Options
Help
My windows live one care is popping up every 5 seconds with the same thing it will not go away how do i get it off.
It says virtool:win32/ursnif.a trojan
  • edited May 2009
    Please note that all instructions given are customised for this computer only,
    the tools used may cause damage if used on a computer with different infections.
    If you think you have similar problems, please post a log in the HJT forum and wait for help.
    Hello and welcome to the forums
    My name is Katana and I will be helping you to remove any infection(s) that you may have.
    Please observe these rules while we work:
    1. Please Read All Instructions Carefully
    2. If you don't understand something, stop and ask! Don't keep going on.
    3. Please do not run any other tools or scans whilst I am helping you
    4. Failure to reply within 5 days will result in the topic being closed.
    5. Please continue to respond until I give you the "All Clear"
      (Just because you can't see a problem doesn't mean it isn't there)
    Please Note, your security programs may give warnings for some of the tools I will ask you to use.
    Be assured, any links I give are safe
    Download and Run RSIT
    • Please download Random's System Information Tool by random/random from here and save it to your desktop.
    • Double click on RSIT.exe to run RSIT.
    • Click Continue at the disclaimer screen.
    • Once it has finished, two logs will open:
      • log.txt will be opened maximized.
      • info.txt will be opened minimized.
    • Please post the contents of both log.txt and info.txt.
  • edited June 2009
    Logfile of random's system information tool 1.06 (written by random/random)
    Run by Owner at 2009-06-03 00:09:30
    Microsoft Windows XP Home Edition Service Pack 3
    System drive C: has 109 GB (73%) free of 149 GB
    Total RAM: 510 MB (34% free)
    HijackThis download failed
    ======Scheduled tasks folder======
    C:\WINDOWS\tasks\Google Software Updater.job
    ======Registry dump======
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{02478D38-C3F9-4efb-9B51-7695ECA05670}]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{0ED403E8-470A-4a8a-85A4-D7688CFE39A3}]
    Gamevance - C:\Program Files\Gamevance\gamevancelib32.dll [2009-05-26 108032]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{18DF081C-E8AD-4283-A596-FA578C2EBDC3}]
    Adobe PDF Link Helper - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelperShim.dll [2009-02-27 75128]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{3049C3E9-B461-4BC5-8870-4C09146192CA}]
    RealPlayer Download and Record Plugin for Internet Explorer - C:\Program Files\Real\RealPlayer\rpbrowserrecordplugin.dll [2008-12-02 304736]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{5BAB4B5B-68BC-4B02-94D6-2FC0DE4A7897}]
    Yahoo! IE Services Button - C:\Program Files\Yahoo!\Common\yiesrvc.dll [2007-12-12 222448]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{5CA3D70E-1895-11CF-8E15-001234567890}]
    DriveLetterAccess - C:\WINDOWS\System32\DLA\DLASHX_W.DLL [2005-11-07 110652]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{761497BB-D6F0-462C-B6EB-D4DAF1D92D43}]
    SSVHelper Class - C:\Program Files\Java\jre1.6.0_05\bin\ssv.dll [2008-02-22 509328]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{AA58ED58-01DD-4d91-8333-CF10577473F7}]
    Google Toolbar Helper - C:\Program Files\Google\Google Toolbar\GoogleToolbar.dll [2009-04-20 259696]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{AF69DE43-7D58-4638-B6FA-CE66B5AD205D}]
    Google Toolbar Notifier BHO - C:\Program Files\Google\GoogleToolbarNotifier\5.1.1309.3572\swg.dll [2009-03-24 668656]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{BEAC7DC8-E106-4C6A-931E-5A42E7362883}]
    Gamevance Text - C:\Program Files\Gamevance\gvtl.dll []
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{C84D72FE-E17D-4195-BB24-76C02E2E7C4E}]
    Google Dictionary Compression sdch - C:\Program Files\Google\Google Toolbar\Component\fastsearch_A8904FB862BD9564.dll [2009-04-20 470512]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Toolbar]
    {327C2873-E90D-4c37-AA9D-10AC9BABA46C} - Easy-WebPrint - C:\Program Files\Canon\Easy-WebPrint\Toolband.dll [2004-08-26 405504]
    {2318C2B1-4965-11d4-9B18-009027A5CD4F} - Google Toolbar - C:\Program Files\Google\Google Toolbar\GoogleToolbar.dll [2009-04-20 259696]
    [HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run]
    "UIUCU"=C:\DOCUME~1\OWNER~2.HOM\LOCALS~1\Temp\UIUCU.EXE [2003-10-30 532480]
    "SoundMAXPnP"=C:\Program Files\Analog Devices\Core\smax4pnp.exe [2004-10-14 1404928]
    "HotKeysCmds"=C:\WINDOWS\system32\hkcmd.exe [2005-04-05 77824]
    "Persistence"=C:\WINDOWS\system32\igfxpers.exe [2005-04-05 114688]
    "medicsp2"=C:\Program Files\twc\medicsp2\bin\sprtcmd.exe [2007-03-07 198184]
    "DLA"=C:\WINDOWS\System32\DLA\DLACTRLW.EXE [2005-11-07 122940]
    "ISUSPM Startup"=C:\Program Files\Common Files\InstallShield\UpdateService\isuspm.exe [2006-03-21 213936]
    "ISUSScheduler"=C:\Program Files\Common Files\InstallShield\UpdateService\issch.exe [2006-03-21 86960]
    "OneCareUI"=C:\Program Files\Microsoft Windows OneCare Live\winssnotify.exe [2009-03-22 63864]
    "ISUSPM"=C:\Program Files\Common Files\InstallShield\UpdateService\isuspm.exe [2006-03-21 213936]
    "SunJavaUpdateSched"=C:\Program Files\Java\jre1.6.0_05\bin\jusched.exe [2008-02-22 144784]
    "HP Software Update"=C:\Program Files\HP\HP Software Update\HPWuSchd2.exe [2007-05-08 54840]
    "PDUiP6220DMon"=C:\Program Files\Canon\Memory Card Utility\iP6220D\PDUiP6220DMon.exe [2005-05-06 69632]
    "TkBellExe"=C:\Program Files\Common Files\Real\Update_OB\realsched.exe [2008-12-02 185872]
    "Adobe Reader Speed Launcher"=C:\Program Files\Adobe\Reader 9.0\Reader\Reader_sl.exe [2009-02-27 35696]
    "Gamevance"=C:\Program Files\Gamevance\gamevance32.exe [2009-05-26 104960]
    [HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run]
    "swg"=C:\Program Files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe [2008-05-26 68856]
    "Yahoo! Pager"=C:\Program Files\Yahoo!\Messenger\YahooMessenger.exe [2007-08-30 4670704]
    "ctfmon.exe"=C:\WINDOWS\system32\ctfmon.exe [2008-04-13 15360]
    "MySpaceIM"=C:\Program Files\MySpace\IM\MySpaceIM.exe [2008-12-12 9555968]
    "Aim6"= []
    C:\Documents and Settings\All Users.WINDOWS\Start Menu\Programs\Startup
    HP Digital Imaging Monitor.lnk - C:\Program Files\HP\Digital Imaging\bin\hpqtra08.exe
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\Notify\igfxcui]
    C:\WINDOWS\system32\igfxdev.dll [2005-04-05 131072]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\ShellServiceObjectDelayLoad]
    WPDShServiceObj - {AAA288BA-9A4C-45B0-95D7-94D524869DB5} - C:\WINDOWS\system32\WPDShServiceObj.dll [2006-10-18 133632]
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\OneCareMP]
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\network\OneCareMP]
    [HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Policies\System]
    "dontdisplaylastusername"=0
    "legalnoticecaption"=
    "legalnoticetext"=
    "shutdownwithoutlogon"=1
    "undockwithoutlogon"=1
    [HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\explorer]
    "NoDriveTypeAutoRun"=145
    [HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Policies\explorer]
    "HonorAutoRunSetting"=
    [HKEY_LOCAL_MACHINE\system\currentcontrolset\services\sharedaccess\parameters\firewallpolicy\standardprofile\authorizedapplications\list]
    "%windir%\system32\sessmgr.exe"="%windir%\system32\sessmgr.exe:*:enabled:@xpsp2res.dll,-22019"
    "C:\Program Files\Yahoo!\Messenger\YahooMessenger.exe"="C:\Program Files\Yahoo!\Messenger\YahooMessenger.exe:*:Enabled:Yahoo! Messenger"
    "C:\Program Files\Yahoo!\Messenger\YServer.exe"="C:\Program Files\Yahoo!\Messenger\YServer.exe:*:Enabled:Yahoo! FT Server"
    "%windir%\Network Diagnostic\xpnetdiag.exe"="%windir%\Network Diagnostic\xpnetdiag.exe:*:Enabled:@xpsp3res.dll,-20000"
    "C:\Program Files\Common Files\AOL\Loader\aolload.exe"="C:\Program Files\Common Files\AOL\Loader\aolload.exe:*:Enabled:AOL Loader"
    "C:\Program Files\AIM6\aim6.exe"="C:\Program Files\AIM6\aim6.exe:*:Enabled:AIM"
    "C:\Program Files\LimeWire\LimeWire.exe"="C:\Program Files\LimeWire\LimeWire.exe:*:Enabled:LimeWire"
    "C:\WINDOWS\explorer.exe"="C:\WINDOWS\explorer.exe:*:Enabled:Windows Explorer"
    "C:\Program Files\MySpace\IM\MySpaceIM.exe"="C:\Program Files\MySpace\IM\MySpaceIM.exe:*:Enabled:MySpaceIM"
    [HKEY_LOCAL_MACHINE\system\currentcontrolset\services\sharedaccess\parameters\firewallpolicy\domainprofile\authorizedapplications\list]
    ======List of files/folders created in the last 1 months======
    2009-06-03 00:09:32 ----D---- C:\Program Files\trend micro
    2009-06-03 00:09:30 ----D---- C:\rsit
    2009-06-02 17:38:31 ----N---- C:\WINDOWS\system32\winlogon.exe81B9E475
    2009-05-29 09:16:37 ----HD---- C:\WINDOWS\PIF
    2009-05-27 23:42:35 ----D---- C:\Program Files\Common Files\DivX Shared
    2009-05-27 23:42:34 ----D---- C:\Program Files\DivX
    2009-05-26 01:43:35 ----D---- C:\Program Files\Gamevance
    2009-05-16 11:52:09 ----D---- C:\Documents and Settings\Owner.HOME-4FBF327C98\Application Data\Ubisoft
    2009-05-14 21:21:13 ----D---- C:\Documents and Settings\Owner.HOME-4FBF327C98\Application Data\Skunk Studios
    2009-05-12 11:53:57 ----D---- C:\Documents and Settings\Owner.HOME-4FBF327C98\Application Data\HiT-MM
    2009-05-06 01:25:31 ----D---- C:\WINDOWS\ie8updates
    2009-05-06 00:19:20 ----HDC---- C:\WINDOWS\ie8
    ======List of files/folders modified in the last 1 months======
    2009-06-02 23:34:10 ----D---- C:\WINDOWS\Prefetch
    2009-06-02 21:15:22 ----SD---- C:\WINDOWS\Tasks
    2009-06-02 21:15:14 ----D---- C:\Documents and Settings\All Users.WINDOWS\Application Data\Google Updater
    2009-06-02 17:38:31 ----D---- C:\WINDOWS\system32
    2009-06-02 17:26:41 ----D---- C:\Program Files\Microsoft Windows OneCare Live
    2009-06-02 17:23:34 ----D---- C:\WINDOWS\Temp
    2009-06-02 17:22:42 ----SHD---- C:\WINDOWS\Installer
    2009-06-02 17:22:42 ----HD---- C:\Config.Msi
    2009-06-02 17:21:32 ----D---- C:\WINDOWS\system32\CatRoot2
    2009-06-02 01:26:21 ----A---- C:\WINDOWS\SchedLgU.Txt
    2009-06-01 18:45:18 ----D---- C:\Documents and Settings\Owner.HOME-4FBF327C98\Application Data\LimeWire
    2009-05-29 17:25:31 ----D---- C:\WINDOWS\system32\drivers
    2009-05-29 09:16:37 ----D---- C:\WINDOWS
    2009-05-29 00:11:43 ----D---- C:\Program Files\Internet Explorer
    2009-05-28 23:10:50 ----D---- C:\WINDOWS\Registration
    2009-05-28 23:05:37 ----D---- C:\Program Files\Yahoo!
