A Little More Help, Katana?
Greetings Katana...
Thank you again for all your help in resolving the now-infamous CyberDefender debacle. My machine is still clean and runs pretty well, but I do have a problem left that I think reverts back to my intial "Sheur2XLC" trojan problem.
I have always had Win XP set to inform me of Windows upgrades via the system tray notification, but not automatically download them or install them. I would get the notification message, then simply click on the yellow shield icon in the tray to open the check box window and start the downloads.
Ever since the attack, however, clicking on the shield only takes me to the check-box window where you select which updates you want to download, but will not start the download when I click the link. It is as if the command to start the download either never gets generated or never makes it to Microsoft. I have had to manually go to the update site and select and download the updates from there...
Although I sometimes would curse that infernal "Updates Available" window popping up all the time, it WAS awfully convenient and sort of forced me into keeping my machine updated.
Any ideas what may be wrong? Just let me know if you want a HJT and or ERUNT posted, didn't want to take up the space if this is a known problem.
I do see alot of lag time in the system , sometimes many seconds going by before clicks are processed. Everything scans clean though and I keep background programs and startups to an absolute minimum....
Slider
Slider
Thank you, Korppu...
Here's the HJT log. It only seems that the download just never starts...the list of available updates is always current. The trojan I had, had disabled all of my Spyware and AV stuff - a possibility it also disabled the download capability from MS...I'm out of my league with this one...
Logfile of Trend Micro HijackThis v2.0.2
Scan saved at 5:43:56 PM, on 6/11/2009
Platform: Windows XP SP3 (WinNT 5.01.2600)
MSIE: Internet Explorer v7.00 (7.00.6000.16827)
Boot mode: Normal
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\csrss.exe
C:\WINDOWS\system32\lsass.exe
C:\PROGRA~1\AVG\AVG8\avgwdsvc.exe
C:\Program Files\Java\jre6\bin\jqs.exe
C:\Program Files\Spyware Doctor\pctsAuxs.exe
C:\PROGRA~1\AVG\AVG8\avgrsx.exe
C:\Program Files\Spyware Doctor\pctsSvc.exe
C:\PROGRA~1\AVG\AVG8\avgnsx.exe
C:\WINDOWS\Explorer.EXE
C:\PROGRA~1\AVG\AVG8\avgtray.exe
C:\WINDOWS\system32\ctfmon.exe
C:\Program Files\Spyware Doctor\pctsTray.exe
C:\Program Files\Spyware Doctor\TFEngine\TFService.exe
C:\WINDOWS\System32\alg.exe
C:\Program Files\Trend Micro\HijackThis\HijackThis.exe
C:\WINDOWS\system32\wbem\wmiprvse.exe
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/fwlink/?LinkId=54896
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://www.comcast.net/
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://go.microsoft.com/fwlink/?LinkId=69157
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = http://go.microsoft.com/fwlink/?LinkId=54896
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/fwlink/?LinkId=54896
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = http://go.microsoft.com/fwlink/?LinkId=69157
R0 - HKLM\Software\Microsoft\Internet Explorer\Search,SearchAssistant =
R0 - HKLM\Software\Microsoft\Internet Explorer\Search,CustomizeSearch =
R1 - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings,ProxyOverride = *.*.attbi.com
N3 - Netscape 7: # Mozilla User Preferences
/* Do not edit this file.
* If you make changes to this file while the browser is running,
* the changes will be overwritten when the browser exits.
