Problems with hard drive
I have an old computer (Pentium 2) with BrillianX S1 motherboard and a 6 gig hard drive.
I wanted to install an 80 gig hard drive. The BIOS didn't recognize it at first but, I sucessfully flashed the BIOS with the newest version from the mobo's website. When the system first POSTS it shows that it can see the new hard drive.
However, now the system hangs just after this point when the BIOS gets the the System Configuration screen. It says: "Primary Master Disk: LBA, UDMA 2," . The cursor is stuck at this point and the system will not boot. The jumper settings for the hard drive is correct. When I connect the orginial, smaller hard drive (only 6 gigs) it boots up fine.
Any help out there?
Greg
Any help out there?
Greg
You'll probably need a PCI ATA100 controller card that you can hook the drive to.
The board should be able to boot from the card, no guarantees though.
You can find one for $20-30 at newegg I think.
http://www.qdigrp.com/qdisite/eng/support/d_bx1s.htm
Greg
I had a similar problem a while back upgrading my parents hard drive on a PII. If I remember correctly, Western Digital and I imagine other drive makers have a utility that can cope with this.
are you using a 40 wire or 80 wire ide cable? ATA66,100,133 drives will NOT work correctly on 40 wire cables.
Detecting Primary Master... WD800(or whatever the exact model number is)
Detecting Secondary Master...
etc..
Then, right after this it goes to the screen that looks similiar to this:
Co-Processor: Installed
CPU Clock: 400Mhz
Diskette Drive A: 1.44 Floppy
Diskette Drive B: None
Primary Master Disk: LBA, UDMA2_ <-the system hangs and the cursor is stuck at this point.
I tried an 80-pin IDE cable which produced the same results. If anyone can help I'd appreciate it.
Thanks,
Greg
try this from Western Digital...
http://support.wdc.com/download/dlg/dlgudma10.zip
qparadox is right, your BIOS most likely won't handle that drive.
Go get a 15-20 dollar PCI IDE card and put the drive on that, that should take care of your problem.
"g"
Cheers,
"g"