    2009-05-28 22:54:54 ----D---- C:\Program Files\Google
    2009-05-28 22:54:54 ----D---- C:\Documents and Settings\All Users.WINDOWS\Application Data\Google
    2009-05-27 23:33:38 ----D---- C:\WINDOWS\network diagnostic
    2009-05-26 12:24:34 ----D---- C:\Documents and Settings\Owner.HOME-4FBF327C98\Application Data\Mozilla
    2009-05-25 11:36:37 ----D---- C:\My Games
    2009-05-25 11:36:35 ----D---- C:\Program Files\RealArcade
    2009-05-25 11:35:01 ----D---- C:\Program Files\Coupons
    2009-05-25 11:34:17 ----D---- C:\Documents and Settings\All Users.WINDOWS\Application Data\Viewpoint
    2009-05-25 11:34:14 ----D---- C:\Program Files\Viewpoint
    2009-05-24 12:48:19 ----RSHDC---- C:\WINDOWS\system32\dllcache
    2009-05-16 13:07:40 ----AD---- C:\Documents and Settings\All Users.WINDOWS\Application Data\TEMP
    2009-05-16 12:19:58 ----D---- C:\Documents and Settings\All Users.WINDOWS\Application Data\BigFishGamesCache
    2009-05-15 18:07:03 ----D---- C:\WINDOWS\system32\Macromed
    2009-05-14 18:11:15 ----SD---- C:\WINDOWS\Downloaded Program Files
    2009-05-14 18:11:11 ----HD---- C:\WINDOWS\inf
    2009-05-07 15:15:12 ----A---- C:\WINDOWS\Sysvxd.exe
    2009-05-07 03:16:29 ----A---- C:\WINDOWS\system32\MRT.exe
    2009-05-06 15:06:31 ----D---- C:\Program Files\AIM Toolbar
    2009-05-06 14:47:04 ----SHD---- C:\System Volume Information
    2009-05-06 09:39:27 ----D---- C:\WINDOWS\system32\NtmsData
    2009-05-06 03:06:45 ----D---- C:\WINDOWS\system32\en-US
    2009-05-06 03:06:43 ----D---- C:\WINDOWS\Media
    2009-05-06 03:06:43 ----D---- C:\WINDOWS\Help
    2009-05-06 01:18:15 ----HD---- C:\WINDOWS\$hf_mig$
    2009-05-06 01:15:35 ----A---- C:\WINDOWS\imsins.BAK
    ======List of drivers (R=Running, S=Stopped, 0=Boot, 1=System, 2=Auto, 3=Demand, 4=Disabled)======
    R1 DLACDBHM;DLACDBHM; C:\WINDOWS\System32\Drivers\DLACDBHM.SYS [2005-11-18 5660]
    R1 DLARTL_N;DLARTL_N; C:\WINDOWS\System32\Drivers\DLARTL_N.SYS [2005-11-18 22684]
    R1 intelppm;Intel Processor Driver; C:\WINDOWS\system32\DRIVERS\intelppm.sys [2008-04-13 36352]
    R1 kbdhid;Keyboard HID Driver; C:\WINDOWS\system32\DRIVERS\kbdhid.sys [2008-04-13 14592]
    R1 MSFWHLPR;MSFWHLPR; C:\WINDOWS\system32\DRIVERS\msfwhlpr.sys [2007-11-28 116416]
    R1 OMCI;OMCI; C:\WINDOWS\SYSTEM32\DRIVERS\OMCI.SYS [2001-08-22 13632]
    R2 DLABOIOM;DLABOIOM; C:\WINDOWS\System32\DLA\DLABOIOM.SYS [2005-11-07 25628]
    R2 DLADResN;DLADResN; C:\WINDOWS\System32\DLA\DLADResN.SYS [2005-11-07 2496]
    R2 DLAIFS_M;DLAIFS_M; C:\WINDOWS\System32\DLA\DLAIFS_M.SYS [2005-11-07 86652]
    R2 DLAOPIOM;DLAOPIOM; C:\WINDOWS\System32\DLA\DLAOPIOM.SYS [2005-11-07 14684]
    R2 DLAPoolM;DLAPoolM; C:\WINDOWS\System32\DLA\DLAPoolM.SYS [2005-11-07 6364]
    R2 DLAUDF_M;DLAUDF_M; C:\WINDOWS\System32\DLA\DLAUDF_M.SYS [2005-11-07 87036]
    R2 DLAUDFAM;DLAUDFAM; C:\WINDOWS\System32\DLA\DLAUDFAM.SYS [2005-11-07 94332]
    R2 DRVNDDM;DRVNDDM; C:\WINDOWS\System32\Drivers\DRVNDDM.SYS [2005-08-12 40544]
    R2 MSFWDrv;MSFWDrv; C:\WINDOWS\system32\DRIVERS\msfwdrv.sys [2007-11-28 91328]
    R3 E100B;Intel(R) PRO Adapter Driver; C:\WINDOWS\system32\DRIVERS\e100b325.sys [2004-02-10 154112]
    R3 hidusb;Microsoft HID Class Driver; C:\WINDOWS\system32\DRIVERS\hidusb.sys [2008-04-13 10368]
    R3 ialm;ialm; C:\WINDOWS\system32\DRIVERS\ialmnt5.sys [2005-04-05 830684]
    R3 IntelC51;IntelC51; C:\WINDOWS\system32\DRIVERS\IntelC51.sys [2004-03-06 1233525]
    R3 IntelC52;IntelC52; C:\WINDOWS\system32\DRIVERS\IntelC52.sys [2004-03-06 647929]
    R3 IntelC53;IntelC53; C:\WINDOWS\system32\DRIVERS\IntelC53.sys [2004-06-16 61157]
    R3 MODEMCSA;Unimodem Streaming Filter Device; C:\WINDOWS\system32\drivers\MODEMCSA.sys [2001-08-17 16128]
    R3 mohfilt;mohfilt; C:\WINDOWS\system32\DRIVERS\mohfilt.sys [2004-03-06 37048]
    R3 mouhid;Mouse HID Driver; C:\WINDOWS\system32\DRIVERS\mouhid.sys [2004-08-04 12160]
    R3 MpFilter;Microsoft Malware Protection Driver; C:\WINDOWS\system32\DRIVERS\MpFilter.sys [2008-05-15 53168]
    R3 senfilt;senfilt; C:\WINDOWS\system32\drivers\senfilt.sys [2004-09-17 732928]
    R3 smwdm;smwdm; C:\WINDOWS\system32\drivers\smwdm.sys [2005-03-22 260224]
    R3 usbccgp;Microsoft USB Generic Parent Driver; C:\WINDOWS\system32\DRIVERS\usbccgp.sys [2008-04-13 32128]
    R3 usbehci;Microsoft USB 2.0 Enhanced Host Controller Miniport Driver; C:\WINDOWS\system32\DRIVERS\usbehci.sys [2008-04-13 30208]
    R3 usbhub;USB2 Enabled Hub; C:\WINDOWS\system32\DRIVERS\usbhub.sys [2008-04-13 59520]
    R3 usbprint;Microsoft USB PRINTER Class; C:\WINDOWS\system32\DRIVERS\usbprint.sys [2008-04-13 25856]
    R3 USBSTOR;USB Mass Storage Driver; C:\WINDOWS\system32\DRIVERS\USBSTOR.SYS [2008-04-13 26368]
    R3 usbuhci;Microsoft USB Universal Host Controller Miniport Driver; C:\WINDOWS\system32\DRIVERS\usbuhci.sys [2008-04-13 20608]
    S2 ASCTRM;ASCTRM; C:\WINDOWS\system32\drivers\ASCTRM.sys []
    S3 UIUSys;Conexant Setup API; C:\WINDOWS\system32\drivers\UIUSys.sys []
    S3 usbscan;USB Scanner Driver; C:\WINDOWS\system32\DRIVERS\usbscan.sys [2008-04-13 15104]
    S3 WpdUsb;WpdUsb; C:\WINDOWS\system32\DRIVERS\wpdusb.sys [2006-10-18 38528]
    S3 WudfRd;Windows Driver Foundation - User-mode Driver Framework Reflector; C:\WINDOWS\system32\DRIVERS\wudfrd.sys [2006-09-28 82944]
    ======List of services (R=Running, S=Stopped, 0=Boot, 1=System, 2=Auto, 3=Demand, 4=Disabled)======
    R2 msfwsvc;OneCare Firewall; C:\Program Files\Microsoft Windows OneCare Live\Firewall\msfwsvc.exe [2007-11-28 755264]
    R2 OcHealthMon;Windows Live OneCare Health Monitor; C:\Program Files\Microsoft Windows OneCare Live\OcHealthMon.exe [2009-03-22 24936]
    R2 OneCareMP;OneCare AntiSpyware and AntiVirus; C:\Program Files\Microsoft Windows OneCare Live\Antivirus\MsMpEng.exe [2008-07-09 18704]
    R2 Pml Driver HPZ12;Pml Driver HPZ12; C:\WINDOWS\system32\HPZipm12.exe [2007-08-09 73728]
    R2 ProtexisLicensing;ProtexisLicensing; C:\WINDOWS\system32\PSIService.exe [2006-11-02 174656]
    R2 sprtsvc_medicsp2;SupportSoft Sprocket Service (medicsp2); C:\Program Files\twc\medicsp2\bin\sprtsvc.exe [2007-03-07 202280]
    R2 winss;Windows Live OneCare; C:\Program Files\Microsoft Windows OneCare Live\winss.exe [2009-03-22 1131896]
    R2 WudfSvc;Windows Driver Foundation - User-mode Driver Framework; C:\WINDOWS\system32\svchost.exe [2008-04-13 14336]
    S2 gusvc;Google Software Updater; C:\Program Files\Google\Common\Google Updater\GoogleUpdaterService.exe [2009-03-24 183280]
    S3 aspnet_state;ASP.NET State Service; C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\aspnet_state.exe [2008-07-25 34312]
    S3 clr_optimization_v2.0.50727_32;.NET Runtime Optimization Service v2.0.50727_X86; C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\mscorsvw.exe [2008-07-25 69632]
    S3 FontCache3.0.0.0;Windows Presentation Foundation Font Cache 3.0.0.0; c:\WINDOWS\Microsoft.NET\Framework\v3.0\WPF\PresentationFontCache.exe [2008-07-29 46104]
    S3 idsvc;Windows CardSpace; c:\WINDOWS\Microsoft.NET\Framework\v3.0\Windows Communication Foundation\infocard.exe [2008-07-29 881664]
    S3 usprserv;User Privilege Service; C:\WINDOWS\System32\svchost.exe [2008-04-13 14336]
    S3 WMPNetworkSvc;Windows Media Player Network Sharing Service; C:\Program Files\Windows Media Player\WMPNetwk.exe [2006-10-18 913408]
    S4 NetTcpPortSharing;Net.Tcp Port Sharing Service; c:\WINDOWS\Microsoft.NET\Framework\v3.0\Windows Communication Foundation\SMSvcHost.exe [2008-07-29 132096]
    EOF
  • edited June 2009
    info.txt logfile of random's system information tool 1.06 2009-06-03 00:09:43
    ======Uninstall list======
    -->C:\Program Files\Common Files\Real\Update_OB\r1puninst.exe RealNetworks|RealPlayer|6.0
    -->C:\WINDOWS\system32\\MSIEXEC.EXE /x {075473F5-846A-448B-BCB3-104AA1760205}
    -->C:\WINDOWS\system32\\MSIEXEC.EXE /x {1206EF92-2E83-4859-ACCB-2048C3CB7DA6}
    -->C:\WINDOWS\system32\\MSIEXEC.EXE /x {AB708C9B-97C8-4AC9-899B-DBF226AC9382}
    -->C:\WINDOWS\system32\\MSIEXEC.EXE /x {B12665F4-4E93-4AB4-B7FC-37053B524629}
    -->C:\WINDOWS\system32\Macromed\Flash\uninstall_plugin.exe
    -->rundll32.exe setupapi.dll,InstallHinfSection DefaultUninstall 132 C:\WINDOWS\INF\PCHealth.inf
    12Sky-->RunDll32 C:\PROGRA~1\COMMON~1\INSTAL~1\PROFES~1\RunTime\10\50\Intel32\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{4235A9E5-EEFF-42E7-BEC9-9D421DD10ECB}\setup.exe" -l0x9 -removeonly
    Acrobat.com-->MsiExec.exe /X{287ECFA4-719A-2143-A09B-D6A12DE54E40}
    Adobe AIR-->c:\Program Files\Common Files\Adobe AIR\Versions\1.0\Resources\Adobe AIR Updater.exe -arp:uninstall
    Adobe AIR-->MsiExec.exe /I{A2BCA9F1-566C-4805-97D1-7FDC93386723}
    Adobe Flash Player 10 ActiveX-->C:\WINDOWS\system32\Macromed\Flash\uninstall_activeX.exe
    Adobe Flash Player 10 Plugin-->MsiExec.exe /X{ECA1A3B6-898F-4DCE-9F04-714CF3BA126B}
    Adobe Media Player-->msiexec /qb /x {1EBB57D4-63FF-87CC-A0F0-D73982CF6008}
    Adobe Media Player-->MsiExec.exe /I{1EBB57D4-63FF-87CC-A0F0-D73982CF6008}
    Adobe Reader 9.1-->MsiExec.exe /I{AC76BA86-7AD7-1033-7B44-A91000000001}
    Adobe Shockwave Player-->C:\WINDOWS\system32\Adobe\SHOCKW~1\UNWISE.EXE C:\WINDOWS\system32\Adobe\SHOCKW~1\Install.log
    AIM 6-->C:\Program Files\AIM6\uninst.exe
    Aim Plugin for QQ Games-->C:\Program Files\Tencent\QQ Games\Plugin\Uninstall.EXE
    AIMTunes-->C:\Program Files\AIMTunes\Uninstall.exe
    Big Fish Games Client-->C:\Program Files\bfgclient\Uninstall.exe
    Canon iP6220D Memory Card Utility-->RunDll32 C:\PROGRA~1\COMMON~1\INSTAL~1\engine\6\INTEL3~1\ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{DD62878E-7631-4D9D-9983-6F30DA4D7FF8}\setup.exe" /PDUUninstall
    Canon iP6220D-->C:\WINDOWS\system32\CNMCP7C.exe "-PRINTERNAMECanon iP6220D" "-HELPERDLLC:\Documents and Settings\All Users.WINDOWS\Application Data\CanonBJ\IJPrinter\CNMWINDOWS\Canon iP6220D Installer\Inst2\cnmis.dll" "-RCDLLcnmi0409.dll"
    Canon Utilities Easy-PhotoPrint-->C:\Program Files\Canon\Easy-PhotoPrint\uninst.exe uninst.ini
    Critical Update for Windows Media Player 11 (KB959772)-->"C:\WINDOWS\$NtUninstallKB959772_WM11$\spuninst\spuninst.exe"
    Dell Resource CD-->MsiExec.exe /X{FCD9CD52-7222-4672-94A0-A722BA702FD0}
    Dell ResourceCD-->RunDll32 C:\PROGRA~1\COMMON~1\INSTAL~1\engine\6\INTEL3~1\ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{D78653C3-A8FF-415F-92E6-D774E634FF2D}\setup.exe"
    DivX Web Player-->C:\Program Files\DivX\DivXWebPlayerUninstall.exe /PLUGIN
    Download Updater (AOL LLC)-->C:\Program Files\Common Files\Software Update Utility\uninstall.exe