* To make a manual change to preferences, you can visit the URL about:config
* For more information, see http://www.mozilla.org/unix/customizing.html#prefs
user_pref("aim.session.firsttime", false);
user_pref("browser.activation.checkedNNFlag", true);
user_pref("browser.bookmarks.added_static_root", true);
user_pref("browser.cache.disk.parent_directory", "C:\\DOCUMENTS AND SETTINGS\\ADMINISTRATOR\\APPLICATION DATA\\Mozilla\\Profiles\\default\\lxcunvvv.slt");
user_pref("browser.search.defaultengine", "engine://C%3A%5CProgram%20Files%5CNetscape%5CNetscape%5Csearchplugins%5CSBWeb_01.src");
user_pref("browser.startup.homepage_override.mstone", "rv:1.7.2");
user_pref("dom.disable_open_during_load", true);
user_pref("intl.charsetmenu.browser.cache", "us-ascii, UTF-8, windows-1252, ISO-8859-1");
user_pref("mail
O2 - BHO: Adobe PDF Reader Link Helper - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Adobe\Acrobat 7.0\ActiveX\AcroIEHelper.dll
O2 - BHO: WormRadar.com IESiteBlocker.NavFilter - {3CA2F312-6F6E-4B53-A66E-4E65E497C8C0} - C:\Program Files\AVG\AVG8\avgssie.dll
O2 - BHO: Yahoo! IE Services Button - {5BAB4B5B-68BC-4B02-94D6-2FC0DE4A7897} - C:\Program Files\Yahoo!\Common\yiesrvc.dll
O2 - BHO: Java(tm) Plug-In SSV Helper - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files\Java\jre6\bin\ssv.dll
O2 - BHO: Google Toolbar Helper - {AA58ED58-01DD-4d91-8333-CF10577473F7} - c:\program files\google\googletoolbar1.dll
O2 - BHO: Google Toolbar Notifier BHO - {AF69DE43-7D58-4638-B6FA-CE66B5AD205D} - C:\Program Files\Google\GoogleToolbarNotifier\3.1.807.1746\swg.dll
O2 - BHO: Java(tm) Plug-In 2 SSV Helper - {DBC80044-A445-435b-BC74-9C25C1C588A9} - C:\Program Files\Java\jre6\bin\jp2ssv.dll
O2 - BHO: JQSIEStartDetectorImpl - {E7E6F031-17CE-4C07-BC86-EABFE594F69C} - C:\Program Files\Java\jre6\lib\deploy\jqs\ie\jqs_plugin.dll
O3 - Toolbar: &Google - {2318C2B1-4965-11d4-9B18-009027A5CD4F} - c:\program files\google\googletoolbar1.dll
O4 - HKLM\..\Run: [AVG8_TRAY] C:\PROGRA~1\AVG\AVG8\avgtray.exe
O4 - HKLM\..\Run: [ISTray] "C:\Program Files\Spyware Doctor\pctsTray.exe"
O4 - HKCU\..\Run: [ctfmon.exe] C:\WINDOWS\system32\ctfmon.exe
O9 - Extra button: Spyware Doctor - {2D663D1A-8670-49D9-A1A5-4C56B4E14E84} - C:\WINDOWS\System32\shdocvw.dll
O9 - Extra button: Yahoo! Services - {5BAB4B5B-68BC-4B02-94D6-2FC0DE4A7897} - C:\Program Files\Yahoo!\Common\yiesrvc.dll
O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~1\MICROS~2\OFFICE11\REFIEBAR.DLL
O16 - DPF: {01012101-5E80-11D8-9E86-0007E96C65AE} (SupportSoft Script Runner Class) - http://www.symantec.com/techsupp/asa/ctrl/tgctlsr.cab
O16 - DPF: {2BC66F54-93A8-11D3-BEB6-00105AA9B6AE} (Symantec AntiVirus scanner) - http://security.symantec.com/sscv6/SharedContent/vc/bin/AvSniff.cab
O16 - DPF: {30528230-99f7-4bb4-88d8-fa1d4f56a2ab} (Installation Support) - C:\Program Files\Yahoo!\Common\Yinsthelper.dll
O16 - DPF: {5ED80217-570B-4DA9-BF44-BE107C0EC166} (Windows Live Safety Center Base Module) - http://cdn.scan.onecare.live.com/resource/download/scanner/wlscbase8300.cab
O16 - DPF: {6414512B-B978-451D-A0D8-FCFDF33E833C} (WUWebControl Class) - http://v5.windowsupdate.microsoft.com/v5consumer/V5Controls/en/x86/client/wuweb_site.cab?1096722207781
