Phenom II X4 system running at 800Mhz
So I built a new system for my brother and I'm having some problems getting it to clock up to 3Ghz.
Right now it is runing @200 x 4 and it won't clock up, even when being stressed with Prime95. Any hints?
Oh yeh, I disabled Cool & Quiet in the bios to no avail and I don't get it.
Each core is running at 2.2GHz
or
you have a 200 clock speed with a x4 multiplier?
If your running at 800Mhz that's messed up... increase your multiplier within your bios.
Also, which Phenom II is it?
Phenom II x4 945
Should be running at 200 x15
I forget what motherboard it is. I thought about just setting the multiplier in the bios, but I really want to use the Cool & Quiet stuff so that it won't be sucking power the entire time it is running.
Go update your BIOS. The BIOS you are running probably doesn't have the CPU ID for your particular processor revision. This is the main reason BIOS revisions are released.
[strike]Screenshot coming.[/strike]
http://www.gigabyte.us/Support/Motherboard/Utility_List.aspx
Also, from the processor list, it does look like you need the F4 BIOS for that procossor
Make a bootable USB key, put the files on it and run it.
Job done.
Such as the followings
Absolute cheapest worth buying but better than stock: ARCTIC COOLING Freezer 64 Pro
Better for a little more: XIGMATEK HDT-S1283 120mm Rifle CPU Cooler
A fancy one
<!-- member.php?u=9719 --><CITE class=ic-username>airbornflght</CITE> but I have other motherboard, I have ECS A790GXM-AD3 v1.0
The machine works fine, but the Far Cry 2 freeze after 5 minutes to start the game.
Excuse my english, but Iรยดm trying to resove this issue and my english is not the best.
Thanks to all.
I've seen lots of reviews that indicate that yes, you guys are right, the brands you listed are generally good. However, Thermaltake does in fact produce an occasional rogue pack-leader HSF. My Big Typhoon cooler was purchased for the simple reason that it came very close to first out of a big list of 25 coolers for cooling capability, and I can see it working in my system. It keeps my CPU running literally 20C cooler than the intel stock HSF.
