Help!!! Need to find best place to get Swiftech water blocks
I have been looking and need to find where to get the Swiftech MCW5002-A CPU block and the Swiftech MCW20 chipset block. I am having a hard time locating them in stock and I will need the 1/2" ID hose barbs for them also.
Edit/ The difference is that the 5002 has 1/2 sized nipples and the fittings is vertical while the 5000 only has 3/8 holes for their quick-tubing thing and have horizontal (kind of) fittings. They do have adapters that you push into those holes though. I use them adapters on the chippy and Radeon block. Thin-walled as well so it won't have so big impact on flow as the case with thick-walled is. I don't like the idea with the horizontal fittings though.
And just split it upstream and downstream.
Then again you could get a DangerDen Maze chipset block with 1/2 barbs in it.
Now I guess I need to figure out my far from flat NB dilema.
Rock and a hard place kind of situation.
Good luck.