O16 - DPF: {644E432F-49D3-41A1-8DD5-E099162EEEC5} (Symantec RuFSI Utility Class) - http://security.symantec.com/sscv6/SharedContent/common/bin/cabsa.cab
O16 - DPF: {6E32070A-766D-4EE6-879C-DC1FA91D2FC3} (MUWebControl Class) - http://update.microsoft.com/microsoftupdate/v6/V5Controls/en/x86/client/muweb_site.cab?1140016650656
O16 - DPF: {AB86CE53-AC9F-449F-9399-D8ABCA09EC09} (Get_ActiveX Control) - https://h17000.www1.hp.com/ewfrf-JAVA/Secure/HPGetDownloadManager.ocx
O16 - DPF: {EB387D2F-E27B-4D36-979E-847D1036C65D} (QDiagHUpdateObj Class) - http://h30043.www3.hp.com/hpdj/en/check/qdiagh.cab?323
O17 - HKLM\System\CCS\Services\Tcpip\Parameters: Domain = MANDP.Local
O17 - HKLM\Software\..\Telephony: DomainName = MANDP.Local
O17 - HKLM\System\CS1\Services\Tcpip\Parameters: Domain = MANDP.Local
O18 - Protocol: linkscanner - {F274614C-63F8-47D5-A4D1-FBDDE494F8D1} - C:\Program Files\AVG\AVG8\avgpp.dll
O20 - Winlogon Notify: avgrsstarter - C:\WINDOWS\SYSTEM32\avgrsstx.dll
O23 - Service: AVG Free8 WatchDog (avg8wd) - AVG Technologies CZ, s.r.o. - C:\PROGRA~1\AVG\AVG8\avgwdsvc.exe
O23 - Service: JavaQuickStarterService - Sun Microsystems, Inc. - C:\Program Files\Java\jre6\bin\jqs.exe
O23 - Service: PC Tools Auxiliary Service (sdAuxService) - PC Tools - C:\Program Files\Spyware Doctor\pctsAuxs.exe
O23 - Service: PC Tools Security Service (sdCoreService) - PC Tools - C:\Program Files\Spyware Doctor\pctsSvc.exe
O23 - Service: ThreatFire - PC Tools - C:\Program Files\Spyware Doctor\TFEngine\TFService.exe
End of file - 7428 bytes
Run by Administrator at 2009-06-12 10:17:08
Microsoft Windows XP Professional Service Pack 3
System drive C: has 199 GB (83%) free of 238 GB
Total RAM: 1023 MB (59% free)
Scan saved at 10:17:30 AM, on 6/12/2009
Boot mode: Normal
Running processes:
C:\Program Files\Outlook Express\msimn.exe
C:\Program Files\Internet Explorer\IEXPLORE.EXE
C:\Documents and Settings\Administrator\Desktop\RSIT.exe
C:\Program Files\Trend Micro\HijackThis\Administrator.exe
user_pref("mail
End of file - 7550 bytes
======Scheduled tasks folder======
C:\WINDOWS\tasks\Schedule Task Weekly.job
======Registry dump======
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{06849E9F-C8D7-4D59-B87D-784B7D6BE0B3}]
Adobe PDF Reader Link Helper - C:\Program Files\Adobe\Acrobat 7.0\ActiveX\AcroIEHelper.dll [2006-12-18 59032]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{3CA2F312-6F6E-4B53-A66E-4E65E497C8C0}]
AVG Safe Search - C:\Program Files\AVG\AVG8\avgssie.dll [2009-05-04 1107224]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{5BAB4B5B-68BC-4B02-94D6-2FC0DE4A7897}]
Yahoo! IE Services Button - C:\Program Files\Yahoo!\Common\yiesrvc.dll [2006-10-31 198136]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{761497BB-D6F0-462C-B6EB-D4DAF1D92D43}]
Java(tm) Plug-In SSV Helper - C:\Program Files\Java\jre6\bin\ssv.dll [2008-12-02 320920]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{AA58ED58-01DD-4d91-8333-CF10577473F7}]
Google Toolbar Helper - c:\program files\google\googletoolbar1.dll [2007-05-21 2403392]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{AF69DE43-7D58-4638-B6FA-CE66B5AD205D}]
Google Toolbar Notifier BHO - C:\Program Files\Google\GoogleToolbarNotifier\3.1.807.1746\swg.dll [2008-09-11 737776]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{DBC80044-A445-435b-BC74-9C25C1C588A9}]
