT -7:00]
Running from: C:\Documents and Settings\Compaq_Owner\Desktop\ComboFix.exe
Command switches used :: C:\Documents and Settings\Compaq_Owner\Desktop\CFScript.txt
* Created a new restore point
FILE ::
((((((((((((((((((((((((((((((((((((((( Other Deletions )))))))))))))))))))))))))))))))))))))))))))))))))
((((((((((((((((((((((((( Files Created from 2008-09-04 to 2008-10-04 )))))))))))))))))))))))))))))))
2008-10-03 17:35 . 2008-10-03 17:35 <DIR> d
C:\_OTMoveIt
2008-10-02 17:37 . 2008-10-02 17:38 <DIR> d
C:\Program Files\Frets on Fire
2008-10-02 17:30 . 2008-10-02 17:30 0 --ah
C:\WINDOWS\system32\drivers\MsftWdf_Kernel_01005_Coinstaller_Critical.Wdf
C:\WINDOWS\system32\drivers\Msft_Kernel_xusb21_01005.Wdf
2008-09-27 12:23 . 2008-09-27 12:24 <DIR> d
C:\Documents and Settings\All Users\Application Data\WinZip
2008-09-23 22:36 . 2008-09-23 22:36 <DIR> d
C:\Program Files\Panda Security
2008-09-18 01:22 . 2008-09-18 01:22 <DIR> d
C:\Program Files\TeaTimer (Spybot - Search & Destroy)
2008-09-17 00:22 . 2008-09-17 00:22 <DIR> d
C:\Documents and Settings\LocalService\Application Data\Apple Computer
2008-09-17 00:07 . 2008-09-17 00:07 <DIR> d
2008-09-17 00:07 . 2008-09-18 18:03 <DIR> d
2008-09-17 00:07 . 2008-09-17 00:08 <DIR> d
C:\temp\mtc2
2008-09-11 00:36 . 2008-09-11 00:37 <DIR> d
C:\Documents and Settings\All Users\Application Data\{3276BE95_AF08_429F_A64F_CA64CB79BCF6}
2008-09-11 00:35 . 2008-09-11 00:35 <DIR> d
C:\Program Files\Bonjour
2008-09-11 00:34 . 2008-09-11 00:34 <DIR> d
2008-09-11 00:32 . 2008-09-05 22:16 1,900,544 --a
C:\WINDOWS\system32\usbaaplrc.dll
2008-09-11 00:32 . 2008-09-05 22:16 36,864 --a
C:\WINDOWS\system32\drivers\usbaapl.sys
2008-09-06 15:09 . 2008-09-06 15:09 90,112 --a
C:\WINDOWS\system32\QuickTimeVR.qtx
2008-09-06 15:09 . 2008-09-06 15:09 57,344 --a
C:\WINDOWS\system32\QuickTime.qts
2008-09-04 22:51 . 2008-09-04 22:53 <DIR> d
C:\Program Files\V CAST Music with Rhapsody
(((((((((((((((((((((((((((((((((((((((( Find3M Report ))))))))))))))))))))))))))))))))))))))))))))))))))))
2008-10-03 08:01
d
w C:\Documents and Settings\Compaq_Owner\Application Data\LimeWire
2008-09-28 19:49
d
w C:\Program Files\Safari
2008-09-23 04:38
d
w C:\Program Files\LimeWire
2008-09-21 00:16
d
w C:\Program Files\Spybot - Search & Destroy
2008-09-19 03:32
d
w C:\Documents and Settings\All Users\Application Data\Spybot - Search & Destroy
2008-09-18 15:51 28,106 ----a-w C:\Documents and Settings\Compaq_Owner\Application Data\wklnhst.dat
2008-09-18 06:41
d
w C:\Program Files\Java
2008-09-11 07:37
d
w C:\Program Files\iPod
2008-09-11 07:34
d
w C:\Program Files\Common Files\Apple
2008-09-05 05:52
d
w C:\Program Files\Real
2008-09-03 04:22
d
w C:\Program Files\Verizon Wireless
2008-08-23 07:15
d
w C:\Program Files\Microsoft Silverlight
2008-08-22 03:15
d---a-w C:\Documents and Settings\All Users\Application Data\TEMP
2008-08-06 16:35
d
w C:\Program Files\Apple Software Update
2008-07-14 19:29 88 --sha-r C:\Documents and Settings\All Users\Application Data\53D7D18ABC.sys
2008-07-14 19:29 2,516 --sha-w C:\Documents and Settings\All Users\Application Data\KGyGaAvL.sys
2008-07-11 02:44 606,848 ----a-w C:\WINDOWS\flashax.exe
2008-07-11 02:44 12,288 ----a-w C:\WINDOWS\impborl.dll
2008-04-29 05:05 69,832 ----a-w C:\Documents and Settings\Compaq_Owner\Application Data\GDIPFONTCACHEV1.DAT
2006-08-17 03:20 184,808 -c--a-w C:\Documents and Settings\Guest\Application Data\shb.dat
2006-06-23 17:39 1,820 -c--a-w C:\Documents and Settings\Guest\Application Data\wklnhst.dat
(((((((((((((((((((((((((((((((((((((((((((( Look )))))))))))))))))))))))))))))))))))))))))))))))))))))))))
---- Directory of C:\WINDOWS\system32\mC02 ----
2008-09-10 13:59 32768 --a
---- Directory of C:\WINDOWS\system32\np5 ----
---- Directory of C:\WINDOWS\system32\pin ----
2008-09-16 14:59 162834 --a
---- Directory of C:\WINDOWS\system32\RES ----
2008-09-04 13:48 402200 --a
---- Directory of C:\WINDOWS\system32\wp ----
2008-05-05 09:16 127488 --a
((((((((((((((((((((((((((((( snapshot_2008-10-01_17.59.14.12 )))))))))))))))))))))))))))))))))))))))))
- 2007-07-31 03:18:40 33,624 -c--a-w C:\WINDOWS\system32\dllcache\wups.dll
+ 2008-07-19 05:10:20 36,552 -c--a-w C:\WINDOWS\system32\dllcache\wups.dll
+ 2006-11-02 14:22:54 492,000
w C:\WINDOWS\system32\drivers\wdf01000.sys
+ 2006-11-02 14:22:52 32,224
w C:\WINDOWS\system32\drivers\wdfldr.sys
