Radeon HD 4550 Dual Display Problem
Hi,
I recently installed an ATI Radeon HD 4550 card, which has DVI, VGA & S-video outputs on it, and I am having a couple of issues.
I have a normal monitor with a standard VGA connection connected to the VGA port on the card & a normal (non digital/non HD) TV connected to the S-video port with an S-video to scart lead.
The two problems I have are:
1: Although the TV is shown in the catalyst display manager - I am unable to enable it. However, if I boot with the VGA to the monitor unplugged - then the display comes up on the TV. Does this mean that the VGA and S-video are using the same signal on the card and, thus, I can't have both connected at the same time? Which would then mean I need to use a SVI to VGA adapter for the monitor OR simply unplug the VGA whenever I want to watch movies on the TV?
2: The display on the TV is in black & white which, from the limited amount of information I could find (and understand with my limited knowledge) is an issue with the S-video to scart lead and nothing to do with the card?
Any help/advice would be greatly appreciated so I can take back the cables, and so on, if they are going to be of no use to me.
Thank you
SV
Thank you
SV
As for the black and white... yes the s-video cable is normally the culprit.
Strikes me as odd to have 3 outputs on a card, but leave you only able to use 2 in unision...
