A few misc. parts for completion needed
yaggayagga Havn't you heard? ... New
edited July 2010 in Hardware
Can you recommend some misc. parts for me?
I need a 1156 (damn I like light bulbs!) cpu cooler.
I also need a ~ <$30 optical drive
I was also considering Tuniq 3, for said cooler.
Also, cheapest source for Windows 7 (Ultimate ideally)
I was considering a Cooler Master 212 + for the cpu cooler. This is $24.99+tax locally. The cooler will be slapped on my 875K! I'm only concerned about being overly heavy, and the heat pipe gaps in the base. This would work well if I decided to make a little HVAC setup with the cpu heat sink, because of the sideways fan mount.
I consider any legit online store, plus Micro Center.
    edited June 2010
    Practically any optical drive will be fine for you. They're down to a science - a drive is a drive is a drive. Pick something you recognize and go to town. Lite-On, Samsung, LG all make fine drives.
  • VicarVicar Icrontian
    edited July 2010
    Win 7 have you considered an upgrade?