+ 2007-08-29 00:05:12 55,808 ----a-w C:\WINDOWS\system32\drivers\xusb21.sys
- 2006-09-26 00:58:48 23,856 ----a-w C:\WINDOWS\system32\spupdsvc.exe
+ 2006-10-09 04:51:14 23,856 ----a-w C:\WINDOWS\system32\spupdsvc.exe
+ 2006-11-02 23:09:50 1,419,232 ----a-w C:\WINDOWS\system32\WdfCoInstaller01005.dll
- 2007-07-31 03:18:40 33,624 ----a-w C:\WINDOWS\system32\wups.dll
+ 2008-07-19 05:10:20 36,552 ----a-w C:\WINDOWS\system32\wups.dll
- 2007-07-31 03:19:12 43,352 ----a-w C:\WINDOWS\system32\wups2.dll
+ 2008-07-19 05:10:40 45,768 ----a-w C:\WINDOWS\system32\wups2.dll
REGEDIT4
--a
Rootkit scan 2008-10-03 17:45:49
hidden files: 0
C:\ComboFix\pv.cfexe
Completion time: 2008-10-03 17:50:42 - machine was rebooted
ComboFix-quarantined-files.txt 2008-10-04 00:50:40
ComboFix2.txt 2008-10-02 00:59:47
ComboFix3.txt 2007-12-21 22:26:53
Pre-Run: 121,423,675,392 bytes free
Post-Run: 121,415,663,616 bytes free
179 --- E O F --- 2008-10-02 07:30:44
hijackthis:
Logfile of Trend Micro HijackThis v2.0.2
Scan saved at 5:21:22 PM, on 10/4/2008
MSIE: Internet Explorer v7.00 (7.00.6000.16705)
Boot mode: Normal
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\Explorer.EXE
C:\Program Files\Messenger\msmsgs.exe
C:\Program Files\iPod\bin\iPodService.exe
C:\Program Files\Safari\Safari.exe
C:\Program Files\Trend Micro\HijackThis\HijackThis.exe
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://go.microsoft.com/fwlink/?LinkId=69157
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = http://go.microsoft.com/fwlink/?LinkId=54896
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/fwlink/?LinkId=54896
O2 - BHO: Yahoo! Toolbar Helper - {02478D38-C3F9-4EFB-9B51-7695ECA05670} - C:\Program Files\Yahoo!\Companion\Installs\cpn\yt.dll
O2 - BHO: Spybot-S&D IE Protection - {53707962-6F74-2D53-2644-206D7942484F} - C:\PROGRA~1\SPYBOT~1\SDHelper.dll
O2 - BHO: Yahoo! IE Services Button - {5BAB4B5B-68BC-4B02-94D6-2FC0DE4A7897} - C:\PROGRA~1\Yahoo!\Common\yiesrvc.dll
O2 - BHO: SSVHelper Class - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files\Java\jre1.6.0_07\bin\ssv.dll
O2 - BHO: SidebarAutoLaunch Class - {F2AA9440-6328-4933-B7C9-A6CCDF9CBF6D} - C:\Program Files\Yahoo!\browser\YSidebarIEBHO.dll
O4 - HKCU\..\Run: [ctfmon.exe] C:\WINDOWS\system32\ctfmon.exe
O4 - HKCU\..\Run: [MSMSGS] "C:\Program Files\Messenger\msmsgs.exe" /background
O9 - Extra button: (no name) - {DFB852A3-47F8-48C4-A200-58CAB36FD2A2} - C:\PROGRA~1\SPYBOT~1\SDHelper.dll
O9 - Extra 'Tools' menuitem: Spybot - Search & Destroy Configuration - {DFB852A3-47F8-48C4-A200-58CAB36FD2A2} - C:\PROGRA~1\SPYBOT~1\SDHelper.dll
O23 - Service: EPSON V3 Service4(01) (EPSON_PM_RPCV4_01) - SEIKO EPSON CORPORATION - C:\Documents and Settings\All Users\Application Data\EPSON\EPW!3 SSRP\E_S40RP7.EXE
O23 - Service: InstallDriver Table Manager (IDriverT) - Macrovision Corporation - C:\Program Files\Common Files\InstallShield\Driver\11\Intel 32\IDriverT.exe
O23 - Service: iPod Service - Apple Inc. - C:\Program Files\iPod\bin\iPodService.exe
O23 - Service: Protexis Licensing V2 (PSI_SVC_2) - Protexis Inc. - C:\Program Files\Common Files\Protexis\License Service\PsiService_2.exe
O23 - Service: Virtual CD v7 Management Service (VC7SecS) - H+H Software GmbH - C:\Program Files\HHVcdV7Sys\VC7SecS.exe
End of file - 3249 bytes
Please run another custom CFScript
Note:
Next,
Please go to Kaspersky website and perform an online antivirus scan.
- Read through the requirements and privacy statement and click on Accept button.
- It will start downloading and installing the scanner and virus definitions. You will be prompted to install an application from Kaspersky. Click Run.
- When the downloads have finished, click on Settings.
- Make sure these boxes are checked (ticked). If they are not, please tick them and click on the Save button:
[*]Click on My Computer under Scan.Spyware, Adware, Dialers, and other potentially dangerous programs
Archives
Mail databases
[*]Once the scan is complete, it will display the results. Click on View Scan Report.
[*]You will see a list of infected items there. Click on Save Report As....
[*]Save this report to a convenient place. Change the Files of type to Text file (.txt) before clicking on the Save button.
[*]Please post this log in your next reply along with a fresh HijackThis log and a description of how your computer is behaving.