    Easy-WebPrint-->C:\WINDOWS\IsUninst.exe -f"C:\Program Files\Canon\Easy-WebPrint\Uninst.isu"
    GIMPshop 2.2.8-->C:\Program Files\GIMPshop\uninst.exe
    Google Toolbar for Internet Explorer-->"C:\Program Files\Google\Google Toolbar\Component\GoogleToolbarManager_BDA1448D3D255554.exe" /uninstall
    Google Toolbar for Internet Explorer-->MsiExec.exe /I{18455581-E099-4BA8-BC6B-F34B2F06600C}
    Google Updater-->"C:\Program Files\Google\Google Updater\GoogleUpdater.exe" -uninstall
    GTOneCare-->MsiExec.exe /X{8B21B9EF-6DBF-4F63-8CC7-9F6A56D1EE8E}
    Hotfix for Microsoft .NET Framework 3.5 SP1 (KB953595)-->C:\WINDOWS\system32\msiexec.exe /package {CE2CDD62-0124-36CA-84D3-9F4DCF5C5BD9} /uninstall /qb+ REBOOTPROMPT=""
    Hotfix for Microsoft .NET Framework 3.5 SP1 (KB958484)-->C:\WINDOWS\system32\msiexec.exe /package {CE2CDD62-0124-36CA-84D3-9F4DCF5C5BD9} /uninstall {A7EEA2F2-BFCD-4A54-A575-7B81A786E658} /qb+ REBOOTPROMPT=""
    Hotfix for Windows Internet Explorer 7 (KB947864)-->"C:\WINDOWS\ie7updates\KB947864-IE7\spuninst\spuninst.exe"
    Hotfix for Windows Media Format 11 SDK (KB929399)-->"C:\WINDOWS\$NtUninstallKB929399$\spuninst\spuninst.exe"
    Hotfix for Windows Media Player 11 (KB939683)-->"C:\WINDOWS\$NtUninstallKB939683$\spuninst\spuninst.exe"
    Hotfix for Windows XP (KB952287)-->"C:\WINDOWS\$NtUninstallKB952287$\spuninst\spuninst.exe"
    Hotfix for Windows XP (KB961118)-->"C:\WINDOWS\$NtUninstallKB961118$\spuninst\spuninst.exe"
    HP Customer Participation Program 7.0-->C:\Program Files\HP\Digital Imaging\ExtCapUninstall\hpzscr01.exe -datfile hpqhsc01.dat
    HP Imaging Device Functions 7.0-->C:\Program Files\HP\Digital Imaging\DeviceManagement\hpzscr01.exe -datfile hpqbud01.dat
    HP Photosmart and Deskjet 7.0 Software-->C:\Program Files\HP\Digital Imaging\{D2A3C9D5-0B56-4656-8277-7EDC65D62B6E}\setup\hpzscr01.exe -datfile hphscr12.dat -showdisconnect -forcereboot
    HP Photosmart Essential-->MsiExec.exe /X{6994491D-D491-48F1-AE1F-E179C1FFFC2F}
    HP Solution Center 7.0-->C:\Program Files\HP\Digital Imaging\eSupport\hpzscr01.exe -datfile hpqbud05.dat
    HP Update-->MsiExec.exe /X{C8FD5BC1-92EF-4C15-92A9-F9AC7F61985F}
    Intel(R) 537EP V9x DF PCI Modem-->rundll32 IntelCci.dll,iSMUninstallation "Intel(R) 537EP V9x DF PCI Modem"
    Intel(R) Extreme Graphics 2 Driver-->RUNDLL32.EXE C:\WINDOWS\system32\ialmrem.dll,UninstallW2KIGfx PCI\VEN_8086&DEV_2572
    Intel(R) PRO Network Adapters and Drivers-->Prounstl.exe
    Java(TM) 6 Update 5-->MsiExec.exe /I{3248F0A8-6813-11D6-A77B-00B0D0160050}
    LimeWire 5.1.2-->"C:\Program Files\LimeWire\uninstall.exe"
    Luxor 2 (remove only)-->"C:\Program Files\MumboJumbo\Luxor 2\uninstall.exe"
    Microsoft .NET Framework 2.0 Service Pack 2-->MsiExec.exe /I{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}
    Microsoft .NET Framework 3.0 Service Pack 2-->MsiExec.exe /I{A3051CD0-2F64-3813-A88D-B8DCCDE8F8C7}
    Microsoft .NET Framework 3.5 SP1-->C:\WINDOWS\Microsoft.NET\Framework\v3.5\Microsoft .NET Framework 3.5 SP1\setup.exe
    Microsoft .NET Framework 3.5 SP1-->MsiExec.exe /I{CE2CDD62-0124-36CA-84D3-9F4DCF5C5BD9}
    Microsoft Compression Client Pack 1.0 for Windows XP-->"C:\WINDOWS\$NtUninstallMSCompPackV1$\spuninst\spuninst.exe"
    Microsoft Internationalized Domain Names Mitigation APIs-->"C:\WINDOWS\$NtServicePackUninstallIDNMitigationAPIs$\spuninst\spuninst.exe"
    Microsoft National Language Support Downlevel APIs-->"C:\WINDOWS\$NtServicePackUninstallNLSDownlevelMapping$\spuninst\spuninst.exe"
    Microsoft Protection Service-->MsiExec.exe /I{85CFDC2D-710E-49D5-B799-F3743CA506BA}
    Microsoft User-Mode Driver Framework Feature Pack 1.0-->"C:\WINDOWS\$NtUninstallWudf01000$\spuninst\spuninst.exe"
    Microsoft Windows Live OneCare Resources v2.5.2900.24-->MsiExec.exe /I{5660022E-F3F2-4126-8CC5-9726C47150EB}
    Microsoft Windows OneCare Live AntiSpyware and AntiVirus-->MsiExec.exe /I{E26B83D1-C0BB-41BC-8F44-31D5354DD6AF}
    Microsoft Windows OneCare Live v2.5.2900.20 Idcrl Install-->MsiExec.exe /I{3851147E-5A91-4469-BA4D-13FFFCC8A920}
    Microsoft Windows OneCare Live v2.5.2900.24-->MsiExec.exe /I{D07A8E7E-D324-4945-BA8C-E532AD008FF3}
    MSN-->C:\Program Files\MSN\MsnInstaller\msninst.exe /Action:ARP
    MSXML 4.0 SP2 (KB936181)-->MsiExec.exe /I{C04E32E0-0416-434D-AFB9-6969D703A9EF}
    MSXML 4.0 SP2 (KB954430)-->MsiExec.exe /I{86493ADD-824D-4B8E-BD72-8C5DCDC52A71}
    MySpaceIM-->C:\Program Files\MySpace\IM\Uninstall.exe
    Picasa 3-->"C:\Program Files\Google\Picasa3\Uninstall.exe"
    PowerDVD 5.5-->RunDll32 C:\PROGRA~1\COMMON~1\INSTAL~1\engine\6\INTEL3~1\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{6811CAA0-BF12-11D4-9EA1-0050BAE317E1}\Setup.exe" -uninstall
    PX Engine-->MsiExec.exe /I{6513E869-647F-40FD-A55D-CFC92579B9BA}
    QQ BlackJack-->C:\Program Files\Tencent\QQ Games\QQ BlackJack\Uninstall.EXE
    QQ Bubble Arena-->C:\Program Files\Tencent\QQ Games\QQ Bubble Arena\Uninstall.EXE
    QQ Chess-->C:\Program Files\Tencent\QQ Games\QQ Chess\Uninstall.EXE
    QQ Games-->C:\Program Files\Tencent\QQ Games\Uninstall.EXE
    QQ Gold Sweeper-->C:\Program Files\Tencent\QQ Games\QQ Gold Sweeper\Uninstall.EXE
    QQ Hearts-->C:\Program Files\Tencent\QQ Games\QQ Hearts\Uninstall.EXE
    QQ Mah-jong-->C:\Program Files\Tencent\QQ Games\QQ Mah-jong\Uninstall.EXE
    QQ Match Master-->C:\Program Files\Tencent\QQ Games\QQ Match Master\Uninstall.EXE
    QQ Pool-->C:\Program Files\Tencent\QQ Games\QQ Pool\Uninstall.EXE
    QQ Puzzle Dasher-->C:\Program Files\Tencent\QQ Games\QQ PuzzleDasher\Uninstall.EXE
    QQ Robo-->C:\Program Files\Tencent\QQ Games\QQ Robo\Uninstall.EXE
    QQ Treasure Hunter-->C:\Program Files\Tencent\QQ Games\QQ Treasure Hunter\Uninstall.EXE
    RealArcade-->"C:\Program Files\RealArcade\Installer\bin\gameinstaller.exe" "C:\Program Files\RealArcade\Installer\installerMain.clf" "C:\Program Files\RealArcade\Installer\uninstall\RealArcade.rguninst" "AddRemove"
    RealPlayer-->C:\Program Files\Common Files\Real\Update_OB\r1puninst.exe RealNetworks|RealPlayer|6.0
    Road Runner Install-->"C:\Program Files\HERACTSTG\smartaccess\unins000.exe"
    Road Runner Medic 6.1-->"C:\Program Files\twc\medicsp2\unins000.exe"
    Roxio DLA-->MsiExec.exe /I{1206EF92-2E83-4859-ACCB-2048C3CB7DA6}
    Roxio MyDVD LE-->MsiExec.exe /I{21657574-BD54-48A2-9450-EB03B2C7FC29}
    Roxio RecordNow Audio-->MsiExec.exe /I{AB708C9B-97C8-4AC9-899B-DBF226AC9382}
    Roxio RecordNow Copy-->MsiExec.exe /I{B12665F4-4E93-4AB4-B7FC-37053B524629}
    Roxio RecordNow Data-->MsiExec.exe /I{075473F5-846A-448B-BCB3-104AA1760205}
    Security Update for Windows Internet Explorer 7 (KB938127)-->"C:\WINDOWS\ie7updates\KB938127-IE7\spuninst\spuninst.exe"
    Security Update for Windows Internet Explorer 7 (KB942615)-->"C:\WINDOWS\ie7updates\KB942615-IE7\spuninst\spuninst.exe"
    Security Update for Windows Internet Explorer 7 (KB944533)-->"C:\WINDOWS\ie7updates\KB944533-IE7\spuninst\spuninst.exe"
    Security Update for Windows Internet Explorer 7 (KB950759)-->"C:\WINDOWS\ie7updates\KB950759-IE7\spuninst\spuninst.exe"
    Security Update for Windows Internet Explorer 7 (KB953838)-->"C:\WINDOWS\ie7updates\KB953838-IE7\spuninst\spuninst.exe"
    Security Update for Windows Internet Explorer 7 (KB956390)-->"C:\WINDOWS\ie7updates\KB956390-IE7\spuninst\spuninst.exe"
    Security Update for Windows Internet Explorer 7 (KB958215)-->"C:\WINDOWS\ie7updates\KB958215-IE7\spuninst\spuninst.exe"
    Security Update for Windows Internet Explorer 7 (KB960714)-->"C:\WINDOWS\ie7updates\KB960714-IE7\spuninst\spuninst.exe"
    Security Update for Windows Internet Explorer 7 (KB961260)-->"C:\WINDOWS\ie7updates\KB961260-IE7\spuninst\spuninst.exe"
    Security Update for Windows Internet Explorer 7 (KB963027)-->"C:\WINDOWS\ie7updates\KB963027-IE7\spuninst\spuninst.exe"
    Security Update for Windows Media Player (KB952069)-->"C:\WINDOWS\$NtUninstallKB952069_WM9$\spuninst\spuninst.exe"
    Security Update for Windows Media Player 11 (KB936782)-->"C:\WINDOWS\$NtUninstallKB936782_WMP11$\spuninst\spuninst.exe"
    Security Update for Windows Media Player 11 (KB954154)-->"C:\WINDOWS\$NtUninstallKB954154_WM11$\spuninst\spuninst.exe"
    Security Update for Windows XP (KB923561)-->"C:\WINDOWS\$NtUninstallKB923561$\spuninst\spuninst.exe"
    Security Update for Windows XP (KB938464)-->"C:\WINDOWS\$NtUninstallKB938464$\spuninst\spuninst.exe"
    Security Update for Windows XP (KB941569)-->"C:\WINDOWS\$NtUninstallKB941569$\spuninst\spuninst.exe"
    Security Update for Windows XP (KB946648)-->"C:\WINDOWS\$NtUninstallKB946648$\spuninst\spuninst.exe"
    Security Update for Windows XP (KB950760)-->"C:\WINDOWS\$NtUninstallKB950760$\spuninst\spuninst.exe"
    Security Update for Windows XP (KB950762)-->"C:\WINDOWS\$NtUninstallKB950762$\spuninst\spuninst.exe"
    Security Update for Windows XP (KB950974)-->"C:\WINDOWS\$NtUninstallKB950974$\spuninst\spuninst.exe"
    Security Update for Windows XP (KB951066)-->"C:\WINDOWS\$NtUninstallKB951066$\spuninst\spuninst.exe"
    Security Update for Windows XP (KB951376)-->"C:\WINDOWS\$NtUninstallKB951376$\spuninst\spuninst.exe"
    Security Update for Windows XP (KB951376-v2)-->"C:\WINDOWS\$NtUninstallKB951376-v2$\spuninst\spuninst.exe"
    Security Update for Windows XP (KB951698)-->"C:\WINDOWS\$NtUninstallKB951698$\spuninst\spuninst.exe"
    Security Update for Windows XP (KB951748)-->"C:\WINDOWS\$NtUninstallKB951748$\spuninst\spuninst.exe"
    Security Update for Windows XP (KB952004)-->"C:\WINDOWS\$NtUninstallKB952004$\spuninst\spuninst.exe"
    Security Update for Windows XP (KB952954)-->"C:\WINDOWS\$NtUninstallKB952954$\spuninst\spuninst.exe"
    Security Update for Windows XP (KB953839)-->"C:\WINDOWS\$NtUninstallKB953839$\spuninst\spuninst.exe"
    Security Update for Windows XP (KB954211)-->"C:\WINDOWS\$NtUninstallKB954211$\spuninst\spuninst.exe"
    Security Update for Windows XP (KB954459)-->"C:\WINDOWS\$NtUninstallKB954459$\spuninst\spuninst.exe"
    Security Update for Windows XP (KB954600)-->"C:\WINDOWS\$NtUninstallKB954600$\spuninst\spuninst.exe"
    Security Update for Windows XP (KB955069)-->"C:\WINDOWS\$NtUninstallKB955069$\spuninst\spuninst.exe"
    Security Update for Windows XP (KB956391)-->"C:\WINDOWS\$NtUninstallKB956391$\spuninst\spuninst.exe"
    Security Update for Windows XP (KB956572)-->"C:\WINDOWS\$NtUninstallKB956572$\spuninst\spuninst.exe"
    Security Update for Windows XP (KB956802)-->"C:\WINDOWS\$NtUninstallKB956802$\spuninst\spuninst.exe"
    Security Update for Windows XP (KB956803)-->"C:\WINDOWS\$NtUninstallKB956803$\spuninst\spuninst.exe"
