OK, I am finally going water
What is the best that won't break the bank? I will most likely go with CPU and NB for now and add the GPU later.
After seening the case my brother ordered first hand I think it is well worth the money and will be getting one myself because it has good cooling potential and is constructed like a brick shi*house.
It is this case.
- I know I want 1/2" ID
- I do plan on mounting the rad inside or possibly on the back of the case.
- Can I mount a rad flat on the bottom of the case if I cut a hole and put higher feet on the case?
- Do I need a 2x120 size rad or will a single 120mm size be good enough?
- Out of curosity, does anyone make a good 2x80 size rad???
It is this case.
I knew you would be the first to come through!
Yes that is a 120 hole on the back with 2 80's above the PSU slot and there are 2 80's in the front. I am thinking about replacing the feet with lockable casters and thought the floor of the case would make a good spot for a rad to be out of the way. And am I correct in beleiving a rad should have the air pulled through it as opposed to pushed???
http://www.swiftnets.com/products/mcw5002.asp
http://www.dtekcustoms.com/index.asp?PageAction=VIEWPROD&ProdID=28
That's rad with shroud, Cpu block and pump. GREAT combo.
Check this case: http://www.newegg.com/app/viewProductDesc.asp?DEPA=1&sumit=Go&description=11%2D182%2D005&searchdepa=1
Don't you think it looks better? it's also cheaper and bigger than the one you are buying.
Good luck with your new project. I'd like to go WC'ing too but I cannot afford it.
cheers!
That is the pump I had in mind and was curious about that rad as I saw it mentioned in another thread. Should I use a resivor or not?
EQ
Sorry dude but that just doesn't do it for me. I also got my hands on the one I want when it arrived as part of my brother's order. (It was much cheaper to have it all sent to me and I will send it in the mail to him as UPS and Fed Ex to Alaska is costly.) The construction on the AMS case is awesome and is so strong. And I like the fan configuration better than just about any other case I have seen.
For the coolant, get Zerex super racing along with distilled/battery water. Use 90 water and 10 zerex. In my loop woth 2 blocks and rad + the tubing for it, i used half liter of water and about a half deciliter of zerex. The zerex is totally odur free where Water wetter stinks like a 15 foot bear in the spring when he wakes up.
Also ...I sure hope you put together a list of everything when you're done including links as to where you get it and price you pay make model etc. ...that would sure be helpful for those of us up-n-coming.
I am going for the CPU and NB to start. I will see where I am come Summer on the GPU end of things before doing that one. You can count on a full report when I'm done.
Mac
Very interesting info on the Zerez as opposed to water wetter.
It's pretty bulky though, probably wont fit on the back of that AMS case (unless you mount it externally):
mtgoat, check "That Pet Place" online and see what they have it for. I've bought fish supplies from them before and they are a good company to deal with.Also, I've bought a lot of stuff from The Pet Warehouse but I haven't bought anything from them since they got bought out. That link is right to the Eheim tubing. You will need the 12/16 mm tubing, which is dirt cheap compared to Silicone.
muddocktor
Thanks for the sites to check. The pet place is out of stock and the pet warehouse has it for $6.99 per 10 ft. package.
EyesOnly, zerex is a name brand of antifreeze for your car.
Hope this helps you all out in your decisions.
For heavens sake Muddocktor, you can't compare tubing qualitys between a fishtank and a watercooling setup. That's silly. (no offence)
A fishtank has....algs, Fishsh*it and most of all Oxygen. A watercooling loop doesn't have anything of that. Sure, tygon is VERY good tubing but to a cost that is unjustified for me. I'm sure if lsevald can see this, he can provide with some pictures of bends that that even surprises me. Besides, who have a rig for 2 years going without changing anything in it? Not many in this forum.
I agree that most people will change stuff around in their computer before 2-3 years are up; the dually has been up in it's present form for about 16 months but before it became a watercooled dually, parts of the system were a pelted, watercooled P3 and the tubing I used then I just adapted over to the Asus board when I got it. So parts of the cooling system in that dually have been in use for right at 2 years with no degradation of the silicone tubing. Anyways, the cost of tubing might be the great decider. I haven't been able to find the 1/2" silicone tubing that I'm using and when I bought it, it was $2.00/foot. The Eheim is only $6.95 for 10 feet and the Tygon is $2.65/foot at D-Tek. Whatever way that mtgoat goes, he will be well served with any of them. I'm just trying to point out some of my experiences with Eheim tubing to him. BTW, I've been using Eheim products since I got back into fish in 1995 and they make the best equipment out there.
Well it does thanks you but can i use any brand antifreeze since i can't find any zerex. Is it safe for the computer to use. Well it looks like i can stop asking for tubing since i think i'll go with the eheim due to the price. I can live with replacing it in a few years should it be necessary.
dtekcustoms.com
* Dtek Pro Radiator combo (Metalic Blue)
* Eheim 1250 pump
xoxide.com
* Swiftech MCW5002-A CPU Block
* Danger Den 1/2" Z-Chip Chipset Cooler
Bought Locally
* 10 Ft. Eheim 1/2" I.D. Tubing and assorted fittings
* More AS-5
Will I need any kind of relay system or other electrical?
I plan on making a fill type resivoir with a 'T' fitting and a piece of 1" tubing and placing it at the highest point in the system. Will that work OK?
Safest simple way to protect yourself is to plug the computer and the pump ONLY into a dedicated power bar - this way, the computer can't be turned on without the pump running. Plus, assuming the power bar has its own switch, you have an additional quick shutdown method for unforseen emergencies (I've never had to use mine).
Good point on the dedicated power. I think I will go pick up one of the UPS they have on sale at Fry's tomorrow as I have been considering getting one anyway. Then I can put the computer, monitor and pump on it.
Setup looks great Larry
Measure how long piece of tubing you need, put that piece in a bowl of boiling water for a minute to make it soft (Eheim can easily take VERY hot water compared to Tygon), then form a 180 degree bend with a piece that is as short as possible, put it in the freeze with something that keeps the bend that way (eg. a couple of jars on each side so it doesn't strech out) and leave it there for a day. When you take it out, it'll stay that way.
Here's some serious Eheim bends:
