i need advice on a low power graphics card
hello,
can anyone help me figure out which graphics card is best for a dell gx280 desktop ?
i recently added a 23" full hd monitor and my current card only allows 1274x720 (or whateveR IS CLOSEST) AND I WANT TO GET 1920X1080 RES.
I WAS TOLD MY PC WOULD ONLY BE SAFE WITH A CARD THAT USES LESS THAN 210 WATTS.(oops sorry bout the caps lock thang) anyway i was told an ati x600 would be good and i can get 1 for 15 bucks shipped .but i was wondering if there is a better card that takes low power? thanks
Have you attempted to update you graphics driver first?
i had a friend do it,but it was to no avail.i think i have a P.O.S.#2 card right now;D
but i just ordered a nvidia 9500 gt.it was only 23 bucks on ebay and my biggest concern was that i had to stay under 210 watts (what the dell dude said).but i read a few reports saying that dell undersizes and card manufacturers over estimate wattage need.
so here's hoping i dont fry anything:bigggrin:
i really only use the cp for surfing and some video's ,basic games and such so i think it will be safe ?
what do you think ?
The Catalyst control center is a software utility that ATI Radeon graphics cards use to adjust visual quality settings including the basic resolution. If you had the stock X300 card, it should do 1920X1080. It won't be a great gaming card, or even that great for HD video playback, but it will be sufficient to display the resolution for a productivity desktop.
I'm having problems figuring out if you have AGP 8X, or first generation PCIE on that board. Do you know? Thats important before you order a card.
I think the 9500 GT is probably pushing it a little on that power supply. If I were you, I would cancel until I am 100% sure what slot type I have and if the card is a low profile version or not.
also i assume i have to install the new card and driver before deleting the old stuff,right ? otherwise how will i see the screen to perform such tasks ?
Windows XP will display it low res, 640X480 16 bit color.
as you can see by my username i will have many dumb questions:bigggrin:
but it's fun when the site says "thank you for logging in dumass"
No problem. Anyone smart enough to find their way to the Icrontic forums when they could use computer advise is not dumb.
What I would do,
I'd make sure I have the latest driver for the 8400 for windows XP. Dowload them here.
When your new card arrives, first remove the old drivers by uninstalling the device from your windows device manager. Click start, go to your control panel, and under the device manager look for video controlers, you should see something that says X300, or ATI, something to that effect, click on it and remove. Shut down the machine.
Open up the box, swap out your video card for the new one, when you boot, it will be ugly, just click the .exe driver file that you already downloaded to your desktop, wait a couple minutes for it to install, it should prompt you to reboot, and upon reboot you should be in business.
I understand the newer 8400 cards are using the ION chip, so if thats the case its a very good low energy desktop solution, heck, it will even do a little light gaming and accelerate HD video for you.
Cheers.
thanks again it will be a few days before i get the card and i will let you know how it works.:thumbup
2 reasons....
1)read my username
2)so you would have something to contribute to the thread:thumbup