KASPERSKY ONLINE SCANNER 7 REPORT
Sunday, October 5, 2008
Operating System: Microsoft Windows XP Home Edition Service Pack 2 (build 2600)
Kaspersky Online Scanner 7 version: 7.0.25.0
Program database last update: Sunday, October 05, 2008 22:11:22
Records in database: 1293379
Scan settings:
Scan using the following database: extended
Scan archives: yes
Scan mail databases: yes
Scan area - My Computer:
C:\
D:\
E:\
F:\
G:\
H:\
I:\
J:\
K:\
Scan statistics:
Files scanned: 107767
Threat name: 74
Infected objects: 448
Suspicious objects: 0
Duration of the scan: 02:37:08
File name / Threat name / Threats count
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\011F76FD.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\01307EC6.dll Infected: not-a-virus:AdWare.Win32.ClientMan 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\013328C2.dll Infected: not-a-virus:AdWare.Win32.ClientMan 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\013752BF.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.af 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\013A7CBB.exe Infected: Trojan.Win32.Stervis.h 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\0197335D.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\01FE2965.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\0292410C.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.i 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\02F93714.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\035030C8.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\03BF1D4C.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\059B5A71.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\05AF504D.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\05B27A49.exe Infected: Trojan-Downloader.Win32.Intexp.c 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\06C072AF.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\06DC7935.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\07B00F9C.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\087C7BAB.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\08E271B2.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\09463F0B.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.u 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\094867BA.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.u 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\094D1303.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.u 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\09503D00.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.u 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\095466FC.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.u 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\095710F9.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.u 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\095A3AF5.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.u 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\095D64F1.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.u 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\09610EEE.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.u 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\096438EA.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.u 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\096A0CE3.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.j 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\097160DC.dll Infected: not-a-virus:AdWare.Win32.ClientMan 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\09740AD8.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.n 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\098806C3.exe Infected: Trojan.Win32.Stervis.c 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\0A8203D8.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\0B8153D0.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\0CBB2C6D.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\0CE55339.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\0D286F5C.tmp Infected: not-a-virus:AdWare.Win32.180Solutions.i 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\0D486B8D.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\0D7F73BF.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\0D8E6563.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\0E7E43B7.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\0E897313.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\0F4F594A.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\0F5E0F6B.htm Infected: Exploit.HTML.Mht 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\0F7E13AF.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\0FB54F52.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\107D63A7.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\114F3A42.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.u 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\117C339F.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\13056DC5.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\13404B9A.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\13A641A2.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\14722DB1.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.u 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\14D823B8.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\153F19C0.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\17B93889.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.a 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\188573D4.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\191E2162.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\1970601E.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\1A192F11.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\1ADF1549.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\1B460B50.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\1CA836C7.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\1ED00799.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\1F2D6256.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\1F367DA0.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\1F9D73A8.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\1FA545D0.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\200369AF.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.u 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\20695FB7.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\20CF55BF.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.u 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\22832A71.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\23DC1088.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.i 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\2496551A.tmp Infected: Trojan-Dropper.Win32.Agent.hl 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\24AF5D61.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\259954AF.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\25AA6B10.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.i 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\26C517CC.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\26D6474F.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\29642E3F.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\2A614397.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\2AC7399F.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\2B9325AE.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\2BF91BB6.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\2C5F11BD.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\2CBA3E3C.tmp Infected: Trojan-Dropper.Win32.Agent.hl 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\2CBD6838.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\2CD57026.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\2DE569C8.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\2ECF4474.dll Infected: not-a-virus:AdWare.Win32.ClientMan 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\303F195F.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\3046320D.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\30A50F67.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\30FA2EAE.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\30FB4732.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.v 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\30FF712F.exe Infected: Trojan-Downloader.Win32.Intexp.e 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\31054527.dll Infected: not-a-virus:AdWare.Win32.ClientMan 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\31086F24.dll Infected: not-a-virus:AdWare.Win32.ClientMan 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\313A270E.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.i 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\31A01D16.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.i 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\31C14940.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\3266034E.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\327A55AA.exe Infected: Trojan-Downloader.Win32.Intexp.e 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\34006E3E.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.l 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\35063BC3.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\3657759E.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\36BD6BA5.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\372361AD.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\378957B4.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\37914F6A.exe Infected: Trojan.Win32.Poler.a 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\379B4D60.exe Infected: not-a-virus:AdWare.Win32.Bestofer.d 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\37B9473F.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ai 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\3A4869EA.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.a 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\3A4B13E6.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.a 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\3A4F3DE3.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.a 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\3A5267DF.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.a 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\3A5511DC.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.i 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\3A583BD8.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.a 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\3A5C65D4.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.i 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\3A5F0FD1.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.i 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\3A6239CD.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.i 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\3A690DC6.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.i 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\3A6F61BF.dll Infected: not-a-virus:AdWare.Win32.ClientMan 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\3A730BBB.dll Infected: not-a-virus:AdWare.Win32.ClientMan 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\3A730BBB.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\3AD0628D.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.a 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\3B637E8D.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.i 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\3BCF555E.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\3C354B65.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\3CCA630D.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.i 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\3DEA3DD0.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\3DF73F4C.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\3E5B0831.dll Infected: not-a-virus:AdWare.Win32.ClientMan 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\3EB22158.exe Infected: Trojan-Downloader.Win32.Intexp.e 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\3EB97551.dll Infected: not-a-virus:AdWare.Win32.ClientMan 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\40CF032B.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\41E7319C.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\424E27A4.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\42B41DAB.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\431A13B3.