Options
Help Help !
hi, i have a problem with my computer , now i am writting from the laptop ! my computer when i start it it loggin everithing is ok and after a minute it restarts but when it apears dell logo it restart and again and again until i put off it from the outlet.... and when it boots it stays some minutes and i do nothing and it restarts again ... etc ! i dont know what to do i switched of the internet , i made a scan ( not completed cauze it restarted ) and i dont know what to do when the first time it restarted i saw a massege like "BPJMAIN.EXE EROR " and i havent seen more this messsage plzz hellp me i need help1!!!
Thank you alot for your help !
ps sorry for my bad english im a greek!
the tools used may cause damage if used on a computer with different infections.
If you think you have similar problems, please post a log in the HJT forum and wait for help.
Hello and welcome to the forums
My name is Katana and I will be helping you to remove any infection(s) that you may have.
Please observe these rules while we work:
(Just because you can't see a problem doesn't mean it isn't there)
If you can do those few things, everything should go smoothly
Please Note, your security programs may give warnings for some of the tools I will ask you to use.
Be assured, any links I give are safe
Can you start the machine in Safe Mode ?
To reboot in safe mode
You can boot in Safe Mode by restarting your computer, then continually tapping F8 or F5 until a menu appears.
Use your up arrow key to highlight Safe Mode, then hit enter.
Download and Run RSIT