Java(tm) Plug-In 2 SSV Helper - C:\Program Files\Java\jre6\bin\jp2ssv.dll [2008-12-02 34816]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{E7E6F031-17CE-4C07-BC86-EABFE594F69C}]
JQSIEStartDetectorImpl Class - C:\Program Files\Java\jre6\lib\deploy\jqs\ie\jqs_plugin.dll [2008-12-02 73728]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Toolbar]
{2318C2B1-4965-11d4-9B18-009027A5CD4F} - &Google - c:\program files\google\googletoolbar1.dll [2007-05-21 2403392]
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run]
"AVG8_TRAY"=C:\PROGRA~1\AVG\AVG8\avgtray.exe [2009-05-13 1947928]
"ISTray"=C:\Program Files\Spyware Doctor\pctsTray.exe [2008-12-08 1173384]
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run]
"ctfmon.exe"=C:\WINDOWS\system32\ctfmon.exe [2008-04-13 15360]
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\AlcWzrd]
C:\WINDOWS\ALCWZRD.EXE [2004-05-17 2545664]
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\ctfmon.exe]
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\High Definition Audio Property Page Shortcut]
C:\WINDOWS\system32\HDAudPropShortcut.exe [2004-03-17 61952]
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\HPWOTOOLBOX]
C:\Program Files\HP\HP Officejet Pro K850 Series\Toolbox\HPWOTBX.exe [2006-11-03 352256]
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\ISTray]
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\MSMSGS]
C:\Program Files\Messenger\msmsgs.exe [2008-04-13 1695232]
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\OSSelectorReinstall]
C:\Program Files\Common Files\Acronis\Acronis Disk Director\oss_reinstall.exe [2007-02-22 2209224]
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\Panasonic Device Manager for Multi-Function Station software]
C:\Program Files\Panasonic\MFStation\PCCMFSDM.exe [2007-05-21 126976]
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\Panasonic Device Monitor Wakeup]
C:\Program Files\Panasonic\Device Monitor\dmwakeup.exe [2006-11-02 303104]
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\Panasonic PCFAX for Multi-Function Station software]
C:\Program Files\Panasonic\MFStation\KmPcFax.exe [2007-08-28 757760]
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\PhotoShow Deluxe Media Manager]
C:\PROGRA~1\Ahead\NEROPH~1\data\xtras\mssysmgr.exe [2004-05-12 196608]
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\QuickTime Task]
C:\Program Files\QuickTime\qttask.exe [2007-06-29 286720]
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\swg]
C:\Program Files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe [2007-08-30 68856]
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\updateMgr]
C:\Program Files\Adobe\Acrobat 7.0\Reader\AdobeUpdateManager.exe [2006-03-30 313472]
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\Windows Defender]
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\services]
"WMPNetworkSvc"=3
"WinDefend"=2
"ThreatFire"=3
"sdCoreService"=2
"sdAuxService"=2
"Panasonic Trap Monitor Service"=2
"Panasonic Local Printer Service"=2
"ose"=3
"JavaQuickStarterService"=3
"gusvc"=3
"C-DillaCdaC11BA"=2
"AVGEMS"=2
"Avg7UpdSvc"=2
"Avg7Alrt"=2
"ATI Smart"=2
"APC UPS Service"=2
"AcrSch2Svc"=2
"aawservice"=3
