HD Won't Show Up on OLD PC (With New Parts)? Something About an 80 Cable?
So here's the deal.
The case is from a Compaq SR1030NX with the OEM power supply. The motherboard is new, (well it was back when I bought it but never used it).
The hard drive I'm trying to use is a SATA (New from this century with a IDE to sata adapter).
The optical drive is a Sony DVDRW (old) and the memory is used, I believe PC3200, cpu is new (again, never used until now)
I got a sata to ide convertor but when I boot up the machine it says something about an 80 pin cable and the hd doesn't show up (not even on BIOS). Everything else shows up, with the exception of the HD. I tried the HD on another computer just to make sure and it's fine, tried the memory also, works fine, it's just the HD issue I'm having now.
I've searched around and found out that there is 40 pin and 80 pin cables but I don't know what's the difference. I wonder also if the case.
My question is if it would be better for me to use an IDE hard drive, use a different cable? I think maybe because of the IDE to SATA adapter the drive isn't working? I don't know so this is the reason I ask
I'm assuming it would be easier to go with an IDE drive? I just want to get it working, cheaply.
