Options
Need Help with Virus and malware removal
Hello,
I would like to say thanks in advance to anyone who helps me. Sometime today I started getting alerts on my computer from a "Antivirus Vista 2010" which I know is a virus of some kind. My computer is also telling me that there is a trojan that is infecting my computer. I would really like to get some help on this as I use this computer to do my school work and work for my job. Thanks again.
Overall I would like to rid my computer of any and all viruses, spyware, and malware.
Thanks,
Andy
  • edited March 2010
    Hi Andy,
    I hope your computer is a vista computer
    First enable the Hidden Files and Folders
    Enable the hidden files and folders by
    Open My computer--> Click on Tools->Folder Options-->View(tab)-->Click show hidden files and folders
    Click OK
    If you cant see the tools menu
    Hold the Alt key and press T in the keyboard when you are inside the My computer window
    Else Start-->Inside the start serach box type Run
    You can also open run by holding Windows key and R key
    Inside the run box type "control folders" without quotes and hit OK.
    You will get the Folder options dialog box
    Then Folder Options-->View(tab)-->Click show hidden files and folders
    Click OK
    Else Go to control panel you can find Folder options
    Click OK
    After that move to the location
    c:\Users\%user Profile%\AppData\Local\
    %User Profile%- - -> Your User Name in the computer
    Inside that Local folder you can see many folders and files
    List out the names of the files in the LOcal folder for me.
    PlayBoyZ