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\438009BA.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\45926C5F.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.a 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\4595165C.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.a 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\45994058.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.a 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\459C6A55.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.a 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\459F1451.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.a 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\45A23E4D.dll Infected: not-a-virus:AdWare.Win32.BookedSpace.e 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\45A23E4D.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.a 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\45A6684A Infected: Trojan-Downloader.Win32.Small.abd 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\45A6684A.exe Infected: not-a-virus:AdWare.Win32.BookedSpace.e 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\45A7331C.dll Infected: not-a-virus:AdWare.Win32.ClientMan 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\45A91246.dll Infected: Trojan-Downloader.Win32.IstBar.gen 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\45A91246.exe Infected: not-a-virus:AdWare.Win32.WinAD.aw 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\45AB5D18.dll Infected: not-a-virus:AdWare.Win32.HotSearchBar.i 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\45AC3C43.dll Infected: not-a-virus:AdWare.Win32.ClientMan 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\45AC3C43.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\45AF663F.dll Infected: not-a-virus:AdWare.Win32.Beginto.c 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\45AF663F.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.c 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\45C0382D.exe Infected: Trojan-Downloader.Win32.Intexp.c 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\46601E8B.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.a 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\46F33A8B.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.i 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\4760115D.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\47C60764.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\47EF5527.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\48C11513.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.i 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\4A123261.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\4B016BD4.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\4C003BCB.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\4C0869CE.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\4D000BC3.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\4D786D9B.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\4DDE63A2.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\4DFF5BBB.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\4E4459AA.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\4EAA4FB2.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\4EFE2BB3.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\4F102722.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\4F792BB5.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\4FFD7BAB.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\50FC4BA3.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\51FC1B9B.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\5284768A.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.a 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\52E96D9C.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\533E2D02.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ao 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\53472AF7.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\53564363.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\54515112.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.i 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\5517374A.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\5630791E.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\563A26F2.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\565A2F83.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\596E1FA1.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\59B21940.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.au 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\59CB716A.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\59D415A9.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\5A7A7802.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.au 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\5A7E21FE.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\5A814BFB.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\5A8475F7.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\5A881FF4.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\5A8B49F0.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\5A8E73EC.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\5A911DE9.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\5A9547E5.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\5A9871E2.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\5A9B1BDE.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\5A9E45DB.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\5AA101B8.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.u 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\5AA26FD7.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\5AA519D3.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\5AA843D0.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\5AAB6DCC.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\5AAF17C9.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\5AB241C5.tmp Infected: not-a-virus:AdWare.Win32.180Solutions.i 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\5D504B1A.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\5EAB012B.dll Infected: not-a-virus:AdWare.Win32.ClientMan 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\5EAB012B.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\5EAF2B28.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\5EB25524.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\5EB57F21.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\5EB8291D.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\5EBC5319.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\5EBF7D16.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\5EC22712.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\5EC5510F.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\5EC97B0B.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\5ECC2507.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\5ECF4F04.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\5ED37900.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\5ED622FD.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\5ED94CF9.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\5EDC76F5.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\5EE020F2.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\5EE34AEE.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\5EE67F61.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\5EE91EE7.dll Infected: not-a-virus:AdWare.Win32.ClientMan 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\5EE91EE7.exe Infected: not-a-virus:AdWare.Win32.WinAD.bw 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\5EED48E4.dll Infected: not-a-virus:AdWare.Win32.ClientMan 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\5EED48E4.exe Infected: Trojan.Win32.Stervis.d 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\60A87348.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\610E6950.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\62631B83.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\62D30677.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.t 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\62D73073.exe Infected: Trojan.Win32.Stervis.j 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\64711D16.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\64986598.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\656551A7.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\68CE0DDB.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\693F643B.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\69D3640F.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\6A6763E3.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\6A773B60.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\6ADD3168.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.t 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\6AFB63B7.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\6B72490F.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\6B8F638B.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\6BD83F17.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.i 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\6C23635F.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\6CB76333.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\6D4B6307.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\6DDF62DB.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\6E7362AE.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\6E8B1013.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\6E9E0646.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.u 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\70292197.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\702E622A.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\703A647D.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\708F179E.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\70C261FE.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\70F50DA6.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\715661D2.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\715B03AD.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\71861803.dll Infected: Trojan-Downloader.Win32.Small.bpk 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\71C179B5.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\71EA61A6.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\72276FBD.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\728E2636.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.i 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\72915032.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\72957A2E.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.i 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\7298242B.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.i 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\729B4E27.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.i 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\729E7824.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.i 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\72A22220.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.i 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\72A54C1C.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.i 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\72A87619.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.i 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\72AB2015.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.i 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\72AF4A12.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.i 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\72B2740E.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\72B51E0A.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\72B84807.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.i 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\72BC7203.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\72BF1C00.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.i 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\72C66FF8.dll Infected: not-a-virus:AdWare.Win32.ClientMan 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\72C66FF8.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\72C66FF8.tmp Infected: Trojan-Downloader.Win32.Apropo.ae 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\72C919F5.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.l 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\73587A81.