problems with WRT54G router need help fast!
edited September 2008 in Nerdery
when i try to access my router's setting i get the dialogue box asking for username and password. i don't believe i have ever set one and i've tried all the defaults and even hit the little reset button on the back all to no avail. i have no idea what else to do, can anyone help me?
    Username is blank (as in nothing in the box)
    Pasword is admin
    Unless you do not have Linksys firmware anymore.
  • edited September 2008
    i've already tried this and it still won't work
    Hold the reset button in for 10 seconds, then unplug the power, continue holding the reset button for another 30 seconds, then plug the power back in, hold the reset button for another 10 seconds and release.
    When the power light stops flashing.. everything should be back at defaults and the above will work.
    thank you i had no idea that i needed to hold the reset button for that length
    i can now access the settings
    thank you very much