    Security Update for Windows XP (KB956841)-->"C:\WINDOWS\$NtUninstallKB956841$\spuninst\spuninst.exe"
    Security Update for Windows XP (KB957095)-->"C:\WINDOWS\$NtUninstallKB957095$\spuninst\spuninst.exe"
    Security Update for Windows XP (KB957097)-->"C:\WINDOWS\$NtUninstallKB957097$\spuninst\spuninst.exe"
    Security Update for Windows XP (KB958644)-->"C:\WINDOWS\$NtUninstallKB958644$\spuninst\spuninst.exe"
    Security Update for Windows XP (KB958687)-->"C:\WINDOWS\$NtUninstallKB958687$\spuninst\spuninst.exe"
    Security Update for Windows XP (KB958690)-->"C:\WINDOWS\$NtUninstallKB958690$\spuninst\spuninst.exe"
    Security Update for Windows XP (KB959426)-->"C:\WINDOWS\$NtUninstallKB959426$\spuninst\spuninst.exe"
    Security Update for Windows XP (KB960225)-->"C:\WINDOWS\$NtUninstallKB960225$\spuninst\spuninst.exe"
    Security Update for Windows XP (KB960715)-->"C:\WINDOWS\$NtUninstallKB960715$\spuninst\spuninst.exe"
    Security Update for Windows XP (KB960803)-->"C:\WINDOWS\$NtUninstallKB960803$\spuninst\spuninst.exe"
    Security Update for Windows XP (KB961373)-->"C:\WINDOWS\$NtUninstallKB961373$\spuninst\spuninst.exe"
    Sonic Update Manager-->MsiExec.exe /I{30465B6C-B53F-49A1-9EBA-A3F187AD502E}
    SoundMAX-->RunDll32 C:\PROGRA~1\COMMON~1\INSTAL~1\PROFES~1\RunTime\10\01\Intel32\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{F0A37341-D692-11D4-A984-009027EC0A9C}\SETUP.exe" -l0x9 -removeonly
    Super Collapse! 3-->"C:\Program Files\RealArcade\Installer\bin\gameinstaller.exe" "C:\Program Files\RealArcade\Installer\installerMain.clf" "C:\Program Files\RealArcade\Installer\uninstall\supercollapse3.rguninst" "AddRemove"
    The Sims 2 Open For Business-->C:\Program Files\EA GAMES\The Sims 2 Open For Business\EAUninstall.exe
    The Simsâ„¢ 2 Deluxe-->C:\Program Files\EA GAMES\The Sims 2 Deluxe\EAUninstall.exe
    Update for Windows Internet Explorer 8 (KB968220)-->"C:\WINDOWS\ie8updates\KB968220-IE8\spuninst\spuninst.exe"
    Update for Windows XP (KB951072-v2)-->"C:\WINDOWS\$NtUninstallKB951072-v2$\spuninst\spuninst.exe"
    Update for Windows XP (KB951978)-->"C:\WINDOWS\$NtUninstallKB951978$\spuninst\spuninst.exe"
    Update for Windows XP (KB955839)-->"C:\WINDOWS\$NtUninstallKB955839$\spuninst\spuninst.exe"
    Update for Windows XP (KB967715)-->"C:\WINDOWS\$NtUninstallKB967715$\spuninst\spuninst.exe"
    VC80CRTRedist - 8.0.50727.762-->MsiExec.exe /I{767CC44C-9BBC-438D-BAD3-FD4595DD148B}
    Visual Watermark 2.9-->"C:\Program Files\Visual Watermark\unins000.exe"
    Windows Internet Explorer 8-->"C:\WINDOWS\ie8\spuninst\spuninst.exe"
    Windows Live OneCare-->"C:\Program Files\Microsoft Windows OneCare Live\OCSetup.exe" /u
    Windows Media Format 11 runtime-->"C:\Program Files\Windows Media Player\wmsetsdk.exe" /UninstallAll
    Windows Media Format 11 runtime-->"C:\WINDOWS\$NtUninstallWMFDist11$\spuninst\spuninst.exe"
    Windows Media Player 11-->"C:\Program Files\Windows Media Player\Setup_wm.exe" /Uninstall
    Windows Media Player 11-->"C:\WINDOWS\$NtUninstallwmp11$\spuninst\spuninst.exe"
    Windows XP Service Pack 3-->"C:\WINDOWS\$NtServicePackUninstall$\spuninst\spuninst.exe"
    Yahoo! Browser Services-->C:\PROGRA~1\Yahoo!\Common\UNIN_Y~1.EXE /S
    Yahoo! Install Manager-->C:\WINDOWS\system32\regsvr32 /u C:\PROGRA~1\Yahoo!\Common\YINSTH~1.DLL
    Yahoo! Internet Mail-->C:\WINDOWS\system32\regsvr32 /u /s C:\PROGRA~1\Yahoo!\Common\YMMAPI.dll
    Yahoo! Messenger-->C:\PROGRA~1\Yahoo!\MESSEN~1\UNWISE.EXE /U C:\PROGRA~1\Yahoo!\MESSEN~1\INSTALL.LOG
    ======Security center information======
    AV: Windows Live OneCare
    FW: Windows Live OneCare Firewall
    ======System event log======
    Computer Name: HOME-4FBF327C98
    Event Code: 3004
    Message: Windows OneCare Live Real-Time Protection agent has detected changes. Microsoft recommends you analyze the software that made these changes for potential risks. You can use information about how these programs operate to choose whether to allow them to run or remove them from your computer. Allow changes only if you trust the program or the software publisher. Windows OneCare Live can't undo changes that you allow.
    For more information please see the following:
    http://go.microsoft.com/fwlink/?linkid=37020&name=VirTool:Win32/Ursnif.A&threatid=2147625266
    Scan ID: {0BF690FA-C204-43FA-ADA1-55F88E70638C}
    Agent: On Access
    User: HOME-4FBF327C98\Owner
    Severity: Severe
    Category: Trojan
    Path Found: file:C:\WINDOWS\system32\winlogon.exe
    Alert Type:
    Process Name: C:\Program Files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe
    Detection Type: Concrete
    Status: Suspend
    Record Number: 20532
    Source Name: OneCareMP
    Time Written: 20090528200623.000000-240
    Event Type: warning
    User:
    Event Code: 3004
    Scan ID: {18B0C385-300C-4808-BF18-007FBB39D919}
    Agent: On Access
    User: \
    Severity: Severe
    Category: Trojan
    Alert Type:
    Process Name:
    Status: Allow
    Record Number: 20529
    Time Written: 20090528200617.000000-240
    Event Type: warning
    User:
    Event Code: 3004
    Scan ID: {D48FE093-C6A1-4AE2-8D5C-D7964CE1EB7A}
    Agent: On Access
    User: NT AUTHORITY\SYSTEM
    Severity: Severe
    Category: Trojan
    Path Found: process:pid:656;file:C:\WINDOWS\system32\winlogon.exe
    Alert Type: Spyware or other potentially unwanted software
    Process Name:
    Status:
    Record Number: 20528
    Time Written: 20090528200616.000000-240
    Event Type: warning
    User:
    Event Code: 7000
    Message: The IMAPI CD-Burning COM Service service failed to start due to the following error:
    The service did not respond to the start or control request in a timely fashion.
    Record Number: 20523
    Source Name: Service Control Manager
    Time Written: 20090528200611.000000-240
    Event Type: error
    User:
    Event Code: 7009
    Message: Timeout (30000 milliseconds) waiting for the IMAPI CD-Burning COM Service service to connect.
    Record Number: 20522
    Event Type: error
    User:
    =====Application event log=====
    Event Code: 1517
    Message: Windows saved user HOME-4FBF327C98\Owner registry while an application or service was still using the registry during log off. The memory used by the user's registry has not been freed. The registry will be unloaded when it is no longer in use.
    This is often caused by services running as a user account, try configuring the services to run in either the LocalService or NetworkService account.
    Record Number: 6966
    Source Name: Userenv
    Time Written: 20090308002007.000000-300
    Event Type: warning
    Event Code: 1517
    Record Number: 6954
    Time Written: 20090307011355.000000-300
    Event Type: warning
    Event Code: 1524
    Message: Windows cannot unload your classes registry file - it is still in use by other applications or services. The file will be unloaded when it is no longer in use.
    Record Number: 6953
    Time Written: 20090307011353.000000-300
    Event Type: warning
    Event Code: 1002
    Message: Hanging application MySpaceIM.exe, version 1.0.789.0, hang module hungapp, version 0.0.0.0, hang address 0x00000000.
    Record Number: 6936
    Source Name: Application Hang
    Time Written: 20090306091754.000000-300
    Event Type: error
    User:
    Event Code: 1002
    Record Number: 6935
    Time Written: 20090306091753.000000-300
    Event Type: error
    User:
    ======Environment variables======
    "ComSpec"=%SystemRoot%\system32\cmd.exe
    "Path"=%SystemRoot%\system32;%SystemRoot%;%SystemRoot%\System32\Wbem;C:\Program Files\Common Files\Roxio Shared\DLLShared\
    "windir"=%SystemRoot%
    "FP_NO_HOST_CHECK"=NO
    "OS"=Windows_NT
    "PROCESSOR_ARCHITECTURE"=x86
    "PROCESSOR_LEVEL"=15
    "PROCESSOR_IDENTIFIER"=x86 Family 15 Model 4 Stepping 1, GenuineIntel
    "PROCESSOR_REVISION"=0401
    "NUMBER_OF_PROCESSORS"=1
    "PATHEXT"=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH
    "TEMP"=%SystemRoot%\TEMP
    "TMP"=%SystemRoot%\TEMP
    "SonicCentral"=C:\Program Files\Common Files\Sonic Shared\Sonic Central\
    EOF
  • edited June 2009
    My computer has said the virus is under the name gamevance but i can not get it to delete
  • edited June 2009
    IMPORTANT
    I notice there are signs of one or more P2P (Person to Person) File Sharing Programs on your computer.
    LimeWire 5.1.2
    I'd like you to read the Guidelines for P2P Programs where we explain why it's not a good idea to have them.
    Also available here.
    My recommendation is you go to Control Panel > Add/Remove Programs and uninstall any P2P programs
    Please note: you must NOT use any P2P whilst we are cleaning your machine.
    Malwarebytes' Anti-Malware
    Please download Malwarebytes' Anti-Malware to your desktop.
    • Double-click mbam-setup.exe and follow the prompts to install the program.
    • At the end, be sure a checkmark is placed next to
      • Update Malwarebytes' Anti-Malware
      • and Launch Malwarebytes' Anti-Malware
    • then click Finish.
    • If an update is found, it will download and install the latest version.
    • Once the program has loaded, select Perform full scan, then click Scan.
    • When the scan is complete, click OK, then Show Results to view the results.
    • Be sure that everything is checked, and click Remove Selected.
    • When completed, a log will open in Notepad. please copy and paste the log into your next reply
    • If requested, please reboot
      • If you accidently close it, the log file is saved here and will be named like this:
      • C:\Documents and Settings\Username\Application Data\Malwarebytes\Malwarebytes' Anti-Malware\Logs\mbam-log-date (time).txt
    Download and Run ComboFix (by sUBs)
    Please visit this webpage for instructions for downloading and running ComboFix:
    Bleeping Computer ComboFix Tutorial
    • You must download it to and run it from your Desktop
    • Now STOP all your monitoring programs (Antivirus/Antispyware, Guards and Shields) as they could easily interfere with ComboFix.
    • Double click combofix.exe & follow the prompts.
    • When finished, it will produce a log. Please save that log to post in your next reply
    • Re-enable all the programs that were disabled during the running of ComboFix..
    A word of warning: Neither I nor sUBs are responsible for any damage you may have caused your machine by running ComboFix on your own.
    This tool is not a toy and not for everyday use.
