Must backup system files without using external device..help please
edited July 2009 in Nerdery
Hello. I have Windows XP Home SP2. I am about to upgrade to SP3, but, before I do, it is suggested to backup my system to an external medium. Problem is, my optical drive (CD/DVD) is broken. My laptop is not in the best physical shape..so even external hard discs and USB flash drives are probably out of the question. Is there a way to backup my system without using any sort of external device? I have heard of a program called Paragon that can apparently help in this regard. Thanks..
    edited July 2009
    I have installed SP3 on some 50 machines, not had it mess anything up. While it can happen, chances are very low.
    If you have 0 external options, then any backup you do on what you already have would not be a backup at all, it would do you 0 good.
  • edited July 2009
    Hi RyderOCZ..thanks so much for your lightning-fast response. So do you think I probably don't have to worry about backing up my system files prior to doing the SP3 update? That would simplify life for me a bit..thanks again.
    edited July 2009
    As I said.. I have never backed anything up prior to installing.
    As long as the system is stable, no issues here.
  • edited July 2009
    Thanks RyderOCZ..I will go ahead and just do the SP3 install..If there is any problem at all, I will post it here...I will also post it here if everything goes well so that this thread can be closed. Thanks again..
  • Nate_LapTNate_LapT Ferndale MI. Icrontian
    edited July 2009
    also, I assume you are using a network to post this from that system, unless you are one of the .0005% that are still on dialup. setup a share and just throw all your important files on that share.
  • edited July 2009
    Hi..I was reading the requirements before installing Windows XP sp3, and one of them said "If you have a 3rd-party wireless network adapter, make sure that it is supported." My wireless network adapter is Intel PRO/Wireless 2200bg Network Connection. Will this be supported by SP3? I don't want to have trouble connecting to the internet after the upgrade...thanks.
    edited July 2009
    Anything that works now will work on SP3.
    edited July 2009
    in general backups are good to have, I think your stressing over the sp3 update a bit too much though.
    You should be stressing over your lack of ever backing up a bit more.
    Being you said your forms of backup devices are fubard, you may want to invest in a form of backup in the near future, either being an external device/network share. or a new system that is CAPABLE of backups, aka a usable dvd burner, and usb ports.
  • edited July 2009
    Hi. Thanks for your help..I have installed SP3 successfully and experienced no problems. Actually, I think I may be able to use my USB port to make a backup of my system on a flash drive. However, the CD/DVD part is broken. Anyway, looks like this thread can be closed now..thanks again.