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\Notify\AtiExtEvent]
C:\WINDOWS\system32\Ati2evxx.dll [2004-04-21 86016]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\Notify\avgrsstarter]
C:\WINDOWS\system32\avgrsstx.dll [2009-05-19 11952]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\Notify\WgaLogon]
C:\WINDOWS\system32\WgaLogon.dll [2007-03-15 236928]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\ShellServiceObjectDelayLoad]
WPDShServiceObj - {AAA288BA-9A4C-45B0-95D7-94D524869DB5} - C:\WINDOWS\system32\WPDShServiceObj.dll [2006-10-18 133632]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Lsa]
"authentication packages"=msv1_0
relog_ap
"notification packages"=
scecli
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\sdauxservice]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\sdcoreservice]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\network\sdauxservice]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\network\sdcoreservice]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\network\UploadMgr]
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Policies\System]
"dontdisplaylastusername"=0
"legalnoticecaption"=
"legalnoticetext"=
"shutdownwithoutlogon"=1
"undockwithoutlogon"=1
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\explorer]
"NoDriveTypeAutoRun"=145
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Policies\explorer]
"HonorAutoRunSetting"=
[HKEY_LOCAL_MACHINE\system\currentcontrolset\services\sharedaccess\parameters\firewallpolicy\standardprofile\authorizedapplications\list]
"%windir%\system32\sessmgr.exe"="%windir%\system32\sessmgr.exe:*:enabled:@xpsp2res.dll,-22019"
"C:\Program Files\AVG\AVG8\avgupd.exe"="C:\Program Files\AVG\AVG8\avgupd.exe:*:Enabled:avgupd.exe"
"C:\Program Files\AVG\AVG8\avgnsx.exe"="C:\Program Files\AVG\AVG8\avgnsx.exe:*:Enabled:avgnsx.exe"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\services\sharedaccess\parameters\firewallpolicy\domainprofile\authorizedapplications\list]
======File associations======
.scr - open - "C:\WINDOWS\notepad.exe" "%1"
.scr - install -
.scr - config -
======List of files/folders created in the last 1 months======
======List of files/folders modified in the last 1 months======
2009-06-12 10:17:16 ----D---- C:\WINDOWS\Prefetch
2009-06-12 10:15:14 ----D---- C:\WINDOWS\system32\CatRoot2
2009-06-12 09:55:35 ----D---- C:\WINDOWS\temp
2009-06-12 09:55:04 ----AD---- C:\Documents and Settings\All Users\Application Data\TEMP
2009-06-12 09:54:43 ----D---- C:\Program Files\Spyware Doctor
2009-06-12 09:54:33 ----D---- C:\WINDOWS\system32\drivers
2009-06-11 21:13:34 ----A---- C:\WINDOWS\SchedLgU.Txt
2009-06-11 17:24:48 ----D---- C:\WINDOWS
2009-06-11 16:34:48 ----A---- C:\WINDOWS\NeroDigital.ini
2009-05-20 10:45:17 ----D---- C:\WINDOWS\system32
2009-05-19 18:34:15 ----A---- C:\WINDOWS\system32\avgrsstx.dll
2009-05-18 20:32:58 ----HD---- C:\$AVG8.VAULT$
======List of drivers (R=Running, S=Stopped, 0=Boot, 1=System, 2=Auto, 3=Demand, 4=Disabled)======
R1 AvgArCln;Avg Anti-Rootkit Clean Driver; C:\WINDOWS\System32\DRIVERS\AvgArCln.sys [2007-01-18 3968]
R1 AvgLdx86;AVG Free AVI Loader Driver x86; C:\WINDOWS\System32\Drivers\avgldx86.sys [2009-05-04 325896]
R1 AvgMfx86;AVG Free On-access Scanner Minifilter Driver x86; C:\WINDOWS\System32\Drivers\avgmfx86.sys [2009-05-19 27784]