    ComboFix SHOULD NOT be used unless requested by a forum helper
  • edited June 2009
    Malwarebytes' Anti-Malware 1.37
    Database version: 2226
    Windows 5.1.2600 Service Pack 3
    6/4/2009 3:10:35 PM
    mbam-log-2009-06-04 (15-10-34).txt
    Scan type: Full Scan (A:\|C:\|D:\|)
    Objects scanned: 263702
    Time elapsed: 1 hour(s), 50 minute(s), 41 second(s)
    Memory Processes Infected: 1
    Memory Modules Infected: 1
    Registry Keys Infected: 33
    Registry Values Infected: 2
    Registry Data Items Infected: 0
    Folders Infected: 19
    Files Infected: 73
    C:\Program Files\Gamevance\gamevance32.exe (Adware.Gamevance) -> Unloaded process successfully.
    C:\Program Files\Gamevance\gamevancelib32.dll (Adware.Gamevance) -> Delete on reboot.
    HKEY_CLASSES_ROOT\Interface\{2e9937fc-cf2f-4f56-af54-5a6a3dd375cc} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKEY_CLASSES_ROOT\Interface\{741de825-a6f0-4497-9aa6-8023cf9b0fff} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKEY_CLASSES_ROOT\Interface\{cf54be1c-9359-4395-8533-1657cf209cfe} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKEY_CLASSES_ROOT\CLSID\{147a976f-eee1-4377-8ea7-4716e4cdd239} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKEY_CLASSES_ROOT\CLSID\{0ed403e8-470a-4a8a-85a4-d7688cfe39a3} (Adware.Gamevance) -> Quarantined and deleted successfully.
    HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{0ed403e8-470a-4a8a-85a4-d7688cfe39a3} (Adware.Gamevance) -> Quarantined and deleted successfully.
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{0ed403e8-470a-4a8a-85a4-d7688cfe39a3} (Adware.Gamevance) -> Quarantined and deleted successfully.
    HKEY_CLASSES_ROOT\Typelib\{d518921a-4a03-425e-9873-b9a71756821e} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{d7adf7c1-14fb-4110-b2df-187884cac12a} (Trojan.BHO) -> Quarantined and deleted successfully.
    HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{b7d3e479-cc68-42b5-a338-938ece35f419} (Adware.SoftMate) -> Quarantined and deleted successfully.
    HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{00a6faf6-072e-44cf-8957-5838f569a31d} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{07b18ea9-a523-4961-b6bb-170de4475cca} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{07b18ea1-a523-4961-b6bb-170de4475cca} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{07b18eab-a523-4961-b6bb-170de4475cca} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{25560540-9571-4d7b-9389-0f166788785a} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{3dc201fb-e9c9-499c-a11f-23c360d7c3f8} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{9ff05104-b030-46fc-94b8-81276e4e27df} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{00a6faf1-072e-44cf-8957-5838f569a31d} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{1d4db7d2-6ec9-47a3-bd87-1e41684e07bb} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKEY_CURRENT_USER\SOFTWARE\Microsoft\Internet Explorer\SearchScopes\{56256a51-b582-467e-b8d4-7786eda79ae0} (Trojan.Vundo) -> Quarantined and deleted successfully.
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\SearchScopes\{56256a51-b582-467e-b8d4-7786eda79ae0} (Trojan.Vundo) -> Quarantined and deleted successfully.
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Code Store Database\Distribution Units\{1d4db7d2-6ec9-47a3-bd87-1e41684e07bb} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{59c7fc09-1c83-4648-b3e6-003d2bbc7481} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{68af847f-6e91-45dd-9b68-d6a12c30e5d7} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{9170b96c-28d4-4626-8358-27e6caeef907} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{d1a71fa0-ff48-48dd-9b6d-7a13a3e42127} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{ddb1968e-ead6-40fd-8dae-ff14757f60c7} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{f138d901-86f0-4383-99b6-9cdd406036da} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\tdssdata (Trojan.Agent) -> Quarantined and deleted successfully.
    HKEY_LOCAL_MACHINE\SOFTWARE\tdss (Trojan.Agent) -> Quarantined and deleted successfully.
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Low Rights\RunDll32Policy\f3ScrCtr.dll (Adware.MyWay) -> Quarantined and deleted successfully.
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Multimedia\WMPlayer\Schemes\f3pss (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    HKEY_CURRENT_USER\SOFTWARE\gvtl (Malware.Trace) -> Quarantined and deleted successfully.
    HKEY_CURRENT_USER\SOFTWARE\Microsoft\Internet Explorer\Toolbar\WebBrowser\{b7d3e479-cc68-42b5-a338-938ece35f419} (Adware.SoftMate) -> Quarantined and deleted successfully.
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\Gamevance (Adware.Gamevance) -> Quarantined and deleted successfully.
    (No malicious items detected)
    Folders Infected:
    c:\documents and settings\All Users\Application Data\SalesMon (Rogue.Multiple) -> Quarantined and deleted successfully.
    c:\documents and settings\all users\application data\SalesMon\Data (Rogue.Multiple) -> Quarantined and deleted successfully.
    c:\documents and settings\kristi kibbey\application data\Starware (Adware.Starware) -> Quarantined and deleted successfully.
    c:\documents and settings\kristi kibbey\application data\Starware\Manager (Adware.Starware) -> Quarantined and deleted successfully.
    C:\Program Files\Temporary (Trojan.Agent) -> Quarantined and deleted successfully.
    c:\documents and settings\All Users\Application Data\systemerrorfixer (Rogue.SystemErrorFixer) -> Quarantined and deleted successfully.
    c:\documents and settings\all users\application data\systemerrorfixer\Data (Rogue.SystemErrorFixer) -> Quarantined and deleted successfully.
    C:\Program Files\Common Files\SystemErrorFixer (Rogue.SystemErrorFixer) -> Quarantined and deleted successfully.
    C:\Program Files\Gamevance (Adware.Gamevance) -> Quarantined and deleted successfully.
    C:\Program Files\CPV (Trojan.Downloader) -> Quarantined and deleted successfully.
    c:\documents and settings\Kristi Kibbey\Application Data\FunWebProducts (Adware.MyWay) -> Quarantined and deleted successfully.
    c:\documents and settings\kristi kibbey\application data\funwebproducts\Data (Adware.MyWay) -> Quarantined and deleted successfully.
    c:\documents and settings\kristi kibbey\application data\funwebproducts\Data\Kristi Kibbey (Adware.MyWay) -> Quarantined and deleted successfully.
    C:\WINDOWS\system32\axV (Trojan.Agent) -> Quarantined and deleted successfully.
    C:\WINDOWS\system32\ExTmp (Trojan.Agent) -> Quarantined and deleted successfully.
    C:\WINDOWS\system32\IDE2 (Trojan.Agent) -> Quarantined and deleted successfully.
    C:\WINDOWS\system32\pinz1 (Trojan.Agent) -> Quarantined and deleted successfully.
    c:\WINDOWS\system32\bharebio05 (Trojan.Agent) -> Quarantined and deleted successfully.
    C:\Program Files\Twain (Trojan.Agent) -> Quarantined and deleted successfully.
    Files Infected:
    C:\Program Files\Gamevance\gamevancelib32.dll (Adware.Gamevance) -> Quarantined and deleted successfully.
    c:\program files\mozilla firefox\plugins\NPMyWebS.dll (Adware.MyWeb) -> Quarantined and deleted successfully.
    c:\system volume information\_restore{1f97d91d-97bb-4de8-8962-43185a80b364}\RP362\A0096948.DLL (Adware.MyWeb) -> Quarantined and deleted successfully.
    c:\system volume information\_restore{1f97d91d-97bb-4de8-8962-43185a80b364}\RP362\A0096949.DLL (Adware.MyWeb) -> Quarantined and deleted successfully.
    c:\system volume information\_restore{1f97d91d-97bb-4de8-8962-43185a80b364}\RP362\A0096950.dll (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    c:\system volume information\_restore{1f97d91d-97bb-4de8-8962-43185a80b364}\RP362\A0096951.scr (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    c:\system volume information\_restore{1f97d91d-97bb-4de8-8962-43185a80b364}\RP362\A0096959.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    c:\system volume information\_restore{1f97d91d-97bb-4de8-8962-43185a80b364}\RP362\A0096961.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    c:\system volume information\_restore{1f97d91d-97bb-4de8-8962-43185a80b364}\RP362\A0096962.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    c:\system volume information\_restore{1f97d91d-97bb-4de8-8962-43185a80b364}\RP362\A0096963.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    c:\system volume information\_restore{1f97d91d-97bb-4de8-8962-43185a80b364}\RP362\A0096964.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    c:\system volume information\_restore{1f97d91d-97bb-4de8-8962-43185a80b364}\RP362\A0096967.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    c:\system volume information\_restore{1f97d91d-97bb-4de8-8962-43185a80b364}\RP362\A0096968.EXE (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    c:\system volume information\_restore{1f97d91d-97bb-4de8-8962-43185a80b364}\RP362\A0096972.EXE (Adware.MyWeb) -> Quarantined and deleted successfully.
    c:\system volume information\_restore{1f97d91d-97bb-4de8-8962-43185a80b364}\RP362\A0096973.DLL (Adware.MyWeb) -> Quarantined and deleted successfully.
    c:\system volume information\_restore{1f97d91d-97bb-4de8-8962-43185a80b364}\RP362\A0096974.DLL (Adware.MyWeb) -> Quarantined and deleted successfully.
    c:\system volume information\_restore{1f97d91d-97bb-4de8-8962-43185a80b364}\RP362\A0096975.EXE (Adware.MyWeb) -> Quarantined and deleted successfully.
    c:\system volume information\_restore{1f97d91d-97bb-4de8-8962-43185a80b364}\RP362\A0096976.EXE (Adware.MyWeb) -> Quarantined and deleted successfully.
    c:\system volume information\_restore{1f97d91d-97bb-4de8-8962-43185a80b364}\RP362\A0096977.DLL (Adware.MyWeb) -> Quarantined and deleted successfully.
    c:\system volume information\_restore{1f97d91d-97bb-4de8-8962-43185a80b364}\RP362\A0096979.DLL (Adware.MyWeb) -> Quarantined and deleted successfully.
    c:\system volume information\_restore{1f97d91d-97bb-4de8-8962-43185a80b364}\RP362\A0096980.DLL (Adware.MyWeb) -> Quarantined and deleted successfully.
    c:\system volume information\_restore{1f97d91d-97bb-4de8-8962-43185a80b364}\RP362\A0096981.DLL (Adware.MyWeb) -> Quarantined and deleted successfully.
    c:\system volume information\_restore{1f97d91d-97bb-4de8-8962-43185a80b364}\RP362\A0096982.EXE (Adware.MyWeb) -> Quarantined and deleted successfully.
    c:\system volume information\_restore{1f97d91d-97bb-4de8-8962-43185a80b364}\RP362\A0096984.EXE (Adware.MyWeb) -> Quarantined and deleted successfully.
    c:\system volume information\_restore{1f97d91d-97bb-4de8-8962-43185a80b364}\RP362\A0096985.DLL (Adware.MyWeb) -> Quarantined and deleted successfully.
    c:\system volume information\_restore{1f97d91d-97bb-4de8-8962-43185a80b364}\RP362\A0096986.EXE (Adware.MyWeb) -> Quarantined and deleted successfully.
    c:\system volume information\_restore{1f97d91d-97bb-4de8-8962-43185a80b364}\RP362\A0096987.DLL (Adware.MyWeb) -> Quarantined and deleted successfully.
    c:\system volume information\_restore{1f97d91d-97bb-4de8-8962-43185a80b364}\RP362\A0096989.DLL (Adware.MyWeb) -> Quarantined and deleted successfully.
    c:\system volume information\_restore{1f97d91d-97bb-4de8-8962-43185a80b364}\RP362\A0096990.EXE (Adware.MyWeb) -> Quarantined and deleted successfully.
    c:\system volume information\_restore{1f97d91d-97bb-4de8-8962-43185a80b364}\RP362\A0096991.DLL (Adware.MyWeb) -> Quarantined and deleted successfully.
    c:\system volume information\_restore{1f97d91d-97bb-4de8-8962-43185a80b364}\RP362\A0096992.DLL (Adware.MyWeb) -> Quarantined and deleted successfully.
    c:\system volume information\_restore{1f97d91d-97bb-4de8-8962-43185a80b364}\RP362\A0097003.DLL (Adware.MyWeb.FunWeb) -> Quarantined and deleted successfully.
    c:\system volume information\_restore{1f97d91d-97bb-4de8-8962-43185a80b364}\RP362\A0097004.EXE (Adware.MyWeb.FunWeb) -> Quarantined and deleted successfully.
    c:\system volume information\_restore{1f97d91d-97bb-4de8-8962-43185a80b364}\RP362\A0097009.DLL (Adware.MyWeb) -> Quarantined and deleted successfully.
    c:\system volume information\_restore{1f97d91d-97bb-4de8-8962-43185a80b364}\RP362\A0097010.DLL (Adware.MyWeb) -> Quarantined and deleted successfully.
    c:\system volume information\_restore{1f97d91d-97bb-4de8-8962-43185a80b364}\RP362\A0097011.EXE (Adware.MyWeb) -> Quarantined and deleted successfully.
    c:\system volume information\_restore{1f97d91d-97bb-4de8-8962-43185a80b364}\RP362\A0097012.DLL (Adware.MyWeb) -> Quarantined and deleted successfully.
    c:\system volume information\_restore{1f97d91d-97bb-4de8-8962-43185a80b364}\RP362\A0097015.DLL (Adware.MyWeb) -> Quarantined and deleted successfully.
    c:\system volume information\_restore{1f97d91d-97bb-4de8-8962-43185a80b364}\RP362\A0097016.DLL (Adware.MyWeb) -> Quarantined and deleted successfully.
    c:\system volume information\_restore{1f97d91d-97bb-4de8-8962-43185a80b364}\RP362\A0097017.EXE (Adware.MyWeb) -> Quarantined and deleted successfully.
    c:\system volume information\_restore{1f97d91d-97bb-4de8-8962-43185a80b364}\RP362\A0097018.EXE (Adware.MyWeb) -> Quarantined and deleted successfully.
