PLZ HELP, no power
hey guys im having major problems, i was listening to music on my acer aspire 1700x when it jus shut off. now it wont turn on at all, i thought maybe powersupply so i got an old 1 out that has a green LED light on the back, now when i plug it in it lights up but when i plug the 24 pin into the MOBO n hit the power button the PSU light shuts off n wont turn on? so what i need 2 know is, is this jus a bad PSU or did my MOBO fry also?
Disconnect the PSU from everything (wall, mobo, etc) ...then plug the unit back into the wall socket and connect a couple hard drives to a molex connector to provide a load.
Now....with the switch on the back of the PSU in the off position...locate the Dark Green wire in the ATX connector and using a paper clip (or something similar) "jump it" to any of the black wires in the connector....Now flip the switch on the back to On.......the PSU should start up and run.
Pictures of the jumpstart are here: http://www.ocztechnologyforum.com/forum/showthread.php?t=34941
Plug in the proper connections on the motherboard and the Video card (if the card has a power connector) and yes, the old PSU should start the board.
If the old PSU does not have the 4 pin for the CPU and the board DOES have one.. then no, it won't work.
