HELP!!!
Jan 1 my boss bought a new HP dc7900 for his office. Finally hooked it up today and it plays some music so I know its up but the monitor (also an hp but about 8 months old) says it is asleep, the keyboard isn't getting power (No lights) and the mouse, while it is lit up, doesn't wake the machine. Can't return the machine at this late date and from what I read it is a really good machine but I gotta get it up. PLEASE HELP ME!!!
Are you running the mouse and keyboard through some sort of external USB hub? I assume its all USB and not PS/2?
Yeah, wake on PS/2 is normaly the default in the bios of just about any machine.
Are you sure the mouse and keyboard are not getting any power?
Does the monitor display when it posts?
-Bobby
Either way you are looking at needing to troubleshoot the video, or at least crack the case (Don't do that if you are still under warranty, if you are, Use it to troubleshoot).
If it is a hardware problem that needs to be troubleshot then you are in the right place, but I don't know the next step here. If Cliff or someone else can step up with some suggestions I am sure they will. From your side, you can help by providing as much information about the system as possible. If it has a service tag of some sort, use it to look up the hardware specs and post them here.
-Bobby
OK. You've answered one question already. There is what appears to be a vertical white parallel port and an adapter that splits into two blue VGA ports. I am plugged into the solitary horizontal port. I knew it would accomodate two monitors but didn't know what that white was for. There is also a pink port not in use....also vertical. I
There ya go. Many adapters have two heads for multi monitor support. In some cases, one is assigned as the primary so you have to be plugged into that one to output video to a single monitor.