    c:\system volume information\_restore{1f97d91d-97bb-4de8-8962-43185a80b364}\RP362\A0097019.DLL (Adware.MyWeb) -> Quarantined and deleted successfully.
    c:\system volume information\_restore{1f97d91d-97bb-4de8-8962-43185a80b364}\RP362\A0097020.EXE (Adware.MyWeb) -> Quarantined and deleted successfully.
    c:\system volume information\_restore{1f97d91d-97bb-4de8-8962-43185a80b364}\RP362\A0097021.DLL (Adware.MyWeb) -> Quarantined and deleted successfully.
    c:\system volume information\_restore{1f97d91d-97bb-4de8-8962-43185a80b364}\RP362\A0097022.DLL (Adware.MyWeb) -> Quarantined and deleted successfully.
    c:\system volume information\_restore{1f97d91d-97bb-4de8-8962-43185a80b364}\RP362\A0097023.DLL (Adware.MyWeb) -> Quarantined and deleted successfully.
    c:\system volume information\_restore{1f97d91d-97bb-4de8-8962-43185a80b364}\RP362\A0097821.DLL (Adware.MyWeb) -> Quarantined and deleted successfully.
    c:\system volume information\_restore{1f97d91d-97bb-4de8-8962-43185a80b364}\RP362\A0097823.DLL (Adware.MyWeb) -> Quarantined and deleted successfully.
    c:\system volume information\_restore{1f97d91d-97bb-4de8-8962-43185a80b364}\RP362\A0096965.SCR (Adware.MyWebSearch) -> Quarantined and deleted successfully.
    c:\system volume information\_restore{1f97d91d-97bb-4de8-8962-43185a80b364}\RP362\A0096983.EXE (Adware.MyWeb) -> Quarantined and deleted successfully.
    c:\system volume information\_restore{1f97d91d-97bb-4de8-8962-43185a80b364}\RP362\A0097014.DLL (Adware.MyWeb) -> Quarantined and deleted successfully.
    c:\system volume information\_restore{1f97d91d-97bb-4de8-8962-43185a80b364}\RP362\A0097824.EXE (Adware.MyWeb) -> Quarantined and deleted successfully.
    c:\system volume information\_restore{1f97d91d-97bb-4de8-8962-43185a80b364}\RP362\A0097842.dll (Adware.MyWeb) -> Quarantined and deleted successfully.
    c:\system volume information\_restore{1f97d91d-97bb-4de8-8962-43185a80b364}\RP362\A0097825.DLL (Adware.MyWeb) -> Quarantined and deleted successfully.
    c:\system volume information\_restore{202550a8-7a33-4bca-9586-051d24ddbf8f}\RP333\A0057473.exe (Rogue.WinPCDoctor) -> Quarantined and deleted successfully.
    c:\system volume information\_restore{202550a8-7a33-4bca-9586-051d24ddbf8f}\RP333\A0057465.exe (Rogue.WinPCDoctor) -> Quarantined and deleted successfully.
    c:\system volume information\_restore{202550a8-7a33-4bca-9586-051d24ddbf8f}\RP351\A0072688.exe (Adware.Rotator) -> Quarantined and deleted successfully.
    c:\WINDOWS\system32\MSINET.oca (Rogue.Trace) -> Quarantined and deleted successfully.
    c:\documents and settings\kristi kibbey\application data\Starware\Manager\ManagerOptions.xml (Adware.Starware) -> Quarantined and deleted successfully.
    c:\documents and settings\kristi kibbey\application data\Starware\Manager\ManagerOptions.xml.backup (Adware.Starware) -> Quarantined and deleted successfully.
    c:\documents and settings\all users\application data\systemerrorfixer\Data\ac (Rogue.SystemErrorFixer) -> Quarantined and deleted successfully.
    c:\documents and settings\all users\application data\systemerrorfixer\Data\em (Rogue.SystemErrorFixer) -> Quarantined and deleted successfully.
    c:\documents and settings\all users\application data\systemerrorfixer\Data\oid (Rogue.SystemErrorFixer) -> Quarantined and deleted successfully.
    c:\documents and settings\all users\application data\systemerrorfixer\Data\SystemErrorFixer.exe.cer (Rogue.SystemErrorFixer) -> Quarantined and deleted successfully.
    c:\documents and settings\all users\application data\systemerrorfixer\Data\user (Rogue.SystemErrorFixer) -> Quarantined and deleted successfully.
    c:\program files\gamevance\ars.cfg (Adware.Gamevance) -> Quarantined and deleted successfully.
    c:\program files\gamevance\gamevance32.exe (Adware.Gamevance) -> Quarantined and deleted successfully.
    C:\Program Files\A.ico (Malware.Trace) -> Quarantined and deleted successfully.
    C:\Program Files\B.ico (Malware.Trace) -> Quarantined and deleted successfully.
    c:\f.exe (Backdoor.Bot) -> Quarantined and deleted successfully.
    c:\documents and settings\Kristi Kibbey\Start Menu\Programs\Startup\DW_Start.lnk (Malware.Links) -> Quarantined and deleted successfully.
    c:\documents and settings\Kristi Kibbey\Start Menu\Programs\Startup\Deewoo.lnk (Malware.Links) -> Quarantined and deleted successfully.
    C:\WINDOWS\Sysvxd.exe (Trojan.FakeAlert) -> Quarantined and deleted successfully.
  • edited June 2009
    ComboFix 09-06-04.01 - Owner 06/04/2009 15:40.1 - NTFSx86
    Microsoft Windows XP Home Edition 5.1.2600.3.1252.1.1033.18.510.185 [GMT -4:00]
    Running from: c:\documents and settings\Owner.HOME-4FBF327C98\Desktop\ComboFix.exe
    AV: Windows Live OneCare *On-access scanning disabled* (Updated) {427ADFC3-B354-4A51-BE34-A9D4218E45C4}
    FW: Windows Live OneCare Firewall *disabled* {A3899D22-27E6-4A7E-AE4E-2C106646DAAB}
    ((((((((((((((((((((((((((((((((((((((( Other Deletions )))))))))))))))))))))))))))))))))))))))))))))))))
    c:\documents and settings\Kristi Kibbey\Local Settings\Temporary Internet Files\bestwiner.stt
    c:\documents and settings\Owner.HOME-4FBF327C98\nah_log.dat
    c:\temp\1cb
    c:\temp\1cb\syscheck.log
    c:\temp\sanR24
    c:\temp\tn3
    c:\windows\Downloaded Program Files\Quarantine
    ((((((((((((((((((((((((( Files Created from 2009-05-04 to 2009-06-04 )))))))))))))))))))))))))))))))
    2009-06-04 01:52 . 2009-06-04 01:52
    d
    w- c:\documents and settings\Owner.HOME-4FBF327C98\Application Data\Malwarebytes
    2009-06-04 01:52 . 2009-05-26 17:20 40160 ----a-w- c:\windows\system32\drivers\mbamswissarmy.sys
    d
    w- c:\documents and settings\All Users.WINDOWS\Application Data\Malwarebytes
    2009-06-04 01:52 . 2009-05-26 17:19 19096 ----a-w- c:\windows\system32\drivers\mbam.sys
    d
    w- c:\program files\Malwarebytes' Anti-Malware
    2009-06-03 04:09 . 2009-06-03 04:09
    d
    w- c:\program files\trend micro
    d
    w- C:\rsit
    2009-05-29 13:16 . 2009-05-29 13:16
    d--h--w- c:\windows\PIF
    2009-05-29 04:09 . 2009-05-29 21:24
    d
    w- c:\documents and settings\Owner.HOME-4FBF327C98\.housecall6.6
    2009-05-28 19:46 . 2009-05-28 19:46
    d
    w- c:\documents and settings\NetworkService.NT AUTHORITY.000\Local Settings\Application Data\Google
    2009-05-28 03:42 . 2009-05-28 03:42
    d
    w- c:\program files\Common Files\DivX Shared
    d
    w- c:\program files\DivX
    2009-05-16 15:52 . 2009-05-16 16:35
    d
    w- c:\documents and settings\Owner.HOME-4FBF327C98\Application Data\Ubisoft
    2009-05-15 01:21 . 2009-05-15 01:21
    d
    w- c:\documents and settings\Owner.HOME-4FBF327C98\Application Data\Skunk Studios
    2009-05-13 01:19 . 2009-05-13 01:19
    d
    w- c:\documents and settings\Owner.HOME-4FBF327C98\Local Settings\Application Data\Gamenauts
    2009-05-12 15:53 . 2009-05-12 15:54
    d
    w- c:\documents and settings\Owner.HOME-4FBF327C98\Application Data\HiT-MM
    2009-05-06 18:47 . 2009-05-06 18:47
    d-sh--w- c:\documents and settings\Owner.HOME-4FBF327C98\PrivacIE
    2009-05-06 13:26 . 2009-05-06 13:26
    d-sh--w- c:\documents and settings\Owner.HOME-4FBF327C98\IETldCache
    2009-05-06 07:12 . 2009-05-06 07:12
    d-sh--w- c:\documents and settings\LocalService.NT AUTHORITY.000\IETldCache
    2009-05-06 05:25 . 2009-05-06 05:25
    d
    w- c:\windows\ie8updates
    2009-05-06 05:16 . 2009-02-28 04:55 105984 -c----w- c:\windows\system32\dllcache\iecompat.dll
    2009-05-06 04:19 . 2009-05-06 04:39
    dc-h--w- c:\windows\ie8
    (((((((((((((((((((((((((((((((((((((((( Find3M Report ))))))))))))))))))))))))))))))))))))))))))))))))))))
    2009-06-04 05:53 . 2008-04-21 01:58
    d
    w- c:\program files\Microsoft Windows OneCare Live
    2009-06-04 02:16 . 2008-08-24 01:55
    d
    w- c:\documents and settings\All Users.WINDOWS\Application Data\Google Updater
    2009-06-01 22:45 . 2008-05-02 18:04
    d
    w- c:\documents and settings\Owner.HOME-4FBF327C98\Application Data\LimeWire
    2009-05-29 03:05 . 2006-02-16 22:55
    d
    w- c:\program files\Yahoo!