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\73E25052.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\73E57A4E.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.u 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\73E8244B.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\73EB4E47.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\73EF7843.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\73F22240.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\73F54C3C.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\73F87639.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\73FC2035.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\73FF4A32.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.u 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\7402742E.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\74051E2A.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\74094827.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\740C7223.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\740F1C20.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\7413461C.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\74167018.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\74191A15.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\741C4411.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\74206E0E.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\7423180A.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\74264206.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\74296C03.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\742D15FF.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.u 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\74303FFC.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\743369F8.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\743613F4.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.u 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\743A3DF1.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\743D67ED.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\744011EA.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\74443BE6.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\744765E2.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\744A0FDF.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\744D39DB.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\745163D8.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\74540DD4.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\745737D0.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\745A61CD.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\745E0BC9.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\746135C6.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\74645FC2.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\746709BF.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\746B33BB.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\746E5DB7.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\747107B4.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\747431B0.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\74785BAD.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\747B05A9.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\747E2FA5.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\748259A2.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.u 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\7485039E.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\74882D9B.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\748B5797.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\748F0193.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\74922B90.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\74953FCE.dll Infected: not-a-virus:AdWare.Win32.ImiBar.h 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\7495558C.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\74987F89.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\749C13C7.dll Infected: not-a-virus:AdWare.Win32.ActivShopper.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\749C2985.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\749F5381.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\74A27D7E.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\74A5277A.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\74A95177.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\74AC7B73.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\74AF256F.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\74B34F6C.exe Infected: Trojan-Downloader.Win32.Intexp.d 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\74F7026C.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\75352A86.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.a 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\75943298.dll Infected: not-a-virus:AdWare.Win32.Virtumonde.am 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\7607775F.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\766D6D66.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\7702050E.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\775A3679.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\77C86B45.dll Infected: not-a-virus:AdWare.Win32.ClientMan 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\77C86B45.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.r 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\782E614D.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\78FE6B13.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\7A1E00D5.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.t 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\7AB404A4.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\7B7910DE.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\7BB95D95.exe Infected: Trojan-Downloader.Win32.Intexp.c 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\7C5C149F.dll Infected: not-a-virus:AdWare.Win32.ClientMan 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\7C8549A5.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.u 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\7DB82BBB.exe Infected: not-a-virus:AdWare.Win32.BetterInternet.ah 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\7E7B0875.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\All Users\Application Data\Symantec\Norton AntiVirus\Quarantine\7FDF6EE1.tmp Infected: not-a-virus:AdWare.Win32.BetterInternet.b 1
C:\Documents and Settings\Compaq_Owner\Desktop\Setup.exe Infected: not-a-virus:AdTool.Win32.Zango.e 1
C:\Documents and Settings\Compaq_Owner\Incomplete\T-5745425-system of a down attack.mp3 Infected: Trojan-Downloader.WMA.Wimad.n 1
C:\Program Files\Morpheus\morpheustoolbar.exe Infected: not-a-virus:WebToolbar.Win32.MyWebSearch.bm 1
C:\Program Files\Online Services\AOL90US\comps\toolbar\toolbr.EXE Infected: not-a-virus:AdWare.Win32.SearchIt.t 1
C:\qoobox\Quarantine\C\WINDOWS\faceback.exe.vir Infected: Trojan-Downloader.Win32.Agent.agcd 1
C:\qoobox\Quarantine\C\WINDOWS\system32\aximqj.dll.vir Infected: not-a-virus:AdWare.Win32.SuperJuan.efv 1
C:\qoobox\Quarantine\C\WINDOWS\system32\binxpe.dll.vir Infected: Trojan.Win32.Monder.pse 1
C:\qoobox\Quarantine\C\WINDOWS\system32\bmjbjpur.dll.vir Infected: not-a-virus:AdWare.Win32.Virtumonde.alee 1
C:\qoobox\Quarantine\C\WINDOWS\system32\bvsvmhpc.dll.vir Infected: not-a-virus:AdWare.Win32.Virtumonde.alvf 1
C:\qoobox\Quarantine\C\WINDOWS\system32\cbXOGXRk.dll.vir Infected: Trojan.Win32.Monder.oqh 1
C:\qoobox\Quarantine\C\WINDOWS\system32\cgveoj.dll.vir Infected: Trojan.Win32.Monder.png 1
C:\qoobox\Quarantine\C\WINDOWS\system32\djtxporv.dll.vir Infected: not-a-virus:AdWare.Win32.Virtumonde.quj 1
C:\qoobox\Quarantine\C\WINDOWS\system32\DOBE~1\Ñhkdsk.exe.vir Infected: not-a-virus:AdWare.Win32.PurityScan.jw 1
C:\qoobox\Quarantine\C\WINDOWS\system32\drivers\rasptii.sys.vir Infected: Rootkit.Win32.Agent.aol 1
C:\qoobox\Quarantine\C\WINDOWS\system32\eqcxywpv.dll.vir Infected: Trojan.Win32.Monder.psh 1
C:\qoobox\Quarantine\C\WINDOWS\system32\eyymhodc.dll.vir Infected: not-a-virus:AdWare.Win32.Virtumonde.alvi 1
C:\qoobox\Quarantine\C\WINDOWS\system32\ffhfkhwf.dll.vir Infected: not-a-virus:AdWare.Win32.Virtumonde.quj 1
C:\qoobox\Quarantine\C\WINDOWS\system32\fhgftgjc.dll.vir Infected: not-a-virus:AdWare.Win32.Virtumonde.alqn 1
C:\qoobox\Quarantine\C\WINDOWS\system32\fifpeuis.dll.vir Infected: Trojan.Win32.Monder.psh 1
C:\qoobox\Quarantine\C\WINDOWS\system32\foxlagsr.dll.vir Infected: Trojan.Win32.Monder.png 1
C:\qoobox\Quarantine\C\WINDOWS\system32\gamtxunv.dll.vir Infected: Trojan.Win32.BHO.hj 1
C:\qoobox\Quarantine\C\WINDOWS\system32\grhiiflh.dll.vir Infected: Trojan.Win32.Monder.qdo 1
C:\qoobox\Quarantine\C\WINDOWS\system32\hhbrlrbn.dll.vir Infected: Trojan.Win32.Monder.psh 1
C:\qoobox\Quarantine\C\WINDOWS\system32\hiyuxggi.dll.vir Infected: Trojan.Win32.Monder.qdo 1
C:\qoobox\Quarantine\C\WINDOWS\system32\hmotvnsj.dll.vir Infected: not-a-virus:AdWare.Win32.Virtumonde.alrx 1
C:\qoobox\Quarantine\C\WINDOWS\system32\hmvjghvw.dll.vir Infected: not-a-virus:AdWare.Win32.Virtumonde.quj 1
C:\qoobox\Quarantine\C\WINDOWS\system32\hravbfcr.dll.vir Infected: not-a-virus:AdWare.Win32.Virtumonde.alqn 1
C:\qoobox\Quarantine\C\WINDOWS\system32\hxnhawln.dll.vir Infected: Trojan.Win32.Monder.psh 1
C:\qoobox\Quarantine\C\WINDOWS\system32\ihscynvh.dll.vir Infected: not-a-virus:AdWare.Win32.Virtumonde.alqc 1
C:\qoobox\Quarantine\C\WINDOWS\system32\iifggdDV.dll.vir Infected: Trojan.Win32.Monder.psf 1
C:\qoobox\Quarantine\C\WINDOWS\system32\iqntiscb.dll.vir Infected: Trojan.Win32.Monder.psh 1
C:\qoobox\Quarantine\C\WINDOWS\system32\ixpospuj.dll.vir Infected: Trojan.Win32.Monder.psg 1
C:\qoobox\Quarantine\C\WINDOWS\system32\jbmehdag.dll.vir Infected: Trojan.Win32.BHO.hj 1
C:\qoobox\Quarantine\C\WINDOWS\system32\jikbnlln.dll.vir Infected: Trojan.Win32.Monder.qwn 1
C:\qoobox\Quarantine\C\WINDOWS\system32\jlhouldu.dll.vir Infected: Trojan.Win32.BHO.hj 1
C:\qoobox\Quarantine\C\WINDOWS\system32\lgaahalc.dll.vir Infected: not-a-virus:AdWare.Win32.Virtumonde.quj 1
C:\qoobox\Quarantine\C\WINDOWS\system32\lquwpfbn.dll.vir Infected: not-a-virus:AdWare.Win32.Virtumonde.quj 1
C:\qoobox\Quarantine\C\WINDOWS\system32\mC02\mC022328.exe.vir Infected: Trojan-Downloader.Win32.VB.hpv 1
C:\qoobox\Quarantine\C\WINDOWS\system32\mlJBRHYS.dll.vir Infected: Trojan.Win32.Monder.psf 1
C:\qoobox\Quarantine\C\WINDOWS\system32\ogkfwtnq.dll.vir Infected: not-a-virus:AdWare.Win32.SuperJuan.efv 1
C:\qoobox\Quarantine\C\WINDOWS\system32\opnmLCvt.dll.vir Infected: Trojan.Win32.Monder.oqh 1
C:\qoobox\Quarantine\C\WINDOWS\system32\qoMgHARH.dll.vir Infected: Trojan.Win32.Monder.psf 1
C:\qoobox\Quarantine\C\WINDOWS\system32\qskiqfgr.dll.vir Infected: not-a-virus:AdWare.Win32.SuperJuan.efv 1
C:\qoobox\Quarantine\C\WINDOWS\system32\RES\comec130t.exe.vir Infected: not-a-virus:AdWare.Win32.WebHancer.f 1
C:\qoobox\Quarantine\C\WINDOWS\system32\RES\comec130t.exe.vir Infected: not-a-virus:AdWare.Win32.WebHancer.390 1
C:\qoobox\Quarantine\C\WINDOWS\system32\rgkyfa.dll.vir Infected: not-a-virus:AdWare.Win32.SuperJuan.efv 1
C:\qoobox\Quarantine\C\WINDOWS\system32\rqRKCuUM.dll.vir Infected: Trojan.Win32.Monder.psf 1
C:\qoobox\Quarantine\C\WINDOWS\system32\sjviinbx.dll.vir Infected: not-a-virus:AdWare.Win32.Virtumonde.quj 1
C:\qoobox\Quarantine\C\WINDOWS\system32\ssqQkhfF.dll.vir Infected: Trojan.Win32.Monder.pfy 1
C:\qoobox\Quarantine\C\WINDOWS\system32\ualylqiy.dll.vir Infected: not-a-virus:AdWare.Win32.Virtumonde.quj 1
C:\qoobox\Quarantine\C\WINDOWS\system32\umxxthbk.dll.vir Infected: not-a-virus:AdWare.Win32.Virtumonde.alub 1
C:\qoobox\Quarantine\C\WINDOWS\system32\urqNeDvV.dll.vir Infected: Trojan.Win32.Monder.psh 1
C:\qoobox\Quarantine\C\WINDOWS\system32\vssjdutq.dll.vir Infected: Trojan.Win32.Monder.qie 1
C:\qoobox\Quarantine\C\WINDOWS\system32\vtUmLbyA.dll.vir Infected: Trojan.Win32.Monder.psf 1
C:\qoobox\Quarantine\C\WINDOWS\system32\wp\xerd2140.exe.vir Infected: Trojan.Win32.Agent.lom 1
C:\qoobox\Quarantine\C\WINDOWS\system32\wvUnNedC.dll.vir Infected: Trojan.Win32.Monder.psh 1
C:\qoobox\Quarantine\C\WINDOWS\system32\xemwxymi.dll.vir Infected: Trojan.Win32.Monder.pse 1
C:\qoobox\Quarantine\C\WINDOWS\system32\yvbubysy.dll.vir Infected: not-a-virus:AdWare.Win32.Virtumonde.quj 1
C:\qoobox\Quarantine\C\WINDOWS\system32\zlsmp.dll.vir Infected: not-a-virus:AdWare.Win32.PurityScan.jv 1
C:\qoobox\Quarantine\catchme2007-12-17_224647.79.zip Infected: not-a-virus:AdWare.Win32.Virtumonde.am 1
C:\qoobox\Quarantine\catchme2008-10-01_175326.31.zip Infected: Trojan-Downloader.Win32.Agent.kwg 1
The selected area was scanned.
