New build problem!! Please help!!
I have just started to build my first pc and I am already having an issue. I have an AMD Phenom II 2X 550 Black Edition CPU; Asus MOBO; 4GB Corsiar DDR2 Dual channel RAM; 1 TB WD Green SATA HDD; LiteOn DVD writer; 300W PSU.
I installed all the components and plugged it in to config the BIOS but the system won't even turn on. The green LED on the MOBO is lit so I know that the MOBO is getting power but it seems like nothing else is getting power. The LED light on the switch to the case isn't even lighting up. When I push the power button, nothing happens. No fans blowing, no LED light on the power button, no nothing. Can anyone tell me what the problem might be????
I desperately need help!!
What do you think it could be since the plugs match??
Not to mention, I don't want to buy a $60-$100 case just to pay $20 shipping. Grrrrr! Do you think it is the switch and how would I fix that problem?
The problem is that you have a proprietary case with front-panel wiring that only matches a proprietary motherboard header. You have two options:
1) Surgically dismantle the wiring to plug it in the way you need to.
or...
2) Buy a new case.
Pull the 2 wires out of the "20pin" that go to the power switch on the case and put them on the proper pins on the mobo. Either that or buy a new case.
Thank you everybody for helping me!!!! If I have any more problems I will definitely get back to you!!
Now, I have to play around and get my windows XP to work on the new system.