    2009-05-29 02:54 . 2006-02-14 22:16
    d
    w- c:\program files\Google
    2009-05-25 15:36 . 2009-02-10 02:07
    d
    w- c:\program files\RealArcade
    2009-05-25 15:35 . 2009-01-12 21:08
    d
    w- c:\program files\Coupons
    2009-05-25 15:34 . 2008-04-30 02:09
    d
    w- c:\documents and settings\All Users.WINDOWS\Application Data\Viewpoint
    2009-05-25 15:34 . 2006-02-14 22:07
    d
    w- c:\program files\Viewpoint
    2009-05-16 17:07 . 2008-07-28 02:06
    d---a-w- c:\documents and settings\All Users.WINDOWS\Application Data\TEMP
    2009-05-16 16:19 . 2008-07-28 01:58
    d
    w- c:\documents and settings\All Users.WINDOWS\Application Data\BigFishGamesCache
    2009-05-06 19:06 . 2008-11-21 17:24
    d
    w- c:\program files\AIM Toolbar
    2009-04-08 03:55 . 2009-04-08 03:55
    d
    w- c:\documents and settings\All Users.WINDOWS\Application Data\Tencent
    2009-04-08 03:55 . 2008-11-22 01:35 6002016 ----a-w- c:\documents and settings\Owner.HOME-4FBF327C98\Application Data\QQ Games\Download\QQGameLite.EXE
    2009-04-06 20:22 . 2009-04-06 20:08
    d
    w- c:\documents and settings\All Users.WINDOWS\Application Data\NOS
    d
    w- c:\program files\NOS
    2009-04-06 20:21 . 2009-04-06 20:21
    d
    w- c:\program files\Common Files\Adobe AIR
    2009-03-20 18:50 . 2009-03-20 18:50 3358720 ----a-w- c:\windows\system32\GPhotos.scr
    2009-03-08 08:34 . 2006-03-04 03:33 914944 ----a-w- c:\windows\system32\wininet.dll
    2009-03-08 08:34 . 2004-08-04 10:00 43008 ----a-w- c:\windows\system32\licmgr10.dll
    2009-03-08 08:33 . 2004-08-04 10:00 18944 ----a-w- c:\windows\system32\corpol.dll
    2009-03-08 08:33 . 2004-08-04 10:00 420352 ----a-w- c:\windows\system32\vbscript.dll
    2009-03-08 08:32 . 2004-08-04 10:00 72704 ----a-w- c:\windows\system32\admparse.dll
    2009-03-08 08:32 . 2004-08-04 10:00 71680 ----a-w- c:\windows\system32\iesetup.dll
    2009-03-08 08:31 . 2004-08-04 10:00 34816 ----a-w- c:\windows\system32\imgutil.dll
    2009-03-08 08:31 . 2004-08-04 10:00 48128 ----a-w- c:\windows\system32\mshtmler.dll
    2009-03-08 08:31 . 2004-08-04 10:00 45568 ----a-w- c:\windows\system32\mshta.exe
    2009-03-08 08:22 . 2004-08-04 10:00 156160 ----a-w- c:\windows\system32\msls31.dll
    2008-03-08 06:38 . 2008-03-08 06:38 0 ----a-w- c:\program files\temp01
    2008-07-10 04:48 . 2008-07-10 04:48 8 --sh--r- c:\windows\system32\C2A7CDAB54.sys
    2008-07-20 05:15 . 2008-07-10 04:48 2516 --sha-w- c:\windows\system32\KGyGaAvL.sys
    Sigcheck
    [7] 2004-08-04 10:00 502272 01C3346C241652F43AED8E2149881BFE c:\windows\$NtServicePackUninstall$\winlogon.exe
    [7] 2008-04-14 00:12 507904 ED0EF0A136DEC83DF69F04118870003E c:\windows\ServicePackFiles\i386\winlogon.exe
    [-] 2008-11-27 02:21 507904 3969440BA384D35317DBBDEEAAE641CE c:\windows\system32\winlogon.exe
    ((((((((((((((((((((((((((((((((((((( Reg Loading Points ))))))))))))))))))))))))))))))))))))))))))))))))))
    *Note* empty entries & legit default entries are not shown
    REGEDIT4
    [HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Run]
    "swg"="c:\program files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe" [2008-05-26 68856]
    "Yahoo! Pager"="c:\program files\Yahoo!\Messenger\YahooMessenger.exe" [2007-08-31 4670704]
    "ctfmon.exe"="c:\windows\system32\ctfmon.exe" [2008-04-14 15360]
    "MySpaceIM"="c:\program files\MySpace\IM\MySpaceIM.exe" [2008-12-12 9555968]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run]
    "SoundMAXPnP"="c:\program files\Analog Devices\Core\smax4pnp.exe" [2004-10-14 1404928]
    "HotKeysCmds"="c:\windows\system32\hkcmd.exe" [2005-04-05 77824]
    "Persistence"="c:\windows\system32\igfxpers.exe" [2005-04-05 114688]
    "medicsp2"="c:\program files\twc\medicsp2\bin\sprtcmd.exe" [2007-03-07 198184]
    "DLA"="c:\windows\System32\DLA\DLACTRLW.EXE" [2005-11-07 122940]
    "ISUSPM Startup"="c:\program files\Common Files\InstallShield\UpdateService\isuspm.exe" [2006-03-21 213936]
    "ISUSScheduler"="c:\program files\Common Files\InstallShield\UpdateService\issch.exe" [2006-03-21 86960]
    "OneCareUI"="c:\program files\Microsoft Windows OneCare Live\winssnotify.exe" [2009-03-22 63864]
    "ISUSPM"="c:\program files\Common Files\InstallShield\UpdateService\isuspm.exe" [2006-03-21 213936]
    "SunJavaUpdateSched"="c:\program files\Java\jre1.6.0_05\bin\jusched.exe" [2008-02-22 144784]
    "HP Software Update"="c:\program files\HP\HP Software Update\HPWuSchd2.exe" [2007-05-08 54840]
    "PDUiP6220DMon"="c:\program files\Canon\Memory Card Utility\iP6220D\PDUiP6220DMon.exe" [2005-05-06 69632]
    "TkBellExe"="c:\program files\Common Files\Real\Update_OB\realsched.exe" [2008-12-02 185872]
    "Adobe Reader Speed Launcher"="c:\program files\Adobe\Reader 9.0\Reader\Reader_sl.exe" [2009-02-27 35696]
    [HKEY_USERS\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\Run]
    [HKEY_USERS\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\RunOnce]
    "RunNarrator"="Narrator.exe" - c:\windows\system32\narrator.exe [2008-04-14 53760]
    c:\documents and settings\All Users.WINDOWS\Start Menu\Programs\Startup\
    HP Digital Imaging Monitor.lnk - c:\program files\HP\Digital Imaging\bin\hpqtra08.exe [2006-2-19 288472]
    HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\drivers32
    "wave"= serwvdrv.dll
    "wave1"= serwvdrv.dll
    "wave3"= serwvdrv.dll
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\OneCareMP]
    @="Service"
    [HKLM\~\services\sharedaccess\parameters\firewallpolicy\standardprofile]
    "EnableFirewall"= 0 (0x0)
    [HKLM\~\services\sharedaccess\parameters\firewallpolicy\standardprofile\AuthorizedApplications\List]
    "%windir%\\system32\\sessmgr.exe"=
    "c:\\Program Files\\Yahoo!\\Messenger\\YahooMessenger.exe"=
    "c:\\Program Files\\Yahoo!\\Messenger\\YServer.exe"=
    "%windir%\\Network Diagnostic\\xpnetdiag.exe"=
    "c:\\Program Files\\Common Files\\AOL\\Loader\\aolload.exe"=
    "c:\\Program Files\\AIM6\\aim6.exe"=
    "c:\\Program Files\\MySpace\\IM\\MySpaceIM.exe"=
    R2 OcHealthMon;Windows Live OneCare Health Monitor;c:\program files\Microsoft Windows OneCare Live\OcHealthMon.exe [3/22/2009 10:59 AM 24936]
    R2 sprtsvc_medicsp2;SupportSoft Sprocket Service (medicsp2);c:\program files\twc\medicsp2\bin\sprtsvc.exe [4/20/2008 9:20 PM 202280]
    [HKEY_LOCAL_MACHINE\software\microsoft\active setup\installed components\>{60B49E34-C7CC-11D0-8953-00A0C90347FF}]
    "c:\windows\system32\rundll32.exe" "c:\windows\system32\iedkcs32.dll",BrandIEActiveSetup SIGNUP
    Contents of the 'Scheduled Tasks' folder
    2009-06-04 c:\windows\Tasks\Google Software Updater.job
    - c:\program files\Google\Common\Google Updater\GoogleUpdaterService.exe [2008-04-21 04:54]
    - - - - ORPHANS REMOVED - - - -
    HKCU-Run-Aim6 - (no file)
    SafeBoot-procexp90.Sys
    Supplementary Scan
    uStart Page = hxxp://roadrunner.com/
    uSearchMigratedDefaultURL = hxxp://www.google.com/search?q={searchTerms}&sourceid=ie7&rls=com.microsoft:en-US&ie=utf8&oe=utf8
    uDefault_Search_URL = hxxp://www.google.com/ie
    uInternet Connection Wizard,ShellNext = iexplore
    uSearchURL,(Default) = hxxp://www.google.com/search?q=%s
    IE: Add to Google Photos Screensa&ver - c:\windows\system32\GPhotos.scr/200
    IE: Easy-WebPrint Add To Print List - c:\program files\Canon\Easy-WebPrint\Resource.dll/RC_AddToList.html
    IE: Easy-WebPrint High Speed Print - c:\program files\Canon\Easy-WebPrint\Resource.dll/RC_HSPrint.html
    IE: Easy-WebPrint Preview - c:\program files\Canon\Easy-WebPrint\Resource.dll/RC_Preview.html
    IE: Easy-WebPrint Print - c:\program files\Canon\Easy-WebPrint\Resource.dll/RC_Print.html
    IE: {{d9288080-1baa-4bc4-9cf8-a92d743db949} - c:\documents and settings\Owner.HOME-4FBF327C98\Start Menu\Programs\IMVU\Run IMVU.lnk
    Filter: x-sdch - {B1759355-3EEC-4C1E-B0F1-B719FE26E377} - c:\program files\Google\Google Toolbar\Component\fastsearch_A8904FB862BD9564.dll
    DPF: ActiveGS.cab - hxxp://www.virtualapple.org/activegs.cab
    DPF: {032C5CBC-2272-438F-AC73-38EA92AF19BD} - hxxp://69.69.237.4/WebViewer.cab
    DPF: {055B4212-4C81-448E-AFA9-C3CA4AAE8F95} - hxxp://games.bigfishgames.com/en_dairy-dash-game/online/DairyDashWeb.1.0.0.15.cab
    DPF: {ADACAA8F-3595-47FE-9C31-9C7471B9BEC7} - hxxp://66.0.208.210/cab/OCXChecker_8000.cab
    catchme 0.3.1398 W2K/XP/Vista - rootkit/stealth malware detector by Gmer, http://www.gmer.net
    Rootkit scan 2009-06-04 15:44
    Windows 5.1.2600 Service Pack 3 NTFS
    scanning hidden processes ...
    scanning hidden autostart entries ...
    scanning hidden files ...
    scan completed successfully
    hidden files: 0
    LOCKED REGISTRY KEYS
    [HKEY_USERS\S-1-5-21-1957994488-1960408961-725345543-1003\Software\Microsoft\SystemCertificates\AddressBook*]
    @Allowed: (Read) (RestrictedCode)
    Completion time: 2009-06-04 15:47
    ComboFix-quarantined-files.txt 2009-06-04 19:47
    Pre-Run: 113,942,790,144 bytes free
    Post-Run: 114,827,931,648 bytes free
    WindowsXP-KB310994-SP2-Home-BootDisk-ENU.exe
    [boot loader]
    timeout=2
    default=multi(0)disk(0)rdisk(0)partition(2)\WINDOWS
    [operating systems]
    c:\cmdcons\BOOTSECT.DAT="Microsoft Windows Recovery Console" /cmdcons
    multi(0)disk(0)rdisk(0)partition(2)\WINDOWS="Microsoft Windows XP Home Edition" /noexecute=optin /fastdetect
    186 --- E O F --- 2009-05-14 04:31
  • edited June 2009
    Custom CFScript
    • Please open Notepad (Start -> Run -> type notepad in the Open field -> OK) and copy and paste the text present inside the code box below:
      FCopy::
      c:\windows\ServicePackFiles\i386\winlogon.exe|c:\windows\system32\winlogon.exe
      DirLook::
      c:\windows\PIF
      File::
      ADS::
    • Save this as CFScript.txt and place it on your desktop.
    • Referring to the screenshot above, drag CFScript.txt into ComboFix.exe.
    • ComboFix will now run a scan on your system. It may reboot your system when it finishes. This is normal.
    • When finished, it will produce a log for you. Copy and paste the contents of the log in your next reply.
    CAUTION: Do not mouse-click ComboFix's window while it is running. That may cause it to stall.
    Note: the above code was created specifically for this user. If you are not this user, do NOT follow these directions as they could damage the workings of your system.
    A word of warning: Neither I nor sUBs are responsible for any damage you may have caused your machine by running ComboFix on your own. This tool is not a toy and not for everyday use.
    Kaspersky Online Scanner .
    Your Antivirus and/or Antispyware may give a warning during the scan. This is perfectly normal
    NOTE:- This scan is best done from IE (Internet Explorer)
    NOTE:- Vista users should start IE by Start(Vista Orb) >> Internet Explorer >> Right-Click Run As Admin
    Go Here http://www.kaspersky.com/kos/eng/partner/default/kavwebscan.html
    Read the Requirements and limitations before you click Accept.
    Once the database has downloaded, click My Computer in the left pane
    Now go and put the kettle on !
    When the scan has completed, click Save Report As...
    Enter a name for the file in the Filename: text box and then click the down arrow to the right of Save as type: and select text file (*.txt)
    Click Save - by default the file will be saved to your Desktop, but you can change this if you wish.
    **Note**
    To optimize scanning time and produce a more sensible report for review:
    • Close any open programs.
    • Turn off the real-time scanner of all antivirus or antispyware programs while performing the online scan.
    Note for Internet Explorer 7 users: If at any time you have trouble viewing the accept button of the license, click on the Zoom tool located at the bottom right of the IE window and set the zoom to 75%. Once the license is accepted, reset to 100%.