hijackthis
Logfile of Trend Micro HijackThis v2.0.2
Scan saved at 7:20:58 PM, on 10/5/2008
MSIE: Internet Explorer v7.00 (7.00.6000.16705)
Boot mode: Normal
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\lsass.exe
C:\Documents and Settings\All Users\Application Data\EPSON\EPW!3 SSRP\E_S40RP7.EXE
C:\Program Files\Common Files\Microsoft Shared\VS7DEBUG\MDM.EXE
C:\Program Files\Common Files\Protexis\License Service\PsiService_2.exe
C:\Program Files\HHVcdV7Sys\VC7SecS.exe
C:\WINDOWS\system32\ctfmon.exe
C:\Program Files\Messenger\msmsgs.exe
C:\WINDOWS\system32\wscntfy.exe
C:\WINDOWS\explorer.exe
C:\Program Files\Mozilla Firefox\firefox.exe
C:\Documents and Settings\Compaq_Owner\Local Settings\temp\jkos-Compaq_Owner\binaries\ScanningProcess.exe
C:\Program Files\Trend Micro\HijackThis\HijackThis.exe
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://go.microsoft.com/fwlink/?LinkId=69157
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = http://go.microsoft.com/fwlink/?LinkId=54896
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/fwlink/?LinkId=54896
O2 - BHO: Yahoo! Toolbar Helper - {02478D38-C3F9-4EFB-9B51-7695ECA05670} - C:\Program Files\Yahoo!\Companion\Installs\cpn\yt.dll
O2 - BHO: Spybot-S&D IE Protection - {53707962-6F74-2D53-2644-206D7942484F} - C:\PROGRA~1\SPYBOT~1\SDHelper.dll
O2 - BHO: Yahoo! IE Services Button - {5BAB4B5B-68BC-4B02-94D6-2FC0DE4A7897} - C:\PROGRA~1\Yahoo!\Common\yiesrvc.dll
O2 - BHO: SSVHelper Class - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files\Java\jre1.6.0_07\bin\ssv.dll
O2 - BHO: SidebarAutoLaunch Class - {F2AA9440-6328-4933-B7C9-A6CCDF9CBF6D} - C:\Program Files\Yahoo!\browser\YSidebarIEBHO.dll
O4 - HKCU\..\Run: [ctfmon.exe] C:\WINDOWS\system32\ctfmon.exe
O4 - HKCU\..\Run: [MSMSGS] "C:\Program Files\Messenger\msmsgs.exe" /background
O9 - Extra button: (no name) - {DFB852A3-47F8-48C4-A200-58CAB36FD2A2} - C:\PROGRA~1\SPYBOT~1\SDHelper.dll
O9 - Extra 'Tools' menuitem: Spybot - Search & Destroy Configuration - {DFB852A3-47F8-48C4-A200-58CAB36FD2A2} - C:\PROGRA~1\SPYBOT~1\SDHelper.dll
O23 - Service: EPSON V3 Service4(01) (EPSON_PM_RPCV4_01) - SEIKO EPSON CORPORATION - C:\Documents and Settings\All Users\Application Data\EPSON\EPW!3 SSRP\E_S40RP7.EXE
O23 - Service: InstallDriver Table Manager (IDriverT) - Macrovision Corporation - C:\Program Files\Common Files\InstallShield\Driver\11\Intel 32\IDriverT.exe
O23 - Service: iPod Service - Apple Inc. - C:\Program Files\iPod\bin\iPodService.exe
O23 - Service: Protexis Licensing V2 (PSI_SVC_2) - Protexis Inc. - C:\Program Files\Common Files\Protexis\License Service\PsiService_2.exe
O23 - Service: Virtual CD v7 Management Service (VC7SecS) - H+H Software GmbH - C:\Program Files\HHVcdV7Sys\VC7SecS.exe
End of file - 3323 bytes
Thank you!
