Problem with Hard Drive
Hi
This may be kind of confusing so I am sorry!
I just bought a new hard drive because I thought my old one broke. It started making scratching noises and Windows would not load, so I thought the hand on it broke.
I did get it started and it kept making really bad noises. I got it started long enough to get some of my files for school off of there and shut it off
So I installed my new hard drive and installed windows. I also have a third hard drive, and it has just my files on it, most of them, and that one is newer, got it about 3 months ago where the old hard drive was 4 years old (so I was expecting it to break), and when I hook up the hard drive with my files on it, the one that I bought 3 months ago, windows will install it, and will read it as a hard drive and install drivers, but then it never assigns it a letter, and so I can't access it. I can't get any of my files off of there. So I thought maybe I had the wrong hard drive and that was the broken one, and tried the other one, and it installed that one, assigned it a letter E:\ and worked 100%.
I went to device manager thinking maybe the drivers were not installed correctly. It says it is fine and everything is working properly.
So then I thought, maybe it wasn't the 4 year old hard drive that was broken, maybe it was the 3 month old one, but then why would Windows not load? Because if the slave drive was broken, wouldn't it just not read it and go on with life? So I wanted to do a disk scan, but it wont assign it a letter, so I can't tell.
If it helps any, they are all Western Digital SATA hard drives, and I replaced the cables and it still wont work. They are all formatted in NTFS. And I had scanned them for viruses a billion times, though I don't know if a virus would do this.
Does anyone have any idea what might be wrong?
Thanks
Thanks
instead I can click it in the bottom and it has a little warning or alert symbol next to it
It says below that:
dynamic
foreign
if I right click it gives option to
import foreign disk
or convert to basic disk
Welcome to Icrontic! We are a big happy family.
I don't know.. I give up. Haha