R1 AvgTdiX;AVG Free8 Network Redirector; C:\WINDOWS\System32\Drivers\avgtdix.sys [2009-05-04 108552]
R1 InCDPass;InCDPass; C:\WINDOWS\System32\DRIVERS\InCDPass.sys [2004-09-13 28672]
R1 intelppm;Intel Processor Driver; C:\WINDOWS\System32\DRIVERS\intelppm.sys [2008-04-13 36352]
R1 pctgntdi;pctgntdi; \??\C:\WINDOWS\system32\drivers\pctgntdi.sys []
R1 WS2IFSL;Windows Socket 2.0 Non-IFS Service Provider Support Environment; C:\WINDOWS\System32\drivers\ws2ifsl.sys [2003-03-31 12032]
R2 Aspi32;Aspi32; C:\WINDOWS\system32\drivers\Aspi32.sys [2002-08-14 17005]
R2 CdaC15BA;CdaC15BA; \??\C:\WINDOWS\system32\drivers\CDAC15BA.SYS []
R2 tifsfilter;Acronis True Image FS Filter; C:\WINDOWS\system32\DRIVERS\tifsfilt.sys [2007-06-20 39712]
R2 tmcomm;tmcomm; \??\C:\WINDOWS\system32\drivers\tmcomm.sys []
R3 ati2mtag;ati2mtag; C:\WINDOWS\System32\DRIVERS\ati2mtag.sys [2004-04-21 729088]
R3 HDAudBus;Microsoft UAA Bus Driver for High Definition Audio; C:\WINDOWS\System32\DRIVERS\HDAudBus.sys [2008-04-13 144384]
R3 HidUsb;Microsoft HID Class Driver; C:\WINDOWS\system32\DRIVERS\hidusb.sys [2008-04-13 10368]
R3 IntcAzAudAddService;Service for Realtek HD Audio (WDM); C:\WINDOWS\system32\drivers\RtkHDAud.sys [2004-05-17 2161792]
R3 mouhid;Mouse HID Driver; C:\WINDOWS\System32\DRIVERS\mouhid.sys [2001-08-17 12160]
R3 MTsensor;ATK0110 ACPI UTILITY; C:\WINDOWS\System32\DRIVERS\ASACPI.sys [2003-03-02 5755]
R3 MVDCODEC;ATI WDM Specialized MVD Codec; C:\WINDOWS\System32\DRIVERS\atinmdxx.sys [2004-03-18 13824]
R3 pctplsg;pctplsg; \??\C:\WINDOWS\system32\drivers\pctplsg.sys []
R3 pfc;Padus ASPI Shell; C:\WINDOWS\system32\drivers\pfc.sys [2006-03-29 9856]
R3 TfNetMon;TfNetMon; \??\C:\WINDOWS\system32\drivers\TfNetMon.sys []
R3 usbehci;Microsoft USB 2.0 Enhanced Host Controller Miniport Driver; C:\WINDOWS\System32\DRIVERS\usbehci.sys [2008-04-13 30208]
R3 usbhub;USB2 Enabled Hub; C:\WINDOWS\System32\DRIVERS\usbhub.sys [2008-04-13 59520]
R3 usbuhci;Microsoft USB Universal Host Controller Miniport Driver; C:\WINDOWS\System32\DRIVERS\usbuhci.sys [2008-04-13 20608]
R3 yukonwxp;NDIS5.1 Miniport Driver for Marvell Yukon Gigabit Ethernet Controller; C:\WINDOWS\System32\DRIVERS\yk51x86.sys [2004-06-01 178560]
R4 InCDfs;InCD File System; C:\WINDOWS\system32\drivers\InCDfs.sys [2004-09-13 93440]
S1 kbdhid;Keyboard HID Driver; C:\WINDOWS\system32\DRIVERS\kbdhid.sys [2008-04-13 14592]
S3 GAGPDrv;GAGPDrv; C:\WINDOWS\system32\drivers\GAGPDrv.sys []
S3 GVCplDrv;GVCplDrv; C:\WINDOWS\system32\drivers\GVCplDrv.sys [2004-05-02 23040]
S3 HdAudAddService;Microsoft UAA Function Driver for High Definition Audio Service; C:\WINDOWS\system32\drivers\HdAudio.sys [2004-03-17 113664]
S3 HidBatt;HID UPS Battery Driver; C:\WINDOWS\system32\DRIVERS\HidBatt.sys [2008-04-13 20352]
S3 MSTEE;Microsoft Streaming Tee/Sink-to-Sink Converter; C:\WINDOWS\system32\drivers\MSTEE.sys [2008-04-13 5504]
S3 NABTSFEC;NABTS/FEC VBI Codec; C:\WINDOWS\System32\DRIVERS\NABTSFEC.sys [2008-04-13 85248]
S3 NdisIP;Microsoft TV/Video Connection; C:\WINDOWS\System32\DRIVERS\NdisIP.sys [2008-04-13 10880]
S3 SLIP;BDA Slip De-Framer; C:\WINDOWS\System32\DRIVERS\SLIP.sys [2008-04-13 11136]
S3 streamip;BDA IPSink; C:\WINDOWS\System32\DRIVERS\StreamIP.sys [2008-04-13 15232]