ComboFix 08-10-01.02 - Compaq_Owner 2008-10-05 16:08:14.5 - NTFSx86
Microsoft Windows XP Home Edition 5.1.2600.2.1252.1.1033.18.187 [GMT -7:00]
Running from: C:\Documents and Settings\Compaq_Owner\Desktop\ComboFix.exe
Command switches used :: C:\Documents and Settings\Compaq_Owner\Desktop\CFScript.txt
* Created a new restore point
((((((((((((((((((((((((((((((((((((((( Other Deletions )))))))))))))))))))))))))))))))))))))))))))))))))
C:\temp\mtc2
C:\temp\mtc2\h5v.log
C:\WINDOWS\system32\mC02
C:\WINDOWS\system32\mC02\mC022328.exe
C:\WINDOWS\system32\np5
C:\WINDOWS\system32\pin
C:\WINDOWS\system32\pin\CONFG32I9.exe
C:\WINDOWS\system32\RES
C:\WINDOWS\system32\RES\comec130t.exe
C:\WINDOWS\system32\wp
C:\WINDOWS\system32\wp\xerd2140.exe
((((((((((((((((((((((((( Files Created from 2008-09-05 to 2008-10-05 )))))))))))))))))))))))))))))))
2008-10-03 17:35 . 2008-10-03 17:35 <DIR> d
C:\_OTMoveIt
2008-10-02 17:37 . 2008-10-02 17:38 <DIR> d
C:\Program Files\Frets on Fire
2008-10-02 17:30 . 2008-10-02 17:30 0 --ah
C:\WINDOWS\system32\drivers\MsftWdf_Kernel_01005_Coinstaller_Critical.Wdf
C:\WINDOWS\system32\drivers\Msft_Kernel_xusb21_01005.Wdf
2008-09-27 12:23 . 2008-09-27 12:24 <DIR> d
C:\Documents and Settings\All Users\Application Data\WinZip
2008-09-23 22:36 . 2008-09-23 22:36 <DIR> d
C:\Program Files\Panda Security
2008-09-18 01:22 . 2008-09-18 01:22 <DIR> d
C:\Program Files\TeaTimer (Spybot - Search & Destroy)
2008-09-17 00:22 . 2008-09-17 00:22 <DIR> d
C:\Documents and Settings\LocalService\Application Data\Apple Computer
2008-09-11 00:36 . 2008-09-11 00:37 <DIR> d
C:\Program Files\iTunes
C:\Documents and Settings\All Users\Application Data\{3276BE95_AF08_429F_A64F_CA64CB79BCF6}
2008-09-11 00:35 . 2008-09-11 00:35 <DIR> d
C:\Program Files\Bonjour
2008-09-11 00:34 . 2008-09-11 00:34 <DIR> d
2008-09-11 00:32 . 2008-09-05 22:16 1,900,544 --a
C:\WINDOWS\system32\usbaaplrc.dll
2008-09-11 00:32 . 2008-09-05 22:16 36,864 --a
C:\WINDOWS\system32\drivers\usbaapl.sys
2008-09-06 15:09 . 2008-09-06 15:09 90,112 --a
C:\WINDOWS\system32\QuickTimeVR.qtx
2008-09-06 15:09 . 2008-09-06 15:09 57,344 --a
C:\WINDOWS\system32\QuickTime.qts
(((((((((((((((((((((((((((((((((((((((( Find3M Report ))))))))))))))))))))))))))))))))))))))))))))))))))))
2008-10-03 08:01
d
w C:\Documents and Settings\Compaq_Owner\Application Data\LimeWire
2008-09-28 19:49
d
w C:\Program Files\Safari
2008-09-23 04:38
d
w C:\Program Files\LimeWire
2008-09-21 00:16
d
w C:\Program Files\Spybot - Search & Destroy
2008-09-19 03:32
d
w C:\Documents and Settings\All Users\Application Data\Spybot - Search & Destroy
2008-09-18 15:51 28,106 ----a-w C:\Documents and Settings\Compaq_Owner\Application Data\wklnhst.dat
2008-09-18 06:41
d
w C:\Program Files\Java
2008-09-11 07:37
d
w C:\Program Files\iPod
2008-09-11 07:34
d
w C:\Program Files\Common Files\Apple
2008-09-05 05:53
d
w C:\Program Files\V CAST Music with Rhapsody
2008-09-05 05:52
d
w C:\Program Files\Real
2008-09-03 04:22
d
w C:\Program Files\Verizon Wireless
2008-08-23 07:15
d
w C:\Program Files\Microsoft Silverlight
2008-08-22 03:15
d---a-w C:\Documents and Settings\All Users\Application Data\TEMP
2008-08-06 16:35
d
w C:\Program Files\Apple Software Update
2008-07-14 19:29 88 --sha-r C:\Documents and Settings\All Users\Application Data\53D7D18ABC.sys
2008-07-14 19:29 2,516 --sha-w C:\Documents and Settings\All Users\Application Data\KGyGaAvL.sys
2008-07-11 02:44 606,848 ----a-w C:\WINDOWS\flashax.exe
2008-07-11 02:44 12,288 ----a-w C:\WINDOWS\impborl.dll
2008-04-29 05:05 69,832 ----a-w C:\Documents and Settings\Compaq_Owner\Application Data\GDIPFONTCACHEV1.DAT
2006-08-17 03:20 184,808 -c--a-w C:\Documents and Settings\Guest\Application Data\shb.dat
2006-06-23 17:39 1,820 -c--a-w C:\Documents and Settings\Guest\Application Data\wklnhst.dat
((((((((((((((((((((((((((((( snapshot_2008-10-01_17.59.14.12 )))))))))))))))))))))))))))))))))))))))))
- 2007-07-31 03:18:40 33,624 -c--a-w C:\WINDOWS\system32\dllcache\wups.dll
+ 2008-07-19 05:10:20 36,552 -c--a-w C:\WINDOWS\system32\dllcache\wups.dll
+ 2006-11-02 14:22:54 492,000
w C:\WINDOWS\system32\drivers\wdf01000.sys
+ 2006-11-02 14:22:52 32,224
w C:\WINDOWS\system32\drivers\wdfldr.sys
+ 2007-08-29 00:05:12 55,808 ----a-w C:\WINDOWS\system32\drivers\xusb21.sys
- 2006-09-26 00:58:48 23,856 ----a-w C:\WINDOWS\system32\spupdsvc.exe
+ 2006-10-09 04:51:14 23,856 ----a-w C:\WINDOWS\system32\spupdsvc.exe
+ 2006-11-02 23:09:50 1,419,232 ----a-w C:\WINDOWS\system32\WdfCoInstaller01005.dll
- 2007-07-31 03:18:40 33,624 ----a-w C:\WINDOWS\system32\wups.dll
+ 2008-07-19 05:10:20 36,552 ----a-w C:\WINDOWS\system32\wups.dll
- 2007-07-31 03:19:12 43,352 ----a-w C:\WINDOWS\system32\wups2.dll
+ 2008-07-19 05:10:40 45,768 ----a-w C:\WINDOWS\system32\wups2.dll
((((((((((((((((((((((((((((((((((((( Reg Loading Points ))))))))))))))))))))))))))))))))))))))))))))))))))
*Note* empty entries & legit default entries are not shown
REGEDIT4
[HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Run]
"ctfmon.exe"="C:\WINDOWS\system32\ctfmon.exe" [2004-08-04 15360]
"MSMSGS"="C:\Program Files\Messenger\msmsgs.exe" [2004-10-13 1694208]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run]
"QuickTime Task"="C:\Program Files\QuickTime\qttask.exe" [2008-09-06 413696]
[HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^America Online 9.0 Tray Icon.lnk]
path=C:\Documents and Settings\All Users\Start Menu\Programs\Startup\America Online 9.0 Tray Icon.lnk
backup=C:\WINDOWS\pss\America Online 9.0 Tray Icon.lnkCommon Startup
[HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^AOL Companion.lnk]
path=C:\Documents and Settings\All Users\Start Menu\Programs\Startup\AOL Companion.lnk
backup=C:\WINDOWS\pss\AOL Companion.lnkCommon Startup
[HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^HP Digital Imaging Monitor.lnk]
path=C:\Documents and Settings\All Users\Start Menu\Programs\Startup\HP Digital Imaging Monitor.lnk
backup=C:\WINDOWS\pss\HP Digital Imaging Monitor.lnkCommon Startup
[HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^HP Image Zone Fast Start.lnk]
path=C:\Documents and Settings\All Users\Start Menu\Programs\Startup\HP Image Zone Fast Start.lnk
backup=C:\WINDOWS\pss\HP Image Zone Fast Start.lnkCommon Startup
[HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^Image Transfer.lnk]
path=C:\Documents and Settings\All Users\Start Menu\Programs\Startup\Image Transfer.lnk
backup=C:\WINDOWS\pss\Image Transfer.lnkCommon Startup
[HKLM\~\startupfolder\C:^Documents and Settings^Compaq_Owner^Start Menu^Programs^Startup^Compaq Organize.lnk]
path=C:\Documents and Settings\Compaq_Owner\Start Menu\Programs\Startup\Compaq Organize.lnk
backup=C:\WINDOWS\pss\Compaq Organize.lnkStartup
[HKLM\~\startupfolder\C:^Documents and Settings^Compaq_Owner^Start Menu^Programs^Startup^LimeWire On Startup.lnk]
path=C:\Documents and Settings\Compaq_Owner\Start Menu\Programs\Startup\LimeWire On Startup.lnk
backup=C:\WINDOWS\pss\LimeWire On Startup.lnkStartup
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\iTunesHelper]
--a
2008-09-08 23:02 289576 C:\Program Files\iTunes\iTunesHelper.exe
[HKEY_LOCAL_MACHINE\software\microsoft\security center\Monitoring\SymantecFirewall]
"DisableMonitoring"=dword:00000001
[HKLM\~\services\sharedaccess\parameters\firewallpolicy\standardprofile\AuthorizedApplications\List]
"C:\\Program Files\\LimeWire\\LimeWire.exe"=
"C:\\Program Files\\Mozilla Firefox\\firefox.exe"=
"C:\\Program Files\\Corel\\DVD9\\WinDVD.exe"=
"C:\\WINDOWS\\system32\\spool\\drivers\\w32x86\\3\\E_DUPA20.EXE"=
"C:\\Program Files\\Firaxis Games\\Sid Meier's Civilization 4 Demo\\Civilization4.exe"=
"C:\\Program Files\\Windows Media Player\\wmplayer.exe"=
"C:\\Program Files\\Bonjour\\mDNSResponder.exe"=
"C:\\Program Files\\iTunes\\iTunes.exe"=
R1 vdrv7000;vdrv7000;C:\WINDOWS\system32\DRIVERS\vdrv7000.sys [2005-01-31 76672]
R2 PSI_SVC_2;Protexis Licensing V2;C:\Program Files\Common Files\Protexis\License Service\PsiService_2.exe [2007-07-24 185632]
R2 regi;regi;C:\WINDOWS\system32\drivers\regi.sys [2007-04-17 11032]
R2 VC7SecS;Virtual CD v7 Management Service;C:\Program Files\HHVcdV7Sys\VC7SecS.exe [2005-11-24 106496]
S4 UPnPService;UPnPService;C:\Program Files\Common Files\MAGIX Shared\UPnPService\UPnPService.exe [2006-12-14 544768]
[HKEY_CURRENT_USER\software\microsoft\windows\currentversion\explorer\mountpoints2\{3afa4cc1-3d8d-11dc-a85b-0011d805b895}]
\Shell\AutoRun\command - H:\system\viewer\Viewer.exe
\Shell\View your videos\command - H:\system\viewer\Viewer.exe
Contents of the 'Scheduled Tasks' folder
catchme 0.3.1361 W2K/XP/Vista - rootkit/stealth malware detector by Gmer, http://www.gmer.net
Rootkit scan 2008-10-05 16:13:49
Windows 5.1.2600 Service Pack 2 NTFS
scanning hidden processes ...
scanning hidden autostart entries ...
scanning hidden files ...
scan completed successfully
hidden files: 0
[HKEY_LOCAL_MACHINE\System\ControlSet001\Services\vdrv7000]
"ImagePath"="system32\DRIVERS\vdrv7000.sys"
Other Running Processes
C:\Program Files\Windows Media Player\wmpnetwk.exe
C:\ComboFix\pv.cfexe
Completion time: 2008-10-05 16:19:32 - machine was rebooted
ComboFix-quarantined-files.txt 2008-10-05 23:19:29
ComboFix2.txt 2008-10-04 00:50:44
ComboFix3.txt 2008-10-02 00:59:47
ComboFix4.txt 2007-12-21 22:26:53
Pre-Run: 121,311,961,088 bytes free
Post-Run: 121,296,928,768 bytes free
164 --- E O F --- 2008-10-02 07:30:44
EMPTY NORTON QUARANTEE FOLDERS
Go to this page and follow the directions for emptying Quarantine for your version of Norton Antivirus:Removing files from Norton AntiVirus Quarantine
Make an uninstall list using HijackThis
To access the Uninstall Manager you would do the following:
1. Start HijackThis
2. Click on the Config button
3. Click on the Misc Tools button
4. Click on the Open Uninstall Manager button.
5. Click on the Save list... button and specify where you would like to save this file. When you press Save button a notepad will open with the contents of that file. Simply copy and paste the contents of that notepad here in your next reply.
Please post the Unisntall List along with a fresh HijackThis log and a description of how your computer is running.
If it has been 7 days or more since your last post, and the helper assisting you posted a response to that post to which you did not reply, this topic will not be reopened. If you still require help, please start a new topic and include a fresh HijackThis log and a link to this thread in your new topic.
If you are not the user who started this thread, you must start your own Thread instead (grin)