  • edited June 2009
    ComboFix 09-06-05.02 - Owner 06/05/2009 15:11.2 - NTFSx86
    Microsoft Windows XP Home Edition 5.1.2600.3.1252.1.1033.18.510.176 [GMT -4:00]
    Command switches used :: c:\documents and settings\Owner.HOME-4FBF327C98\Desktop\CFScript.txt
    FILE ::
    "c:\program files\temp01"
    FCopy
    c:\windows\ServicePackFiles\i386\winlogon.exe --> c:\windows\system32\winlogon.exe
    ((((((((((((((((((((((((( Files Created from 2009-05-05 to 2009-06-05 )))))))))))))))))))))))))))))))
    2009-06-04 19:30 . 2009-06-04 19:30
    d
    w- C:\32788R22FWJFW.0.tmp
    d
    d
    d
    d
    d
    w- C:\rsit
    d
    d
    d
    d
    d
    d
    d
    d
    2009-06-05 19:01 . 2008-04-21 01:58
    d
    2009-06-05 03:17 . 2008-08-24 01:55
    d
    d
    d
    d
    d
    d
    d
    d
    d
    d
    d
    d
    d
    d
    (((((((((((((((((((((((((((((((((((((((((((( Look )))))))))))))))))))))))))))))))))))))))))))))))))))))))))
    ---- Directory of c:\windows\PIF ----
    ((((((((((((((((((((((((((((( [EMAIL="SnapShot@2009-06-04_19.44.43"]SnapShot@2009-06-04_19.44.43[/EMAIL] )))))))))))))))))))))))))))))))))))))))))
    + 2009-06-05 18:14 . 2009-06-05 18:14 16384 c:\windows\Temp\Perflib_Perfdata_614.dat
    + 2004-08-04 10:00 . 2008-04-14 00:12 507904 c:\windows\system32\dllcache\winlogon.exe
    REGEDIT4
    @="Service"
    2009-06-05 c:\windows\Tasks\Google Software Updater.job
    Supplementary Scan
    Rootkit scan 2009-06-05 15:17
    hidden files: 0
    Completion time: 2009-06-05 15:20
    ComboFix-quarantined-files.txt 2009-06-05 19:19
    ComboFix2.txt 2009-06-04 19:47
    Pre-Run: 114,830,168,064 bytes free
    Post-Run: 114,855,563,264 bytes free
    170 --- E O F --- 2009-05-14 04:31
  • edited June 2009
    That's looking better :)
    **Note**
  • edited June 2009
    when i go to that website the accept button is not working the only one i can use is the exit
  • edited June 2009
    Never mind its working now
  • edited June 2009
    Sorry its taking so long its been storming and we have been losing electric half way through the scan
  • edited June 2009
    KASPERSKY ONLINE SCANNER 7.0 REPORT Monday, June 8, 2009
    Operating System: Microsoft Windows XP Home Edition Service Pack 3 (build 2600)
    Kaspersky Online Scanner version: 7.0.26.13
    Program database last update: Monday, June 08, 2009 15:40:20
    Records in database: 2326376
    Scan settingsScan using the following databaseextendedScan archivesyesScan mail databasesyesScan areaMy ComputerA:\
    C:\
    D:\ Scan statisticsFiles scanned104990Threat name9Infected objects16Suspicious objects0Duration of the scan03:15:28
    File nameThreat nameThreats countC:\Program Files\MUSICMATCH\Common\ComponentMgr\HoldingArea\WebSys2\WebSys.mmzInfected: not-a-virus:RiskTool.Win32.Deleter.f1C:\Program Files\MUSICMATCH\Musicmatch Jukebox\WebSys\offline.mmzInfected: not-a-virus:RiskTool.Win32.Deleter.f1C:\System Volume Information\_restore{1F97D91D-97BB-4DE8-8962-43185A80B364}\RP362\A0096970.DLLInfected: not-a-virus:WebToolbar.Win32.MyWebSearch1C:\System Volume Information\_restore{1F97D91D-97BB-4DE8-8962-43185A80B364}\RP362\A0096988.DLLInfected: not-a-virus:WebToolbar.Win32.MyWebSearch1C:\System Volume Information\_restore{1F97D91D-97BB-4DE8-8962-43185A80B364}\RP362\A0096993.DLLInfected: not-a-virus:WebToolbar.Win32.MyWebSearch.at1C:\System Volume Information\_restore{1F97D91D-97BB-4DE8-8962-43185A80B364}\RP362\A0096995.DLLInfected: not-a-virus:WebToolbar.Win32.MyWebSearch.bc1C:\System Volume Information\_restore{1F97D91D-97BB-4DE8-8962-43185A80B364}\RP362\A0096996.DLLInfected: not-a-virus:WebToolbar.Win32.MyWebSearch1C:\System Volume Information\_restore{1F97D91D-97BB-4DE8-8962-43185A80B364}\RP362\A0096997.DLLInfected: not-a-virus:WebToolbar.Win32.MyWebSearch.l1C:\System Volume Information\_restore{1F97D91D-97BB-4DE8-8962-43185A80B364}\RP362\A0096998.DLLInfected: not-a-virus:WebToolbar.Win32.MyWebSearch.af1C:\System Volume Information\_restore{1F97D91D-97BB-4DE8-8962-43185A80B364}\RP362\A0096999.DLLInfected: not-a-virus:WebToolbar.Win32.MyWebSearch.au1C:\System Volume Information\_restore{1F97D91D-97BB-4DE8-8962-43185A80B364}\RP362\A0097000.DLLInfected: not-a-virus:WebToolbar.Win32.MyWebSearch.au1C:\System Volume Information\_restore{1F97D91D-97BB-4DE8-8962-43185A80B364}\RP362\A0097001.SCRInfected: not-a-virus:WebToolbar.Win32.MyWebSearch1C:\System Volume Information\_restore{1F97D91D-97BB-4DE8-8962-43185A80B364}\RP362\A0097002.DLLInfected: not-a-virus:WebToolbar.Win32.MyWebSearch.au1C:\System Volume Information\_restore{1F97D91D-97BB-4DE8-8962-43185A80B364}\RP362\A0097005.DLLInfected: not-a-virus:WebToolbar.Win32.MyWebSearch.an1C:\System Volume Information\_restore{1F97D91D-97BB-4DE8-8962-43185A80B364}\RP362\A0097006.DLLInfected: not-a-virus:WebToolbar.Win32.MyWebSearch.aq1C:\System Volume Information\_restore{1F97D91D-97BB-4DE8-8962-43185A80B364}\RP362\A0097007.DLLInfected: not-a-virus:WebToolbar.Win32.MyWebSearch1The selected area was scanned.
    Scan settings:
    Scan using the following database: extended
    Scan archives: yes
    Scan mail databases: yes
    Scan area - My Computer:
    A:\
    C:\
    D:\
    Scan statistics:
    Files scanned: 104990
    Threat name: 9
    Infected objects: 16
    Suspicious objects: 0
    Duration of the scan: 03:15:28
    File name / Threat name / Threats count
    C:\Program Files\MUSICMATCH\Common\ComponentMgr\HoldingArea\WebSys2\WebSys.mmz Infected: not-a-virus:RiskTool.Win32.Deleter.f 1
    C:\Program Files\MUSICMATCH\Musicmatch Jukebox\WebSys\offline.mmz Infected: not-a-virus:RiskTool.Win32.Deleter.f 1
    C:\System Volume Information\_restore{1F97D91D-97BB-4DE8-8962-43185A80B364}\RP362\A0096970.DLL Infected: not-a-virus:WebToolbar.Win32.MyWebSearch 1
    C:\System Volume Information\_restore{1F97D91D-97BB-4DE8-8962-43185A80B364}\RP362\A0096988.DLL Infected: not-a-virus:WebToolbar.Win32.MyWebSearch 1
    C:\System Volume Information\_restore{1F97D91D-97BB-4DE8-8962-43185A80B364}\RP362\A0096993.DLL Infected: not-a-virus:WebToolbar.Win32.MyWebSearch.at 1
    C:\System Volume Information\_restore{1F97D91D-97BB-4DE8-8962-43185A80B364}\RP362\A0096995.DLL Infected: not-a-virus:WebToolbar.Win32.MyWebSearch.bc 1
    C:\System Volume Information\_restore{1F97D91D-97BB-4DE8-8962-43185A80B364}\RP362\A0096996.DLL Infected: not-a-virus:WebToolbar.Win32.MyWebSearch 1
    C:\System Volume Information\_restore{1F97D91D-97BB-4DE8-8962-43185A80B364}\RP362\A0096997.DLL Infected: not-a-virus:WebToolbar.Win32.MyWebSearch.l 1
    C:\System Volume Information\_restore{1F97D91D-97BB-4DE8-8962-43185A80B364}\RP362\A0096998.DLL Infected: not-a-virus:WebToolbar.Win32.MyWebSearch.af 1
    C:\System Volume Information\_restore{1F97D91D-97BB-4DE8-8962-43185A80B364}\RP362\A0096999.DLL Infected: not-a-virus:WebToolbar.Win32.MyWebSearch.au 1
    C:\System Volume Information\_restore{1F97D91D-97BB-4DE8-8962-43185A80B364}\RP362\A0097000.DLL Infected: not-a-virus:WebToolbar.Win32.MyWebSearch.au 1
    C:\System Volume Information\_restore{1F97D91D-97BB-4DE8-8962-43185A80B364}\RP362\A0097001.SCR Infected: not-a-virus:WebToolbar.Win32.MyWebSearch 1
    C:\System Volume Information\_restore{1F97D91D-97BB-4DE8-8962-43185A80B364}\RP362\A0097002.DLL Infected: not-a-virus:WebToolbar.Win32.MyWebSearch.au 1
    C:\System Volume Information\_restore{1F97D91D-97BB-4DE8-8962-43185A80B364}\RP362\A0097005.DLL Infected: not-a-virus:WebToolbar.Win32.MyWebSearch.an 1
    C:\System Volume Information\_restore{1F97D91D-97BB-4DE8-8962-43185A80B364}\RP362\A0097006.DLL Infected: not-a-virus:WebToolbar.Win32.MyWebSearch.aq 1
    C:\System Volume Information\_restore{1F97D91D-97BB-4DE8-8962-43185A80B364}\RP362\A0097007.DLL Infected: not-a-virus:WebToolbar.Win32.MyWebSearch 1
  • edited June 2009
    Congratulations your logs look clean :)
    Let's see if I can help you keep it that way
    First lets tidy up
    Please delete RSIT.exe and C:\RSIT (entire folder)
    You can also delete any logs we have produced, and empty your Recycle bin.
    Uninstall Combofix
    • This will clear your System Volume Information restore points and remove all the infected files that were quarantined
    • Click START then RUN
    • Now type Combofix /u in the runbox and click OK. Note the space between the X and the /U, it needs to be there.
    Your Java is out of date. Older versions have vulnerabilities that malware can use to infect your system.
    Please download Java SE Runtime Environment (JRE) . ( don't install it yet )
    • Scroll down to where it says "Java SE Runtime Environment (JRE)".
    • Click the "Download" button to the right.
      • Platform = Windows
      • Language = Multi Language
    • Check the box that says: "Accept License Agreement".
    • The page will refresh.
    • Click on the link to download Windows Offline Installation with or without Multi-language and save to your desktop.
    Now download JavaRa and unzip it to your desktop.
    ***Please close any instances of Internet Explorer (or other web browser) before continuing!***
    • Double-click on JavaRa.exe to start the program.
    • From the drop-down menu, choose English and click on Select.
    • JavaRa will open; click on Remove Older Versions to remove the older versions of Java installed on your computer.
    • Click Yes when prompted. When JavaRa is done, a notice will appear that a logfile has been produced. Click OK.
    • A logfile will pop up. Please save it to a convenient location.
    Now install the Java SE Runtime Environment (JRE) package you downloaded
    (it comes with a toolbar pre-selected, so make sure you uncheck the box)
    You can delete JavaRa (zip and exe)
    The following is some info to help you stay safe and clean.
    You may already have some of the following programs, but I include the full list for the benefit of all the other people who will be reading this thread in the future.
    ( Vista users must ensure that any programs are Vista compatible BEFORE installing )
    Online Scanners
    I would recommend a scan at one or more of the following sites at least once a month.
    http://www.pandasecurity.com/activescan
    http://www.kaspersky.com/kos/eng/partner/71706/kavwebscan.html
    !!! Make sure that all your programs are updated !!!
    Secunia Software Inspector does all the work for you, .... see HERE for details
    AntiSpyware
      AntiSpyware is
    not the same thing as Antivirus.
    Different AntiSpyware programs detect different things, so in this case it is recommended that you have more than one.
    You should only have one running all the time, the other/s should be used "on demand" on a regular basis.
    Most of the programs in this list have a free (for Home Users ) and paid versions,
    it is worth paying for one and having "realtime" protection, unless you intend to do a manual scan often.
    [*]Spybot - Search & Destroy <<< A must have program
    • It includes host protection and registry protection
    • A hosts file is a bit like a phone book, it points to the actual numeric address (i.e. the IP address) from the human friendly name of a website. This feature can be used to block malicious websites
    [*] MalwareBytes Anti-malware <<< A New and effective program
    [*]a-squared Free <<< A good "realtime" or "on demand" scanner
    [*]superantispyware <<< A good "realtime" or "on demand" scanner
    Prevention
      These programs don't detect malware, they help stop it getting on your machine in the first place. Each does a different job, so you can have more than one
    • Winpatrol
      • An excellent startup manager and then some !!
      • Notifies you if programs are added to startup
      • Allows delayed startup
      • A must have addition
    • SpywareBlaster 4.0
      • SpywareBlaster sets killbits in the registry to prevent known malicious activex controls from installing themselves on your computer.
    • SpywareGuard 2.2
      • SpywareGuard provides real-time protection against spyware.
      • Not required if you have other "realtime" antispyware or Winpatrol
    • ZonedOut
      • Formerly known as IE-SPYAD, adds a long list of sites and domains associated with known advertisers and marketers to the Restricted sites zone of Internet Explorer.
    • MVPS HOSTS
      • This little program packs a powerful punch as it blocks ads, banners, 3rd party Cookies, 3rd party page counters, web bugs, and many hijackers.
      • For information on how to download and install, please read this tutorial by WinHelp2002.
      • Not required if you are using other host file protections
    Internet Browsers
      Microsoft has worked hard to make IE.7 a more secure browser, unfortunately whilst it is still the leading browser of choice it will always be under attack from the bad guys. Using a different web browser can help stop malware getting on your machine.
    • Make your Internet Explorer more secure - This can be done by following these simple instructions:
      1. From within Internet Explorer click on the Tools menu and then click on Options.
      2. Click once on the Security tab
      3. Click once on the Internet icon so it becomes highlighted.
      4. Click once on the Custom Level button.
        • Change the Download signed ActiveX controls to Prompt
        • Change the Download unsigned ActiveX controls to Disable
        • Change the Initialise and script ActiveX controls not marked as safe to Disable
        • Change the Installation of desktop items to Prompt
        • Change the Launching programs and files in an IFRAME to Prompt
        • Change the Navigate sub-frames across different domains to Prompt
        • When all these settings have been made, click on the OK button.
        • If it prompts you as to whether or not you want to save the settings, press the Yes button.
      5. Next press the Apply button and then the OK to exit the Internet Properties page.
    If you are still using IE6 then either update, or get one of the following.
    • FireFox
      • With many addons available that make customization easy this is a very popular choice
      • NoScript and AdBlockPlus addons are essential
    • Opera
      • Another popular alternative
    • Netscape
      • Also has Addons available
    Cleaning Temporary Internet Files and Tracking Cookies
      Temporary Internet Files are mainly the files that are downloaded when you open a web page. Unfortunately, if the site you visit is of a dubious nature or has been hacked, they can also be an entry point for malware. It is a good idea to empty the Temporary Internet Files folder on a regular basis. Tracking Cookies are files that websites use to monitor which sites you visit and how often. A lot of Antispyware scanners pick up these tracking cookies and flag them as unwanted. CAUTION :- If you delete all your cookies you will lose any autologin information for sites that you visit, and will need your passwords Both of these can be cleaned manually, but a quicker option is to use a program
    • ATF Cleaner
      • Free and very simple to use
    • CCleaner
      • Free and very flexible, you can chose which cookies to keep
    Also PLEASE read this article.....So How Did I Get Infected In The First Place
    The last and most important thing I can tell you is UPDATE.
    If you don't update your security programs (Antivirus, Antispyware even Windows) then you are at risk.
    Malware changes on a day to day basis. You should update every week at the very least.
    If you follow this advice then (with a bit of luck) you will never have to hear from me again :D
    If you could post back one more time to let me know everything is OK, then I can have this thread archived.
    Happy surfing K'
  • edited June 2009
    Thank you!