S3 usbccgp;Microsoft USB Generic Parent Driver; C:\WINDOWS\system32\DRIVERS\usbccgp.sys [2008-04-13 32128]
S3 usbprint;Microsoft USB PRINTER Class; C:\WINDOWS\system32\DRIVERS\usbprint.sys [2008-04-13 25856]
S3 usbscan;USB Scanner Driver; C:\WINDOWS\system32\DRIVERS\usbscan.sys [2008-04-13 15104]
S3 USBSTOR;USB Mass Storage Driver; C:\WINDOWS\system32\DRIVERS\USBSTOR.SYS [2008-04-13 26368]
S3 WSTCODEC;World Standard Teletext Codec; C:\WINDOWS\System32\DRIVERS\WSTCODEC.SYS [2008-04-13 19200]
S3 WudfPf;Windows Driver Foundation - User-mode Driver Framework Platform Driver; C:\WINDOWS\system32\DRIVERS\WudfPf.sys [2006-09-28 77568]
S3 WudfRd;Windows Driver Foundation - User-mode Driver Framework Reflector; C:\WINDOWS\system32\DRIVERS\wudfrd.sys [2006-09-28 82944]
S4 IntelIde;IntelIde; C:\WINDOWS\system32\drivers\IntelIde.sys []
======List of services (R=Running, S=Stopped, 0=Boot, 1=System, 2=Auto, 3=Demand, 4=Disabled)======
R2 avg8wd;AVG Free8 WatchDog; C:\PROGRA~1\AVG\AVG8\avgwdsvc.exe [2009-05-19 298776]
R2 JavaQuickStarterService;JavaQuickStarterService; C:\Program Files\Java\jre6\bin\jqs.exe [2008-12-02 152984]
R2 sdAuxService;PC Tools Auxiliary Service; C:\Program Files\Spyware Doctor\pctsAuxs.exe [2009-01-07 348752]
R2 sdCoreService;PC Tools Security Service; C:\Program Files\Spyware Doctor\pctsSvc.exe [2009-01-21 1095560]
R3 ThreatFire;ThreatFire; C:\Program Files\Spyware Doctor\TFEngine\TFService.exe [2009-04-26 70944]
S3 WudfSvc;Windows Driver Foundation - User-mode Driver Framework; C:\WINDOWS\system32\svchost.exe [2008-04-13 14336]
S4 AcrSch2Svc;Acronis Scheduler2 Service; C:\Program Files\Common Files\Acronis\Schedule2\schedul2.exe [2007-01-31 407072]
S4 APC UPS Service;APC UPS Service; C:\Program Files\APC\APC PowerChute Personal Edition\mainserv.exe [2002-10-15 155770]
S4 Ati HotKey Poller;Ati HotKey Poller; C:\WINDOWS\System32\Ati2evxx.exe [2004-04-21 397312]
S4 ATI Smart;ATI Smart; C:\WINDOWS\system32\ati2sgag.exe [2004-04-21 516096]
S4 C-DillaCdaC11BA;C-DillaCdaC11BA; C:\WINDOWS\system32\drivers\CDAC11BA.EXE [2004-10-09 54784]
S4 gusvc;Google Updater Service; C:\Program Files\Google\Common\Google Updater\GoogleUpdaterService.exe [2007-05-21 138168]
S4 ose;Office Source Engine; C:\Program Files\Common Files\Microsoft Shared\Source Engine\OSE.EXE [2003-07-28 89136]
S4 Panasonic Local Printer Service;Panasonic Local Printer Service; C:\PROGRA~1\PANASO~1\LocalCom\lmsrvnt.exe [2004-08-03 36864]
S4 Panasonic Trap Monitor Service;Panasonic Trap Monitor Service; C:\PROGRA~1\PANASO~1\TRAPMO~1\Trapmnnt.exe [2004-02-24 69632]
S4 WMPNetworkSvc;Windows Media Player Network Sharing Service; C:\Program Files\Windows Media Player\WMPNetwk.exe [2006-10-18 913408]
EOF
Sure thing...here you are:
EOF
Korppu...
I just noticed something. This last entry (above) is apparently a WMP Sharing device. This computer was definitely hacked at one point and was subject to remote control. Is this device a left-over? I have never intentionally activated any sharing capabilities such as this. Is this service automatically installed when XP is installed?
Unfortunately I don't know what I'm looking at when I read these logs, but it worries me to see this entry.
Thank you,
Slider
I'll look more into the log tomorrow.
