Over the edge, must have water cooling
So after reading sledge's thread on his water cooling he is doing I couldn't help myself I think with enough pushing I am finally going to do it. I had planned on doing WC shortly after doing my main's build but just never bought the parts.
I was getting to the point of giving up on it again when I ran across CrazyPC.com and saw their prices on the gear I was looking at.
Swiftech MCP655 Water Pump -80$
Swiftech MCRES-MICRO Rev2 Reservoir - 26$
Swiftech MCR320-QP Radiator Black ***WHAT THE HELL PRICE***
w/ G025_Fittings: 9342820-2_Bitspower_05_FITTINGS - 55$
PrimoFlex UV Green 1/2ID x 3/4OD Tubing 5ft - $13
And then order Swiftech Apogee GT CPU block from Microcenter for 43$ to my door. The only thing crazy has to that price is a DD block and I really don't want to use that plus its only for AMD.
I wouldn't feel to bad though ordering the Swiftech Apogee GTZ Extreme Duty Waterblock for 54$ to just get it all in one shipment. I am really trying to keep it as close to 200$ as possible with a swiftech pump and at least a 2x120 rad.
I can't believe that triple rad price or the fact the variable speed pump is the same price as the B version. I really want to press buy now! With the GTZ block its ~240$ to my door.
So any suggestions on parts to change or places to look for cheaper gear?
Good luck.
Sidewinder has thermochill radiators in stock, and thats a good price on a triple. I would use a T line with a fill port over a reservoir any day. It gives much better flow.
Looks like you can get that radiator, a swiftech xt, and a MCP655 for about 240. I dont know where you are looking to buy that pump for 80 but thats a rip off. Unless you are looking at the one with the stupid speed control feature. Its available without it for about 60.
Why would you want your pump pushing water anything but as fast as it can?
How about this:
MCP655-B - 65$
Swiftech Apogee GTZ - 55$
Black Ice Xtreme 3(2191840 volume) - 64$
Swiftech MCRES v2 - 26$
PrimoChill Pro 5 ft - 9$
shipped 220$
removing the rez and doing
primochill black nylon T - 2$
Danger den brass fillport - 12$
shipped 217$
How should I really plumb this? The rad is going on top of my case, Thermaltake Armor, and I can put everything else high, low, and middle.
The temp difference between a reservoir and a T line is probably negligible. It's really down to which is more convenient for you.
Keep the flow of that loop as simple and efficient as possible and you won't need a lot of effort removing heat from that system. Also it is advisable to have surrounding ambient temps as low as possible.
Res or "T" line, personal preference. I put mine before the pump to make sure it has plenty of water, don't want the pump to run dry. The res is easier to bleed the air out, T line takes up less space.
Water gear on-line, personally I like.
http://www.jab-tech.com/
http://www.petrastechshop.com/
I'll check those 2 first, then go to Sidewinders, Frozen CPU...
Double check your order, usually I'll order 10' of tubing. (extra goes in the parts box, for when I change a block or whatever) Stinks to be putting it all together and have to wait because you were a foot short. Clamps and barbs, make sure you have enough.
Coolant, I personally used distilled and PHP nuke. Some use special coolant, some prefer just a silver "kill coil" and distilled.
WC-1021
Danger Den Fillport (Brass)
10
BW-1025-UR-34
PrimoChill UV Colored Nylon Hose Clamps (UV Red - 3/4 inch)
1
PC-1060
PrimoChill Black Nylon Barbed T Fitting for 1/2" ID Tubing
10
TB-1011
PrimoChill PrimoFlex Pro LRT 1/2" ID x 3/4" OD Tubing (UV Red)
1
WC-1080
Swiftech MCP655-B Pump
1
WC-1017
Hardware Labs Black Ice Xtreme III Radiator (Black)
1
PT-1001
Petra'sTech PT Nuke Concentrated Biocide (10mL)
1
AK-1009-34
PrimoChill UV Red Anti-Kink Coils (3 Sizes Available) (3/4 inch)
and by forgot I mean I couldn't find them in the box.
And.............;)
Just working on cleaning the CPU block mas0n gave me, mounting fans with scotch tape, making sure rad fittings are on tight. Going to try and work out plumbing lengths and placement tomorrow so I can cut tubes and leak test friday or saturday.
Every set up in the tub to begin this pain of filling and bleeding air.
Distracted.
Sitting around waiting for air to collect in the t-section.
The final setup that got the last of the air out and I am finished up the 20ish hour leak test.
Does it really matter how much PH nuke you put into the system as long as you meet the min recommended amount? There is about a litter of water in the system and I put two drops in, I am wondering if it matters if I put two more in just to make sure since I might get lazy and not swap water for over a year.
Guess it was telling me it didn't want to be replaced by a competitor's WC block..........
I ran into a little snag, my secondary video card that I run my second monitor off of had to get pulled. It is slightly taller than my GX2 and the pump housing was bumping into it so it had to say bye bye. Tubing should really be trimmed in two places but eh it sits behind a desk all day, I view it has holding more water that way and the sink factor gets larger.
I am running 40-50F off of ambient which is about 20F better than air...I think I need to spend some time working numbers. I gunned the CU side of the block as best as I could during load, 120F 50C. Running a q9450 at 3.6 on 1.38v. I can work the vcore down some but don't want to.
Looks hot Michael!
So is that high low don't worry about it until the mobo stops working or the system crashes...?
